Results 1 to 28 of 28
Thread: Tube Issues
    Reputation: blown240's Avatar
    Tube Issues
    I have read a ton of threads about using regular tubes in fat bikes. So I picked up some 26x2.5 tubes and tried installing them. It was difficult to get the tires to seat, so I took a look inside and found the tube wasnt inflating evenly.
    Is this an issue? I ended up reinstalling the stock (very heavy) tubes for now.
    Here is what the tube did:
    Tube Issues-1ea4867e-e429-4965-9fa1-ef5bd5438cee-19516-0000163e9eab9b43_zps48802ce4.jpg
    Thoughts? Comments? Suggestions?
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I've had good luck with the bontrager 2.5 tubes.
    I've tried some skinnier ones (2.1) in a pinch, that did similar things as yours.
    The tubes I used were Forte brand. Maybe thats the problem...
    aka bOb
    Reputation: bdundee's Avatar
    I'm with Shark the Bonty 26x2.5 dh tubes work great. Also a friend of mine is using a 24" Specialized tube that is working awesome!
    Just to clarify: a 24" tube in a 26" wheel?
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    2.4-2.75 SL Q-tubes are great for this application.
    "ORANGE IS THE NEW BLACK"
    I dont think they are reinforced, but there sure is something different about that spot!
    gone walk about
    Mar 2012
    Quote Originally Posted by MiniTrail View Post
    is that tube reinforced at the skinny spots in the image?
    sure looks that way.
    gone walk about
    Mar 2012
    shape it into a critter for giggles
    maybe even a cool kid...LOL
    Nov 2007
    Quote Originally Posted by nvphatty View Post
    What he said. I tried a few other brands that did not work well at all.
    aka bOb
    Quote Originally Posted by blown240 View Post
    Yup, blow a 26 " tube up to the size you need to fill a 4.0 without being in a tire and see what the diameter is. He swears that the 24" is the way to go and I believe him.
    edit: I was just told that the Spesh tubes 24x 2.3/3.0 are discontinued but you might be able to find some at your lbs otherwise there are a few other companies making 24x3.0 tubes but not sure about the reinforcing on them and how they expand.
    New Specialized Bike Tyre Tube 24 x 2 4 3 0 Shraeder Valve Car Pair | eBay
    be1
    be1 is offline
    Sep 2013
    ^+1
    We just used Specialized presta DH tubes on the Canning Stock Route trip running BFL's, and honestly there was no discernible performance difference between them and the Surly Toobs. Even at uber-low pressures. Lighter, cheaper, and they pack smaller. All around a pretty decent fatbike tube, even if they are made by the Big-S...
    Scott
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    These Q tubes have worked fine in my BFL's, running 5 to 6 psi. I just put them in my Bud n Lou and they aired up fine, although I have yet to ride them. Inflated out of the tires, there is a noticeable constriction by the valve, but I'm not aware of it while riding.
    Riding Fat and still just as fast as I never was.
    Nemophilist
    Reputation: TrailMaker's Avatar
    Ummm...
    Air pressure will seek the path of least resistance, until it can't expand the weak spots any farther. When the soft spots in the tube hit the inside of the tire, they will not be the soft spots anymore, relative to the rest of the tube. The other spots will then expand. Blowing a tube up outside the tire might be ugly in this case, but it is not a particularly relevant situation.
    Will it be ideal? Don't know. Blow it up to 40 to seat your soaped tire, air down, and see if you then have spots on the tire that are unsupported. I'd guess not.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Nov 2007
    Quote Originally Posted by TrailMaker View Post
    Ummm...
    You can't prove that. It's like saying you're positive that the refrigerator light goes off when you close the door.
    gone walk about
    Mar 2012
    Quote Originally Posted by SmooveP View Post
    my oven light goes off when i close it does that count?
    Nov 2007
    Only if you're closing it from the inside.
    gone walk about
    Mar 2012
    it has a glass window whilst to see through.
    Nov 2007
    So it's a little less claustrophobic when you're in there, then?
    Ummm...
    I see your point, but one of the issues I had was that the soft spots expanded until they touched each other and that left a "fold" of sorts where the thin spot was. Maybe this isnt an issue at all, maybe it is. Thats one of the reasons I started this thread.
    As a side note, I never thought of soaping the bead.... thats a great idea...
    Reputation: damnitman's Avatar
    ...This is an outrage! I can't believe you would have the audacity to go off-topic in the fatbike forums...you are doing a disservice to yourselves and those new to the sport, looking to you as ambassadors of fat! And please ensure the gas is off next-time you climb into your oven...your misunderstanding of oven lights is obviously a result of near-asphyxiation which precipitates an elitist-disrespect for the common-man and the people that hate Whirlpool just because they make a great oven...
    If Huffy made an airplane, would you fly in it?
    ...air it up in the tire on the rim to about 10 psi for a few hours then run up the pressure to set the bead...or set the bead then air it down to 10 and let it sit for a few hours...see if that helps the tube stretch...
    Reputation: duggus's Avatar
    Quote Originally Posted by damnitman View Post
    ...Be careful what you're looking at because it might be looking back...
    Nemophilist
    Don't think so, but;
    Even if it did, that would mean the tire was fully supported anyway. I think you can illustrate this by blowing up a balloon, especially the long ones used for balloon art. They never fill evenly, do they? They start at one spot and gradually fill until the entire balloon is one diameter. The clowns here do have a point of course, but I don't think it will never expand at those spots. In any event, throw the damn thing in there, air it up, and ride the crap out of it. Next time you have reason to take it off (I bet you'll forget), you'll probably see an even tube come out.
    Every time;
    Fat tires have a habit of not seating very well in the first place, and it's harder with the "wrong" tubes. I use 409 or Fantastic or whatever spray cleaner is handy, spray down both the tube and tire bead really well, and crank them to 40psi. Tires like Nates and Floaters give you a nice POP there, especially if they are 27TPI. HuDu's not so much. After every riding flat repair, I redo them again. There is usually no bear snot handy, and because I don't carry soap, they won't seat. That and the mini pump would take 2 weeks to get to 40PSI!
  1. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  2. Reynolds 853: 44mm head tube, 30.9mm seat tube
    By butasan in forum Bike and Frame discussion
    Last Post: 04-07-2012, 10:30 AM
  3. Need help. Carbon 456 head tube issues
    By joezuri in forum On One
    Last Post: 11-01-2011, 04:38 AM
  4. Replies: 13
    Last Post: 09-05-2011, 07:43 PM
