Page 1 of 2 12 LastLast
Results 1 to 100 of 136
    Lord Thunderbottom
    Reputation: TitanofChaos's Avatar
    The TRUE tire size thread
    ohh no, here we go again, not another tire thread
    I'd really like all the info in one place, so lets see what we can gather here
    Post your actual inside bead to bead measurements with tires lying flat so help us out filling in missing data where we can
    here's what I've gathered from other threads and this one, if I'm missing any tires and you have the info, post it up
    all collected data is in black, if measurements came in together I kept them on the same line
    I added averages and estimates so we can see the predictions and the actuals
    Rim sizes added as well, no I don't care if there's a 44 and a 102 or whatever, this is enough
    Weights added, these are averages or published weights, tires fluctuate by up to 100g, usually 50 one way or the other from the numbers in the chart
    tire sizes.pdf
    Today I will do what others won't, so tomorrow I can do what others can't
    [QUOTE=TitanofChaos;10933399]ohh no, here we go again, not another tire thread
    Could you provide a picture demonstrating how this should look so we can be consistent?
    Lord Thunderbottom
    Quote Originally Posted by genefruit View Post
    you want this measurement, bead edge to bead edge but from the inside, tire tread flat on the table
    nvphatty
    Guest
    But sir what if we lack the techno for such things?
    Anchorage, AK
    Reputation: Lars_D's Avatar
    ...by the way you can get a pretty decent approximation of mounted casing width by simply adding rim width to the casing's flat width and dividing by 3.14. I tested it with a few of the tires on the above table and it came reasonably closed to the measured widths that I have seen for those tires when mounted.
    --Peace
    Lord Thunderbottom
    Quote Originally Posted by Lars_D View Post
    Thanks for the tip, this plus surly's tire spec sheet looks like it got really close for all of their tires, I added them above
    Feb 2006
    I'm no mathematician, but does this system take into account any variances in sidewall height? Or is sidewall height standardized among all fat tires?
    Reputation: thickfog's Avatar
    Oct 2010
    I'm not sure how useful this is. My bfl rubbed the inside of my 907 fork. My snowshoe is nowhere even close. Both at 12 psi on a 90 mm uma.
    And you have an identical bead to bead width on both tires.
    So what "true size" do you hope to get from this?
    Sent from my XT1060 using Tapatalk
    CRAMBA Chairman
    Lord Thunderbottom
    Quote Originally Posted by thickfog View Post
    depends where you get the info, I posted what I think is better info from surly's site
    Oct 2010
    Re: The TRUE tire size thread
    Quote Originally Posted by TitanofChaos View Post
    I got my own tire width info with my own actual experience. I'm not sure what you are trying to accomplish. Is this to determine what an actual mounted width would be? Or approx?
    I'll measure my bfl, larry and snowshoe in a bit to contribute.
    CRAMBA Chairman
    Oct 2010
    238 Big Fat Larry lightweight casing.
    233 Snowshoe 4.7
    CRAMBA Chairman
    Lord Thunderbottom
    I'm only attempting to estimate mounted sizes for the 3 surly rim sizes and somewhat demystify the tire size confusion, manufacturer tire sizes obviously don't mean much as they all measure their tires on different rims at different PSI, some are broken in or stretched and some brand new
    I understand that there will be variations in every tire produced, we see 20-50 gram weight changes in a stack of the same tire so I don't assume anything here is 100% accurate
    I'm just a geek about numbers and data
    Oct 2010
    Ok. I added mine. Hope that helps.
    CRAMBA Chairman
    nvphatty
    Guest
    I appreciate your efforts and others will too.
    Reputation: duggus's Avatar
    Bud & Lou are actually labeled as 4.8... not sure where the 4.7 came from.
    ...Be careful what you're looking at because it might be looking back...
    OP, thanks for taking the time to compile this. It was interesting to study the numbers and compare the differences between the smallest rim and tire combo vs. the largest. 30mm or just over an inch difference from one extreme to the other sure puts things in perspective. As a side note, the range in size between like-sized car tire is also significant. We just replaced one set of 225/45/17's with another set of 225/45/17's from a different manufacturer, and the new ones are noticeably larger, so I doubt the small-potatoes fat bike industry will ever be consistent.
    Reputation: gcappy's Avatar
    Edit:
    Morning brain fart.
    Nov 2008
    Nice Idea, thanks. Maybe add a couple of more columns. Uma 70mm and 90mm.
    Steven
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by shoo View Post
    Steven
    It'd also be cool to add us little guys that run 47mm-50mm (Schlick Northpaw, Surly Rabbit Hole 26", etc.)
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Reputation: wetpaint's Avatar
    Just measured my Snowshoe on a 80mm RD. 96mm wide at the case, 85mm at tread blocks
    Lord Thunderbottom
    Quote Originally Posted by duggus View Post
    this http://surlybikes.com//uploads/downl...Geometries.pdf
    Vee8 (new, unmounted): 230mm
    Fat & Single
    Reputation: ozzybmx's Avatar
    Any chance of putting another column on there with the tyre weights ? I keep looking for it.
    cheers
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Lord Thunderbottom
    Quote Originally Posted by ozzybmx View Post
    cheers
    Done
    Fat & Single
    Cheers... now when I go "hmmm nice width" the weight weenie part of my brain looks at the new column and dismisses it as too heavy.
    I wonder what my bald buds tip the scales at.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Lord Thunderbottom
    measured some missions last night
    Lord Thunderbottom
    More measuring, added a sterling bead length and BFL bead length and size on uma 70
    This review of the 45nrth Dillinger 5 has a bead to bead measurement of 245 mm.
    45NRTH Dillinger 5 – Six Week Test Ride | FAT-BIKE.COM
    Reputation: iamkeith's Avatar
    Feb 2010
    Quote Originally Posted by 2LO4U2C View Post
    This review of the 45nrth Dillinger 5 ....
    Classic: "we tested it for 6 weeks, but never as a rear tire. I'm sure it has good traction and will be good in the snow, though."
    I've been anxiously awaiting some info on this tire, but this is pretty funny. I'm glad to at least hear some production-version width measurements though, and that's really the most important part, so thanks for posting this.
    We still hang bike thieves in Wyoming [Pedal House]
    Lord Thunderbottom
    lots of new stuff added, PDF file attached, the image keeps getting downsized by the forum software
    My 2 Vee Bulldozers weighed in at 1339g and 1380g, and measure 109mm knob to knob on 80mm Sun Mulefut rims, tubeless, at 15psi. 104.5mm at casing.
    Jason
    Disclaimer: www.paramountsports.net
    This is GREAT work. Thanks for all the effort on this!!! I like the addition of the PDF too, the tables in the forums were impossible to read.
    One note, the Ground Control Fat tire is actually 1450g, not 1350g. I heard that 1350 somewhere too, but the special-ed website says 1450 and the one I got the other day was 1468.
    Lord Thunderbottom
    Quote Originally Posted by JAGI410 View Post
    Quote Originally Posted by jasongerken View Post
    Done and Done
    Awesome!
    Can you add placeholders for Knard 4.8, or whatever they are calling it. Panaracer Fat-B-Nimble, and the various versions of the Schwalbe Jumbo Jim? Schwalbe has specs listed on their site.
    aka bOb
    Reputation: bdundee's Avatar
    I weighed 4 Ground Controls and got anywhere from 1420g to 1486g
    Quote Originally Posted by bme107 View Post
    Awesome!
    Curios what the reality size of the 4.8 Jumbo Jim is. Looks really jumbo.
    Aug 2014
    Weighed a 60 TPI Fat B Nimble and got 1350. :-)
    My Snowshow (4.5 120TPI) was 1250 as well. I had the widths written down on my 47mm rims but I lost my paper and now the rims are in the shop getting laced up.
    Sep 2014
    Some info for Specialized Ground Control 4.6". Bought two tyres. Measured bead to bead as per instructions and took four measurements for each tyre at approx 90 degree intervals. Also weighed them.
    Tyre 02145219:
    243; 244; 243; 245 -> average 244mm
    Weight = 1430g
    Tyre 03145131:
    240; 238; 239; 239 -> average 239mm
    Weight = 1440g
    Will post widths on 90mm rims as soon as the wheelbuilder finishes building up the wheelset.
    Thanks for the info provided in your PDF. I think it is really helpful.
    wjh
    wjh is offline
    Feb 2012
    I am trying to determine if a dillinger 5 with studs will clear a 170 spaced 9zero7. Nates on margelites clear with room to spare and according to the chart they are both 99 mm wide. Can anyone verify that these 2 tires are in fact the same width? I measure my nate at 98 but a 4 and a 5" tire are the same size? Seems odd
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by wjh View Post
    About 4 and 3/8" on my LB 90mm rims from tread to tread. Couldn't believe the traction in deep snow today I run them on a 170mm bike. Some guys with skinnier rear ends are switching to 65mm rims just to be able to run them, although I'm not sure that'd be a huge benefit, but idk.
    wjh
    wjh is offline
    Feb 2012
    What bike is it? I know some bikes (salsa) are wider than a 907
    Reputation: blowery's Avatar
    Aug 2014
    Framed 26 x 4.0
    I don't have a way to weigh them.
    Bead to bead flat: 228mm
    80mm rim: 98mm
    Here is what some reviews showed for specs:
    Weight 1328g and 1330g
    The spread out test measuring bead to bead flattened out 225mm
    Reputation: DubzOxford's Avatar
    Nov 2012
    OP. Thanks for doing this!
    Fat and Single
    Jan 2015
    Vee8 on 80mm rim: 97mm measured. Oh, and please add the Panaracer Fat B Nimble tires.
    Jan 2013
    Attachment 925861
    I'm trying to wrap my head around the attachment TitanofChaos posted. I have Nates on 80mm rims which supposedly measure in at 98mm. I'd like to go wider/higher volume but read that Ground Controls's and D5's can't fit a pugsley. However they come in at 97 and 99 respectively on 65mm rims. How accurate is the chart? Has anyone tried a 5'' tire on a 65mm in a pugsley? This is a great thread by the way.
    Jan 2014
    can we get a thread that describes how the tires actually work too? I've been reading reviews for weeks now and my head is spinning. I need to buy tires in the next day or two for a race this weekend. Sucks that I have to spend almost as much as I paid for the bike to have it not suck big donkey.
    Lord Thunderbottom
    Quote Originally Posted by ntm1973 View Post
    Attachment 925861
    There's a lot more to tire fit than just width, overall diameter and chain clearance play a big part
    lots of updates, thanks for all the info folks!
    Jan 2015
    I take interest in this post.
    On rolling darryl my 27tpi nates measured 3-15/16" wide. Freshly mounted 120 tpi D4 studded only measured 3-11/16" wide. Not to happy about that. Maybe there is some stretching over time? Will update.
    Anybody have cross-references to provide Titan about the Bontrager Hodag? Seems to have escaped this list.
    Jan 2014
    Just got my Vee Bulldozer 26x4.7 120TPI
    1330g/1360g
    248mm/250mm
    They will be going on 100mm rims soon.
    edit:
    115mm at the casing and 111.5 at the side knobs on 100mm rims with tubes at 15psi.
    Jan 2014
    Vee Rubber Mission Command 26x4.0 72TPI tubeless ready (stock tires on Mongoose Vinson) These have about 160 miles on them.
    1410g/1440g
    236mm/238mm
    they measured right at 4" on 100mm rims
    Jan 2014
    Halo Nanuk 26x4.0 60tpi. Freshly mounted with 1/4 mile on 'em.
    210mm bead to bead.
    Measure exactly 3.5" wide at 10# on 65 mm Marge Lites. Tread-to tread, outer edge.
    Don't own a digital scale, other than my bathroom scale which is semi-accurate to 0.1 lbs. One tire felt a wee bit heavier than the other.
    I accomplished my goal of reducing the rotational mas of my wheels. By weighing myself, and then picking up my bike and weighing myself and the bike, both before I removed my Larrys, and doing the same after mounting these new Nanuks and substituting an ultralite Surly tube for the original (80 gram weight savings on the one tube), the same scale read 2.5 lbs less. That's with an error + or - 0.1 lb.
    At that level of accuracy, I suppose that I lost a approx 1.25 lbs per wheel.
    Almost forgot to mention that Nanuk is 3/8" (approx 10mm) smaller in diameter than Larry. A set of these will lower one's bottom bracket 3/16" compared to a set of the Larrys.
    Reputation: AllMountin''s Avatar
    These ties don't love laying completely flat due to wire bead and tall profile, but I get a shade over 10 1/2" bead to bead, or 267mm. They may be closer to 270mm.
    Chaoyang 4.9
    267mm bead to bead
    111.5mm casing
    101mm lug to lug
    ~1550 grams (not my measurement)
    Edited to adjust carcass width to 114 millimeters, when set up tubeless, at 15 psi.
    All measurements taken on 80mm rims.
    Sep 2012
    Why is this not a sticky? This should be sticky. Big props to TitanofChaos for putting that table together, how about something along the lines of a Googledoc that people could add their own info to? Just a thought
    Sep 2014
    Tyres were mounted tubeless on 90mm rims a week ago, so I'm guessing they've had enough time to stretch out. 7psi. Widths on 90mm rims added below in bold.
    Quote Originally Posted by 2bliss View Post
    Tyre 02145219:
    Weight = 1430g
    Width (sidewall-to-sidewall) on 90mm rim: 109mm
    Width (across side knobs) on 90mm rim: 112mm
    Tyre 03145131:
    Weight = 1440g
    Width (sidewall-to-sidewall) on 90mm rim: 108mm
    Width (across side knobs) on 90mm rim: 111mm
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    Quote Originally Posted by Willum View Post
    I added a link to this thread to the Fatbike Info thread already stuck to the top of the board as I was searching for it after seeing a few people mention this thread.
    Where is the latest version posted?
    Don't think the chaotic Titan is updating the list anymore. Perhaps one of you IT geeks could transfer the info into a public document?
    Lord Thunderbottom
    Quote Originally Posted by AllMountin' View Post
    sorry, added 2 measurements for tires we already have data on and added 2 tires no one is talking about
    Muchas gracias.
    Also, I've got a fat b 4.0 that measures 85mm on a 47mm rim.
    Where is the latest version of the document?
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Quote Originally Posted by CraigH View Post
    He has been replacing the pdf in the first post every time the list get's edited.
    Quote Originally Posted by sean salach View Post
    Thanks! I hadn't noticed the edit.
    Reputation: akacoke's Avatar
    i wonder where i can buy the chaoyang 4.9 tire
    17 Lynskey Fatskey
    07 Kona Stab
    14 Specialized Fatboy
    04 Santa Cruz V10
    My Parts for sale link
    Thanks for all the great infohow about a column for tire circumference ?
    Quote Originally Posted by akacoke View Post
    I tried to contact the fat bike company that installs them on their complete bikes to see if they sold them separate but they never responded.
  67. #67
    Jan 2014
    I asked at Wheel & Sprocket about them too. I suggested they sell them through their ebay store.
  68. #68
    Feb 2015
    It appears you can order them from the u.k. eBay site. Shipping sticks you pretty good but it's still not bad for what you get.
  69. #69
    Aug 2014
    Schwalbe Jumbo Jim 4.8", liteskin version.
    1350 grams
    111 mm width on an 80mm wide rim (Sun Mulefut) running tubeless at 15 PSI.
    Some weights from my postage scale:
    Vee Bulldozer 4.6" folding: 1350g
    Vee Snowshoe XL 4.8" folding: 1450 and 1460g
    Surly Big Fat Larry 4.7" 120 tpi: 1190g
  70. #70
    LBS has a Farley 5 in stock. Stopped by last night to measure the Barbegazi 4.7's on 80mm Mulfuts.
    I measured:
    761mm diameter at max pressure
    116mm outside edge of tread at max pressure
    117mm sidewall width at max pressure
    113mm outside edge of tread at 10psi
    Sorry I couldn't get the flat casing or tread width. The shop and I were unprepared for the pain of pulling the tires off the rims. That should be a bullet-proof tubeless setup, for sure! People are gonna have to CUT those tires off those rims!
  71. #71
    Oct 2015
    Schwalbe Jumbo Jim Evo foldable Liteskin 120 TPI 4.8 on 82 mm rims with 4.0 innertubes.
    - 260 mm bead to bead
    - 111 mm outside thread to thread
  72. #72
    Jan 2015
    Dunderbeist
    1498grams
    248mm bead to bead
    Flowbeist
    1320 grams
    250mm bead to bead
  73. #73
    Reputation: tundratrader's Avatar
    I am not seeing the data. I am on my phone with tapatalk.
  74. #74
    Quote Originally Posted by tundratrader View Post
    it's a link to a PDF in the first post of the thread.
  75. #75
    I see a icon with mountain with sgwigly line horizontal.
  76. #76
    Oct 2015
    Chaoyang 26x4.9 60 TPI folding
    bead to bead 272 mm
    mounted on 82 mm rim at 15 PSI
    knob to knob 106 mm
    somehow the rear Jumbo Jim looks bigger because of the side knobs.
    Anyone knows how much bigger both tires are gonna get if i put them tubeless?
  77. #77
    Quote Originally Posted by Gabriel F. Popescu View Post
    bead to bead 272 mm
    knob to knob 106 mm
    Not sure on the growth, but I found the same thing. Sitting next to Spesh Ground Control, the GC looked bigger, even though the numbers don't back that up.
  78. #78
    Reputation: rain100's Avatar
    Sep 2014
    I measured the 27.5" Hodag 3.8, and the bead to bead was 215mm. I measured 1260 g.
  79. #79
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Bump to keep this near the top
  80. #80
    Reputation: Misterg's Avatar
    Jul 2014
    Bontrager Barbegazi 26 x 4.7 120tpi Team Issue folding (stock on 2016 Farley 5)
    Weight 1.346 kg / 1.356 kg (front & rear) = 1.35kg / 3lbs average
    I couldn't get the carcass to lay completely flat, but the bead to bead measurement with it as flat as it would go is 260mm / 10.25" (would be more if it would lay flat).
    On the stock 80mm Mulefut rims it measures ~115mm / 4.5" across the knobs at ~~10 PSI.
  81. #81
    Jun 2010
    Quote Originally Posted by Misterg View Post
    I'll remeasure mine before I mount it tomorrow, but Barbegazi 120 TPI folding as well, 1360g. 255mm bead to bead. Will be mounting on Marge Lites, hoping to fit rear of 170mm 907.
  82. #82
    Forgot to measure the bead to bead width, but I just mounted up a snowshoe xl. At 10psi, new (no time to stretch out), 80mm rims (Mulfut), tubeless, it measures 111 mm to lugs, 109 carcass.
    Update. After stretching for a week or so, it measures 111 at the carcass. Had to trim knobs for it to fit in my frame, so I don't know exactly the knob width, but I would guess about 113.
    Typed on my phone. Pardon the autocorrect.
  83. #83
    Squ-eti
    Reputation: mccartney7499's Avatar
    Snowshoe XL's
    1474 g, 1530 g
    117 mm knob to knob on 90 mm rims
    114 mm at the carcass
    standard 4.0/4.9 tubes 623 g
    specialized 24x2.4-3.0 presta tubes 283 g
    rolls fairly smooth @ 9 psi with my 200 lb self aboard
    sounds like it's ripping apart the fabric of the earth @ 7 psi
    (I'm talking velcro like/kung fu grip)
    starts to feel "floaty" like you're riding
    a marshmallow or a cloud at below 6 psi
    not surprisingly self steer also begins to show up around 7 psi
    when the traction goes through the roof
    The wire bead, 72 tpi Vee H-Billies (4.25) these replaced
    were both 1445 grams.
    "Trails? Where we're going we don't need, trails!"
  84. #84
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    45nrth Dillinger 5 studded 1528g & 1605g
    Schwalbe Jumbo Jim 4.0 light skin 1109g & 1090g
    ptarmigan hardcore
  85. #85
    I got 1180g and 1137g for my JJ 4.0 Liteskins.
    So much for the 999g ones that were floating about when they first became available
    Fat Biker
  86. #86
    Reputation: kaleidopete's Avatar
    Feb 2015
    My sad story... I put a Dillinger 5 studded on the rear of my 2014 Farley with am 80mm wheel last year and it just fit. Three studs "ticked" the derailleur, but I didn't care, I ran it anyway. Fast forward to this year, I bought a Dillinger 5 unstudded to run on the rear. Guess what! I can't even squeeze it in there, even with 5 psi it's too big and too fat! Hard to believe there is that much discrepancy it the same tire and brand. So reading spec's and tire sizes doesn't always work as I found out. Makes me wonder if I bought 5 tires and tried them all until I found one that fit. ps, I even unmounted and rotated and remounted the tire several times because I really wanted it to work, but no dice.
  87. #87
    Reputation: xjoex's Avatar
    I have two new Maxxis Minion FBF and FBR tires. They claim 4.8" but they measure
    FBF 4.18" on a 81mm DT Swiss BR 710
    FBR 4.31" on a 81mm DT Swiss BR 710
    Honestly a bit of a disappointment.
    -Joe
  88. #88
    Reputation: Jseis's Avatar
    Dec 2009
    tire sizes.pdf
    Hey thanks for doing this, it is VERY helpful.
    One thing that likely messes with fit is aspect ratio: tire depth/sidewall height. A lower aspect fat tire is likely going to fit a [marginal] frame where a higher aspect ratio fat tire is going to hit the stays. Wouldn't take more than a centimeter to screw things up and it appears that air pressure figures prominently here. Higher pressure stacks sidewall height.
  89. #89
    Jan 2015
    Incredibly useful thread, given the price of these tires. Thanks to the OP.
  90. #90
    Jul 2013
    Quote Originally Posted by xjoex View Post
    -Joe
    weight is 1600gramm per tire?
    Then i certainly stick with my 4.6 45nrth ..
  91. #91
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    I will be taking delivery of a 2016 KHS Four Seasons 1000 in a matter of hours, I will measure the ChaoYang made KHS 120TPI Foldable 26 x 4.9s as mounted on 100mm rims the bike comes with, but if the bead-to-bead number a few messages back is correct, they should be monsters.
    Ok so they're a tall casing tire, bead to bead flat is 260mm but the tread is only 113mm flat and as what is essentially the same tire design as Panaracer's Fat B Nimble (which also never actually lives up to its claimed width) this didn't surprise me too much. At 5.7psi on 100mm rim the casing measured out to 115mm width but the tread was only about 103mm. Light weight and very supple casing though, 1306 grams for the front one on the bike and 1335g for the rear one. If you're after a large air volume with a fast rolling footprint this is a good tire to run.
    The TRUE tire size thread-bigdaddy1.jpgThe TRUE tire size thread-bigdaddy2.jpg
    I don't post to generate business for myself or make like I'm better than sliced bread
  92. #92
    Anyone got measurements of the Maxxis Colossus yet?
  93. #93
    Jul 2015
    Quote Originally Posted by slabber View Post
    So how is it ? Width ?
  94. #94
    LCW
    LCW is online now
    Reputation: LCW's Avatar
    Flowbeist/Dunderbeist 26x4.6
    Didn't measure bead to bead (saw this thread after they were already mounted), but happended to weigh them before installing:
    Flowbeist: 1380g
    Dunderbeist: 1440g
    And in comparison, Surly Nate 26x4.0 27tpi pair weighed:
    -1720 & 1760g
    ... so pretty good savings!!!
    Rough measurement of them installed, after about 1/2 dozen rides (6-8 psi), they are appox 4.2" (107mm) at the knobs, 4 (101mm) at the casing. Far cry from the "4.6" they are supposed to be. This is on My Other Brother Darryl rims. Running them tubeless.
    Santa Cruz Hightower LT
    EVIL Following
  95. #95
    Jan 2016
    Quote Originally Posted by DeeEight View Post
ID:	1037727Click image for larger version.
    Hello Dee8, ive been on the fence about buying a 2016 1000 khs, may we know your impressions please? Ive been riding a 2015 and been quite happy with it. But its smaller frame cant accomodate the bigger tires unfortunately. Thanks.
  96. #96
    Jun 2010
    Quote Originally Posted by Jukahia View Post
    Sorry, didn't see this question earlier, not visiting site that regularly these days...
    Mounted tubeless on Marge Lites - casing measured out just over 104mm, knob width 109.5mm.
    Pretty happy with the tire overall, but going to try Flowbeist now for more positive cornering traction as the Barbegazi knobs aren't super tall but it does roll relatively well as a result.
  97. #97
    Old, Slow and now FAT! :)
    Reputation: TheNormsk's Avatar
    Quote Originally Posted by LCW View Post
    Flowbeist: 1380g
    Dunderbeist: 1440g
    That's a low weight for your tired. Is that accurate?
    I weighed mine on kitchen scales and mine came to:
    Flowbeist 1446g
    Dunderbeist 1479g
  98. #98
    Just browsing this thread to help inform my next tyre purchase and saw the Maxxis Minion FBF size quoted. I have an FBF on the same rim (81mm) and it measures 4.46" @ 10psi. Quite a difference - that is the outside knob measurement.
  99. #99
    Jun 2016
    I did not take them off the rim, but the Kenda 4.5" Gumwalls measured 4.49" wide on a 101mm rim:
  100. #100
    Quote Originally Posted by GiantTurd View Post
    Anyone measure a JJ 4.8 on a 65mm rim?
    Someone from the Jumbo Jim thread said 110mm on 65. Not sure how accurate that is.
    http://forums.mtbr.com/fat-bikes/jumbo-jim-928088-post12483975.html
  1. Maxxis Minions DHR II 2.3 true to size?
    By Whip Chop! in forum Wheels and Tires
    Last Post: 08-14-2017, 11:51 PM
  2. 19.5/49.5cm? What is the true size for me?
    By wfp in forum Bike and Frame discussion
    Last Post: 09-16-2013, 02:37 PM
  3. Kenda slant 6 true to size
    By Learux in forum General Discussion
    Last Post: 03-22-2013, 08:08 PM
  4. How do the sizes on XXX shoe run? True to size? Or not quite?
    By squareback in forum Apparel and Protection
    Last Post: 03-13-2013, 10:45 AM
  5. 45NRTH Wlvhammer--they fit true to size.
    By lawfarm in forum Fat bikes
    Last Post: 08-21-2012, 05:01 AM
Members who have read this thread: 200
