Page 3 of 3 FirstFirst 123
Results 101 to 118 of 118
  1. #101
    Jun 2016
    I did not take them off the rim, but the Kenda 4.5" Gumwalls measured 4.49" wide on a 101mm rim:
  2. #102
    Quote Originally Posted by GiantTurd View Post
    Anyone measure a JJ 4.8 on a 65mm rim?
    Someone from the Jumbo Jim thread said 110mm on 65. Not sure how accurate that is.
    http://forums.mtbr.com/fat-bikes/jumbo-jim-928088-post12483975.html
  3. #103
    Reputation: kyttyra's Avatar
    Mar 2012
    Recently purchased a Jumbo Jim 4.4" (Snakeskin) to my alloy Beargrease. The tire weighed in at 1205 g. I did not measure the bead to bead width, but on a 65 mm rim with 0,6 bar pressure the width at the knobs was about 104 mm and at the casing, about 99 mm. Quite reasonable
    Update: on mulefut (already stretched) 0,5 bar pressure: knobs 105 mm, casing 106 mm (≈4,17").
  4. #104
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    Terrene Wazia 4.6 Studded.
    1668g on kitchen digi scale.
    240mm bead to bead same as my 45nrth D5s
    102mm on my DT Swiss BR710 80mm rim and 106m knob t knob.
    Attached Thumbnails Attached Thumbnails The TRUE tire size thread-20161201_185413small.jpg
    ptarmigan hardcore
  5. #105
    Jan 2014
    Quote Originally Posted by kyttyra View Post
    Thank you!. I've been hoping to hear some measurements of a 4.4 JJ width on a 65mm rim.
    How do you like the profile? Are the shoulder knobs still where we'd want 'em for good cornering grip?
  6. #106
    Reputation: solarplex's Avatar
    Apr 2014
    When is everyone measuring. My gnarwhal was almost flush with the sides of my mulefut new, now it has some bulge out. Would say it probably widened 1/4"
    Fatbike, XC bike, Gravel Bike....
  7. #107
    Reputation: Techspec360's Avatar
    Quote Originally Posted by Co-opski View Post
    105mm on my DT Swiss BR710 80mm rim.
    How's the Wazia in snow? Any chance you've ridden it on any wet roots as well? Been eyeballing it but can't find much info as far as rubber compound, durameter, or reviews for that matter..... Thx!!
  8. #108
    sluice box
    Oct 2013
    Quote Originally Posted by Techspec360 View Post
    The ground
    has been frozen this winter. I have had them in light loose snow, hardpack groomers and an ice rink. More info here. New tire company, Terrene Tires
    ptarmigan hardcore
  9. #109
    Mar 2012
    Quote Originally Posted by PlutonicPlague View Post
    The profile is (not surprisingly) quite rounded. I have a feeling that for best cornering grip a little wider rim would be better, but so far I'm not complaining.
  10. #110
    Reputation: brilleaux's Avatar
    May 2016
    Snowshoe 2XL on 80mm DT-Swiss rim. Knob to knob. 10Psi and tubeless. Now over a month from that picture width is 127-128mm.
    Life, Love & The Blues. And Fatbiking.
  11. #111
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Just got a pair Jumbo Jim 4.4 Liteskins. Weight: 1174 grams, casing width: 245 mm.
    --Peace
  12. #112
    Jul 2015
    I may have missed it, but my 120TPI Fat B Nimbles (FBN) measure a true 4" on a 100mm rim with about 10psi. They work very well in the sandy washes here in Az. Great budget tire for here.
  13. #113
    Reputation: tyriverag's Avatar
    Jan 2014
    Quote Originally Posted by brownmruk View Post
    Just browsing this thread to help inform my next tyre purchase and saw the Maxxis Minion FBF size quoted. I have an FBF on the same rim (81mm) and it measures 4.46" @ 10psi. Quite a difference - that is the outside knob measurement.
    I just measured my FBF 4.8 on a 80mm Sun Ringle Mule Fut: 4.375". Brand new tire, no time to stretch.
    2015 Trek Farley 6
    2009 Fuji Cross Comp
    2001 Schwinn Frontier SS
  14. #114
    sluice box
    Oct 2013
    updated my 4.6 Wazia numbers.
    ptarmigan hardcore
  15. #115
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Snowshoe XL'S on a 100 mm rim or Snowshoe 2XL's on a 80 mm rim. Anybody got numbers on this?
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
  16. #116
    Quote Originally Posted by RockyJo1 View Post
    XL's on 100 width 4.54" or 115.47mm. Casing and knob width for all intents and purposes the same.
    Latitude 61
  17. #117
    Oslo, Norway
    Feb 2012
    All at industry standard 20psi test pressure:
    I have measured tons of XLs and they are typically 4.7 to 4.8 on 100s.
    They are 4.4'' on my current 80mm ice setup.
    2XLs are typically spot on 5.0 on an 80.
    If you are checking for comparison, remember that the rolling diameter of the 2XL is much, much bigger than the XL. It is a 300mm bead to bead tire vs. 260mm for true size 4.8s (XL, JJ, Bud/Lou, etc).
    4.0s are typically around 220mm, so the difference in volume beween the 2XL and a 4.8 is as big as the difference between a 4.8 and a 4.0.
    Espen Wethe
    Bicycle Engineering Consultant
    Norway
    https://fat-bike.com/2016/06/diamant...an-pennington/
  18. #118
    Rocking on a Rocky
    Quote Originally Posted by Espen W View Post
    Cool thanks. Trying to decide between getting 2XL's on 80's or get 100mm rims and run my XL's.
  1. Maxxis Minions DHR II 2.3 true to size?
    By Whip Chop! in forum Wheels and Tires
    Last Post: 11-24-2015, 06:05 PM
  2. 19.5/49.5cm? What is the true size for me?
    By wfp in forum Bike and Frame discussion
    Last Post: 09-16-2013, 02:37 PM
  3. Kenda slant 6 true to size
    By Learux in forum General Discussion
    Last Post: 03-22-2013, 08:08 PM
  4. How do the sizes on XXX shoe run? True to size? Or not quite?
    By squareback in forum Apparel and Protection
    Last Post: 03-13-2013, 10:45 AM
  5. 45NRTH Wölvhammer--they fit true to size.
    By lawfarm in forum Fat bikes
    Last Post: 08-21-2012, 05:01 AM
