Page 2 of 2 FirstFirst 12
Results 101 to 136 of 136
  1. #101
    Reputation: kyttyra's Avatar
    Mar 2012
    Recently purchased a Jumbo Jim 4.4" (Snakeskin) to my alloy Beargrease. The tire weighed in at 1205 g. I did not measure the bead to bead width, but on a 65 mm rim with 0,6 bar pressure the width at the knobs was about 104 mm and at the casing, about 99 mm. Quite reasonable
    Update: on mulefut (already stretched) 0,5 bar pressure: knobs 105 mm, casing 106 mm (≈4,17").
  2. #102
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    Terrene Wazia 4.6 Studded.
    1668g on kitchen digi scale.
    240mm bead to bead same as my 45nrth D5s
    102mm on my DT Swiss BR710 81mm rim and 106m knob to knob.
    Attached Thumbnails Attached Thumbnails The TRUE tire size thread-20161201_185413small.jpg
    ptarmigan hardcore
  3. #103
    Jan 2014
    Quote Originally Posted by kyttyra View Post
    Thank you!. I've been hoping to hear some measurements of a 4.4 JJ width on a 65mm rim.
    How do you like the profile? Are the shoulder knobs still where we'd want 'em for good cornering grip?
  4. #104
    Reputation: solarplex's Avatar
    Apr 2014
    When is everyone measuring. My gnarwhal was almost flush with the sides of my mulefut new, now it has some bulge out. Would say it probably widened 1/4"
    Fatbike, XC bike, Gravel Bike....
  5. #105
    Reputation: Techspec360's Avatar
    Quote Originally Posted by Co-opski View Post
    105mm on my DT Swiss BR710 80mm rim.
    How's the Wazia in snow? Any chance you've ridden it on any wet roots as well? Been eyeballing it but can't find much info as far as rubber compound, durameter, or reviews for that matter..... Thx!!
  6. #106
    sluice box
    Oct 2013
    Quote Originally Posted by Techspec360 View Post
    The ground
    has been frozen this winter. I have had them in light loose snow, hardpack groomers and an ice rink. More info here. New tire company, Terrene Tires
    ptarmigan hardcore
  7. #107
    Mar 2012
    Quote Originally Posted by PlutonicPlague View Post
    The profile is (not surprisingly) quite rounded. I have a feeling that for best cornering grip a little wider rim would be better, but so far I'm not complaining.
  8. #108
    Reputation: brilleaux's Avatar
    May 2016
    Snowshoe 2XL on 80mm DT-Swiss rim. Knob to knob. 10Psi and tubeless. Now over a month from that picture width is 127-128mm.
    Life, Love & The Blues. And Fatbiking.
  9. #109
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Just got a pair Jumbo Jim 4.4 Liteskins. Weight: 1174 grams, casing width: 245 mm.
    --Peace
  10. #110
    Jul 2015
    I may have missed it, but my 120TPI Fat B Nimbles (FBN) measure a true 4" on a 100mm rim with about 10psi. They work very well in the sandy washes here in Az. Great budget tire for here.
  11. #111
    Reputation: tyriverag's Avatar
    Jan 2014
    Quote Originally Posted by brownmruk View Post
    Just browsing this thread to help inform my next tyre purchase and saw the Maxxis Minion FBF size quoted. I have an FBF on the same rim (81mm) and it measures 4.46" @ 10psi. Quite a difference - that is the outside knob measurement.
    I just measured my FBF 4.8 on a 80mm Sun Ringle Mule Fut: 4.375". Brand new tire, no time to stretch.
    it's a challenge some of us are ultimately worthy of.
  12. #112
    sluice box
    Oct 2013
    updated my 4.6 Wazia numbers.
    ptarmigan hardcore
  13. #113
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Snowshoe XL'S on a 100 mm rim or Snowshoe 2XL's on a 80 mm rim. Anybody got numbers on this?
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
  14. #114
    Quote Originally Posted by RockyJo1 View Post
    XL's on 100 width 4.54" or 115.47mm. Casing and knob width for all intents and purposes the same.
    Latitude 61
  15. #115
    Oslo, Norway
    Feb 2012
    All at industry standard 20psi test pressure:
    I have measured tons of XLs and they are typically 4.7 to 4.8 on 100s.
    They are 4.4'' on my current 80mm ice setup.
    2XLs are typically spot on 5.0 on an 80.
    If you are checking for comparison, remember that the rolling diameter of the 2XL is much, much bigger than the XL. It is a 300mm bead to bead tire vs. 260mm for true size 4.8s (XL, JJ, Bud/Lou, etc).
    4.0s are typically around 220mm, so the difference in volume beween the 2XL and a 4.8 is as big as the difference between a 4.8 and a 4.0.
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
  16. #116
    Rocking on a Rocky
    Quote Originally Posted by Espen W View Post
    Cool thanks. Trying to decide between getting 2XL's on 80's or get 100mm rims and run my XL's.
  17. #117
    Icebiker
    Reputation: Bugeye's Avatar
    Great info, thanks! I am trying to decide between grip studding my Ground Controls or buying a studded pair of tires. I am running my 4.6 GC's on a 170mm Mukluk frame on 82mm rims. They measure 4.3" in this config. Enough to avoid frame rub/chain rub (had to install a wider BB) but don't think I can go much wider. Grip studding will run about $120 - $150 per tire. Studded Vee XL's go for about that much new these days, but I can only find 4.8's. Any idea where I can find 4.0's? I have searched online with no luck. Any other studded tire suggestions in this price range welcome. Thanks!
  18. #118
    Jul 2015
    Can we get this stickied?
  19. #119
    Jun 2017
    White silica snowshoe xl 26 x 4.8 250mm 1660g
  20. #120
    Dec 2016
    Jumbo Jim 26 x 4.0 @ 20 psi mounted on a Surly Rabbit Hole 50mm rim measured at the knobs (widest part) 3.8” (96.53mm). Also clears on my Manitou Magnum 27.5 boost fork.
  21. #121
    Flying Sasquatch
    Reputation: KTMNealio's Avatar
    Jun 2016
    Quote Originally Posted by gumba View Post
    Could you post a pic of this setup ? I've always been curious what a 4.0 (or 3.8) looks like on a 50mm rim..
  22. #122
    Dec 2016
    This is the JJ, I've also test fit the H-Billie 4.25, and the Nate 3.8. More to make sure it clears the fork.The TRUE tire size thread-salsa-jj-sm.jpg
  23. #123
    Quote Originally Posted by KTMNealio View Post
    Tire Size V. Rim Size- Mtbr.com
    It is an old photo with old tires but the first post in the attached thread should do it.
    Latitude 61
  24. #124
    Chris Bling
    Reputation: dustyduke22's Avatar
    Anyone have a b2b measurement on a set of Jumbo Jim 4.8 tires?
  25. #125
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by dustyduke22 View Post
    From memory approx 265mm
    In other words, some of the widest 4.8 labeled ones out there.
    Typical 4.8 width is right at 260m B-B
    Espen Wethe
    www.kindernay.com
  26. #126
    That's what I've recorded from other members as well.
  27. #127
    Chris Bling
    Quote Originally Posted by bme107 View Post
    Thanks guys. I have it mounted on some 70mm rims are really dig the profile. Still plenty of float, but so much more fun on trails. No self steer and fun as heck. Here is a pic.
    I have some new studded Cake Eaters that are 4.6, so I was curious how much smaller they will be.
    Sent from my SPH-L720T using Tapatalk
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  28. #128
    WNC Native
    Reputation: nitrousjunky's Avatar
    This is the JJ, I've also test fit the H-Billie 4.25, and the Nate 3.8. More to make sure it clears the fork.Click image for larger version.
Name:	salsa jj sm.jpg
    Do you have any pics of the clearance in the fork? I've been wondering about this combo in my Magnum Pro. Sent you a PM also.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  29. #129
    Oct 2012
    How are you liking the cake eaters? I’m thinking about picking up a set and trying to decide between the 4” and 4.6”.
  30. #130
    sluice box
    Oct 2013
    Here are some of the Terrene Cake Eater 4.6 120 TPI next to 45nrth Dillinger 5 120 TPI and Terrene Wazia 4.6 120tpi on DT Swiss BR710 rims that are 76mm inner and 81mm outer rim width.
    Measured on the BR710 103mm casing width and 109mm to the tread knobs. 240mm bead to bead same as my Wazia 4.6 and 45nrth D5s
    1580g on my weed scale.
    Dillinger 5 vs Cake Eater 4.6
    Cake Eater 4.6 vs Wazia 4.6
    ptarmigan hardcore
  31. #131
    Chris Bling
    Quote Originally Posted by tschram72 View Post
    They are studded and currently we have no snow!
  32. #132
    Dec 2017
    Mounted tubeless on 100 mm rims, Origin8 120 TPI folding bead Tsunami measurements @ 5 PSI, 35 Degrees F
    Tsunami 4: Tread - 3.5" / Sidewall - 4.3"
    Tsunami 4.9: Tread - 4.1" / Sidewall - 5"
    Yukon Truck
    Novatec / Mulefut 80's
    Tsunami 4.9's
  33. #133
    Chris Bling
    Here is a Cake Eater 4.6 studded next to a Wazia 4.0
  34. #134
    Reputation: Kirkerik's Avatar
    Apr 2016
    xxx
    Studded Dillinger 4/5 For Sale
    The tires are the things on your bike that make contact w the trail
  35. #135
    Reputation: BlueCheesehead's Avatar
    Quote Originally Posted by Pack66 View Post
    i would find it more useful than the daily pics thread that is stickied.
  36. #136
    Believe it was stickied at one point. Ebb and flow of the times.
    There was a big influx of people posting numbers 2-3 years ago and now that is on the wane. With fewer new offerings the excitement dies out........
  1. Maxxis Minions DHR II 2.3 true to size?
    By Whip Chop! in forum Wheels and Tires
    Last Post: 07-09-2018, 06:47 PM
  2. 19.5/49.5cm? What is the true size for me?
    By wfp in forum Bike and Frame discussion
    Last Post: 09-16-2013, 02:37 PM
  3. Kenda slant 6 true to size
    By Learux in forum General Discussion
    Last Post: 03-22-2013, 08:08 PM
  4. How do the sizes on XXX shoe run? True to size? Or not quite?
    By squareback in forum Apparel and Protection
    Last Post: 03-13-2013, 10:45 AM
  5. 45NRTH Wölvhammer--they fit true to size.
    By lawfarm in forum Fat bikes
    Last Post: 08-21-2012, 05:01 AM
Members who have read this thread: 49
