Results 1 to 8 of 8
    Reputation: 7HVN's Avatar
    Tire Width on a Speedway Uma 50mm
    Does anybody know the width of these tires on a Speedway Uma 50mm rim:
    1. Husker Du
    2. Nate
    3. Endo
    4. Larry
    I have limited space between the fork legs.
    Fatback
    Reputation: thirstywork's Avatar
    I'm getting about 89 and 88mm on an Endo and Larry. Haven't tried the others.
    Speedway Cycles owner http://fatbackbikes.com
    I'm thinking it might be a good idea to start a spreadsheet/database like was done with the wheelset spreadsheet on google docs. Include tire and rim then measured width...average if there are some reporting with the same combo. Seems like the question of how wide is x tire on y rim comes up a lot.
    May 2010
    Width of the Husker Du on my 49mm Onza rim (should be similar) is 87 mm.
    Made to Shred
    Reputation: Fortyfour's Avatar
    Feb 2010
    Nate x Uma 50mm
    Nate on an Uma 50mm with Paul Whub is approximately 91.8mm by my calipers. (that's from knob to knob...)
    Kristofer Henry - 44 BIKES - Made to Shred™
    www.44bikes.com - 44 Flickr - 44 Facebook
    That Unicycle Guy
    I got 88mm at the tread @ ~15 PSI for my Larry on 50mm speedway rim.
    EDIT: if you want measurements for skinnier rims as well; the same Larry on a 46mm Echo rim 86mm at the knobs when it was new.
    I'm attracted to Gravity!
    Reputation: campredcloudbikes's Avatar
    Endo on my 44mm Echo Trials rim is 84-86 mm as I recall. Tons of mud clearance in the Enabler fork.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    A couple of months ago I measured these on my Speedway 50 and got:
    Nate 11psi, 96 mm wide, 29" tall
    Larry 13.5 psi,88 wide, 28 7/8" tall
    Endo 13.5psi, 83 wide, 28 3/4" tall
    The height is a little fuzzy
    Wondering why my Endo is skinnier? Mine's from August '08...
    I just got a Hüsker Dü; I can add a measurement when I swap it out.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
