Results 1 to 18 of 18
    Dec 2016
    Tire Pressure and Snow Question
    Hi, I am 65 years old and new to Fat Bike riding in the snow. I recently bought a Farley 5 and tried riding down the street after a pretty big snow storm we just had in NJ. There was about 4 inches of snow over a plowed road and I was slipping quite a bit. My tires are not tubeless and at 10lbs pressure. Would going tubeless and having lower pressure fix this problem? How does lower pressure affect riding in the snow. Any advice would be appreciated. Thank you.
    Aug 2015
    I have only had my fat bike a couple of months, but that is WAY too much pressure in the tires. I ride mine on dry trails between 6-7.5 lbs. Go down to about 5 and see what happens.
    -edit
    Mine has tubes.
    Reputation: fishboy316's Avatar
    Jan 2014
    When in the snow I run about3-6 psi. Helps a lot. I am tubeless. I also run my 26x4.7 tire/wheel setup. I personally like tubeless over tubes for all my setups.
    2013 Cannondale F29 1 Alloy
    2013 Cervelo S5 Rival
    2012 Trek X01 crosser
    2017 Trek Farley 7
    2017Trek Domane SLR 6
    Professional Crastinator
    Reputation: Fleas's Avatar
    Tubeless is not a requirement for running <5psi. I have had the tire rotate on the rim and apply stress to the valve stem, though.
    But for snow, few people run more than 7psi. Fiddle with it a little, and remember that if your pressure is 8psi in a warm house, it will be <5psi out in the cold.
    -F
    It's never easier - you just go faster.
    Rippin da fAt
    The idea of low tires for snow is to make the tire become wider and longer in terms of footprint. The larger the footprint the more surface area of treads propelling ya forward. Some peeps get scared when their tires wrinkle, some of us count the number of wrinkles to determine if we've let out enough air for the conditions present. My Bud/Lou have never been inflated enough to remove the wrinkles and still look excellent after 4 winters of daily driving. You're gonna hafta play with air pressure as your setup and weight are yours alone.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Oslo, Norway
    Feb 2012
    As others have mentioned, 10psi in a fatbike tire is rock hard.
    Take them down to 3-4psi in those conditions and marvel at the difference.
    Tubeless and you can probably go (well) below even that.
    Here is a video with closeups of my tires, riding at 0.7psi:
    Low pressure for this kind of riding (here at 0.0psi unloaded):
    https://www.youtube.com/watch?v=OHEgnVaLZaE
    High pressure for this kind (7psi):
    https://www.youtube.com/watch?v=lOumMRdlqHk
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
    Dec 2016
    Thanks for the advice. I will definitely take it.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Used to ride 4 psi front and 6 psi rear on my old bike with 4" tires and tubes, never had a flat and had plenty of traction.
    Light fluffy snow like the one that the blizzard left is hard to ride on anyway. We tried to ride on non plowed roads during the storm and was really hard, we kept sinking and sliding; let the snow compress a little a give it another try.
    Incredulous bastard
    Reputation: no one in particular's Avatar
    jf19451, just thought I'd offer the perspective of someone running tubes. I'm running Surly light fat tubes in Maxis 4.8 DHF/DHRs on 80mm rims. For dry, rooty and rocky trails, I'm running 7-8psi--basically enough to get rid of self-steer and give a little pinch protection. But for snow cover, I start at 4psi, and depending on conditions I'll go down to 2psi or lower if needed.
    After about 650 miles like this, I haven't gotten a pinch flat.
    __________________
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Some snow doesn't care, especially soft soupy wet snow. Lowering the pressure helps, but snow is extremely dynamic and dependent on the temperature and consistency. In some conditions we can ride through 8" of dry powder, in some conditions we can't ride through 3" of slop.
    Reputation: bikeny's Avatar
    Also get a good low pressure gauge. The one on your floor pump is useless at fatbike pressures.
    I weigh 180lbs, ride rigid, with 4.6" Flow/Dunderbeist tires. The trail conditions here (BC) have run from smooth/groomed to bumpy, post-holed, no fresh snow to 4" of powder. I was running 7-8psi when I first tried snow riding and found the rear tire was digging down instead of floating and propelling me forward. A drop to 3psi rear and 2psi front has made a world of difference, good to go anywhere.
    Reputation: ADKMTNBIKER's Avatar
    Nov 2014
    I know I'm good as long as I can push my thumb into the tire tread and make a good inch deep dimple. If you can't press your thumb down easily then lot air out.
    Reputation: Bacon Fat's Avatar
    Mar 2016
    We got a range of snow here in NJ, close to NYC it is slop. Out west it is better snow. Don't be afraid to run super low pressure. I know some of the guys outside the NYC slop zone were running 0 psi
    You don't really need a pressure gauge to adjust air pressure. You can just air out until you can ride. After saying that ;-P I run up to 10psi but the trails are very solid for that. Usually I ride with anywhere between 4-8psi.
    Sep 2014
    Good info. I run Flow/Dunder and am 200#. 6psi'ish is too much for softer stuff but great on hard pack and roads to/from trails.
    Sent from my iPhone using Tapatalk Pro
    Feb 2017
    27.5" / 4.5" (tubes for now) here on a farley 9.6 -> 2-4psi in from and 3-5 psi in rear has been working for me in NJ as well this winter.
    Even those warm days we had where there was no snow I upped it to 6-7 front and 7-8 max in the rear. I find it way too bouncy anything over 9-10psi
  1. Tire Pressure Question
    By bgar15 in forum Beginner's Corner
    Last Post: 10-21-2016, 01:20 PM
  2. Tire pressure question?
    By rickcin in forum Cyclocross
    Last Post: 09-01-2015, 06:39 PM
  3. Tire pressure question.
    By procos in forum Fat bikes
    Last Post: 10-07-2014, 08:49 PM
  4. Question on tire pressure for my GF
    By Sleevem1 in forum Women's Lounge
    Last Post: 05-18-2014, 06:32 AM
  5. tire pressure question
    By fuzygrub in forum Clydesdales/Tall Riders
    Last Post: 08-29-2013, 04:17 PM
Members who have read this thread: 9
