Results 1 to 11 of 11
    Jul 2013
    Tightening Pug Crank Question
    Hey all, so I just got a pug and ive been greasing her up and doing a little maintenance. I re greased the crank and when i was putting it back together i wasnt sure how much to tighten the drive side crank. If i hand tighten it then the pedals are a little tougher to push (not difficult but u can tell theres more resistance). I wanted to know if its suppose to be like that or can I just tighten to the point where there is no more play in the crank. Im sort of a noob so help me as much as you can. Thanks! Its a single speed if hat makes a difference.
    Jul 2013
    Ya that looks like it, i just have one chain ring. Why doesnt it say what to torque the driver side allen bolt too
    There doesn't seem to be a spec; take all the slop out, then tighten the crank arm on the spindle. Bearing preload, like an old-style bottom bracket or bike hub.
    FWIW, I am not impressed with this set-up.
    Reputation: Schott's Avatar
    Nov 2012
    Yup, there isn't a torque spec as it is will change, and probably barely even register on a torque wrench. Adjust it like you would any other bearing. Tighten until there isn't any more clicking. I found on the whirly, after a while anyway, that I would actually have to leave it a little bit loose, and clicking, as the bearings started to go, as anything close to not clicking was obviously to tight. Got a new bottoms bracket and crankset....fixed it.
    Jul 2013
    What kind do you go with and how much did it cost if you don't mind me askin?
    Nov 2012
    I went with Race Face Turbine, not sure on cost as I shop wholesale...but a simple search will prove results. Love the crankset, but we will see how the BB holds up to the onslaught of winter.
    Jul 2013
    Ya Im fortunate that I don't have to worry about winter messin much up being in florida haha.
    And this might seem like a dumb question but the trails I ride have a good amount of roots an I bounce around a little. I know I'm not gonna get it to feel like a FS bike but would putting more air in the tires help or taking it out?
    Reputation: duggus's Avatar
    Quote Originally Posted by desperado213 View Post
    Less air always. Try 8 psi.
    ...Be careful what you're looking at because it might be looking back...
    Jul 2013
    10-4 thanks
    Nov 2012
    Yup, lose air until not bouncy. Summer I'm around 7-8.
  1. bottom bracket tightening.
    By crazee horse in forum Beginner's Corner
    Last Post: 05-30-2013, 07:22 AM
  2. Fork Bottom nut not tightening
    By ehigh in forum Shocks and Suspension
    Last Post: 01-14-2013, 09:29 PM
  3. Schrader valve tightening.
    By arcticrobot in forum Shocks and Suspension
    Last Post: 04-16-2012, 10:18 AM
  4. Tightening spokes?
    By morningmist in forum Wheels and Tires
    Last Post: 05-10-2011, 05:35 PM
  5. I'm changing my headset spacers, question about tightening....
    By ProjectDan35 in forum General Discussion
    Last Post: 02-08-2011, 09:59 PM
