Results 1 to 35 of 35
Thread: Swagman FatRack
    Reputation: Solo-Rider's Avatar
    Sep 2013
    Swagman FatRack
    I have the Swagman XTC2, love this style of rack and now with my fat bike on order. All I can do sit and wait.
    So, I started to get my swagman ready for those fat tires. I wanted to keep the cost down and still have the OME look. I was able to do this under $10 total. At work, I used a vice, hacksaw, grinder wheel, hand drill and a milling machine.
    Parts:
    Needed to cut Two 8 1/2" sections from a 1" X 10' EMT Conduit pipe
    Four Cotter Pins 5/32 X 2"
    Two HD chair leg tips 1"
    First, I cut the supporting hoop from the base with a hacksaw. Then ground all the burs off from the hoops and base.
    Bending the hoop and trying to get the 5" spread was a bit of trial and error because of a lack of a pipe bender.
    The O.D. of the tubing on the hoop is .630" so I used a 5/8 drill bit on the mill then a small hand grinder. I wanted the tolerance to be as close as possible. Also, the O.D. on the base tube was was just under 1" a perfect fit for the conduit. Just needed to be tapped down with an aluminum mallet
    With the new pipe sleeve on, and snug up to the mounting block. I drilled a 5/8 hole 1" away from the block and a 5/8 hole a 1/2" past the inner tube.
    Anyway you get the idea. It was easy to do and turned out well. I used the 5/32 pins to hold it all together. The chair tips I used for end caps. A coat of paint and that's it. Nothing is loose however, because I didn't have a welder handy, I needed to use those pins.
    I may ask a friend to weld it later if needed. At the base, going from the inside of the hoop, it's 5 1/2" and tappers to 4 1/8" at the top.
    Last edited by Solo-Rider; 10-14-2013 at 04:18 AM. Reason: because I'm using a tablet. :-)
    DB Overdrive Pro (MTB)
    TREK 2.3c (Road)
    MASI Custom (Coffee Bike )
    Mercier (Gravel Bike)
    Sycamore Area Cycling
    My plan for my Swagman rack is to use some 1/2" steel square tubing to make a rectangular "hoop" connected to a piece of 1" square tubing. Then weld that onto a piece of 10 gauge bent into a shape that will work with the plastic insert that came with the rack platforms. Unfortunately my brother's welder has been on a bit of a traveling road show the past few months.
    Sep 2013
    Quote Originally Posted by gecho View Post
    Lol, If your brother's welder stops for a vacation, post up some photos.
    Oct 2013
    Love the work guys! We are looking into the potential of doing an accessory for Fat Bikes. It is difficult to get reliable numbers for the number of bikes out on the market currently. Stay tuned to Swagman Facebook for more details.
    Quote Originally Posted by Okanagan Dave View Post
    If you were to do a production run of platforms that fit on the XTC2 I'd buy a pair (or set of 4). They'd probably be lighter than anything I could weld together. I'm try to avoid buying a whole new rack.
    Oct 2013
    I will definitely post on this thread if we make the decision to do something. We want to do something like this, but we have to be conscious of the cost involved. Tooling up for a special run is not inexpensive, and something every company is careful with. The other thought is to do something for our new Semi 2.0 and 4.0 as they share common parts (wheel trays) and are Zero-Frame contact racks which is a nice bonus if you happen to have other high-value bikes to haul around.
    I'm not sure how well something that clamps onto the tire would work with the low tire pressure of fat bikes. While my bike is stopped, with my hand on the brake I can rock the bike back and forth a fair bit on tire flex alone.
    Sep 2013
    Dave,
    Thank you for having the time to take a look. As im sure you are aware that Fat bikes, are the fastest growing segment in cycling right now.
    Whatever Swagman, decides to do with a fat rack attachment design. I'm sure people are glad to see the aftermarket paying attention.
    Fred.
    Sep 2013
    Update.
    Here are three photos of my fatrack with my bike installed. As everyone can see. Even when you mount the bike in the closest position to your car, there is no problems with clearance. It holds true just like any other bike that you would normally mount.
    TREK 2.3c (Road)
    Reputation: proline69's Avatar
    Good post
    thanks for the write up and pics. i'm guessing that with the rings widened you wouldn't be able to fit a smaller wheel in there now? i ask because i would like to purchase a rack that is versatile enough for my road bike as well as my 29er and fatbike.
    the feedback from swagman in this thread is promising, so might just end up buying this rack and flipping the rings upside down and using velcro straps with my fatbike until they make an attachment available.
    Sep 2013
    Quote Originally Posted by zcmack View Post
    This rack is versatile and economical.
    The rack is designed to hold two bikes. Thus, the rack comes standard with two sets of holders. Modify one to hold your fatbike, and keep the other stock to hold any other bike you wish.
    Folds up nicely and fits in your trunk when not in use.
    TREK 2.3c (Road)
    I've got the 4 bike version and have been thinking of the best way to carry my fat bike. My idea was to have a V or U shaped piece of aluminum made to fit into the existing trays. This new tray would have sides that came up a few inches on each side to secure the wheels. There would be slits in the new tray for the existing straps to go through and secure the tire and tray. Very simple, easy to take on and off and cheap. I've got it sketched out somewhere and a buddy was going to make a couple for me. Just need to get around to doing it!
    Sep 2013
    Maybe, this might help?
    It gives Swagman, a good idea of the available tire sizes on the market today. I do realize some others are still in the works. However, most should fall within the 3.8" - 5.0" range. It does look like the 4.0" has become the standard fatbike tire size. Being adopted by most every new player in the fatbike market such as Trek, Kona, Specialized, Motobecane, On One and others.
    Surly Endomorph. 3.7
    $89 - $120
    Discontinued by manufacturer, still available at some retailer's.
    Surly Larry. 3.8
    $90 - $160
    Casing: 120tpi with Kevlar bead (1255g) 27tpi with wire bead (1635g)
    Surly Black Floyd. 3.8
    $81 - $90
    Casing: 60tpi with Kevlar bead (1050g)
    Surly Nate. 3.8
    $81 - $150
    Casing: 120tpi with Kevlar bead (1350g); 27tpi with wire bead (1730g)
    Vee Rubber Mission. 4.0
    $39 - $75
    Casing: 27tpi wire- 120tpi Kevlar bead
    1800g +/- 50g. 1450 +/- 40g
    Vee Rubber Vee8. 4.0
    $61 - $90
    Casing: 120tpi Kevlar bead (1390g)
    Manufacturer suggested use, medium to hard pack trail conditions.
    On One Floater. 4.0
    $65 w/Free Shipping outside European Union.
    Casing: 120tpi Kevlar bead (1498g)
    Runs great on rims from 55-90mm. (Looks to work on 100mm rims as well.)
    Origin8 Devist-8er 2. 4.0
    $35 - $59
    Casing: 60 tpi wire bead (2000g)
    Origin8 Devist-8er UL. 4.0
    $34 - $57
    Casing: 120tpi Kevlar bead (1750g)
    45NRTH Husker Du. 4.0
    $110 - $150
    CASING: 120tpi or 27tpi
    bead folding (120tpi option), Wire (27tpi option)
    RIM COMPATIBILITY 65-102mm wide rims
    45NRTH Dillinger. 4.0
    $165 - $225
    OPTIONS 120tpi Studded, 27tpi Studded, 120tpi Stud-less
    STUDS Aluminum/Carbide (120tpi), Steel/Carbide (27tpi)
    bead folding (120tpi), Wire (27tpi)
    FATBACK STERLING 4.25
    $135
    4.25″ on a 70mm rim , Casing: 120 tpi Kevlar bead.
    Tubeless compatible (1300g)
    Vee Rubber Snowshoe. 4+?
    $120 or about. New to market.
    Casing: 120tpi Kevlar bead. (1350g)
    Surly Big Fat Larry. 4.7
    $144 - $190
    Casing: 120tpi with Kevlar bead (1400g)
    Surly Bud. 4.8
    $145 - $185
    Casing: 120tpi with Kevlar bead (1585g)
    Surly Lou. 4.8
    $153 - $200
    TREK 2.3c (Road)
    Apr 2014
    I had called swagman when I discovered that Hollywood racks has fat bike wheel trays. Fork Block and Wheel Mount for bike racks, trunk racks, bicycle carriers - Hollywood Racks
    The rep said there were no plans to produce anything for the xtc. I have a xtc 4 so I may need to sell to buy another brand.
    Need something now. Transport issue with bike was not expected.
    Jan 2014
    I have the Swagman XC and am using it stock with Larrys and Floaters. With tire pressure around 4 psi it slips in and locks tight and fills the whole tire support. The bike is rock solid in the stock hoops. Didn't even need bungees. Transported my bike 720 miles on the way back from Big Sky, checked every stop and made no adjustments.
    Apr 2014
    And no extra straps? The tires seem to have very little lateral support when I took the bike to the beach this past weekend. Based on your experience, maybe I will call off the search for "better", deflate tires for transport, and go from there.
    Jan 2014
    Everything was copacetic. No extra straps. At 4 psi, I was able to push the tires down till they hit the ends as well as the sides of the oval hoop. Missed the rims. Couldn't have asked for a better fit without any further adjustments. I do, however push the bike down when I bring the bar to the top tube, which means you have to do the same to release. A couple of pumps and back up to street ride or no pumps and good for single track (bumpy).
    Quote Originally Posted by Leftcoasterca View Post
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Swagman FatRack-img_2014081554890.jpgAnyone know if those Hollywood fat trays fit onto the square tubing of the swagman?
    I just picked up am xtc2, looks like it'll be a great rack, would love the fat trays though.
    I flipped a set, probably add an extra bungee and looks like they'll be fine... But those fat trays would be perfect
    Apr 2014
    Quote Originally Posted by Shark View Post
ID:	916053Anyone know if those Hollywood fat trays fit onto the square tubing of the swagman?
    That is exactly my solution. Fits the xtc rack fine. Fork Block and Wheel Mount for bike racks, trunk racks, bicycle carriers - Hollywood Racks
    Feb 2006
    Thanks!!
    I found some online for $40....avant bicycle supply...
    Apr 2014
    Excellent. I paid more cause hollywood would not ship to canada. Had to go through distributor to get them. Fill msrp and high ship cost.
    Who is the distributor in Canada?
    Feb 2006
    Used it first time today, almost 40 miles, bike stayed put nicely. I added bungee cords around each tire, until the fat trays arrive.
    Reputation: Lu-Max's Avatar
    Specialized Ground Control Fat 4.6
    $160
    Casing 120tpi, folding bead
    Advertised at 1450g, my four averaged out at 1350g
    I finally got around to trying the Hollywood fat trays with my Swagman XTC 2. When I first got the trays they were too loose on the rack arms, to the point they would easily slide even when fully tightened. So I made a pair of shims with some 24 gauge (0.025") aluminum, and they are much more snug. With Bud & Lou on Clown Shoes the included strap is long enough to secure the tires.
    My only problem has more to do with the design of the rack itself. The instructions indicated to place the hold down hook at the lowest part of the top tube. On several of my bikes this is not possible without having the bike extended far to one side of the vehicle. Using it as shown in my picture the bike does start to wiggle around when the car hits bumps, even when setting the hold down hook very tight. No so much that the bike risks falling off, but it does scuff the paint. I usually wrap the top tube with a bit of old inner tube.
    Thanks for the report, have been interested in knowing more about that particular solution.
    As for it loosening, what if you set the tire pressures low enough that you can compress the tires when setting the hook? If the tires are under compression, that might keep tension on the hook so it doesn't wiggle around. On my suspension bikes, I usually set the hook tight enough to compress the fork a bit.
    Oct 2013
    Gecho, where did you buy the fat trays from? I haven't been able to find them online and ended up emailing Hollywood and they say dealer only. My nearest dealer is 40 miles away according to their website. Just curious if there is a better way to order them.
    I got mine at etrailer.com as they were the only online place that shipped to Canada. Ended up being a little over $100 after international shipping and exchange. Within the USA shipping should be cheap or free.
    Oct 2013
    Thanks for the info. Really appreciate it.
    Oct 2013
    For those that are interested, free shipping the next few days from etrailer.com. just ordered mine.
    Reputation: J.R.B's Avatar
    Swagman FatRack
    Thanks for posting up the etrailer.com info. I ordered the Hollywood fatbike rack and it came with both the fat tire trays and regular trays. Great customer service and fast shipping to Ontario, Canada as well. Received email notification that it was shipped on a Monday and the rack was delivered on Wednesday.
    A much nicer and secure trailer hitch rack compared to my old swagman top tube mount rack.
    Apr 2014
    Did you order from Hollywood directly or their distributor in Quebec. They would not sell directly to me.
    Oct 2013
    I ran into the same problem ordering direct from Hollywood so go to etrailer.com. they will hook you up. They had to put my trays on back order and it took a while to get but there was great communication. Wasn't their fault anyways, they ran out of stock.
    Reputation: Captain_America1976's Avatar
    Mar 2005
    I ordered mine from etrailer just after Christmas. They arrived the other day. I installed them tonight on a Performance Xport rack, and they fit great.
  1. Swagman XTC 2 review
    By fripple in forum Cars and Bike Racks
    Last Post: 02-25-2016, 12:58 PM
  2. Anyone see the Swagman Jackknife?
    By sand wedge in forum Cars and Bike Racks
    Last Post: 05-16-2014, 06:45 AM
  3. Swagman Racks
    By criscobike in forum Cars and Bike Racks
    Last Post: 03-15-2013, 06:34 PM
  4. Difference between Swagman XTC and XC?
    By DaggerK1 in forum Cars and Bike Racks
    Last Post: 03-08-2012, 05:03 AM
  5. Swagman XTC 4 $255
    By ssuperlight in forum Cars and Bike Racks
    Last Post: 05-23-2011, 03:15 PM
