Results 1 to 24 of 24
    Which Suspension fork for Trek Farley 9.8?
    I have a Trek Farley 9.8 and want to put a suspension fork on it. I know there is a lot of information about it in the Trek Farley 2016 thread but was wondering if there are any updated options for a suspension fork?
    I have ordered a 29 inch wheelset with 45mm internal width rims to run 3.0 tires in addition to the 4.5 inch 27.5 Barbegazis that came with it.
    If the only good option is still the Rockshox Bluto, should I get 100 or 120 travel?
    My farley 9 came with 100 stock. They should have the same geo
    Reputation: glockrocket17's Avatar
    Aug 2015
    You should look at the manatou mastadon. The Farley rigid fork is corrected for a 100mm fork but I'm going to get a 120mm when I get mine.
    Sent from my Nexus 6P using Tapatalk
    Reputation: Tunalic's Avatar
    Feb 2012
    I don't think the Bluto will work with the Barbs.
    2016 Trek Farley 9.6
    2015 616 Muenzie
    2013 On One Fatty
    2011 Trek Sawyer
    Tunalic is right. Go for the manitou mastodon ext
    Quote Originally Posted by Tunalic View Post
    Now that is something I did not know! I was planning on using the 29 plus 3.0 tires during everything but snow riding. But I did want to be able to put the Barbegazis on in snow, and with the suspension fork.
    The 3 inch 29 plus tires I have my eye on is the Chupacabra by Trek.
    Anyone have any experience with the manitou masstodon fork and the Farley and the Barbegazis and also 29 plus tires?
    Feb 2012
    You won't have any problems with the manitou. Here's a couple threads about the bluto.
    27.5 x 4.5 Barbegazi and a Bluto?
    26" Bluto for my 27.5"Farley 9.6?
    2015 616 Muenzie
    2013 On One Fatty
    2011 Trek Sawyer
    Thank you very much for that info! Do you have the Mastodon on your Farley?
    Also if anyone here owns a Farley and the Manitou Mastodon and has used it with the Barbegazis and also with 29 plus 3 inch tires I would like to hear from you too. How well it works, what size Mastadon you got, etc.
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by treasureman View Post
    The farley 7 for 2018 comes with a 80mm mastodon extended. I did some number crunching and with sag, like 90ish mm is same ride hight as the carbon fork so 100mm would work.
    Fatbike, XC bike, Gravel Bike....
    Feb 2012
    I been waiting and watching. I may get one after I get a 29+ wheelset built up. I believe someone said a few of the 2018 Farleys will come with the Mastodon. Since it such a new fork you may want to go thru that Mastodon thread.
    2015 616 Muenzie
    2013 On One Fatty
    2011 Trek Sawyer
    You need to verify that the Mastodon will fit the older frames, Trek may have modified the 2018 frame to clear the fork.
    Mastodon EXT fits 29+ no probelm, Bluto does not allow for gravel/mud clearance.
    Quote Originally Posted by Nurse Ben View Post
    My Farley 9.8 is a 2017 so it should work right?
    It looks like I need to get the Mastodon 120 EXT model to work with both the Barbegazis and 29 plus.
    The specs for the Mastodon says it has Brake 180mm Post Mount. My Farley 9.8 has 160mm rotors. Does that mean I will need to buy 180mm rotors, or is there a way to make it work with the existing 160mm?
    You have to buy a 180 rotor.
    MN/WI
    Reputation: theGliberal's Avatar
    Farley mit Lauf
    Last year's 9.8. Needed 180mm rotors.
    Remember, nobody knows. So let's find out...
    Quote Originally Posted by the mayor View Post
    Thanks! And I guess there is some sort of spacer I can buy to put on the original carbon fork to use 180mm rotors should I want to switch forks?
    Quote Originally Posted by theGliberal View Post
Name:	Farley mit Lauf.JPG
    That's the same bike I have!
    Just a rotor change and used the existing calipers, correct?
    You either put a spacer under the caliper with the carbon fork....or switch back to the 160 rotor.
    Probably just easier to buy the spacer and a rotor ( or rotors if you have multiple wheels)
    Something like this for spacers?
    https://www.amazon.com/Avid-Post-Mou...TF8&th=1&psc=1
    I am getting a 2nd wheelset so it would be easier to have both front rotors at 180 than to switch rotors if I want to use the stock carbon fork.
    Apr 2014
    Sexy! Thinking of getting a 2018 9.6 and getting that fork.
    MN/WI
    Yes. Had to go to a 180mm on the front rotor but kept everything else.
    Nov 2015
    I've just fitted a Mastodon 120mm Pro EXT to my Farley 5, its an XL frame and it fits no problems, the clearance this for has is unbelievable, currently running 26 x 4.7 Barbegazi's and the Mastodon makes it look like a skinny xc tyre there is that much clearance all round! Only done a short trial ride but this think rocks like no other, had a Bluto and a Wren and it is leagues ahead of both of them, hate to use the cliché but it really is a game changer, this is what the Bluto should have been and the quality is superb. I'll post some pics shortly.
    Aug 2015
    I have a Farley 9.6 how does the geometry feel with 120mm on bike with 10mm of extra travel than recommended 100 ?
    Hi, I have a 2016 Trek Farley 9.6 and was told by Trek support that the Manitou Mastodon fork or not recommended for this bike because its crown race can touch the downtube of the frame. Has anyone installed the Mastodon on a 2016 Farley 9.6 and if so how any issue?
  1. Replies: 4
    Last Post: 06-06-2017, 08:39 AM
  2. 2014 Farley 2015 Farley 6 Fork Recall
    By josh8 in forum Fat bikes
    Last Post: 01-13-2017, 11:13 AM
  3. 2014 Farley 2015 Farley 6 Fork Recall
    By josh8 in forum Trek
    Last Post: 11-02-2016, 09:14 AM
  4. 2015 Farley 6 or 2016 Farley 5?
    By jgdblue in forum Fat bikes
    Last Post: 10-24-2015, 04:41 PM
  5. Replies: 4
    Last Post: 10-04-2014, 11:31 PM
Members who have read this thread: 49
