    Reputation: mongol777's Avatar
    Surly OD cranks - will these ones fit Moonie
    Was ordering remainder of the parts for my Moonie builds last nights.
    Found these at universal cycles Universal Cycles -- Surly OD Crankset - 100mm Bottom Bracket and ordered them. Right after saw that they also list Moonie specific ones separately - Universal Cycles -- Surly OD Moonlander Crankset - 100mm Bottom Bracket and Moonie ones are not in stock.
    Surly website does not have any specifics on OD cranks being different models. Online descriptions also did not reveal any difference.
    So should I cancel my order or will the ones I ordered work with Moonolander?
    Reputation: lancelot's Avatar
    Pretty sure you need the Moonlander set to avoid chainline problems. I'm pretty sure Yxan has a new set he doesn't need. If you can't find them elsewhere.
    The LPG
    i thin they will fit, but the moonie ones have an even greater offset to clear bud/lou so maybe if you are using bfl's you would be okay
    but i might be wrong
    i want some moonie OD cranks and no one has got any in the UK at all
    Talked to super nice guy from universal cycles, Brad. He found schematics for of cranks - Moonie indeed needs special of model. They should have them in stock within next 2 weeks
  1. More Moonie questions
    By mongol777 in forum Fat bikes
    Last Post: 11-20-2013, 03:33 PM
  2. Moonie or Krampus
    By crux in forum Fat bikes
    Last Post: 01-16-2013, 09:50 AM
  3. WTF? sorry, Surly cranks suck!
    By jeffgothro in forum Surly
    Last Post: 04-06-2011, 11:28 PM
  4. Hive 15g cranks + Surly 135mm SS hub?
    By mattbryant2 in forum Singlespeed
    Last Post: 02-02-2011, 10:14 AM
  5. surly 1x1 profile cranks spindle question
    By melvinscentral in forum Surly
    Last Post: 01-26-2011, 09:48 PM
