Page 4 of 4 FirstFirst 1234
Results 301 to 334 of 334
  1. #301
    Reputation: coastkid71's Avatar
    A 5" BFL will fit in on a 65mm wide rim, though 4" on any width rim fits ok, as does 29+ wheels
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
  2. #302
    Dec 2013
    Thanks for the info, BTW I shot you a PM
  3. #303
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by cjbiker View Post
    I think I have enough miles on my old Mukluk and the Wednesday to prove that the 100mm BB is not a problem in real life.
    I've actually grown to prefer 100mm BB width on my bikes. Feels more neutral, natural to my knees and ankles. On the rare days that I ride my one remaining 73mm BB bike, I immediately notice the narrowness and it takes some re-adaptation. Going back and forth between them, 100mm always feels like 'coming home'.
  4. #304
    Oct 2014
    Quote Originally Posted by mikesee View Post
    I was thinking exactly the same thing today. Been commuting on the Krampug for a few weeks to get some off road time in but rode to work on the Lomg Haul Trucker today. Just felt wierd. Going from 100mm bb and wide handlebars back to drops and 68mm I felt all scrunched up. Legs didn't quite work as well either.
  5. #305
    Aug 2003
    Quote Originally Posted by Co-opski View Post
    Easy to deal with part. Just my $.02 whatevs many seem to like him.
    I'd love to know what I did wrong, and how I can make it right.
    Please drop a line to: info@lacemine29.com at your convenience.
  6. #306
    Jan 2016
    I've switched to flat pedals on all my bikes, even the road bikes. I find myself positioning me feet toward the outer edge of the pedals. I've always battled knee pain, but it seems to be in check. I wonder if the narrow cranks and clipless pedals I used for years forced me into a stance too narrow and stressed my knees too much.
  7. #307
    Aug 2003
    Lots o' variables. Sometimes just a cleat position adjustment can make the difference. Hard (impossible, really) to diagnose online.
  8. #308
    Jan 2016
    Could be. When I switched from SPD to Speedplay Frogs, that made a huge improvement. I'm happy with flat pedals now, though.
  9. #309
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    Anyone know if I c a n just relace a krampus rear wheel to fit the pugs, or do you need different spoke lengths for the offset?
  10. #310
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    Quote Originally Posted by skankingbiker View Post
    You need to offset the rim by 17.5mm. The Rabbit Hole wheelset has 64 spoke holes so that it can be laced symmetrically, or entirely on one side. In the latter, the wheel is offset.
    Ultralight bikepacking and gear lists... MaxTheCyclist.com
  11. #311
    Yes same spokes will do, i swapped a rabbit hole from symmetrical to offset and back again several times as i played around with different builds. Pug - ECR- Pug - Krampus, and back to a Pug!, I reused the spokes but replaced the spoke nipples
  12. #312
    Rednose/Greenback
    Reputation: apbtlvr's Avatar
    New wheels for the pugs. Should be prove more versatile option for urban wanderings.
    38° 54' -77° 15
  13. #313
    KramPug; Commuter bike, shops bike, pub bike, trail bike,
    Some detour off road commuting home...
    http://<iframe width="425" height="2...reen></iframe>
  14. #314
    Reputation: Magicscreen's Avatar
    Dec 2016
    If your fat bike doesn't use an off-set rear wheel and the hub width matches up, should you be able to put the stock Krampus RH/Knards on a fat frame?
    MaxTheCyclist.com
    Dec 2014
    I don't think any fatbikes use a symmetrical 135mm hub. That's the whole reason offset or super-wide hubs were made in the first place. With a regular hub like the Krampus has, the chain can't clear a 4-5-inch tire in low gear.
    So, the answer is, if you have a 135mm spaced dropout and its symmetrical, yes, a Krampus wheel will fit, but no fatbikes have that so it's irrelevant.
  16. #316
    Dec 2016
    That makes sense. The guy I bought my bike from had posted this picture of my bike with plus tires on it. I was hoping it might just be a simple swap, but apparently it's more complicated than that.
    Thanks sincerely for your reply. Also, I just followed your blog link - what a great resource that is! Strong work!
  17. #317
    MaxTheCyclist.com
    Dec 2014
    Quote Originally Posted by Magicscreen View Post
    Not simple, but not too complicated either! You can have a rear wheel made. 29+ wheels are super fun and it's a great way to get two bikes out of one.
    You can also put a regular fork on a fatbike most of the time to make use of a premade Krampus front wheel. Just make sure the axle-to-crown and rake match up. I think a stock Krampus fork fits a lot of fatbikes well. But, you can always have a 29+ whee made on a fatbike hub in the front, too, if you don't want to buy another fork.
  18. #318
    Dec 2016
    If I had another wheel built then I would REALLY have no excuse for hanging on to my Krampus! Thanks for taking the time to answer my question, Max. I really appreciate it.
  19. #319
    MaxTheCyclist.com
    Dec 2014
    Oh, ok, I'm glad you have a Krampus You can get your 29+ fix. No problem! Enjoy~
  20. #320
    Dec 2016
    Big Wheel Krampug
    I tried something that I haven't seen anyone discuss yet:
    Threw on a Karate Monkey fork (+21 mm vs. the stock Pugs offset fork) and a Rabbit Hole laced (non-offset) to a 100mm XT hub (thanks, MikeSee!). Picked up a used Innova Transformer 29x3.0 for $10 and created what I am dubbing the "Big Wheel" Krampug.
    I didn't have high hopes for matching the Spray Tan orange fork to the snow white frame, but I actually dig it and think it jives well. The front end feels way more slack (and lighter, though not by much). The 29x3 is probably 1"+ taller than the 26x4 I kept on the back. I still get the traction/large volume benefits of having a full fat rear end, but now enjoy an even larger (and almost as wide) front end.
    I've only put ~20 miles on the new setup, but really like it so far. SURLY KramPug thread...-img_0777.jpgSURLY KramPug thread...-img_0779.jpgSURLY KramPug thread...-img_0781.jpgSURLY KramPug thread...-img_0782.jpg
    Attached Thumbnails Attached Thumbnails SURLY KramPug thread...-sidebyside.jpg
  21. #321
    Reputation: zachary_miller's Avatar
    May 2013
    Good job! Karate-Krampug
    Sweeeeeeet spray tan fork! I similarly just made the switcharoo to a Karate-Krampug and really enjoy the slightly slacker front-end (and the speed of 29+ wheels)! I owned a Krampus years ago, and sold it because I just loved my Pugs more... but with the wheel swap (after 6000+ miles and two frames of pedalling 26 fat on my favorite bike) my Pugsley is a whole new animal! I'd strongly recommend it for a summer speedy option if you're waffling out there!SURLY KramPug thread...-_dsc4252.jpg
    Once you go fat, you'll never go back...
    Some words and photos from wandering: www.zacharystephenmiller.wordpress.com
  22. #322
    Dinner for wolves
    Reputation: buddhak's Avatar
    Krampug brain trust,
    I am wondering aloud if the Surly ECR 27.5+ fork would accept a Knard/RH 29+ combo. The Surly website suggests NO since the max tire size advertised is 29 x 2.5. ANyone out there try to shove a 29+ into an ECR 27.5 fork? The reason I am considering it is that I want to run a 100mm dynamo hub and I like the braze-ons on the ECR.
    Responds to gravity
  23. #323
    turtles make me hot
    Reputation: NYrr496's Avatar
    Quote Originally Posted by buddhak View Post
    Probably won't fit. Do you already have a wheel with a dynamo? What are your options here? I'm asking because I've built a few generator wheels for Krampus and Pugs. MAYBE I can help.
    I like turtles
  24. #324
    Dinner for wolves
    Quote Originally Posted by NYrr496 View Post
    No, I don't have the wheel yet. I like to marinate on stuff like this long before I take the plunge and order parts. In the end I have to decide which is more important to me: the proper A-C of the Pugsley non-offset fork, or the neat braze-ons of the longer ECR 29 fork. The 27.5" ECR would have been the ideal solution if it would clear a 29x3.0 tire.
    Thanks. I like turtles, too.
    Responds to gravity
  25. #325
    VENI VEDI BIKI
    A few years late to the party, but I finally build me a Krampug. Decided to get 2 bikes in 1 instead of getting a Stache.
    So far only been on railtrail gravel but the handling is much improved. It really is a whole new bike. Having trouble setting up the rabbits tubeless though....Do people remove the surly rim strip when using gorilla tape?
    Can't wait to get it on some singletrack
    20180303_112155 by T_MB, on Flickr
    2018-03-12_01-29-12 by T_MB, on Flickr
    Veni Vidi Biki
    I came, I saw, I biked.
  26. #326
    Feb 2014
    I'm thinking about going the krampug route also. Did you get your wheels set up tubeless?
  27. #327
    turtles make me hot
    I do Rabbit Holes split tubeless.
    I like turtles
  28. #328
  29. #329
    turtles make me hot
    Unlacing and lacing the wheel with the tire in place. My hat's off to you, sir.
    I like turtles
  30. #330
    VENI VEDI BIKI
    Quote Originally Posted by dezzrat1 View Post
    Yes.... the problem was the valve stems. I had trouble getting the stans stems to work--i.e. they wouldn't sit tight in the valve hole. I used cut-up stems from old tubes...they worked like a charm.
    I also initially experimented with Scotch webbed packing tape, but that didn't seem to work well, so I went back to the tried and ture 2 layers of gorrila tape.
    Veni Vidi Biki
  31. #331
    Reputation: blockphi's Avatar
    Mar 2012
    Been riding a pugs since 2012. I just got a warranty replacement for the frame from Surly - long story. Anyway, they sent me a 2018 orange frame. I've decided to pull the trigger and have a set of rabbit holes built up for the bike. I'm stoked reading through this thread. Love the pugs, but the krampug sounds like the shiz.
  32. #332
    Dec 2013
    Silly, but fun, wheel!! Polished Roval 32 hole hub with DT swiss internals, laced to a polished rabbit hole. I've got 2 of these wheels actually, but can only use one. PM me if want the spare.SURLY KramPug thread...-030.jpgSURLY KramPug thread...-031.jpgSURLY KramPug thread...-032.jpgSURLY KramPug thread...-034.jpg
    With the pugsley offset, these came out to 306mm straight pull spokes both sides. Being DT swiss, can swap stuff around, so the newer pugsleys could run a 142x12mm thru axle, can run XD drivers, etc etc etc. I believe this older Roval hub has the same dimensions as a newer DT 350 straight pull hub and I have a giant pile of the 306mm straight pull spokes, so if I'm bored, I may build up several of these.
    Deflated - buy parts to sell parts to buy more parts.. bikes are my drug of choice
    FATTrailer for the kiddo
  33. #333
    Feb 2014
    Quote Originally Posted by Jason Rides Bikes View Post
    Silly, but fun, wheel!! Polished Roval 32 hole hub with DT swiss internals, laced to a polished rabbit hole. I've got 2 of these wheels actually, but can only use one. PM me if want the spare.Click image for larger version.
ID:	1203916Click image for larger version.
ID:	1203917Click image for larger version.
ID:	1203915Click image for larger version.
    Interested,. Plz email me at dezzrat1@yahoo.com
  34. #334
    Mar 2012
    Been away for a while, but thought I'd share some picks of the built up KramPugs:SURLY KramPug thread...-inflight.jpg
    I like it quite a bit. However, it does seem to be a bit slow to respond on the front end on fast, tight corners.
  1. My Surly Necromancer Experience Thread
    By Keski in forum Fat bikes
    Last Post: 12-26-2014, 08:24 PM
  2. Paid SPAM: Surly Black Floyd with Surly tubes
    By tracerprix in forum Fat bikes
    Last Post: 11-15-2012, 09:02 PM
  3. 24" Surly Ogre Build Thread
    By fatpig in forum 29er Bikes
    Last Post: 09-15-2012, 09:34 AM
  4. Surly Bikes Film Thread
    By coastkid71 in forum Surly
    Last Post: 10-24-2011, 07:09 PM
  5. Replies: 0
    Last Post: 01-21-2011, 08:17 AM
Members who have read this thread: 114
