Results 1 to 32 of 32
    Specialized Fatboy specs and Australian pricing :)
    Here are the specs and pricing of both model Fatboys coming to Australia, no geo data yet but will post it as soon as it is available
    Fatboy $2299.00
    Technical Specifications
    FRAME New Specialized M4 Premium Aluminum, 29er geometry, fully butted w/ smooth welds, tapered headtube, post-mount disc dropouts, replaceable alloy derailleur hanger
    FORK FACT carbon full monocoque, 5.0" tire clearance, 135mm spacing
    HEADSET 1-1/8" upper and 1-1/2" lower FSA, Campy style w/ integrated cartridge bearings, 3.8mm cone spacer
    STEM Specialized 3D forged 6061 alloy, 4-bolt clamp, 6-degree rise, 60mm/70mm/90mm length, 31.8mm
    HANDLEBARS Specialized mini riser bar, 6061 double-butted alloy, 660/700mm wide, 10-degree backsweep, 6-degree upsweep, 31.8mm
    GRIPS SRAM, 92mm grip, included with SRAM S-Series GS shifter
    FRONT BRAKE Tektro Draco 2, hydraulic disc, dual piston, 180mm rotor
    REAR BRAKE Tektro Draco 2, hydraulic disc, dual piston, 160mm rotor
    BRAKE LEVERS Tektro Draco 2, hydraulic lever
    FRONT DERAILLEUR SRAM X7, low direct mount
    REAR DERAILLEUR SRAM X7, 10-speed, medium carbon cage
    SHIFT LEVERS SRAM S-Series, Grip Shift twist shifter, 10-speed
    CASSETTE Sunrace, 10-speed, 11-36
    CHAIN KMC X-10
    CRANKSET Custom 2x10, 2 piece, PF30, forged alloy crankarm, w/ 100mm CNC spindle, 170mm/175mm length
    CHAINRINGS 36/22
    BOTTOM BRACKET Samox, PF30 for 2 pc. crankset, 100mm shell, included w/ crankset
    PEDALS Alloy, 1 pc. body and cage, w/ reflectors, 9/16"
    RIMS Stout SL Fat, alloy disc, single wall, 26mm pin joint, hookless design, 32 hole
    FRONT HUB Specialized MTB disc, alloy, Hi Lo flange, sealed bearings, 135mm wide, alloy axle, QR, 32h
    REAR HUB Specialized MTB disc, alloy, Hi Lo flange, sealed bearings, 190mm wide, alloy axle, QR, 32h
    SPOKES Stainless, 2.0, threadlock, 14g
    FRONT TYRE Specialized Ground Control, 26x4.8", Kevlar bead, 120TPI
    REAR TYRE Specialized Ground Control, 26x4.8", Kevlar bead, 120TPI
    INNER TUBES Standard presta valve
    SADDLE Body Geometry Henge, steel rails, 143mm
    SEATPOST Specialized alloy, 2-bolt, micro-adjust, 30.9mm, 350mm/400mm
    SEAT BINDER Forged alloy, QR, 34.9mm
    NOTES
    Specifications subject to change without notice.
    Fatboy Bike Geometry
    No geometry info is available for this bike model.
    Then there is the top of the range
    Fatboy Expert $2999.00
    FRAME New Specialized M4 Premium Aluminum, Fat Bike Geometry, fully butted w/ smooth welds, tapered headtube, post-mount disc dropouts, replaceable alloy derailleur hanger
    FRONT BRAKE Shimano Deore, BR-505, hydraulic disc, 180mm rotor
    REAR BRAKE Shimano Deore, BR-505, hydraulic disc, 160mm rotor
    BRAKE LEVERS Shimano Deore, hydraulic lever, w/ reach adj.
    REAR DERAILLEUR SRAM X0, Type 2, 10-speed
    CASSETTE Sunrace, 10-speed, , alloy spacers, alloy lock-ring, 11-36
    CHAIN KMC X-10L, hollow outer links
    CRANKSET Custom e.thirteen, 2 piece, PF30, 100mm spindle, 170mm/175mm length
    CHAINRINGS 36/22
    BOTTOM BRACKET e.thirteen PF30, included w/ crankset
    PEDALS Specialized Bennies, 6061 alloy body, sealed cartridge bearings, removal 4.5mm pins
    SPOKES Stainless, double butted, threadlock, 14g
    SADDLE Body Geometry Henge SL, hollow Cr-Mo rails, lite PU foam, 143mm
    Differences I can see from the standard to Expert model are, Cranks, brakes, pedals, spokes, bottom bracket and rear derailleur.
    More details on Expert Fatboy
    New, fully butted M4 Premium Aluminum frame with 190mm rear spacing and a tapered headtube for a lightweight platform with stiffness where you need it and clearance for 5" tires
    > New, full monocoque, Specialized FACT carbon fiber fork with 5-inch tire clearance is super-lightweight and stiff
    > Wide, 4.8" Specialized Ground Control tires with foldable aramid bead are light, fast rolling, and provide excellent traction regardless of the terrain
    > Custom e.thirteen 2x10 crankset with PF30 bottom bracket and 100mm spindle provide worry free and efficient pedaling
    > Shimano Deore hydraulic disc brakes provide powerful and consistent braking, regardless of the weather, temperature or terrain.
    > SRAM X0 Type 2 10-speed rear derailleur provides fast and reliable shifting that can handle all elements
    and for the Fatboy
    > Custom 2x10 PF30 crankset with 100mm spindle provides tough and dependable performance
    > Tektro Draco 2 hydraulic disc brakes provide powerful and consistent braking, regardless of the weather, temperature or terrain
    > SRAM X7 10-speed rear derailleur provides fast and reliable shifting that can handle all the elements
    Why the brake difference ? The Draco vs the deore ? Is mineral oil that much of an upgrade ? Why not xt ?
    I would have preferred a full shimano bike but thats my personal preference.
    Cant wait
    I am waiting to see the tires.
    aka bOb
    Reputation: bdundee's Avatar
    Hookless rim that will be interesting. I'm all over it for carbon rims to help strengthen the rim but on a fat bike? Not really seeing any advantages for that especially with the big variances in some of the tires and the uber low pressures.
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by jonshonda View Post
    Me too, nothing else catches my eye.
    Trek 9.9 Superfly SL
    FM190 Fatty
    Indy Fab Deluxe 29
    Pivot Vault CX
    Cervelo R3 Disc
    Reputation: Schott's Avatar
    Nov 2012
    4.8...curious to see the profile on these. Closer to a BFL would be awesome.
    aka bOb
    Quote Originally Posted by Schott View Post
    Yessssss this!!!! We are still missing a good betweener tire, I don't want to buy a 190mm frame!!
    any news on delivery date?
    Quote Originally Posted by gogoolplex View Post
    Late 2013
    Reputation: Wombat's Avatar
    The cheap one's around A$800-$900 more expensive than the on-one fatty. If I was looking for a cheap entry into the fat space I'd pick up the on-one.
    Tim
    Mar 2012
    stopped at my LBS to pick up some tubes and talked to the guys about the Fatboy. He said that he talked to the rep a couple days ago. He said they are going to be pretty sweet but what fat tire bike doesn't make you smile?
    To arrive November 2013 (just in time for the snow... well depending on where you live just in time)
    Pricing (approx)
    Base Model: $2,000
    Expert Model: $2,500
    Reputation: OFFcourse's Avatar
    No one cares about cost they just want to know how much everything weighs ;-)
    Fat & Single
    Quote Originally Posted by shanesbw View Post
    Fatboy $2299.00
    Quote Originally Posted by SRock24 View Post
    Base Model: $2,000
    We like to pay 15-20% more in Oz as they are 20% better quality and lighter when they arrive here.
    FM190 Fatty
    Indy Fab Deluxe 29
    Pivot Vault CX
    Cervelo R3 Disc
    Quote Originally Posted by ozzybmx View Post
    It would be mind boggling if they showed up here in time for xmas and less than $3K, I only buy bottle cages from our S-shop ;-)
    Quote Originally Posted by Wombat View Post
    Tim
    and miss out on 4.8" tyres, 90mm light weight (ish) rims, carbon fork and much lighter bike. I would take the Fatboy anyday.
    Quote Originally Posted by OFFcourse View Post
    If you are talking about Oz delivery? The bikes are listed on Specialized B2B at the prices listed and delivery for Dec 31, I am hoping sooner as they are only waiting on tyres
    Nah NZ
    Tires are the stand out item - 4.8 ground controll - can't wait to see these I hope they're not as expensive as Surly.
    Jul 2013
    Looking out for the tyres too, though in the meantime i looked up reviews of the 2.3 versions of the ground control and reviews mention that the tire has weak walls and needs high pressure.
    Lets hope that won't be the case with the 4.8 ones
    aka bOb
    Guilty here! Oh and size matters as well.
    This might help a bit more
    http://ridefatbikes.com/wp-content/u...tboy-Pages.pdf
    Once I get mine I will be pulling it apart and weighing every part for all to see
    Reputation: NZPeterG's Avatar
    Good job! New Zealand
    Nah NZ
    Fatboy's ETA in New Zealand is late November this year, Specialized shop's have placed there orders (in NZ) and we just have too wait.
    I have missed out (at my LBS) on 1st shipment to NZ.
    So have to wait on 2nd ship load too NZ for me! (yes I can call around all the Specialized in NZ, but i'm looked after by my LBS).
    All Cool as 2nd shipment will be here before the snow .
    Pete
    Feb 2005
    I wonder if these will actually make it here to Oz; I'll believe it when I see it. The price is less scary than I was expecting, and the parts spec doesn't look as shabby as expected. If they import more than 2 of each size and it is possible to see one that'd be a good thing! (I won't hold my breath though.)
    Quote Originally Posted by satanas View Post
    Where do you live in Oz? I would suggest visiting your local Spec store and express an interest. I f you live in South East Qld then come by Just Ride and I will give you all the details you need. We will have bikes on the floor as soon as they arrive
    Feb 2005
    ^ I'm in Sydney. While I'm interested I'm not prepared to pay upfront sight unseen, and the local store is in the CBD and probably wouldn't talk to me anyway since I'm not a suit...
    Once the bikes arrive I will be posting more info here. I f you are ever on the Gold Coast swing by and take a look. Surely it wouldn't hurt to give local dealers a call, they can't see what you are wearing then
    Feb 2005
    It's more the "you're not an Armani-suit-wearing stockbroker so there's no point me wasting my time on you" attitude that's the problem for me (CSC are especially bad in this respect). I'll wait and see what happens, and if anything makes it here - at least there's a little more hope now.
    Reputation: MuruCycles's Avatar
    Sep 2012
    The funny thing is that complete FATbikes have been available in Australia for years.
    Surly Pugsleys for almost 4 years now and Mukluks and Moonlanders for the last 2 years.
    The problem has always been that no dealer wanted to carry "stock". And the same will be true of Specialized or any brand.
    You'll get random local dealers with knowledgeable staff like shanesbw who will buy a couple for floor stock. But sadly, most stores will not want to carry stock. (most of them are still getting their heads around 29ers just as 650b rolls into town)
    I'm not being down on Specialized (I'm looking forward to getting some of their tyres for our bikes)... or their dealers. Just being realistic about the majority of Australian dealers. (regardless of the brand)
    Mr Muru.
    Too true, stores dont realise how much interest in fatties is out there until you have one regularly sitting on the shop floor. We have people asking questions and showing interest every day now that we have fatties on show
    Feb 2005
    ^^ It may be that DW et al have had stock, but I've seen no sign of this apart from the one Salsa at CBD a few months ago. As you say, most shops have only had anything 29" in the last 6-12 months. It's kinda weird for me, as I would have thought the Internet ought to have cut down the "normal" 5 year lag behind USA/Euro trends here in Oz, but no...
    What this might mean is that many shops aren't doing too well these days, and just cannot afford to take chances on anything that's not guaranteed to sell; one guy I've known for decades said a couple of weeks ago that he'd just had his worst week/month in 30+ years in the business...
  1. Specialized Fatboy
    By fc in forum Fat bikes
    Last Post: 2 Weeks Ago, 09:03 PM
  2. Specialized Roval Hub Specs
    By dberndt in forum Wheels and Tires
    Last Post: 12-18-2015, 01:43 PM
  3. Specialized Fatboy
    By fc in forum Specialized
    Last Post: 07-15-2013, 05:17 PM
  4. specialized big hit specs
    By lpskier5 in forum Downhill - Freeride
    Last Post: 04-23-2013, 07:03 PM
  5. DT/specialized wheel specs?
    By vqdriver in forum Wheels and Tires
    Last Post: 10-26-2011, 11:23 AM
