Results 1 to 33 of 33
    parts leftover
    Reputation: schlim's Avatar
    Specialized Fatboy review - how I ended up fat
    How I ended up fat:
    I did not envision myself on a fatbike. After all, Iím a racerboy Ė Iím into saving grams where possible, preferably from my wheelset. Itís rotating weight, right? Easier to pedal is better. Butyl tubes, tubeless, supersonic sidewalls, low rolling resistance are all entrenched in my vocabulary. A test ride changed my mind.
    I happened to jump on a Fatback at Outerbike in Moab. You can read my review of that bike, but it was an immediate attention grabber for me. Krob and the DL were off riding, well, normal bikes and I grabbed the Faback 190 while waiting for Yetiís bling carbon Arc 29er to be returned. There was no snow there in the desert, and the Fatback just looked massively weird. Except it wasnít. It was amazing.
    I got home and told my wife, ďI think Iím going to need a fatbike.Ē She was not surprised. Sheís a very understanding woman. Given the Fatback experience, I narrowed down the neighborhood by looking for a 190mm rear hub spacing, 100mm bottom bracket, clearance for the widest tires on the market, a carbon fork, and somewhat affordable total package.
    Up for consideration were the Fatback 190 (obviously given my demo), the 9:zero:7 190, Salsa Beargrease carbon, Surly Moonlander, and the Specialized Fatboy. Briefly, the aluminum Fatback, while USA made, was expensive for what you got (same price as a carbon Beargrease). The Beargrease is carbon, pretty, and light, but designed around 170mm rear hub spacing, which limits what tires and rims it can handle. The 9:zero:7 and its diamond section curving toptube somehow didnít do it for me asthetically, plus I would have needed an aftermarket carbon fork. The Moonlander is steel, which is generally suggests a nice ride, but the weight concerned me. The complete bike also had some uninspired components. Itís a small quibble, but the Borealis Yampa didnít make my list because the complete bike ships with 3.8 tires (and only 27tpi on some builds). However, it certainly deserves a hard look if the full carbon frame option is important to you.
    I settled on the Specialized Fatboy. It had the 190 rear hub, massive 4.6Ē tires I wanted, carbon fork, plus a decently light aluminum frame, grip shift (which I like very much), 2x10 gearing for range and cheaper maintenance (Iím opposed to SRAMís $400 11-speed cassettes, a wear component, on principle), Shimano hydraulic brakes (I will tolerate no other brandís current offerings), and more aggressive geometry borrowed from the Carve/Crave. Additionally, my race team is sponsored by Specialized, significantly increasing my chances of even getting my hands on one this season.
    Geometry and fit:
    Itís always a dangerous proposition to deposit money on a bike you have not ridden. Itís redoubled when virtually no one else has either. What made me more comfortable with the idea was that the ETT measures 625mm, which is the same as my Yeti ASR-5. Iím running a 75mm 6 deg stem on the Yeti and the Faboy ships with a 70mm 6deg stem.
    Some folks have said the toptube feels short. It isnít. I measure the center of the headtube at the headset horizontally to the center of the seatpost as exactly the same on both the large (long, low, and relatively slack) ASR-5 and the 19Ē large Fatboy. I do think that with the shorter stem, the short stack height of the headtube and the flat bar, it kind of tucks everything in somewhat, resulting the compact feel. Compared to a large Trek Farley with a 100mm stem, the Specialized Fatboy feels much less stretched out, slightly tighter, and better balanced. At 6í1Ē with ape arms and a 34Ē inseam, a medium would have been a crunch and I probably would have had issues with seatpost extension. The medium Borealis Yampa I took a spin on had lots of headset spacers and a riser bar building up the stack height, so I canít really comment on Spec fit compared to that one.
    The bottom line is that the Fatboy is purpose built to run aggressively, but neutral with its low stack height and shorter stem. I did swap in a 20mm rise Easton Haven bar to match what Iíve got on my Yeti and further dial in the feel. The stock aluminum ďmini-riseĒ bar was far too unyielding for my comfort and I needed slight lift to take some pressure off my palms.
    The wheelbase feels respectably tight, but given my lack of experience on fatbikes, I canít really comment on the merits of a shorter chainstay in the snow compared to a longer 9:zero:7 or a Yampa. What I can say is that when climbing dry ground, the rear wheel felt nicely tucked underneath me to facilitate good climbing and a responsive feel descending. I can lean back and lift the front wheel back into a different line if necessary.
    Unfortunately, the chainstays flare quite wide and I have knocked my heel against them a lot. To keep paint on the bike, polyurethane helicopter tape and a neoprene sleeve on the drive side are indispensable. The tradeoff for the wide chainstays are the gloriously massive 4.6 Ground Controls mounted in 90mm rims. In person, they look spectacular and intimidating. Additionally, Iím betting the future standard will be 190, and that additional wheelset options in that format will materialize as time goes on.
    What I added/altered:
    I already mentioned the switch to the Haven bar for some additional hand height. While the glossy black Henge saddle looks trick on the Fatboy, it didnít agree with my backside the first few rides out. I may eventually give it a chance to break in, but I went back to my trusty WTB Pure V that I know is a winner. As a survivor of multiple 24 hour races, it's well adapted to my rear. Additionally, I swapped out the low-end Specialized post first for a Thomson Elite, and then for an Easton EC70 carbon post. The carbon fork, bar, and post combined with the high volume fat tires effectively cancel out the overly harsh ride qualities offered by aluminum frames.
    After doing the math on the weight of gorilla tape and Stanís vs. lighter tubes, I settled on the Specialized 24 x 2.4-3.0Ē tubes. They weighed in at right around 235g apiece and filled out nice and evenly. Over the 610g stock tubes, I dropped 285g per wheel. I might try the tubeless route eventually, but the bead is very loose on the Ground Controls. Iím betting on reliability for now vs. potentially rolling off a tire in frigid conditions and having to deal with sealant everywhere. I also tossed on some red Wellgo MG-1s and a red bottle cage to match the frame. Weighed without my Daveís Mudshovel fenders or GPS, sheís rolling at 29.7 lbs .
    So whatís the ride like?
    The Fatboy definitely feels like it leans to the fast side of the spectrum vs. plodding, which is saying something given the massive width of the rolling stock. It can certainly grind along just fine, but when standing up and hammering, it will move. Itís light steering even brings out a zippy feeling on a slight decline. The geometry facilitates this, as it puts a little more weight up front and mimics that of a 29er hardtail. The comparatively low gearing of the 22x36 combined with the 11-36 cassette is absolutely necessary in deep snow and sloppy conditions. Stomping on the pedals with too much torque to the ground causes the rear wheel to dig in and slide out sideways in unpacked snow. Regulated power and spinning is critical to keeping momentum.
    In dry stuff, the optimal pressure seems to be around 8psi or so. Itís difficult to tell since my floor pump isnít particularly accurate at low pressure, and my analog dial gauge broke after the first few days of usage. Anything less in the front, though, and the bike risks some self-steer on dry trails. The bouncing also becomes more pronounced and the ride (oddly) harsher. I learned this the hard way on a night ride using the headlights when the bike had so much traction that it steered me into a hole I didnít see and then bucked me off. That was a-typical though. The planted feeling from the bike and confidence letting it roll through anything is just tremendous, especially around built-up corners.
    In snow, which was the whole point of the bike for me, I generally run the tires so I can push them in about a third of the way in toward the rim. The pressure is around 5-6 PSI I believe, and Iíve run them even lower. I can see that the Ground Control tires are developing 3-4mm diagonal wrinkles in the sidewalls due to low pressure rides. In general, I can out-climb someone in soft snow who is running a Larry or a Nate tire. Those on Buds and Lous seems to have less difficulty and I'm working to hang with them. Itís clear that the additional volume is an advantage. There does reach a point, though, where too low of a pressure results in the rear struggling to find grip in powder. Itís almost as if the floatation overcomes the ability to dig in and get traction. Itís a very odd thing, but absolutely real in deeper conditions. On one steep climb in nearly unbroken powder around 3-4 inches deep, it was the difference between being able to ride some of it vs. walking all of it when I aired down to a very low pressure. It was a useful lesson in terms of the Fatboyís behavior and ability. Downhill sections in snow sometimes result in a pretty significant drift (especially when the front wheel is turned and the bike is heading straight). Happily, on one descent in deep, snowmobile churned snow, my bike stayed upright and other fatties with narrower tires (3.8-4.0) did not.
    On packed courses that are groomed or stomped down by snowshoes and snowmobiles, the Fatboy just flies. For me, it feels most comfortable and capable in these conditions. Getting into the 36t ring allows the bike to carry so much momentum that it usually evokes a happy whoop from me. The grip shift is definitely helpful, as it allows a single click front shift and easy rear shifts when paired with thick down gloves. Rather than my usual clipless setups, Iíve been using the Wellgo MG-1s I mentioned earlier, which are optimal for quick exits, outriggers, and for standing starts uphill in the snow. I donít have to worry about snowballs building up in the mechanism, and my Five-Tens paired with alpaca socks keep my toes nicely warm and comfortable. With the stealth rubber soles, climbing is no problem.
    The Fatboy has carried me along just fine down to 10 or 12 degrees with no malfunctions, however I found out quickly that ice is death. Given our strange winter, weíve had some pretty large ice patches in some places instead of the usual snow. On these, the Fatboy and Ground Controls donít offer much advantage or assurance. My major mistake seems to be seeing the ice patch approaching and feathering the brakes. This unfortunate maneuver causes me significant bruising and abrasions, such that I ride with soft elbow and knee protection now. The bike has been mostly unscathed. For next year, Iím weighing the pros and cons of adding in Grip Studs to the Ground Controls or alternatively picking up some studded Dillingers to keep from losing the front end in suboptimal conditions and the yardsales that result. Ouch.
    What would I change?
    Much of what follows is nitpicking, but I hope Specialized takes it into account for future updates to the Fatboy. First, the top tube could be lower or bent for sudden dismounts. While I have managed not to rack myself, I have come uncomfortably close in sudden stops and deep snow. Fatback and 9:zero:7 have the right idea here. The straight tube is nice to look at, but function over form should rule for extreme conditions.
    In the same vein, because the top tube is so tall and the stackheight is so short, with the stock bars the brake levers do impact the top tube. I solved this with the Easton riser bar, but folks who run the stock setup may find themselves with dented and scarred top tubes. Mine is covered with helicopter tape for a little additional insurance when my lights and batteries are mounted to the bar.
    The previous-generation Deore brakes seem pretty good, although the rear has developed some pump-up resulting in little movement in the lever to full bite in the cold. This might be solvable by bleeding out some of the mineral oil, but I havenít been bothered enough to mess with it yet. Additionally, the brakes do squeal in moisture, unlike my XTs and XTRs. It goes away once the rotors heat back up. Iím thinking about maybe trying an organic compound or sintered pads to see if that improves things.
    While I would not trade out the grip shift and am pleased with the new 2x10 redesign on bearings, the stock interlocking grips arenít comfortable. They taper down to the end of the bar, where there is little rubber compound left to absorb shock from a rigid front-end. Iíve swapped them out for trimmed ESI Chunky grips, and that seems to be a huge improvement so far. I may try shortie Ergon GP1 grips at some point as well to compare.
    Taking a look at the frame, I was curious whether it could handle a 29+ setup. The stock wheelset with the Ground Controls is 740mm in diameter. A 29+ with 3.0 Knards is 780mm on Rabbit Hole rims according to Surly. Measuring, the frame clears the extra 20mm radius, but it would impact the SRAM X.7 top pull front derailleur. Unless a lower profile front derailleur is available (maybe a direct mount XTR would work?), 29+ on the Fatboy would require a single ring setup.
    It would have added some weight, but I would have preferred a through-axle setup for precision, ease of removing the front wheel, and consistency with modern design. Quick release, outside of road applications, feels like outdated technology and comes across as flimsy on a fatbike. Would TA provide any kind of performance advantage? Who knows. However, any kind of increased resistance to torsion should be beneficial. Specialized is still in love with QR and itís inexplicable.
    Lastly, what a crummy rear cassette! A 348 gram Sunrace? Really? Iíll run it until itís shredded, but then an XT is going on. By the way, I can get 5 new XT cassettes for the price an X01 XG-1195. 2x10 just makes more economic sense to me right now, but I might change my mind if the front derailleur gets packed with ice and fails me.
    Final verdict?
    Having owned the bike for six weeks, I remain convinced I picked the right one. Nitpicking aside, the Fatboy is a tremendous value and a well-designed first generation product. I have never been able to ride outside any day I felt like in January and February before. Fatbiking (in my short experience) is about fun, adventure, determination, accomplishment, and a little bit of insanity. Specialized has rolled all of this up into a nice package that makes me (of all bizarre things) actually want to go out in 12 degree temperatures to ride in the snow. In the dark. With headlights. Thatís not just the bike making me a better rider. Itís life altering.
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    You did a great job ruling out every other bike.
    parts leftover
    So many fantastic bikes out there, I wish i could have gotten significant time in the snow on all of them. I came really close to ordering either the Beargrease or Fatback when I wasn't sure I could get a Fatboy, but a lot comes down to the $ in the checking account too.
    Apr 2005
    Re: your 170 vs 190 statement....pretty certain your rim and tire would fit fine in my 170 mukluk ti. With less heel strikes.
    Re: 2x10...have you considered 1x10 with a 40 or 42T cog? Much cheaper option than 1x11
    I'm looking fwd to those spesh tires becoming available aftermarket. Hearing good things so far.
    Originally posted by bucksaw87
    I still fail to see how mustaches, fixies, and PBR are ironic.
    Loser
    Reputation: Jisch's Avatar
    Nice write up, and it came a really good time as I get mine this week. I'm even more psyched for it now!
    Reputation: jackdz's Avatar
    Aug 2010
    Excellent write up....I have a Fatboy and have ridden it in temps to -5 degrees F with no issues. I have it setup tubeless (use two wraps of your helicopter tape, I found the gorilla tape to be too stiff to seal) and it has worked flawlessly.
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by frorider View Post
    And imho sucks poo as a system in whole at least with Shimano, no experience with the 42 Sram hack.
    Aug 2010
    Quote Originally Posted by bdundee View Post
    Can you/would you elaborate on this statement? I'd like to hear your experience using this....
    Sep 2013
    Really good review.
    I echo your sentiments about the top tube height. I've never really been concerned about stand over height, except on my Mukluk (which has good stand over). The first time you step into that deep snow and your foot goes down a foot or so, you really start to get it!
    One other note, I really have to remember to back off of the front brake on my fatty in snow. It usually takes about a mile of trail and at least one wipe out to remind me of this. Its all about the back brake; although on ice, nothing really helps.
    Reputation: Zoo1424's Avatar
    Re: Specialized Fatboy review - how I ended up fat
    "makes me (of all bizarre things) actually want to go out in 12 degree temperatures to ride in the snow. In the dark. With headlights. Thatís not just the bike making me a better rider. Itís life altering."
    That pretty much sums up my thoughts on fat bikes. I held out as long as I could for a Fatboy and finally went with the Beargrease. Glad I did as I probably would just now be getting a Fatboy vs all the riding I've done the last 7 weeks. Glad you like it. They certainly are sharp. These things are so much fun.
    aka bOb
    Quote Originally Posted by minte View Post
    Really good review.
    If you post hole a foot or so a few inches of stand over doesn't really help that much and yes this is from experience (spoken in a really high voice).
    aka bOb
    Quote Originally Posted by jackdz View Post
    A lot of good reading here, I'm not sure what page I chime in but just skim through it.
    11-42T conversion: OneUp vs. Wolf Tooth
    Some ok results some craptastic. For a fat bike and having a tendency of being in the middle of nowhere in very cold weather this system just adds more to "the what could go wrong list"
    Laramie, Wyoming
    Oct 2012
    ...about top tube height...The first time you step into that deep snow and your foot goes down a foot or so, you really start to get it!...
    Get what? In deep snow, it doesn't matter where your top tube is. Maybe even, the higher it is, the better. That way one doesn't have as far to fall before making contact.
    Actually, I find the full triangle very functional. Being able to use a full size frame bag is one of the reasons I liked the "straight" top tube.
    parts leftover
    I'll bet that ti is a nice ride! It's definitely possible that a 90mm rim/4.6 tire could fit a narrower hub spacing depending on the space available at the chainstay yoke. It's pretty clear up close, though, that the Fatboy's chainstays could have been flared further inboard for clearance and still accommodate getting the wheel in and out.
    parts leftover
    Less time to accelerate. Good thinking! Maybe I'll bubble wrap the top tube to be safe.
    Nice write up. I have thoroughly enjoyed my Fatboy. I have owned mine for four weeks now. I have ridden it nearly every day to work and for much more extended ventures on the weekends.
    I found that I have done some of the same changes to mine. I swapped the handlebar for an Enve and the seatpost for a Thomson, both take-offs from another bike. I did go tubeless with the Gorilla Tape/Stans sealant method. I have had no troubles thus far. I've ridden as low as 3.5 psi, but usually ride at 6 psi.
    aka bOb
    Yeah what I really like is how you managed to insult most everyone else's bike in just one post., takes skill I say!!
    nothing to see here
    Reputation: Stevob's Avatar
    I didn't see it that way. All I saw was his selection thought process. Sure, his team sponsorship makes the post sound a little biased towards Specialized, but we all like to sell the virtues of the bikes we ride. In that respect, he is no different to anyone else on here.
    A good review in my opinion.
    There is much Specialized butt hurt in this world
    I see hills.
    I want to climb them.
    aka bOb
    Quote Originally Posted by Stevob View Post
    Mmmm maybe I took it wrong, that being said I'm a Specialized Fan boy. I really like the stuff they put out and I really am impressed with the Fatboy.
    nothing to see here
    All good. A friend of mine who has absolutely no interest in fatbikes (can't see them as being fun) saw a Fatboy at a shop and really liked the look of it and wanted to test ride it. No demo bike available however. They do build a pretty bike, that's for sure.
    I see hills.
    bummed on the short stack height. Looks like you get two spacers worth of steerer to play with then it is off to riser bar land...this is in contrast to the mukluk I saw the other day which looked to have at least 4 spacers worth of steerer. Betting a carbon fat boy frame option is in the works....
    Nov 2013
    this is such a fantastic and thorough review. I was going to buy the comp (yellow) Fatboy for my wife but maybe I'll buy the Expert and give my wife my KHS to ride (though it's an awesome ride too).
    I have too many bikes, but it's not enough
    parts leftover
    Quote Originally Posted by CHSAD View Post
    I can't help but think that Specialized has taken notice of the demand out there, as well as the the carbon offerings from Salsa, Borealis, 9:zero:7, and Fatback. I think I'd buy the carbon version if it were available... and then add carbon HED rims. That'd be a rocket.
    fc
    fc is offline
    head minion Administrator
    Reputation: fc's Avatar
    Aug 1996
    We republished the review here. It is so detailed and awesome.
    Gregg will be in touch with some schwag.
    Where do you live Fatboy Schlim?
    fc
    IPA will save America
    schlim
    are you in north Idaho. pic's look like the cda area.
    Dec 2013
    Thanks for the writeup!
    Some of the other bikes have slightly longer chainstays and slacker head angles, which some argue are better for snow riding. Given that snow is your primary use and you've had some time on the bike, do you think it would be improved if it were a bit longer and slacker?
    parts leftover
    Quote Originally Posted by tim208 View Post
    schlim
    That's it! Good eye for detail. If you're ever in the area, shoot me a message and we'll ride sometime.
    parts leftover
    Quote Originally Posted by matto6 View Post
    Thanks for checking out the writeup!
    It's a good question. I remember reading one guy's comments on his Mukluk and how he adjusted the dropouts to get a longer effective chainstay, which stabilized the bike in the snow. I wish I had more experience on different fatbikes, but I'm really a newbie to this side of the sport.
    As far as the Fatboy goes, I like the compact feel vs a longer one because it's nimble, but I don't feel like it's nervous. It seems like others have suggested it's less plodding than other offerings. A slacker head angle would take some of the precision of this bike away (relative to a monster fatty, anyway) and may not really contribute a lot to stability in snow. Maybe dirt riding is a different story?
    Any thoughts from the snow veterans out there?
    Apr 2005
    Now that I have a number of rides in, under challenging conditions -- slush and grit everywhere -- I can say that the 1x10 setup with shimano XT, 42T one up cog, and 30T RF nw ring is working extremely well on my mukluk. B limit screw just needed a few more turns than normal. Correct chain line is important. Shifting and backpedaling-no issues. Big thumbs up.
    schlim
    I will. I actually live here in cda. Wolf lodge area.
    May 2010
    uh...can you please just drink some beer and pass out...I hope you were whining with a humorous vintage here! Every bike deserves an honest review...if you feel insulted, it sure wasn't from this guys review!
    hellboy
    Reputation: Bearhunter's Avatar
    Mar 2014
    I thought this was a very good review. Like others have stated, it showed your thought process and how you arrived at your conclusions. Well done.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Nice review!
    I saw a fatboy with the big ground control tires last week at the lbs, good looking bike.
    I'm in the Post Falls area, we need to do a fat ride together sometime.
  1. Specialized Fatboy
    By fc in forum Fat bikes
    Last Post: 05-03-2018, 10:32 PM
  2. Specialized Fatboy Accessories
    By thumpermeister in forum Fat bikes
    Last Post: 04-17-2015, 11:29 AM
  3. Specialized Fatboy - Should I be concerned?
    By palmermtb in forum Fat bikes
    Last Post: 01-10-2015, 07:50 AM
  4. Specialized Fatboy vs 9:zero:7 190mm
    By Streetdoctor in forum Fat bikes
    Last Post: 11-28-2013, 10:54 AM
  5. Specialized Fatboy
    By fc in forum Specialized
    Last Post: 07-15-2013, 04:17 PM
Members who have read this thread: 4
