Page 1 of 4 1234 LastLast
Results 1 to 100 of 322
    Reputation: jfrbikes's Avatar
    Specialized Fatboy newest info
    Fatboy Expert Black
    Fatboy Expert $2600 November
    FRAME New Specialized M4 Premium Aluminum, Fat Bike Geometry, fully butted w/ smooth welds, tapered headtube, post-mount disc dropouts, replaceable alloy derailleur hanger
    FORK FACT carbon full monocoque, 5.0" tire clearance, 135mm spacing
    HEADSET 1-1/8" upper and 1-1/2" lower FSA, Campy style w/ integrated cartridge bearings, 3.8mm cone spacer
    STEM Specialized 3D forged 6061 alloy, 4-bolt clamp, 6-degree rise, 60mm/70mm length, 31.8mm
    HANDLEBARS Specialized mini riser bar, 6061 double-butted alloy, 660/700mm wide, 10-degree backsweep, 6-degree upsweep, 31.8mm
    GRIPS SRAM, 92mm grip, included with SRAM S-Series GS shifter
    FRONT BRAKE Shimano Deore, BR-505, hydraulic disc, 180mm rotor
    REAR BRAKE Shimano Deore, BR-505, hydraulic disc, 160mm rotor
    BRAKE LEVERS Shimano Deore, hydraulic lever, w/ reach adj.
    FRONT DERAILLEUR SRAM X7, low direct mount
    REAR DERAILLEUR SRAM X0, Type 2, 10-speed
    SHIFT LEVERS SRAM S-Series, Grip Shift twist shifter, 10-speed
    CASSETTE Sunrace, 10-speed, , alloy spacers, alloy lock-ring, 11-36
    CHAIN KMC X-10L, hollow outer links
    CRANKSET Custom e.thirteen, 2 piece, PF30, 100mm spindle, 170mm/175mm length
    CHAINRINGS 36/22
    BOTTOM BRACKET e.thirteen PF30, included w/ crankset
    PEDALS Specialized Bennies, 6061 alloy body, sealed cartridge bearings, removal 4.5mm pins
    RIMS Specialized Fatboy SL, alloy disc, single wall, 90mm wide, sleeve joint, hookless design, 32 hole
    FRONT HUB Specialized MTB disc, alloy, Hi Lo flange, sealed bearings, 135mm wide, alloy axle, QR, 32h
    REAR HUB Specialized MTB disc, alloy, Hi Lo flange, sealed bearings, 190mm wide, alloy axle, QR, 32h
    SPOKES Stainless, double butted, threadlock, 14g
    FRONT TIRE Specialized Ground Control, 26x4.6", Kevlar bead, 120TPI
    REAR TIRE Specialized Ground Control, 26x4.6", Kevlar bead, 120TPI
    INNER TUBES Standard presta valve
    SADDLE Body Geometry Henge SL, hollow Cr-Mo rails, lite PU foam, 143mm
    SEATPOST Specialized alloy, 2-bolt, micro-adjust, 30.9mm, 350mm/400mm
    SEAT BINDER Forged alloy, QR, 34.9mm
    NOTES
    Specifications subject to change without notice.
    Fatboy Green
    Fatboy Black
    Fatboy $2000 Novemeber
    FRAME New Specialized M4 Premium Aluminum, 29er geometry, fully butted w/ smooth welds, tapered headtube, post-mount disc dropouts, replaceable alloy derailleur hanger
    FRONT BRAKE Tektro Draco 2, hydraulic disc, dual piston, 180mm rotor
    REAR BRAKE Tektro Draco 2, hydraulic disc, dual piston, 160mm rotor
    BRAKE LEVERS Tektro Draco 2, hydraulic lever
    REAR DERAILLEUR SRAM X7, 10-speed, medium carbon cage
    CASSETTE Sunrace, 10-speed, 11-36
    CHAIN KMC X-10
    CRANKSET Custom 2x10, 2 piece, PF30, forged alloy crankarm, w/ 100mm CNC spindle, 170mm/175mm length
    CHAINRINGS 36/22
    BOTTOM BRACKET Samox, PF30 for 2 pc. crankset, 100mm shell, included w/ crankset
    PEDALS Alloy, 1 pc. body and cage, w/ reflectors, 9/16"
    SPOKES Stainless, 2.0, threadlock, 14g
    SADDLE Body Geometry Henge, steel rails, 143mm
    Fatboy Expert Bike Geometry
    Size 15.5 17.5 19.0 21.0
    Bottom Bracket Drop 60mm 60mm 60mm 60mm
    Bottom Bracket Height 315mm 315mm 315mm 315mm
    Chainstay Length 455mm 455mm 455mm 455mm
    Crank Length 170mm 175mm 175mm 175mm
    Handle-Bar Width 700mm 700mm 700mm 700mm
    Head Tube Angle 70.5 70.5 70.5 70.5
    Head Tube Length (Carve) 110mm 120mm 135mm 150mm
    Reach 395mm 420mm 437mm 458mm
    Seat Tube Angle (Actual) 73 73 73 73
    Seat Tube Angle (Effective) 73 73 73 73
    Seat Tube Length, Center to Top (Carve) 394mm 445mm 483mm 533mm
    Seat-Post Length 350mm 350mm 400mm 400mm
    Stack 590mm 600mm 615mm 629mm
    Stem Length 60mm 60mm 70mm 70mm
    Top Tube Length (Horizontal) (Carve) 576mm 603mm 625mm 650mm
    Wheel Base 0mm 1105mm 1128mm 1154mm
    Reputation: Schott's Avatar
    Nov 2012
    4.6.........interesting!
    "You're like a Ferrari engine driving a dump truck"
    Anybody think the E13 cranks and the Deore brakes are worth the $600 upgrade in price?
    Nov 2007
    Quote Originally Posted by Slow Danger View Post
    X0 (vs X7) R. derrailleur on the Expert model, too. Not sure what "S" series Gripshifters are.
    But no, unless the specs are wrong, not worth it. Plus, I like the matte green/black of the base model better .
    Human Test Subject
    Reputation: Volsung's Avatar
    Anyone know anything new about the tires other than the revised size?
    Re: Specialized Fatboy newest info
    They have not posted any new info on the ties yet
    aka bOb
    Reputation: bdundee's Avatar
    I'm liking the revised tire size!!
    Med Moonlander Vs Fat Boy 17.5
    Both have the same HTA, STA, HTL, & BBD.
    ML has a 321 BBH vs 315 far the FB = a 12mm shorter dia. tire on the FB (750mm?)
    ML WB = 1093.9 vs 1105.0 for FB
    ML FC = 643.9 vs 650.0 for FB * unknown for FB is the A/C & Offset
    ML CSL = 450.0 vs 455.0 for FB
    ML ETT = 595.0 vs 603.0 for FB
    ML STL = 457.2 vs 445.0 for FB = (18.0000" vs 17.5196")
    ML Bar = 660 vs 700 for FB
    ML Stem = 100 vs 60 for FB
    The FB should have more SO room than the ML, which is listed at 800.1mm = 31.5000"
    Weights not given but expect the FB to be lighter.
    Looks like a shot across the bow at Surly?
    Aug 2013
    Unless I am missing something, this is the same info that has been listed on the Specialized web site for a while.
    As far as I can tell, the only new info here is the ETA. There is another thread discussing the ETA. Originally, my LBS told me December. Recently, however, my LBS is cautiously optimistic about November.
    Since Specialized does not mention an ETA on their web site, I am wondering what your source is for an ETA of November? I am not doubting you because you confirm what my LBS has told me recently. However, I am curious where you saw or heard an ETA of November?
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I'd like to see people stop obsessing over the bottom line, and start paying heed to the abominable, inexcusable business practices that Specialized uses to maintain market share.
    I understand that business is business. I also understand that many people are making their bike buying decisions based on very, very tight financial considerations. It follows that many are willing to ignore (or are simply ignorant of) Specialized's ability to royally screw little guys the world over when making their bike buying purchases.
    I ask that all whom are considering *any* bike purchase the next few years give a *lot* more thought to where that money will ultimately end up.
    Shipment dates are from internal LBS site for specialized dealers on when bikes will ship.
    Sorry i missed post i thought specs and geo was new information.
    Also did not know if people knew the confirmed colors.
    Never understand the Specialized hate. Looking at Surly Pug Ops with my own build. new option for the market and new tire options always make me happier but to each there own.
    Aug 2013
    Quote Originally Posted by mikesee View Post
    I have a better idea. I'll spend my money where I want, and you spend your money where you want.
    Most of us on this forum are adult males, and we do not need some weenie telling us how to spend our money. Nobody is telling you how to spend your money.
    And who exactly is the "little guy" anyway? Surly and Salsa? If I understand correctly, they are subsidiaries of the largest wholesale distributor in the cycling industry. Not exactly little guys, and competition is a good thing.
    Instead of hijacking a thread about a product launch, why don't you start a separate thread dedicated to your obvious hatred of Specialized? Wouldn't that be a better idea? Especially if you can provide some factual and logical justification for your hatred?
    Like normal Spock saves the day with logic.
    aka bOb
    Forget it we don't need another thread off topic
    Aug 2013
    Very well said...
    Aug 2013
    Quote Originally Posted by jfrbikes View Post
    Awesome, thanks!
    Feb 2005
    Yep, lambs to the "S"laughter......
    Oh boy, it's "S"hiny, run to it.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Nov 2007
    Mike,
    This is a topic that interests me, and I'd love to hear some specifics. Feel free to PM me if you don't want to put it up here on the thread. Everyone should care about where their money goes when it leaves your wallet.
    Aug 2013
    Quote Originally Posted by MendonCycleSmith View Post
    Great forum. Even the moderators can't stay on topic. Especially when they sell competing products.
    Aug 2003
    Educate yourself is all I'm asking. Not telling, not hating, just asking.
    When a company (regardless of industry) spends more money on bullying the true innovators (via the legal system into giving up their trademarks, patents, dreams, and ultimately businesses) than most of the little guys *combined* see in total income in a year, something is flawed.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Quote Originally Posted by Armyballer View Post
    Very well said...
    I agree.
    I like turtles
    I hate this bike. I hate the new AWOL too. Blatant copies. Add in the PF30 BB and I'm really annoyed. The only innovation coming from the big S is a new tire. I agree with Mike C, there's some shady stuff going on (ehhh continuing) and a little education would go a long way before throwing thousands at the monster.
    Sadly, as the Mongoose has proven, these new Spec bikes will soon be polluting our beloved forum.
    Jason
    Disclaimer: www.paramountsports.net
    Reputation: jvm051's Avatar
    Quote Originally Posted by JAGI410 View Post
    Umm "polluting our beloved forum"! Wow man, Unless you are somehow a stakeholder in ConsumerREVIEW, then I don't see how your 2 cents, or mine for that matter, account for anything. I get this vibe from posters as yourself, that the fatbike, is some type of too cool for the room subculture of mountain biking, that only people who own a Purple Pugsly, or Surly, Salsa whatever should be allowed into. Does it really affect your day that Specialized, or Trek is producing fat bikes, and is going to dilute down your coolness factor the next time you are on the trails...Or did somebody on a Mongoose get more looks from onlookers than you expensive rig. Either way, its kinda sad that there is so much dissent from a "community" of riders, that frowns upon the bigger companies are getting in on it. If it gets more people on bikes, who cares if they are riding a Mongoose, Fatback, 38Frameworks, or a Specialized. I have read about Specialized and their practices, but people should have choices regarding what they buy, and can choose to look into a companies practices if they choose to....or not. Your company has Cannondale listed on the website. Well Cannondale is owned by Dorel, that makes the Mongoose Beast, you dislike, and is sold at Walmart. Walmart is a far bigger threat than Specialized to consumers, yet you sell Cannondale.....Just sayin.
    Now since this is a thread about the newest info, I was told by the LBS that the Ground Control tires would be priced at $89....Yet I was at another shop, and they mentioned that nothing was even in they system yet. Keeping my fingers crossed for the $89 price.
    Reputation: vikb's Avatar
    Quote Originally Posted by SmooveP View Post
    Mike,
    Just be aware you could be sued just for reading this info...
    https://www.google.com/search?q=spec...&oe=utf-8&aq=t
    Safe riding,
    Vik
    www.vikapproved.com
    I will look when i am at work again, but could not find a part number or price on internal specialized page.
    Thanks, I am hoping they are released soon. I sliced a sidewall on my On One Floater this weekend, so probably just going to order another floater to tide me over, until the Ground Controls come out. I want something a little larger, but am willing to wait to see if they are cheaper than the Surly options.
    Feb 2005
    Quote Originally Posted by jvm051 View Post
    If you look at enough "brand X introduces a fatbike" threads, most don't contain specific concerns, just things like, "I don't like brand X, why didn't brand Y jump in yet?"
    What Specialized (and Trek) bring is a level of corporate nastiness that other big brands have not risen to (yet).
    Forcing long time brand carrying shops to drop them unless they carry them exclusively, and allow said brand to even determine what brand accessories are "acceptable" to their corporate palate. Many shops that carried the brand for years (always paid on time, followed their contracts to the letter), found out that they got dropped, and someone effectively across the street now carries the brand. Simply because they wanted to be an "Independent Bicycle Dealer" and choose the brand mix offered on their floor. Nice discovery with your morning coffee as a business owner huh?
    Specialized sues just about anything that moves, uses the word Stump, or is red. This is a disgusting waste of money and time.
    Specialized, Mountain Cycle disagree on "Stumptown" | BikePortland.org
    Epic Wheel Works will change name due to potential trademark conflict with Specialized | BikePortland.org
    So when you wonder why bikes are getting expensive, and the big boys lead the pack, look at their legal teams, not their Tour De France teams...
    But that's all just business stuff and has nothing to do with the end consumer, or, does it?
    - FrostyStruthers
    After Mike posted I did a little search. The biggest trouble I have, as with anything of this sort, is that it is hard to determine just which side to believe.
    The Stumptown/Stumpjumper threat, however is an easy one. The term Stumptown, has been applied to Portland Oregon well before Specialized existed. Why would a company think to capitalize off of the name Stumpjumper to help sell their product?
    It seems quite natural for a company from Portland to use the term Stumptown.
    While I do welcome a heads on competition, it will be interesting to see what develops in the future.
    Nov 2012
    Personally, I think that what I do is a drop in the bucket to these guys. I like my Surly, but QBP is as corporate as anything else. I'm not concerned about being sued. I'm not going to begin to tell a company as large and successful as Specialized that their business practices aren't worth a hoot, I wish mine were as successful. The only thing I care about is that this is a pretty cool looking bike, with a decent build, and golly I want to try those tires. I'm not buying a new fatty this year, but if I were, this one would be at the top of the list.
    Reputation: druidh's Avatar
    Quote Originally Posted by Mister Spock View Post
    +1
    Not the behaviour I expect from the moderators of a non-manufacturer-specific forum, especially when they are selling competitive products.
    Aug 2013
    Well said. I'd like a fatboy. Don't care one bit about big bike politics. Why worry about big bike business when it's the government that needs reform more than the bike industry. A fatboy and a fattie for after the ride is all I want. Specialized has done more good for mountain bikes than bad in my opinion.
    2013 StumpJumper FSR Comp 29er
    2011 Trek Sawyer 29er
    2000 Bianchi b.u.S.S.
    1999 Trek 930
    1997 Trek 850
    Aug 2013
    I am asking too, and I am asking for only three things.
    First, I am asking that you show some minimal respect for the forum by starting a separate thread in this forum entitled "Why You Shouldn't Buy From Specialized" instead of disrespectfully hijacking a legitimate thread about a product launch. I am not opposed to different opinions, but those opinions clearly are not appropriate on this specific thread.
    Second, I am asking that you and the rest of the whiners clearly identify whether or not you directly or indirectly compete with Specialized.
    Third, I am asking that you and the rest of the whiners provide some minimal factual and logical justification for your obvious hatred of Specialized.
    I participate in other non-cycling internet forums, and the members of those forums do not have to make such requests. In those forums, the members understand what thread hijacking is and they respect the forums. Also, the moderators of those forums have the integrity and common sense to know that the forum members will not tolerate moderators that bash competitors if the moderators own businesses that directly or indirectly compete with products from the same competitors the moderators are bashing.
    Apparently, this is too much to expect from MTBR.
    Reputation: ~gomez~'s Avatar
    I have a theory that when a fat-bike reaches 11.3725 MPH the name on the down-tube becomes reasonably inconsequential or, at least, a whole lot less important. In other words a Trek fat-bike in motion is every bit as funtastic as a Salsa, Specialized, KHS, Surly, etc. while riding in the great outdoors. Thus, the phrase - 'Ride & Smile'.
    How can you argue with a 29 pound symmetrical fat-bike with the girth of a moonlander? - plus the new tire is near the top of my wish list for this winter's fat-bike funskies.
    My only question is how 190mm spaced rear ends will handle size 13 winter boots?
    Big Feet - Big Picture?
    owner/raconteur at fat-bike.com
    Feb 2005
    Quote Originally Posted by druidh View Post
    +1
    Oy vey.
    Not a mod on this forum, only in one tiny little sub forum, which, coincidentally, happens to focus on an era of Specialized et al, that I do happen to respect.
    Besides, I'm human, and have opinions, which, just like ya'll, I'm entitled to.
    Never signed a contract when I *volunteered* to be a mod, to obsequiously accept all the garbage that any players in the industry want to toss.
    As for competing products, you may note, I "broke" the KHS fatbike launch, despite not selling the brand, and am more than willing to be stoked when various other brands (or pretty much any smaller company) comes out with something worth getting jazzed about, so I'm hardly just trying to hawk my own stuff and trash talk others.
    Please consider thinking before assuming I'm being some kind of bad actor......
    - FrostyStruthers
    Aug 2013
    Oy vey.
    Nobody has claimed you are not entitled to opinions.
    However, your opinions are not appropriate on this thread.
    This thread is for exchanging info on an upcoming product launch. We want to do that in peace without your obnoxious off-topic thread hijacking.
    Why not start a separate thread entitled "Why You Shouldn't Buy From Specialized" in this same forum?
    Or is that too obvious?
    Nov 2007
    Interesting stuff. I'm no Spesh fanboy (I've never owned one of their bikes, but I do have 2 pairs of their shoes.) I'm also not in the bike industry. But playing devil's advocate, I'll say a few things in their defense. Regarding intellectual property (patents, trademarks, etc.). Once a company enters into the realm of using them, they're more or less forced into enforcing them. If they choose not to enforce them on one occasion, subsequent cases can use that against them, basically by saying "you didn't enforce it against company X, why are you selectively suing us?"
    So, some of the anger should be directed at the ways the laws are written. It's easy to paint a picture of a scenario where the big evil company unfairly squashes the little guy. But it's the responsibility of any company, large or small, to thoroughly research any new product name or patents before bringing the product to market. Most of the time, these issues are resolved quietly with a few letters exchanged between lawyers. For example, Surly went through that with the Black Ops/Necromancer Pugsley names, and nobody on the forum tried to turn it into a cause. Surly seemed to handle it with good humor (Neck Romancer anyone?), but who knows? Maybe things were nastier behind the scenes.
    I've also heard both sides of the Spesh dealer relationship issue. Yeah, it seems heavy handed on the surface, but from Specialized's perspective, loyalty is a 2-way street, and they have a good reputation for a distribution network that is solely focused on the LBS. No internet, no big box stores, etc. I've heard their warranty support is pretty good, too. Probably not my style if I owned a bike shop because I value independence too much.
    Yeah, each person's opinion and purchasing decision is drop in the bucket, but I guarantee that all of the companies involved read these forums. The big guys spend big bucks managing their reputations on the web. So vote with your wallet and speak up, but support your opinions with some facts or at least some thoughtful rationale.
    Do you really think that you can control what other people can post or decide what's appropriate? In a forum? On MTBR?
    Oye Vay
    Aug 2013
    Quote Originally Posted by ~gomez~ View Post
    Oye Vay
    Yes, I think it is possible to determine what are on-topic posts and and what are off-topic posts.
    It is possible at every other internet forum where I participate.
    Why is it impossible to determine what are on-topic posts and what are off-topic posts at MTBR?
    Feb 2005
    When folks start bagging on me personally, for having an an opinion and sharing it, I'm not going to just sit by and let it happen. Simple as that.
    Have yours, I'll have mine, I'm not out here bagging on you, for yours, just the brand in question, so unless you work for them, I really fail to see the necessity of defending them, they're big boys after all.
    All this being said, I'm simply supporting another member's feelings on said topic.
    Plenty of OT and sideways threads here, this isn't the first, and won't be the last.
    Enjoy, I'm out.
    - FrostyStruthers
    In the end, with Spec/Trek getting on board ultimately means more fatbikes on the trail, which we all are hoping for. This isn't an exclusive club. The more fatties on the road/trail also lowers my chances of being stopped and asked questions about it
    Jason
    One example, hopefully relevant given lots of fat bikers use frame bags - the big S forcing "Epic Designs" to take the Epic out of their name:
    Epic Design vs Specialized
    David and Goliath?
    No big company is perfect, but alas, S seems to be a fair bit less perfect than most.
    I never said it was impossible. I'm saying that you don't get to decide. The fat-bike community, for the most part gets to determine how a forum is run. You have one voice and 12 posts. You've already started off on the wrong foot by calling people whiners. You have misjudged MendonCycleSmith. I think that all opinions (good or bad) about the company that makes the bike that the thread is about to be germane and therefore not a thread hijack and as long as the discussion remains civil, It's what forums are all about.
    las bicis gordas, para ti,
    g
    Aug 2013
    Enjoy, I'm out.
    No, I do not have any affiliation of any kind with Specialized.
    However, I have pre-ordered a Fatboy. This thread interests me, and the thread began in a completely constructive manner with very useful info - until you and your cronies hijacked the thread.
    I am new to fatbikes. The early info on this thread was useful to me and other novices. Now, that useful info has been interrupted and probably terminated.
    I do not appreciate that you and your cronies - most of whom seem to compete directly or indirectly with Specialized - destroyed what would have been a useful thread.
    I also do not appreciate being called ignorant or referred to as a sheep (or a lamb or whatever). If you don't want to be "bagged" on, then you and your cronies should stop "bagging" on others.
    Hey Kettle...oh Hi Pot!
    Since Spec/QBP had a falling out about tires, I wonder what tubes will be used in the Fatboy. Would be nice to have another option there as well.
    Jason
    Trying to push the this thread back onto the orginal topic here. Have we heard about final weights for the Fatboy yet? Anyone who has already pre-ordered, have you thought of what you would want changed?
    Personally I'm thinking I want to switch the shifters, however I'll wait till I ride with them to make up my mind.
    Reputation: buckfiddious's Avatar
    Dear f**king god.
    It's nothing more than another f**king bike. That's it.
    I'm serious when I say I've never seen a group of cyclists as utterly obsessed with authenticity as the fatbike "Community". No one makes bikes out of the goodness of their hearts. They are consumer products, sold for profit. Doesn't matter how long the beards are on the website or how edgy their website is, they are selling consumer products.
    And before y'all get all "but Specialized is evil because..." STFU. Seriously. The enormous parts distributor QBP ripped off tons of designs, but since they had a bunch of cash, they could capitalize on those designs in ways that Fatback, Snowcat and all the others could not. And then, they packaged these products in meat-flavored hipster friendly websites.
    And they made enough noise that the even bigger boys, Specialized and Trek and Kona and whoever else, companies that have even more money, have taken notice and decided to rip off QBP. Tough. THat's how it works.
    And for everyone who says that QBP would never force a dealer to choose between them and another manufacturer, that's just because at this point, they can't. They aren't big enough, they don't sell enough bikes. QBP currently has the luxury of looking like they have integrity, man. But when they get big enough, they will do the same thing. Because destroying your competition is at the heart of business.
    Suck it up, cherish your rare purple first gen pugsley and maybe if we're lucky, more people will start riding fatbikes, and that's kind of the point, init?
    You can't just lie your way out of being wrong. Nothing has been terminated and nothing has been destroyed. I have no competition with Specialized and I am not a cronie of anyone or anything related to this thread. If you want to operate in a pro-specialized forum bubble, start your own forum and only allow people with your viewpoint. Till then, get used to people taking up opposing view points and making their case, while operating within the forum guidelines. That means no name calling or insults.
    Aug 2013
    You seem confused. My comments were not directed at you.
    Furthermore, I haven't lied. And I don't appreciate the accusation.
    Mike I understand your passion but in the age of Apple, you really think people give a shit?
    OG Ripley v2
    Carver 420 TI
    I honestly doubt there are weights out yet. When i was talking to inside reps, zero have shipped beside the prototypes that were not speced the same as what specialized offers as complete.
    We placed a full size run order in pre season. Should have soon
    Aug 2003
    Quote Originally Posted by TwoTone View Post
    The continued existence of brands like Specialized, Cannondale, and WalMart would seem to support your position.
    I guess I'm just a hopeless optimist, believing that the human race can pull it's collective head out of it's collective ass before someone accidentally flushes.
    Nov 2007
    For the record, I give a shit.
    aka bOb
    So I buy a bike from a small manufacturer and I got crap from not buying local, I buy local and I get crap from not supporting the little manufacturer. I do know some of the money I spent on my last Spesh went to supporting a local shop which provides awesome service which in turns employs local people which in turn supports our local clubs and trails. I think the complainers need to just worry about themselves and stfu!!
    p.s. I have a mix of both and try going small when I can but I still thinks it's nobody's business.
    Reputation: E6roller's Avatar
    Apr 2013
    My first BMX Bike was a converted Schwinn in 19seventy-something. My first Mountain Bike was a Spec. RockHopper Comp in 1986.
    There was a time when internet-forums' members'-dial-up-connections and forums' servers could not afford the bandwidth wastage of off-topic discussion.
    In the present time......In this forum......folks will have their own voice! ...AAANNNNDDDD, this is the day of HUGE bandwidth.
    Cries to stay "on-topic" are unnecessary.
    AAAAAAAAAAAAAAs to big-guys with big-lawyers..........I am in the aircraft industry. I recall the biggest guy on the block filing suit against the little guys about product names that the big guys had "stolen fair and square". Also even a CERTAIN SHADE OF YELLOW!!!!!!!! was brought to court. ...the big guys lost both cases.
    The big guys had been high-grading ideas and S.T.C.'ing (a certain form of approval-for-installation and also a way of guaranteeing rights) the ideas of someone who had been coming up with ideas for EVER! This still goes on...
    ......I choose where my money is spent because I do not wish to fund unreasonable and unfair activity........maybe that is just part of my world view.
    Sometimes that means caring about the Chinese factory worker who should be making WAAYYYYY more for the effort....even if I would have to pay more.......but I'd rather fund domestic production.
    Why would you not care about how your money is spent?
    Reputation: smithcreek's Avatar
    Nov 2012
    And for the record, I took one. In the end it all works out, you know yin-yang and all that stuff.
    Lord Thunderbottom
    Reputation: TitanofChaos's Avatar
    I hope the new ground control tires have enough float to get over all the BS....
    Any more info on them?
    Today I will do what others won't, so tomorrow I can do what others can't
    I am off work today, i will call my Specialized Rep tomorrow see if i can get eta. Part number and price for you guys.
    As far as what you replace first. IMHO i always replace handelbar, stem, and seatpost. The stock stuff is always so heavy. Saved almost a pound and a half off my carve/crave SL.
    aka bOb
    Could you maybe ask him if there is any more info on the tires yet as well?
    What else do i need to ask
    Sent from my SGH-T989 using Tapatalk 2
    aka bOb
    Maybe when the tires will be available and cost and any other specs they might know.
    I inquired at a large Spec. dealer close to me about the complete bike. Sales person seemed to have heard about the Fatboy, but I was the first to inquire. Within 10 minutes of searching he states November and I would need to come into the shop to preorder. So,sounds like the same info posted was easily found by salesperson that really knew nothing about dates.
    Eaxctly specialized does make it easy now to find out info.
    Chill. Its ironic that of your 14 total posts, over half have been in this thread and of those 8, it appears that 5 have been totally off topic as you have striven to wrench the conversation back to what you considered "on-topic". And you've been quite heavy-handed in your endeavors.
    I do agree, that to some extent, the posts that were not pro-Spesh weren't strictly on-topic, but I took their perspective with a grain of salt and filed it away. I enjoy the fact that the mods afford us some latitude in our discussions here.
    As far as the topic goes, you are obviously looking forward to your first Fat bike (as am I) and I share the anticipation. I will be curious to see what effects the Fatboy has on market, and particularly the Ground Control tires and how they will handle a toob-less setup.
    Human Test Subject
    Can this thread be about bikes instead of whatever it is about now?
    Aug 2013
    Quote Originally Posted by Volsung View Post
    I certainly hope so.
    Early in the thread when the thread was still constructive, somebody asked if the upgraded components on the Fatboy Expert were worth an additional $600 compared to the components on the Fatboy base model.
    I would be interested in opinions about which model is a better value. I am new to fatbikes. I pre-ordered the Expert, but I really don't know whether it is worth an additional $600.
    Aug 2013
    I'd be fine with the base model my self. Upgrade components when they break. To me it would be just a fun woods/winter bike I wouldn't need top of the line spec for that. It looks to be a quality ride.
    1999 Trek 930
    1997 Trek 850
  67. #67
    Nov 2012
    I'd think that I would be more interested in the regular...non-expert, or better yet a frame and fork option. I like my BB7 brakes for winter riding, as it is regularly below zero, and sometimes much colder here when I ride my morning commute, so hydro doesn't appeal to me. If they were specd with XT, than maybe it would be worth it to switch back fir the warmer months. Also, I think a 1x setup is the way of the future, so I'm surprised to see multiple chain rings, especially on the expert. Get rid of the front der, gain the tire/mud/snow clearance. Also....I like the green, and I like being vain. Really though, I just want the wheels and tires for my Necromancer....what are the odds of them fitting back there, I wonder....
  68. #68
    Reputation: duggus's Avatar
    Wow... the fat bike section has really started to turn into a pissing match lately with every new person that comes into the forum.
    Dear those of you: Could you pleeeeease skim the posts or do a search? There is a bunch of this and that isn't relative to this thread bla bla bla... well, there are about 4 or so Specialized Fatboy threads right now that this "new info" could have been posted in. But gotta keep that post count up, right?
    ...Be careful what you're looking at because it might be looking back...
  69. #69
    Dude... you are being kind of a dick, sorry... but piss people off much? You reap what you sow in this life... maybe some day you will figure that out. Then maybe come back to the forums.
  70. #70
    Back on topic, the differences are a few subtle changes as well as those mentioned earlier. Official page as I can see is as follows. Price difference in Oz $2299-$2999 =$700
    Upgrades to Expert include, Brakes are Deore as opposed to Tektro Draco, rear derailleur is XO as opposed to X7, chain is KMC with hollow plates vs standard KMC, cranks are "custom" E13 as opposed to basic alloy(Samox?), BB is E13 as opposed to Samox, pedals are Specialized Bennies with sealed bearings as opposed to standard aluminium, spokes are double butted as opposed to straight gauge, saddle has hollow chromo rails as opposed to standard steel rails. For me I see the value and hence I have ordered the Expert model for myself
  71. #71
    Talked to Specialized rep today. The 4.6" Ground Control Tire will be avaliable after market "later in the season" no pricing or part number as of yet.
    They are not making a 4.8"
  72. #72
    Feb 2012
    Nice! Sounds like they have a good chance of fitting on the back of a Pugsley.
  73. #73
    Reputation: CJones's Avatar
    Is the ETA still November?
  74. #74
    Nov 2012
    Quote Originally Posted by Raul34 View Post
    I hope against hope, wish against wish, that with my 1x10 setup these will clear.
  75. #75
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    I give two shits. Specialized is a plague that began with Sinyard hijacking designs and has done nothing but stoop to ever lower measures since. The Big Ess can suck it.
  76. #76
    Talking to my rep most of the bikes will be available "early November"
  77. #77
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    Quote Originally Posted by Dirty $anchez View Post
    your new screen name makes this hilarious ,I assume you are being literal
    I am slow therefore I am
  78. #78
    Nov 2012
    Will somebody just ask their rep if it fits on the pugsley/necromancer? Somebody must have thought, "hey, we will sell a lot of tires if it fits the pugs".
  79. #79
    Ho'lier than thou
    Reputation: Katz's Avatar
    Quote Originally Posted by Schott View Post
    That could very well be the reason why they chose 4.6" instead of 4.8".
  80. #80
    Quote Originally Posted by Katz View Post
    I was guessing they came out of the mold and someone mounted a set up and measured them and went SH!T. Then they got the label guy to change the size on the sidewall.
  81. #81
    I really want to agree with CJ here, kinda like the first ground controll 29x1.9 who rides a 1.9?
  82. #82
    Ho'lier than thou
    Quote Originally Posted by CJones View Post
    I was guessing they came out of the mold and someone mounted a set up and measured them and went SH!T..
    LOL.
    Actually that's more plausible considering they changed it at the last minute.
    Whatever the case may be, I'm pleased we'll have a size in between 4.0" and 4.8". I can probably fit them on my On-one.
  83. #83
    Sup
    Dec 2008
    Whatever the case may be, I'm pleased we'll have a size in between 4.0" and 4.8". I can probably fit them on my On-one.[/QUOTE]
    if only girls would say that you would be so boss
  84. #84
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Ha! Word.
  85. #85
    Nov 2012
    I ride a Pugsley Medium (18") and i find it a little too big. Do someone know if the FatBoy Small (15.5") could fit? I'm 5'7" and it's for snow biking. don't seems to be so small in the specs: Specialized Bicycle Components
  86. #86
    Nov 2012
    In Canada they will be here in january.
  87. #87
    Quote Originally Posted by collinox View Post
    Medium 18" Pugsley has 595mm toptube
    the small 15.5 Fatboy has a 576mm toptube
    the medium 1.5 Fatboy has 603mm toptube
    If you feel stretched out in your fit i would go small because it looks like the Fatboy is a bit bigger medium to medium.
  88. #88
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I talked to the Specialized rep who was in my LBS and he said the Fatboy should be available Nov/Dec, will be extremely limited, and AK folk will get first shot at them. My LBS is the largest single store dealer in the West and they have a lot of pull, but when I asked if I would be able to get a pair of them (1 each for me and the wife) the rep said the shop will be lucky to get 1!
    14 Aurum, 16 Fuse, 17 T130
  89. #89
    Wow that is the polar oposite of what my rep. (who i have worked with for ten years) said. They even added it to the employee ensentitive program.
    We have five on order for stock and three for employees.
    I work at a US Concept dealer but that still shocks me. Almost sounds like trying to scare you to pre-order.
    Unless he is taking first shipment or they are worried about tire avaliabilty. I was told bikes are sitting in warehouse waiting for tires.
  90. #90
    Yeah these Dates are kinda wacked. Oct/Nov/Dec. Last week there was a rep in my local shop. The word is Oct.
  91. #91
    Jun 2010
    I hope your right! My inlaws live on the coast and wanted to get the Walmart fatbikes. I was hoping to get a pair of the Fatboys so they could use them for beach riding in the summer and my wife and I can use them the rest of the year.
    I just wish they would come out and be honest with what is going on with them.
  92. #92
    Have not heard anything from specialized about the fatboy that was not honest.
  93. #93
    Jun 2010
    I'm not saying their dishonest, I'm saying they need to just come out and say exactly what is going on. I dont get the secrecy. Like the Enduro 29er stuff. They kept saying there wasn't any plans for it, then suddenly they are announced and showing up in stores 2 weeks later.
  94. #94
    Human Test Subject
    I applaud them for relabeling their tires as 4.6 instead of 4.8. I wish 45Nrth would do that instead of claiming their 4.0 tires aren't 3.7ish.
  95. #95
    Jan 2011
    I ordered a fatboy expert last week and the shop called the rep and they say the expert will be released in oct, and the lower end model with 2 color choices will be released in november. Also the price is $200 cheaper then advertised on both models.
  96. #96
    Reputation: mevadus's Avatar
    So the cheaper version will be $1800? Hmmm, I might actually be interested, and I live in AK. Hmmmm....
  97. #97
    Reputation: Tincup69's Avatar
    Sep 2012
    For $1800 I think I just resolved my bigger tire issue on my Mukluk.
    2016 Trek Farley 7
    2015 Specialized Fatboy Comp
    2014 Trek Fuel EX8
    2015 GT Grade 105
  98. #98
    Yeah... my local Specialized dealer (Nicollet Bike) said they are getting 11 in and 5 are sold already. Beginning of November is what they were told.
  99. #99
    Pre-ordered mine today, i can't wait. Sorry Surly fans.
  100. #100
    Sep 2012
    Those of you that have pre-ordered, was the pricing around $1800 for the non expert model?
    2016 Trek Farley 7
    2014 Trek Fuel EX8
    2015 GT Grade 105
  1. Specialized Fatboy
    By fc in forum Fat bikes
    Last Post: 4 Weeks Ago, 07:53 AM
  2. Specialized Tandem Info
    By DirtSS in forum Tandem Mountain Bikes
    Last Post: 12-20-2017, 12:26 PM
  3. Replies: 31
    Last Post: 08-09-2013, 03:17 PM
  4. Specialized Fatboy
    By fc in forum Specialized
    Last Post: 07-15-2013, 04:17 PM
  5. Newest Jet 9 RDO build info
    By herothedog in forum Niner Bikes
    Last Post: 03-27-2013, 10:47 AM
