FAT BIKES
WINTER APPAREL
TRAINERS
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 76 to 100 of 137
  1. #76
    It was only a color change and which width to get to replace the white strip that was on my Fat Boy
    Quote Originally Posted by alshead View Post
    I'm confused. Are people using the surly rim strip to set up tubeless? Without tape?
    There are two types of mountain bikers. Those who are faster than me, and me.
  2. #77
    Reputation: alshead's Avatar
    Oct 2007
    Quote Originally Posted by reig3 View Post
    Cool- thanks. And did you figure out which width works best?
    "There are two kinds of mountain bikers in the world: those who are faster than me, and me."
  3. #78
    I went with the 75MM wide and no you cant use orange now <g>
  4. #79
    Quote Originally Posted by Jisch View Post
    I often wondered if you could feel the difference in frame materials on a fat bike. I figured with that much bounce you wouldn't be able to feel any aluminum harshness or steel springy-ness. Interesting. V8s are definitely going to have lower rolling resistance than GCs
    i wouldn't have thought that it would be noticeable, but it really is.
    mmmmmm, v8 season
    rog
  5. #80
    I put these tires to the test yesterday and decided that ...they rock! beat them silly in the dirt, mud, broken and weathered granite gardens. Climbed EVERYTHING with endless traction and descended with near reckless abandon.
    Who cares what they weigh!
  6. #81
    Quote Originally Posted by gravitylover View Post
    GO E-MAN!!!!
    rog
  7. #82
    Oct 2007
    I just finished converting my fatboy to tubeless and it couldn't have been easier. I read all these comments and didn't experience any of these problems. I purchased 2 surly orange 75mm rim strips, which by the way are 40 grams heavier for both, than the specialized rim strips, but I didn't like the white with my green frame so they had to go! Then I purchased Orangeseal's fat bike kit with subzero sealant and 75mm tape. After removing the specialized rim strip and installing the surly 75mm strip (required some stretching to install which gave it a nice tight fit). Then after thoroughly cleaning the rim with alcohol and making sure it was dry, I wrapped the orange seal rim tape while pulling it tightly, first wrapping one layer to the edge of the rim( not the upright bead portion, just to where the rim turns up perpendicular at the edge.) Then a second layer on the opposite side. Just be sure you cover the little gas venting holes they punch in the rim for the welding of the rim. The tape doesn't cover the holes by very much, but don't worry it will seal. I wrapped in different directions so the tape would pull on itself and stay tight.You will get a lot of wrinkling in the middle over the rim strip, but it doesn't show through the rim strip once is all pushed down with the tube. Punch out the valve hole with a pointed punch, preferably heated so it melts the tape as you push it through. Reinstall the original tube and tire and reinflate to 20 psi. Let it sit overnight. It will completely push the orange seal tape into the cracks and crevises and will seal the first time. After sitting overnight, remove the valve core, and be very careful and only remove one side of the bead of the tire to remove the tube. Be gentle, the other bead doesn't attach very tightly to the rim. Now install the orange seal valve stem, and lay the rim with tire now installed either on top of a five gallon bucket, with the loose bead down. This is very important, if you don't put the loose bead down, you will never get the bead to seat. The weight and flex of the tire will allow the loose bead to hang down against the side of the rim. This will allow you to set the bead with a hand pump almost effortlessly. The first few pumps need to be done quickly at a fevered pitch until you don't here any air leaking out which should be very quickly. I had no problems doing both tires this way. pump them up to 20 psi to get the loose bead to seat. Now this part can be tricky. A helper might be needed but I did by myself with no problem. While supporting the tire and rim, remove the valve core of the orange seal stem. don't let the rim weight rest on the tire during this step, hold it by the spokes in the air while you install 4 oz. of orangeseal subzero formula. If you don't expect cold temps, you can use the regular orangeseal. Reinstall the stem holding the threaded part because as the core starts to get tight, the stem will spin in the rim, so hold it while you tighten the core. After you install sealant gently lay the rim back on the bucket with the side that had the loose bead down, and hook up the pump and air it up again in the same manner . You may see a little sealant around stem or seam in rim but thats ok. Pump up to 20 psi and move the tire back and forth while holding the tire rim combo horizontal and move the tire rim around like a coin when it self levels when dropped on a table. Then install rim and spin tire back and forth in both directions and go for ride, your done! The orange seal rim is no where near the weight of duct tape, and it is designed to be used with sealant. The thin crackly feeling of the tape is deceiving. Once you wrap the rim and inflate the tube overnight, that tape sticks like crazy. My tubes weighed 530 grams each, not 600+ like some of the guys had on their bikes, but losing 1060 grams in tube, adding 40 grams in rim strips, and 55 grams of sealant, comes out to 2.12 lbs reduction in rolling mass! Huge difference when I went out for a ride. Well worth it. Rode the local trails here with some small jumps and a few 2 to 3 foot drops, and roots mammy, with no issues at all. No loss of air and I run around 8 psi. Best mod so far to my fatty!
  8. #83
    awesome keep us updated....have you rode any rutted trails yet? Our trails are a bit rough here.....if this works for you I want to consider it. Any pics of new tape installed? I would like to red surly rim strips if possible. Why did you not run stans?
  9. #84
    Oct 2007
    Why not Stans.
    Quote Originally Posted by barry1me View Post
    Orange seal makes a ready made kit, and I couldn't find that in Stans, supposedly Fatback sells it but I couldn't find it, plus they are in Alaska, I'm in Fl. didn't want to wait 2 weeks for it. Orange seal also makes a subzero sealant that won't freeze in 0 temps. I do a couple trips a year to Alaska and Montana, and it gets way down there in Alaska! There's tons of ruts and roots here in Florida, muck, down tree limbs on the trail all the time. I didn't take any pics of the tape on my bike, but I'm doing one this weekend for a buddy, and i'll snap some pics and post them
  10. #85
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Re: Specialized Fat Boy wheel/tire weights and photos
    Slime Pro is good to -35 F.
    --Lars
    --Peace
  11. #86
    Quote Originally Posted by 4wdoutfitters View Post
    anymore updates on this? which valvestems did you use?
  12. #87
    Oct 2007
    I used orange seal's stems. I did replace the tape with clear gorilla tape. Sticks much better! The sealer eventually seeped under the orange seal tape.
  13. #88
    The tubes coming in Fatboys seem to vary greatly.... my front tube weighed 415g on my new Fatboy (orange/blue) I think tonight I will make an attempt at tubeless gorilla tape, bontrager valve stems and stan's. I see stan's is rating their sealant to -30F/-34C
    Attachment 929295
  14. #89
    May 2005
    The Gorilla tape work for a time but after somes days, the stan penetrate between the tape layer and make leak. I search for larger tape.
  15. #90
    WHOA! Just setup my front wheel tubeless and damn what a weight savings. I used gorilla tape, 4 ounces of Stan's and a Bontrager valve stem. Here's the before and after wheel weights.
    Attachment 929385
    Attachment 929386
  16. #91
    or you coulda just gone with a q-lite tube and saved about the same amount of weight.
    rog
  17. #92
    sorry rog, not possible to save 860g just by swapping tubes.
  18. #93
    Reputation: bonesetter2004's Avatar
    The bike feels so different to pick-up after the tubes have gone
    Rides better too of course. My ride was fun today - tyres gripping so much making me smile
    My Gorilla set-up is holding fine after 2 weeks
  19. #94
    Quote Originally Posted by crohnsy View Post
    sorry, but you added weight back with stanz and tape, q-lite tubes are 250ish grams a piece. so that cuts your 860 down to 500g. then you add stanz front and rear and the difference is now only about 270g, then you add gorilla tape and yer under 200g difference..............
    rog
  20. #95
    ya 3.49lb down to 3.06.
    seeing as how you dropped less than a 1/2 pound per wheel going tubeless, i'd say the q-lites may be about even in the end. and no mess or fussing.
    sorry, guy
    rog
  21. #96
    Jul 2013
    Quote Originally Posted by newmarketrog View Post
    sorry, guy
    rog
    For me the biggest reason to go tubeless is flat reduction, since I like to go bushwhacking on my fatbike. Last group ride we did everyone who wasn't tubeless ended up flat. You may be right that you will end up at the same weight with lightweight tubes as you will with tubeless, but you don't have the flat reduction or ride quality improvement that comes with tubeless.
    I am taking delivery of my fatboy at the end of this month at which point I'll be converting to tubeless and Bud/Lou. I'll make sure to get weights at each stage. I'll be using 4" Pegasus tape for the first time, in the past (Moonlander and Krampus) I've used Gorilla Tape.
  22. #97
    Thank you for taking the time to post this!!!
  23. #98
    Reputation: soloyo's Avatar
    May 2012
    I read here the rims weight 767gr so i think the heaviest weight are on the hubs. Anybody know the weight of the hubs? i,m thinng on installin tune hubs on the stock wheels of the fatboy.
    Friends, forgive me for my spanish-inglish
  24. #99
    Jan 2014
    Thanks Wadedro. I currently have Holy Rolling Daryls and have done the foam, gorilla tape, and split tube methods. Most recently, I've used the 3M fat tape and no foam with good results. The foam typically gets compressed so much after the initial inflation that it's useless for subsequent mountings, and I've been able to get a Nate, a Husker Du, and a Bud all to seat up just fine by mounting them up with a tube first and just popping one bead. Plus, the Specialized rims don't have that deep center cavity, so I don't think the foam is necessary.
    Why did you go away from the split tube method?
  25. #100
    Nov 2007
    Random ?
    With the Spec Sl 26 Wheelset what hubs are they using and what bushings are available with this wheelset. IE 15mm thru, 12mm rear... Hopefully they are using a hub that accepts DT bushings. Was looking at buying the wheelset just want to make sure it can meet the wider back end and thru axle front.
    Aaron Boatman
    Lake Havasu City
    Local Rides AZ stuff
    FACEBOOK
  1. Replies: 4
    Last Post: 12-21-2014, 10:14 PM
  2. Actual wheel weights
    By chuckie108 in forum Weight Weenies
    Last Post: 09-23-2013, 04:12 PM
  3. '09 Anthem x2 wheel weights
    By goatdance in forum Giant
    Last Post: 10-04-2011, 09:20 AM
  4. Wheel weights.
    By Lino. in forum Wheels and Tires
    Last Post: 09-29-2011, 06:10 PM
  5. SLX Crank Weights... WITH PHOTOS!
    By ADDam in forum Weight Weenies
    Last Post: 05-13-2011, 04:48 PM
Follow MTBR on Facebook
