Page 2 of 2 FirstFirst 12
Results 101 to 145 of 145
  1. #101
    Aug 2013
    I'm thinking of replacing the red rim tape on my Fatboy. What width do I need for these 90 mm rims?
  2. #102
    If you want to sell the Ground Control tires that came on your Fatboy when you replace them with Bud/Lou, I'd be interested. Thanks!
  3. #103
    Specialized Fat Boy wheel/tire weights and photos
    I'm rebuilding my front wheel onto a Hope Fatsno 15x150 hub for my new Bluto. For anyone curious about the hub flange size, they're VERY similar:
    I'll start putting them together tomorrow. If anyone has any questions about the wheels/hubs, let me know!
  4. #104
    I would like to do the same as I have a bluto waiting for my Fatboy. My buddy has his done at the LBS and they re-used the same spokes and said it was an easy swap.
    I'm thinking about taking a stab at this myself. It would be my first attempt at wheel building so any tips from your experience would be greatly appreciated. Thanks!
  5. #105
    It's my first try too, going to be a lot of trial, and likely even more error. But I want to learn.
    First new detail: the hex on the spoke nipples is a 5.5mm hex head. I picked up a screwdriver -> 1/4" socket adaptor and a 5.5mm socket head. I have friends staying through the weekend, so it might take me a bit to get it done.
  6. #106
    Loser
    Reputation: Jisch's Avatar
    I swapped to a Surly hub a few months back. Building this wheel was much easier than a regular mountain bike wheel - I guess because it's so wide. I tightened the spokes up to the same tension as the back wheel (more or less) by plucking the spoke and tuning it to the same frequency. I had no hops and didn't really have to do any truing of the wheel, it was stable too, no re-truing after the first few rides. Other normal bike wheels I have built it took quite a bit of time to balance the tension and the trueness of the rim.
  7. #107
    Not the fake Jay Leno
    Reputation: Chinman's Avatar
    Dec 2014
    Fatboy SE weights
    I thought folks might be interested in how the weights differ with the Fatboy SE - the new low end model. Here's what I measured:
    Fatboy SE, L, w/RaceFace AEffect pedals and bottle cage: 34.08 lbs
    Front wheel, complete: 8.29 lbs
    Front wheel wo/rim strip and skewer: 1540 g
    Front wheel w/ rim strip and skewer: 1670 g
    Rear wheel, complete: 9.35 lbs
    Rear wheel w/rim strip and skewer: 2210 g
    Bike wo/wheels: 16.47 lbs
    26 x 4.6 Ground Control 60 TPI wire bead tire: 3.4 lbs (1540 g front, 1490 g rear) edit: from reading other posts, it seems that folding bead GC tire is ~1450 g. Could it be that I have the 120 TPI tire?
    Tubes: 520 g each front and rear
    It's pretty clear the wheels & tires is where the extra weight is on this bike.
  8. #108
    Hello, Just wondering if you could tell me the spoke hole number for the specialized fat boy rims? Trying to figure out if I can rebuild them, offset, for a Moonlander. Thanks.
  9. #109
    Dec 2014
    Specs are here:
    Specialized Bicycle Components
    32 spokes per rim.
  10. #110
    Sorry, this is a bit of a cross post, but didn't get any bites in the Spec brand forum.
    I got a XD Driver hub for the rear wheel, and it dropped right in but spins with a LOT of resistance. If it's on the stand it doesn't freewheel at all. I checked the tension on the hub bearings and they're spinning freely - so it's not tightened down too much (confirmed by our shop manager).
    Has anyone else had this issue? Did it free up over time? Were you able to make it work better?
    blood in / blood out
    Reputation: majack's Avatar
    Quote Originally Posted by jester6578 View Post
    Do you have a spacer behind the cassette? That is the only thing I can think of that might cause this issue.
    RICOH for LIFE
    Pain is Weakness
  12. #112
    Reputation: cycloxer13's Avatar
    Oct 2014
    Yes, you have two seals in your freehub, in error. You need to take one out. This drove me crazy until I figured out the problem. It is the small black lip seal that goes between the freehub and the hub body.
    When you took the old body off the seal remained in the hub. Then Spec ships the XD driver with a new seal, so you probably put it right in (just like I did) and now you have two seals stacked on top of one another.
    '15 Evil The Following
    '15 Spec Fatboy R
  13. #113
    Quote Originally Posted by cycloxer13 View Post
    Good to know about this. Thanks
    RICOH for LIFE
    Pain is Weakness
  14. #114
    Hey fellow Fatboy owners what stems for tubeless conversion work best with the standard Fatboy rims?
  15. #115
    Oct 2014
    The regular Stans work fine. Nothing special required.
    '15 Spec Fatboy R
  16. #116
    Stans are the ones I use in the shop and work the best. The ones from Orange Seal don't seem to work all that great so this is why I use the Stans.
    RICOH for LIFE
    Pain is Weakness
  17. #117
    Interesting.
    I didn't notice any seals included with the XD Driver - I certainly didn't put any in. But I'll take it apart and take a look.
  18. #118
    Oct 2014
    You'll know if you have two seals in there as your wheel will not freewheel. Here is the seal:
    Attached Thumbnails Attached Thumbnails Specialized Fat Boy wheel/tire weights and photos-img_20150110_152421228.jpg
    '15 Spec Fatboy R
  19. #119
    Took it apart, removed that seal, and it freewheels now! Thanks so much!
    I was nervous to remove it, but it does look like there is a nearly identical seal on the hub itself.
  20. #120
    Oct 2014
    The seal on the hub is the same one and it does indeed come out with a pick, but you can just leave it in there if it is in good shape. The design definitely only calls for one seal.
    '15 Spec Fatboy R
  21. #121
    Nov 2008
    Has anyone measured the weight of the stock hubs? I plan on building up a new wheel set and was curious as to how much weight can be shaved off
  22. #122
    Oct 2010
    Quote Originally Posted by fastpunk View Post
    I actually did weigh them and compared the weight to 907 hubs. Problem is I don't remember what they weighed, but though I don't have exact weights, I can tell you the combination front and rear were almost identical in total when compared to 907, but I remember it being the rear was heavier by 15 grams or so and front was lighter by the same, so it was very close to a wash. My i9 torch hubs were about 30-40 grams lighter for the pair I believe. So don't expect too much in the way of weight savings from the hub itself.
  23. #123
    Jul 2014
    Depends on the internals as I've read Specialized has changed the axle over the past year. My dealer rebuilt rear stock hub is 460g (no skewer) so I saved 95 grams switching to a Hope 190mm hub.
    Not sure on the front as I forgot to weigh it before I sold it.
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  24. #124
    Oct 2010
    Quote Originally Posted by Paochow View Post
    Good point. And I know mine was off one of the first ones the US. Though I was lucky and never had problems before I sold it. It certainly could have been lighter (weaker) than they are now.
  25. #125
    Jul 2014
    I thought my LBS said they had put a steel axle in mine when they rebuilt it. it did last longer than the original, it was still working when I swapped it.
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  26. #126
    Nov 2008
    Quote Originally Posted by bpd131 View Post
    Thanks! I'm thinking about building up a budget summer trail wheelset with neon trials rims and origin8 hubs.
  27. #127
    Sep 2012
    Did you weigh the stock fatboy front hub?
  28. #128
    Here's a minority report of tubeless success without G-tape ... I snagged a pair of 20" Schwinn "Chopper" replacement tubes and used those for rim strips. Aired it up with a compressor, popped out the valve core, added 3 oz of Stans and have had zero flats for a year. Took 15 minutes total.
    Just sayin...
  29. #129
    May 2015
  30. #130
    Slow-Thyrol... That's exactly the thing!
    On my FatBoy I had about 3/4" to trim on either side. It stretches out nice and tight around the rim. It's actually a really elegant solution.
    To set the beads, I took out the valve core and gave it a blast with an air gun. Drop in a bit of sealant, insert the core, air it to 6-9 PSI and Bobs your uncle. Ready for crazy time in the dirt.
  31. #131
    SimonsJ
    Tubeless FatBike Wheel Conversion and uber lightweight wheels...
    Wow... A ton of info on this thread. I used to think all of my FatBoy wheelsets were competitive, once the were set up tubeless, but not anymore. The ENSO6105 wheelset weighed in at 1866g complete. Those Tune hubs are spectacular and Kuroshiro wheels (Alchemy builds them) are unmatched. Max rider weight of 220 lbs, 105mm Inside Bead Width for 1866g. Wow...
    Specialized Fat Boy wheel/tire weights and photos-enso6105_scale2.jpgSpecialized Fat Boy wheel/tire weights and photos-enso6105.jpg
    As far as converting FatBoy wheelsets to tubeless, check out FattyStripper Tubeless Solutions for a complete conversion kit that Blings the wheel & makes it a super-reliable tubeless conversion. I've got 4 FatBoy's set up with that system and they went all summer without loosing air... with only 2 oz of Stan's in them. I just refreshed the Stan's for the winter... but FattyStripper is the simplest way to go.
    Specialized Fat Boy wheel/tire weights and photos-3m_blingstrips_ryb.jpg
  32. #132
    thought it meant Mt. Beer
    Reputation: bbender785's Avatar
    Sep 2015
    picked up my SE friday and tubeless is first on the agenda, so reviving this thread.
    Quote Originally Posted by wileycoyote View Post
    Just sayin...
    ..On my FatBoy I had about 3/4" to trim on either side. It stretches out nice and tight around the rim. It's actually a really elegant solution.
    this has my attention. so did you just make one cut around the tube opposite the valve stem, and then trim the 3/4" per side you mentioned? any idea how the tube weight compares to other methods' materials in this thread?
    VILLAGE RACING
  33. #133
    Barn Burner
    Jan 2016
    I too was curious about weight savings when I switched to the FattyStrippers.
    It came out like this:
    Stock 2016 Fat Boy Comp tube weight: 508 grams
    FattyStripper weight: 49g minus 12.5g trimmed off after installing=36.5g
    Stans tubeless stem: 7g
    2 oz Stans sealant: 60g
    Comes out to 404.5g per wheel weight saved.
    First tried with only one ounce of Stans, but had some leaking. Two seemed to fix it right up. I also did not glue the strips to the wheel.
  34. #134
    Trail Sanitizer
    Reputation: Bulldozer's Avatar
    Quote Originally Posted by Johnwa View Post
    This week I have started the process to convert my Fatboy Trail to tubeless using Fatty Stripper. I've finished the front wheel but not the back. Stock weight of front wheel, tire, tube, and rotor was exactly 8lbs. This doesn't include the QR. After the conversion, the weight was down to just over 7lbs with the caveat that I didn't measure how much sealant I put in.
  35. #135
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Yeah but you could have saved 300 of those grams just by going with a lighter tube.
    --Peace
  36. #136
    SimonsJ
    Quote Originally Posted by Lars_D View Post
    And get pinch flats PLUS the massive rolling resistance caused simply having a tube inside the tire rubbing against the tire continuously at the deflection points. At 4psi, 170 lb rider, 16 mph... it was 25W of loss with said Q-tube. And Q-tubes cost more...
  37. #137
    Reputation: IPA Rider's Avatar
    Wow.
    Not to jinx this, but I am really impressed with 1. the amount of useful info on this thread, and 2. the lack of flame wars, heckling, and derailment that are so common.
    Good on ya! Thanks...
    Riding: '91 Carbon Epic Stumpjumper w/1" Slicks and a Rack on the Back
  38. #138
    Anchorage, AK
    Quote Originally Posted by SimonsJ View Post
    How did you measure the 25 watt loss?
    --Peace
  39. #139
    Dec 2014
    q-tube lights on my fatboy with ground controls since September 2015 running pressure anywhere from 2-10psi. No pinch flats yet.
  40. #140
    I'm a huge proponent of tubeless, because my area has tons of goat heads... But I'd like to know this as well.
  41. #141
    Reputation: MI-29er's Avatar
    Okay I just bought a new 16 Fatboy Comp (orange one). Are the hubs of any value? Are they light enough to for say use them to lace up some carbon rims? I just ordered the xd driver to convert to 11 spd using Sram X01. So that will help some weight. But just curious on the hubs by themselves.
    1983 Ross Custom Deluxe Mtb
    2014 Giant Anthem Advanced 1 27.5
    2015 Giant TCX SLR 2
    SAVE GAS RIDE A MTB BIKE
  42. #142
    Anymore insight on the weight of the newer Stout rims/hubs?
    I'm looking at upgrading my '17 and am wondering if a DT BR710/DT 350 combo will be enough of a weight savings over the stock setup to make it worth spending the money.
    I'd pull mine apart and measure them, but they've got Fatty Strippers installed and I don't want to pull them apart.
    I just built up a Hope Fatsno w/XD driver, Mulefut SL 80 l, Dt Triple Butted spokes, Dt brass nipples, and I lost maybe 1.5 lbs total. Between the stock wheelset and new wheelset.
  44. #144
    Quote Originally Posted by MI-29er View Post
    Thanks for the info. On paper, the BR710s are about 150 grams a piece less than the Mulefuts, so that would be another 1/2 pound. Interesting.
  45. #145
    Also by just changing out the tubes to Q tubes (2.4 to 2.7)you will shave well over a pound. And changing out the tires will shave a couple pounds depending on what you replace them with.
  1. Replies: 4
    Last Post: 12-21-2014, 10:14 PM
  2. Actual wheel weights
    By chuckie108 in forum Weight Weenies
    Last Post: 09-23-2013, 03:12 PM
  3. '09 Anthem x2 wheel weights
    By goatdance in forum Giant
    Last Post: 10-04-2011, 08:20 AM
  4. Wheel weights.
    By Lino. in forum Wheels and Tires
    Last Post: 09-29-2011, 05:10 PM
  5. SLX Crank Weights... WITH PHOTOS!
    By ADDam in forum Weight Weenies
    Last Post: 05-13-2011, 03:48 PM
Members who have read this thread: 23
