Results 1 to 15 of 15
    Reputation: dRjOn's Avatar
    SON 135 front hub
    can anyone confirm this is a 10mm axle (and presumably therefore a rear spaced brake?) thanks!
    Oct 2012
    I have one on my Pugsley. It fits fine in the 135mm Symmetric Moonlander Fork, so is definitely rear spaced. I'd have to break out my calipers to get you the axle size, though...
    99.9% sure that will mean 10mm axle then..i have a moonlander fork also and it takes a rear hub spec. thanks muchly!
    Oct 2012
    No problem; I like the hub, although it's VERY spendy. But having light on my evening commute is worth it to me. I got mine from Peter White (via my LBS). Not sure if there's any other source for them in the states yet.
    Reputation: bikeny's Avatar
    For a cheaper option, you could get this hub:
    SP Hub Dynamo Dynohub PD 8x 32 36h QR15 Less Drag Than The 8 Series | eBay
    And then this adapter:
    Mountain Bike 15mm x 100mm thru Axle to 5mm QR Wheel Adapter for 135mm Fat Fork | eBay
    I've never tried either of them, but I've read that it works.
    Reputation: Mark_BC's Avatar
    Sep 2012
    Now if they'd make one that accepts a chainring so you can swap it with the front wheel in an emergency ... then you'd have everything.
    All I am saying is give pizza chants
    Sep 2012
    Quote Originally Posted by Mark_BC View Post
    Actually, you probably could do that if you built the wheel symmetrical like I am hoping to do. You could attach a sprocket to the brake rotor mount and go without a brake on the rear in an emergency which would be acceptable in the case of emergency.
    I'd really like to avoid having to lug my solar panel around to charge up my batteries.
    Sep 2012
    There was another post on this topic here.
    I assume you mean: "Now if they'd make one that accepts a cog so you can swap it with the rear wheel in an emergency ... then you'd have everything."
    Yes, I've thought about that as well, but on a bikepacking rig, not a fatbike. It would first of all require both frame and fork to be 135mm symmetrical spaced. Then you just need to carry one of those fixed gear ISO disc mount cogs. Then you just swap wheels and remove the disc rotor from the dynamo wheel and mount the cog instead and then tension the chain. You would then have a fixed gear bike with no generator and no rear brake, but it would get you out of a jam!
    Or, you can try to convince one of the dynamo hub manufacturers to put disc mounts on both sides of the hub, then it would work on an offset 135 frame/fork and keep the use of both brakes. I guess that would be a niche inside a niche inside a niche, not a big market!
    Mark
    Oct 2012
    Quote Originally Posted by bikeny View Post
    Mark
    While I agree and have thought about this... you also need some space free for the wire to come out. It is a dynohub, after all. I can't see them doing anything that might leave them in a place to be sued because someone's wire got caught in a rotor/cog
    Sep 2012
    Symmetrical 135 mm fatbike
    Mark
    Exactly! It's a little early in the morning, still half asleep...
    It may be niche but it wouldn't add much to the price. BTW, I'm working on figuring out a 135 symmetrical. It will work with a Rohloff and will fit a Lou no problem. Now I just need the money to get my frame builder to build it.
    Quote Originally Posted by evandy View Post
    But with a 135mm hub, you have an extra 17.5mm to work with on each side, that should bo more than enough extra room. Also, the wiring stays on the fork, so when you put it on the rear, there are no wires, just the connector on the hub. Unless of course you want wiring to the rear as well...
    Actually, thinking about this some more, you don't need to swap wheels at all if you carry a fixed ISO disc cog. You just have to replace the rotor with the cog and flip the rear wheel around. This would require a symmetrical rear triangle, and before leaving you would want to check that the cassette clears the brake caliper and that you have decent chainline from your chainring to the cog. As a last resort in the event your freehub dies, I think it would be good insurance!
    Sep 2012
    Good point, it would only be an issue with offset wheels. Yet another advantage to building a symmetrical 135 mm...
    get down!
    Reputation: appleSSeed's Avatar
    I believe the Origin 8 is a symmetrical 135.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
  1. Replies: 0
    Last Post: 09-15-2013, 09:34 AM
  2. Replies: 1
    Last Post: 07-11-2013, 06:16 PM
  3. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  4. Replies: 4
    Last Post: 09-13-2012, 01:33 AM
  5. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
