• 08-21-2012
    patineto
    So what is the closest "Fat" frame geometry to a "XC-Mountain bike"
    You know low handlebars, "Step" head angle, long toptube, short chainstays, etc..
    If it helps I'm almost 6,2" with short legs at 33" and a really long torso...
    Ps: thanks again for answering my silly questions..
  • 08-21-2012
    patineto
    Oh I will be great If you post pictures (or links) of each contender
  • 08-21-2012
    ward
    A few of us have custom fatties built w/ a more "XC" geometry. Mine with it's Maverick fork now mounted w/ the Husker Du's/LM's rides quite well on trails & Summer dirt. It also has quite a bit higher BB than snow/sand bikes. Sometimes I think a little too high, but when I get "out amongst 'em" it rips pretty good. It is a big 'ol bike compared to a 26er XC bike, after all it's basicly a 29er. Seems like the high BB gives me some kind of "command" over the big 'ol thing. It also has short chainstays and was built specific for the Maverick's A to C length. I'll dig up a pic for you if you like.
    The SandMan has always seemed to be a little more towards an XC design as well... not sure about U.S. availability though.
    Rumor has it one of the 2013 Mukluks (the white one I think) will have shorter CS's, and a higher BB specifically to give it better "dirt" abilities. Got a feeling with a Lefty mounted up that one's going to ride summer trails pretty well.
    Also, OnOne is putting a more XC oriented fat bike out soon as well. Theres a pretty long thread on here about it. It's pretty cool looking. I'd like to see it w/ a susp. fork on it as well.
    Lots of info on Lefty's on this forum, might have to search around a bit. You can still find Maverick's around but I think at this point I'd go Lefty... unless something else pops up in the near future.
    Her's a pic of mine. BTW, I LOVE this bike!!
    <a href="http://www.flickr.com/photos/51222326@N04/6344311485/" title="FILE0037 by wardee61, on Flickr"><img src="http://farm7.staticflickr.com/6058/6344311485_465721ea2b_b.jpg" width="1024" height="768" alt="FILE0037"></a>
  • 08-22-2012
    Nothing's impossible
    Sandman HOGGAR Ti | SANDMAN
    With the fork high it is a pretty easy riding setup with a comforting enduro geometrie, with the fork low the bike becomes more eager to ride faster.
    In the current fat version on the hoggar, the change can not be made on the fly anymore, but one can ask!
    The sandman is for sale worldwide, but it 's online!
  • 08-22-2012
    deuxdiesel
    A Pugsley rides much more like a traditional XC bike than a Mukluk does, due to it shorter headtube.
  • 08-22-2012
    ejj
    I rode both '12 and '13 Mukluks on the dirt the other day and did not notice a difference.
  • 08-22-2012
    buckfiddious
    there's no significant difference in how my pugsley rides compared to any other xc bike I've ever ridden.
    in general, it rides like a cross between a rigid bike and a FS bike.
    at low speeds, it feels like an FS bike- the tires do the work of the suspension. At higher speeds and on fast downhills, it feels more like a rigid bike- the undamped suspension of the tires bounces you around like a rigid. (YMMV with tire pressure, tire selection, etc)
  • 08-22-2012
    kyttyra
    It has also shorter chainstays and slacker seat tube than a Mukluk.
  • 08-22-2012
    drofluf
    Probably depends on what your definition of a XC bike would be. :D
    As an exercise I compared the dimensions of my Singular Swift and a similar sized Pugsley (my Pugsley is actually the 16" because I bought second hand) using data from the respective manufacturers' websites.
    Swift (M) Pugsley (18")
    Head Angle 71.5 70.5
    Seat Angle 73 72
    Ef Top Tube 592 595
    C/Stay 450 488
    Wheelbase 1082 1082
    Standover 796 786
    To my mind they're almost too close to call and for me the difference in handling is largely down to the tyres.
    EDIT apologies for the formatting:eek:
  • 08-22-2012
    SmooveP
    Totally agree. I upgraded from a Pugs to a Ti Twenty2. One of the reasons was they offered a frame size and geometry that was almost identical to my Pugs. Also went with the 450mm A/C fork (vs the 468) to keep the front end down.
    Here's Twenty2's website: https://www.twenty2cycles.com/bikes/fat-snow-bully
    Patineto, you can always go custom if you need to fit your unique requirements.
  • 08-22-2012
    patineto
    Thanks for all the great responses, I kind of dismiss the Pugs do to the frame been made of steel > corrosion in the snow, but I think is time to reconsider it.
    Please keep them coming.
  • 08-22-2012
    wrkgstiff
    My steel Fatback handles better than my Jamis Trail X3. A lot better. The Fatback is also lighter. While I'm no expert in bike geometry, I can only state how the bike feels and it rocks any surface. It may not be for everyone, but it is for me.
  • 08-22-2012
    drofluf
    I think you should definitely reconsider, no reason to reject the Pugs (or any other steel frame) because of the material. If you look after it a good steel frame will last a lifetime.
  • 08-22-2012
    buckfiddious
    Even if you don't look after it, a steel frame is pretty hard to break/damage/rust out.
    When was the last time you saw a crappy old huffy or schwinn that never gets taken inside rust in half?
  • 08-22-2012
    patineto
    Oh don't take me wrong, I have Fat chance's, IBIS's, kona's all made of fancy steel and I love them very much, but I do know you need to take special care of them when it comes to water and corrosion, for sure something the fatbike will be expose to..
    Does anybody know what kind of tubing is used on the Surly's..!?
  • 08-22-2012
    DavidJohn
    I raced and rode XC mountain bikes for years and I feel right at home on my new Moonlander.. I just changed the bars because I didn't like the wide swept back angle of stock bars and I put a slightly shorter and straighter pair on that makes it feel very much like the XC bikes that I'm so used to.
    DJ
  • 08-22-2012
    SmooveP
    That would be Surly 4130 CroMoly. I only know that because I looked it up here:
    Pugsley | Bikes | Surly Bikes
  • 08-23-2012
    Nothing wrong with steel, but if you plan to keep a frame for a decade, I would invest in Titanium.
    After 10 years you brush it and its as new!
    by the way, framesize is verry important for the bike position, I tested a size M and L for the sandman, and they handle different!
  • 08-23-2012
    JAGI410
    Surly uses their proprietary 4130 Cromo steel, double butted main triangle. Nice and beefy but not as heavy as your old Schwinn Le Tour, and not as light as your old Reynolds 531 Trek.
    Steel lasts a long time, and a fresh coat of paint or powder coat a few times in its life span will still end up cheaper than Titanium. Different materials for different budgets, but both can be a life long investment.
    FWIW, I rode my 38yr old steel bike to work today.
  • 08-23-2012
    deuxdiesel
    A thorough coating of Amsoil HDMP at first build with a yearly inspection and the Pugsley is a lifetime frame. I know a lot of riders are dumping their Pugsley's for lighter and fatter (and more $$$) bikes, but it is extremely versatile. Any disadvantage my Pugs has had in a race is due to the motor, not the bike.
  • 08-23-2012
    sean salach
    Seat Angle 73 72
    Ef Top Tube 592 595
    C/Stay 450 488
    Wheelbase 1082 1082
    Standover 796 786
    An inch and a half of extra chainstay and 1 degree slacker angles all around? I would say that would account for a noticeable difference in handling.
  • 08-23-2012
    drofluf
    Or perhaps it speaks volumes about my inability to notice the difference between the two bikes :D
  • 08-23-2012
    Velobike
    Originally Posted by JAGI410 View Post
    ...Steel lasts a long time, and a fresh coat of paint or powder coat a few times in its life span will still end up cheaper than Titanium...
    True, but Titanium is shinier. :)
    BTW a hole in the bottom of the BB is a longstanding method of preserving the interior of the frame from rust. I've got 80 year old bikes with no interior rust other than the usual patina.
  • 08-24-2012
    if you want a steel bike to become realy old, you'll need to take good care for it, not only preventing it from rust but also preventing it from high mechanical strain!
    In general, older USED high end steel mountainbikes used in Belgium have:
    -A really dirty shine on it as the varnish has deteriorated
    -Scratches in the paint
    -Dents at the double/ tripple butted tubes
    -Rust on the welds, in the scratches/dents
    -Internal rust
    -fatiguecracks in the material
    -a fixed deraileurhanger that nobody dares to straighten anymore
    there are some nice looking frames on the second hand market, but they are either repainted either hardly used for mountainbiking!
    The titanium frames on the other hand are in general structurable still as new, some stickers may be gone, and the patina migh have imperfections but that's it! People stop riding them because they 're bored, and other people are still willing to pay rather high amounts for an old frame!
    Livetime warranty on a steal frame? On a titanium one it's not unusual!
  • 08-24-2012
    buckfiddious
    -Internal rust
    I've ridden steel my whole life and I have never done much more than washing/brushing the salt off in the winter and I have never seen a frame rust out.
    As long as you take reasonably precautions (keep them inside, knock the big chunks of slush off, oil the chain every now and then) you will be fine.
    My winter commuter was an old steel trek 850 I found on the side of the road, abused and abandoned on trash day. it had not had an easy life, looked like it had spent most of it's life outside. It served me through 3 nasty Wisconsin winters, on roads that are heavily salted, through heavy snow. All I ever did was to knock the slush off it and occasionally hose down the bottom bracket area and drivetrain.
    On occasion it got small bits of rust where the paint had chipped off. But anywhere there was paint it never rusted, never even bubbled.
    Look, steel isn't that fragile. If it was, you'd never see cars made of steel and you'd definitely never see motorcycle frames made of steel.
    you don't have to baby steel.
    (caveat) really really super thin, super light steel, you have to baby. but if they put it on a MTB, it's not that kind of steel. And if it's just good ol' 4130, as long as you don't store it IN a lake, you are probably good for a looooooong time to come.
  • 08-24-2012
    sryanak
    I'd have to agree with what he said and then take it farther and say the same goes for aluminum and ti too. All three can last like forever if they are sized for the application they are being used for. Sure they can all be broken but all of them are used in aircraft where they go for thousands of fatigue cycles without failing and where the consequence of failure is very severe.
    It seems to me that ride quality and asthetics are valid reasons to choose between a certain frame material but potential for failure really isn't. Fixability out in the remote world, maybe is another reason.
  • 08-27-2012
    Buckfidious,
    Thanks for sharing that you have an old steel bike with small bits of rust where the paint had chipped:D
    If you would have found a Titanium frame of the same age as the trek, it would look as new and save some weight! But people tend to hold on to these bikes instead of abandonning them.
    That is one of the reasons why I bought a Titanium hoggar ;)
    But, again, there is nothing wrong with steel, it is cheep, can be welded in open air, and if you protect it well it lasts its time.The overal weight of a fatbike does not really suffer a lot from a pound extra on the frame, it's the parts that makes it heavy!
  • 08-27-2012
    ozzybmx
    Even more so the wheels ! Careful choice of rims, tubes, tyres and rims strips can drop 3kg (6.5lb) off a fatbike.
  • 08-27-2012
    Sorry Oz, I considered the rolling parts under parts!
    I guess that you did the math with the 25lbs fatbike!
    I am not into weight weenie world anymore, but I can imagine that 25 lbs will be even more difficult based on a steel frame!
  • 08-27-2012
    ozzybmx
    It most definately all adds up. If you want to build light without sacrificing the bikes capabilities theres a load of thought to go into it.
    Brakes are a big one, losing weight from a 1200g set of BB7's to a lighter set of hydro brakes that will stop a big wheeled bike - you cant weenie on good brakes and rotors but you can shave a 1lb+ off easily.
    Cranks are another big weight dropper, i came from being a singlespeeder so having 10 gear is like heaven so 1 x 10 was a no brainer, saved the weight of a front mech, shifter and 1 or 2 chainrings.
