Results 1 to 84 of 84
    Reputation: SundayRiverRider's Avatar
    Small 65mm rim vs Medium 80mm rim vs 100mm rim and tire sizes/profiles.
    What are you running and why? It's probably the most confusing thing about fat bikes aside from hub standards and q factors, lol.
    The wheelset on my bike is rather heavy compared to something like a Sun Ringle Mule. I am thinking I might like to build up a second lighter set of wheels with the Sun Ringle rims. I'm just not sure if it's worth it and what tires I'd run on them.
    I'd like to discuss the ramifications of tire sizes and profiles when they are mounted on the different rims. Is it better to have a wider area of contact or is better to have a rounder tire profile with more cushioning?
    I've seen some of you recommend 65mm and big 4" plus tires. I've seen some you recommend two 100mm rims and the biggest tires 4.8". I've seen some recommend 80mm rims and 4" inch tires.
    I'd like to discuss things like would you get less rim strikes and pinch flats running 65mm and big tires vs 100mm and big tires. Or do the tires behave differently depending on the rim size you choose? Does 100mm front and rear and big tires "definitively" provide the best float in snow? Should you run a bigger rim up front and maybe run a smaller rim in the back to save weight and hopefully not lose any float?
    Should you run different tire sizes in the front and back? Are smaller 65" inch rims definitely better for dirt riding? Or is the 80mm rim size a true happy medium and best for most fat bike riders?
    I'd like to hear what people have chosen for their bikes and why. Would you have 2 sets of wheels if you could with different tires for winter riding and summer riding?
    I'll start. I will mostly (90% of time) ride my fatty in the winter on packed/semi packed trials so I set up a 100mm front and an 80mm rear both using On One Floaters and Specialized 3" tubes, I don't feel like dealing with tubeless. I thought the front wheel at 100mm might help push through the snow and I'm hoping the rear wheel can provide enough float on 4" tires. I don't think my bike could handle a 100mm wheel in the back, and I could probably only fit a max of 4.6" tire in back anyways. I was also thinking the medium 4" tires would be lighter than the 4.8 size so it might be easier to pedal in the snow. I could be totally wrong with my theory and I may have to increase the tire size on both rims for better float in the snow. We'll see. I won't be able to really test my theory until December probably.
    Thanks for your thoughts regarding this post.
    Reputation: brankulo's Avatar
    Aug 2005
    i have 90mm rims and plan on using as big of a tires as i could fit. just for riding during winter. i plan on getting 50mm 29" rims with 3" or so tires for summer when i will be using the bike for bikepacking. i have full for rest of my riding needs.
    Maine year round. 65 mm marge lites with knards for non snow. Nates for snow. One nice light set of wheels.
    No fuss.
    rog
    aka bOb
    Reputation: bdundee's Avatar
    90mm rims and 4.6 tires year round in WI. Might build up a set of carbon 65's with Jumbo Jims for next summer but I doubt it.
    My bike is setup with 100mm CS front, 80mm HRD rear. I run 4.8" Bud and Lou in the soft snow, 3.8" Dillinger when its packed and icey, 3.8" Knards in the dirt. I like as much float as possible in the snow for exploring and bike packing. 3.8" tires work on the 100mm front but the profile flattens out some.
    wjh
    wjh is offline
    Feb 2012
    I built my 907 with clownshoes, hudu rear tire, and a big fat larry on the front. I didnt know any better, and clownshoes were all that i could get at the time. I rode it with this setup for winter, spring, summer and fall, before coming to the conclusion that it was too heavy and slow. 95% of my winter riding is packed snow so flotation isnt much of an issue.
    I lost my shirt selling the clownshoes, the bfl, and getting marge lites and laced up. I bought another 120 tpi hudu for the front, and 2.5 bontrager tubes in place of the heavy surly tubes. The decrease in rolling resistance with the lighter tire/wheel combo was huge.
    Shortly after i wanted more traction so i added a bud front and a nate rear. This is a great combo for wet fall, winter, and spring mud traction. When things dry up, i go back to the hudu tires.
    I have recently added the bluto and i now declare this bike perfect for my needs. I sold my fs trek and never miss it
    Quote Originally Posted by newmarketrog View Post
    No fuss.
    rog
    I do like your one wheelset does it all approach. 65mm year round and your OK in Maine eh? i hadn't really considered going smaller than 80mm. But if you can run 4.5" tires on the 65mm then that might work for me too. Interesting.
    I run bud/lous on 65mm's with no issues in deep snow - however I am considering going to an 80mm front with the 65mm rear
    Quote Originally Posted by wjh View Post
    Interesting, another vote for Marge Lite's. I will use my fat bike on packed trails most of the time, I doubt I will go anywhere deep in the woods and untracked. Also, it is fascinating that you ditched your FS bike. I'm going to have try the fatty on my local trail networks before I even think of selling the FS bike. I love FS. I could see getting a FS fatty in a few seasons.
    wjh
    wjh is offline
    Feb 2012
    My rear suspension now consists of a squishy rear tire, canecreek thudbuster, and a brooks saddle.
    Quote Originally Posted by SundayRiverRider View Post
    You can run 4.8" tires on 65mm. Thats the beauty of it. With either 3.8 or 4.8 you get a nice round tire profile which makes for much better cornering/handling than 80mm and less chance of pinch flatting with 65 vs 80 at same air pressure. Better bb crank/ bb clearance from a taller tire height as well. Wins everywhere you look.
    Ok in maine
    Rog
    Sep 2014
    I think to help your analysis of what does and does not work you need one more variable, rider/bike weight.
    A smaller combo on a 145# rider like me will behave much different on a 200# rider.
    On the road I use 100 psi front and rear and my tire has a small amount of squish, my brother uses the same tire but to get that same amount of squish he needs around 130# in his tires, he has 60# on me.
    Feb 2014
    Nates on HRDs. I'm going to try to showhorn a Bud on the front this winter, when things get sloppy.
    2012 Surly Black-Ops
    Aug 2014
    I thought the point of a fatter rim was to spread the carcass wider so that air pressure had less to do with the width of the tire? That and doesn't the most rigid sidewall support come from approaching a 90 degree angle from the rim?
    I somehow see the tread going concave at low pressures, where the rubber meets the trail, when the sidewall(s) profile is too trapezoidal. I derive this from tire wear patterns on autos when they see a lifetime of under inflation.
    I would have expected the fat tire on the skinny rim to perform like a flacid you know what. Turns me on my head it does.
    With all that said I do not know....
    turtles make me hot
    Reputation: NYrr496's Avatar
    I've told this story before, but you're askin'...
    When I built my fatbike last winter, I had to have the biggest, fattest wheels... after all, I'm the wheel guy.
    The guy I work for has vast fatbike experience and tried to talk me into Darryls but I wasn't having it. Clownshoes or nothing. So I laced up Clownshoes and installed Bud and Lou. I almost gave myself a heart attack riding this monster on the beach.
    I've since ridden bikes with Marge-HuskerDu combos and Darryl-Bud/Lou. Even a Moonlander with BFlarrys.
    Now, the plan is building Darryls for my Bud Lou combo and BF Larrys on my Clownshoes for the beach.
    I couldn't believe how fast and fun a Marge HuskerDu bike can be.
    I like turtles
    Quote Originally Posted by NYrr496 View Post
    I couldn't believe how fast and fun a Marge HuskerDu bike can me.
    with marge lites and 3.8 120tpi knards i have no trouble keeping up with fit, technically strong riders on the latest greatest 120-140mm carbon full sussy 650/29er bikes thru the rough and techy with climbs and descents of a mile or more on my fully rigid steel charge cooker maxi.
    the wheel/tire combo makes such a difference.
    rog
    bigger than you.
    Reputation: Gigantic's Avatar
    Marge lites and Vee snowshoes. I have no trouble keeping up with xc racers; I'm taking it cx racing this weekend.
    So, if the marge lites work so well ( especially with big tires) what is the reasoning behind the popularity of 100mm rims? Does the 100mm rim provide a much larger contact area with a big tire vs the Marge' s contact area with the same tire? You guys running the 65's really notice that big of a difference in rolling resistance and overall bike quickness?
    100mm spreads the tire wider but also decreases the height. the increased width obviously provides more float in soft sand and snow. yes i notice a huge difference in rolling resistance, handling precision, and quickness/flickability with the 65's vs the 80's they replaced.
    rog
    OP, you have to remember that the conditions ridden, and rider weight play a hugh part in what wheel/tire combo would be best. I live in Wisconsin, am 230lbs w/o gear, and if I only wanted to ride groomed/packed trails in the winter, I wouldn't be doing much riding. I ride RD w/ Hudu/Knard in the summer, and RD w/ Bud/Nate in the winter.
    It's not a matter of WANTING a fatter setup, its a matter of NEEDING a fatter setup. Airing down Bud and Lou on Marge Lites for float with be VERY different than Clownshoes, with respects to tire profile and squirm. There are numerous times when I am airing down to 3-4psi (tubeless), to get the float and traction I need in SNOW!.
    Be carefull when a rider claims he can keep up with REALLY GOOD riders on FS bikes bombing down hill, as either he is full of it, or his buddies aren't as great as HE thinks they are. Fat bikes will not offer the control or performance of a FS bike (unless you are referring to a XC race FS bike, which might be a different story) when the going gets rough.
    bigger than you.
    You understand the correlation between lifted 4x4 trucks and male genital insecurity?
    Seriously, the 65mm rims are noticeably faster & lighter. In the winter, there is a tradeoff in floatation in the snow. I'm a very large rider, I would probably benefit from the wider contact patch of hundos and bud/lou, but in all honesty the smaller rims work just fine in the winter and the difference they make in speed and handling for the other 8 months of the year makes the compromise more than worthwhile to me. Ymmv.
    I'm weigh 175 lbs and I'm probably not going to be packing all sorts of gear on my bike.
    I'm probably just going to ride from my house down the street 1/2 mile to this huge network of snowmobile trails and just ride around for an hour or 2. Just using the bike to get some winter exercise and have something to do when the conditions at the mountain are cruddy and I don't feel like snowboarding. I am not going to be bike packing with the thing and probably won't race it either. I may use it in the summer a little bit, we'll see.
    I just find it interesting to hear everyone's thoughts and what their experiences have been using different rim options. I appreciate all the feedback.
    I can see where people really like to Monster Truck their fat bikes, it's interesting to see people that have Speed Racer their's out , and to see the people that have their fatty's set up to travel across the Sahara desert or the frozen tundras of Alaska.
    It seems like I may benefit from the 65mm rims as it might not affect the ride negatively too much in the winter, and in the summer the bike might have a quicker feel to it which would be a positive.
    Thanks for starting this thread, the replies really have put things into perspective. I read a comment earlier today by someone that recently purchased a fat bike, has not ridden it in snow yet and is looking at upgrading to wider rims and tires. The reason to go fatter for some people is just because.
    I left out that i'm 165/170 and use bottles and repair items/snacks in jersey pockets. No camelback for this guy. So i keep things light.
    We ride about the same length rides in winter 1-2 hours and i only ride if the surfs not good. So if the surfs good for 2-3 weeks straight, i don't touch my bike at all. When there's no surf i ride pretty much every day.
    My fatty is my only mtb, so having it quick for trail is paramount.
    Do you live up by sunday river?
    rog
    Reputation: Welnic's Avatar
    Feb 2013
    The main advantage of wider rims with any bike tire and rim combination isn't that the contact patch gets bigger with the wider rim at the same pressure, it is that you can run a lower pressure with the wider rim and it will work. Depending on the tire carcass you might get a bigger contact patch at the same pressure with a wider rim, but usually you have to run a lower pressure to get a bigger contact patch. The wider rim will allow you run a lower pressure without the tire feeling squirrelly.
    The advantages of 65s in the summer are lighter weight, better tire shape for most tires, and the rim is protected better from rim strikes.
    Quote Originally Posted by Welnic View Post
    Ya, and thats vs running the same pressure as with wider rims. So what say you again?
    I was getting a pinch flat a week running the same pressure in my 80's as i am my 65's and have had ZERO pinch flats with my 65's in two months.
    rog
    I like the concept of less pinch flats the most. I generally don't flat much on my bike right now, but I run burlier bigger and heavier tires. I find they deal with the rocks betters. Lighter weight with the 65's would be an added bonus, but I'm not a weight weenie.
    Rog, I own a house right in the Village of Bethel, I spend a lot of time there.
    Right on. I lived in bethel from 93-2000 winters and 95-96 year round. Great area. Did a super fun ride up around there on the fatty this summer.
    rog
    Dec 2008
    907 offset: marge lites w/ vee h-billie front / snow shoe rear
    907 190mm: clown shoes w/ bud and lou
    The lighter wheeled bike see's a lot more use that the 4.8" bike. 4.8" bike is mostly for tough conditions like after a fresh snow fall or after a flood when the trail is super soft and sandy for miles and miles. 4.8's are slow, but they go through much more than the 3.8's can.
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    If we are talking snow, rim width, tire width, and tire pressure can often make the difference between walking and riding if not riding on groomed trails. Jay P told a bunch of bikers a night ago that he didn't feel the need for 100mm rims and 4.8" tires. But what he didn't mention is that he lives in an area that has a HUGE amount of nearly always perfectly groomed trails that go for hundred's of miles and a ski area that has one of the most pristine nordic tracks where fat bikes can be ridden. If those are your conditions, I would agree. If you live where you have to keep your own trails groomed by riding them and you get much snow, or even if there is a lot of new snow on those groomed tracks, or if the temps are above freezing much, the wider tires and rims will help tremendously.
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    snip..........
    Girdwood Alaska, mix of tarmac, dirt and snow year round use. 2013 Fatback 170 non-rocker. Started with Uma 70s on Larry's. (summer and winter) Then Velocity Dually's 44mm (Summer with 4.0 HuDu) Uma 90's (Winter soon to be Dillinger 5) all tubeless with the inner city method.
    Why two sets of wheels? b/c it is my only bike, and I'm thinking of adding a 3rd set of 29+ for longer summer tours.
    Reputation: blockphi's Avatar
    Mar 2012
    No fuss.
    rog
    Alaska, year round daily rider. Had 65 standard Marge for 2.5 years. Rolled Nates in winter, Knard/Larry/Endo combo of some sort or another in summer. I'm now on 80 with the Hodag tires (new Farley) and we'll see how it goes. I opted for the Farley over something like the Fatboy specifically because I didn't want to be dragging a 5 inch tire on my commutes every day. I've also found that 99% of the riding I do wouldn't need that big of a tire. Yes, I ride off-piste, but found that, for me and my mass (280 range last winter) that a 5 inch tire doesn't provide that much more float than a 4 on powder and heavy wet snow just sucks regardless.
    I do plan on building a 29 wheelset for the summers for the Farley.
    Reputation: schnee's Avatar
    Quote Originally Posted by blockphi View Post
    Huh, we're the same weight class and you're making me think.
    I'm getting a 9:ZERO:7, the new one with 190mm clearance. I could totally go with clown shoes / 5" tires, and I was thinking due to my size I might want to go there, but I'm thinking again.
    I'm going to be mostly riding winters in southern Sweden. Stockholm is so well-maintained during snow that I could get away with studded tires on my road bike and be fine for all my city riding. I'll mostly be riding gravel bike trails and some local MTB paths on Hellas, and that is pretty tree-covered in most places so it won't ever be deep snow.
    I might want to go 65mm/4" or 80mm/5" instead.
    Yes, I'm probably over-thinking this, but fat bike stuff is HARD to get in Sweden so the penalties for choosing wrong are much bigger than in the 'states.
    Reputation: letitsnow's Avatar
    I'm not sure if this adds anything to this thread, but my wife and I bought fatbikes at the same time. Me a Mukluk, her a Pugsley. They both came with the same tires, but her bike had Marge lites, mine Daryls. Her Pugsley seemed to handle much better than my Mukluk, even though the Mukluk was lighter. I found a used set of Marge Lites and put them on the Mukluk-much better!
    After talking to some of the fast fat bike racers - they also told me that rims wider than 65mm's isn't ideal unless running Bud/Lou's...
    Quote Originally Posted by letitsnow View Post
    As some of my past posts would indicate, I'm not a fan of 100's and Bud Lou for everyday riding but the above generalization is just as bad. At least in Anchorage, by far the majority of winter riding is done on 80mm rims and nominal 4" tires. To pick one width or tire size and say it is best for everyone is just not correct. They all have their place and they all have places where they are less appropriate. People need to look at what type of surface they are riding most often and what type of riding they do and pick for that. And for what it's worth snow is not a single surface type. OK rant over
    Latitude 61
    Quote Originally Posted by sryanak View Post
    Generalization? I was telling about an actual experience.
    turtles make me hot
    I actually like riding hundreds and Bud and Lou for regular trail riding.
    I like turtles
    I guess I was responding to the statement that rims wider than 65mm are not ideal for anything but Bud and Lou. In my experience backed up by riding with many other people that is not true as a general statement. It can be true for a specific set of conditions, but not for everything. As to your specific experience with your two bikes, I don't doubt that is what you found for the conditions you were using them in but it is still a generalization to say Marge Lites are better without telling people what those conditions were. If we are talking about hardpacked and narrow twisty trails I completely agree with you that the 65mm rims, and even narrower, do handle better. However as the surface gets softer, for me at least, wider is better. Obviously what works for me doesn't work for everybody but I would hope that when people say what works best for them they also say in what conditions they ride.
    Latitude 61
    turtles make me hot
    One of my friends rides Darryls with 4" HuskerDus. It seems to work on all conditions for him. He weighs about 170.
    I like turtles
    Reputation: smthgfshy's Avatar
    To keep my cost down I run 1 wheelset year round changing the tires only.
    summer: 70mm UmaII's w/ HuskerDu's front and rear
    winter: 70mm UmaII's w/ Dillenger 4 & 5's
    from what I've seen/heard in Anchorage, wider is better the softer it gets. Also, wider is better the heavier you get. If I had more money I'd build up 2 wheelsets, 1 for summer w/ Rabbit Holes/Knards, and 1 for winter w/90mm carbon and Dillengers. My only bike is a fatbike and I ride it year round in AK. Most if not all rim & tire combo's are possible. Just find what you like as it fits with your size, the conditions you ride, and how you ride your bike. There is no right answer.
    OK, since this thread seems to have died, I'm gonna hijack it a bit.
    I'm 275.
    For my riding, I'll mostly crunch through shallow snow, and possibly bike pack or ride techie rocky single track. I have a RIP9 and EMD9 for other riding.
    I'm thinking 80mm is the best compromise that will get me the same tire behavior as you lighter folks do with 65mm. (I usually have to go one spec up, so wider tires, tougher components, stuff like that.)
    Start with Nates for winter, maybe Husker Du for summer, Bud/Lou if I go crazy and explore lapland or Iceland. The one rim should handle all of those OK.
    Thoughts?
    whether yer 10lbs or 275lbs, tire profile is tire profile. nothing wrong with 80mm and 3.8, just not as fun as 65mm and 3.8, imo.
    i rode 80mm and 4.0 all winter/spring and i smiled the whole time.
    go 4.8 on 80 if you want a nice combo of good floatation/handling.
    rog
    turtles make me hot
    82mm rims are great all around rims.
    I like turtles
    Thanks! It helps a lot.
    Lord Thunderbottom
    Reputation: TitanofChaos's Avatar
    I'm 250# I've never run a rim wider than 65s and 70s, I do swap from 3.8's to 4.7" tires for winter and have had to air down under 5 psi where I can see a wider rim being better but the times that I ride something that unpacked are few and far between
    city streets and sidewalks rarely get a ton of snow buildup here in WI, we groom our local MTB trails for winter riding (the snowshoers love us) and the lake michigan beach snow fluctuates so much day to day it's crazy
    only twice in the last 3 years have I turned around because we couldn't ride, then we snowshoed ourselves so the trail was good to go for the next ride
    Today I will do what others won't, so tomorrow I can do what others can't
    Aug 2014
    So I have 80mm rims with 4.0 vanhelgas and the rear tire sits about an 1/8 of an inch from the chain and when I lean non drive side over it will actually lightly rub. I didn't have this problem when I had the 4.0 fee mission tires would going to a 65mm wide rim in the rear fix this issue as I would like to keep the aggressive tread.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Yes. that would most likely fix it. Tightening your spoke tension might be worth it too.
    Don't know your bike specs but maybe you can shim your driving crank.
    Quote Originally Posted by Upinflames7 View Post
    Aug 2014
    the cranks are square taper so not sure tgat i can shim them
    Aug 2014
    not sure what spoke tension has to do with the chain hitting as it is just gravity working not wheel flex as I can just stand and lean the bike over and the chain touches the tire
    Aug 2014
    170mm rear spacing on my frame just wondering if a more narrow rim will change the tire profile enough to fit without rubbing
    That's why, but yes, a 65mm rim will most likely let your tire fit without rub if you get 1/8" of clearance currently.
    I would also highly recommend a clutch-type derailleur, that also significantly cuts down on chain-slap and any rub that results from it. You can run really close to the tire with this type of derailleur with no problems (where with an older or non-clutch design you can't, it will eat-through)
    Aug 2014
    I do plan on upgrading the rear mech but still would like more clearance as a lot of crap gets tossed into the chain by it being so near the tire
    Jan 2014
    I don't know if this will help, but my 3.8" 27 tpi Surly Larrys mounted on Marge Lites measure only 3 9/16" (3.56") wide at 10 lbs of pressure. Larry got up to 3 5/8" wide at 20 lbs of pressure.
    On the same Marge Lites, my new 60 tpi 4" Halo Nanuks at 10 lbs of pressure, measure just 3.5" wide. At 20 lbs, they were about 3 17/32"+ (or, not quite 3 9/16") wide.
    These #s using a good old analog sliding caliper.
    Reputation: FatBike&SlenderWoman's Avatar
    Apr 2016
    I tend to lean towards the wider side. My formula is tire size in inches * 20 = target rim width in mm.
    4.8" on 100mm rim, 4" tire on 80mm, 3" tire on a 50-65mm etc.
    For summer, I am running a 26x3.5 on a 100mm CS because that is the biggest slick I can find...a little oversteer on hard turns but fast on pavement and great traction while commuting through woods.
    I am searching for a 3.5-4.0" road tire that I could run tubeless on a 27.5x80mm rim or a 3.0 on a 29x65mm rim and save Bud & Lou and the 100mm CS for heavy snow.
    N8R
    N8R is offline
    A wider rim doesn't necessarily give a wider tire contact patch like most people think it does. I used to run 100mm with 4" tires because I thought it did, but then I measured the imprint width in the sand of 4" tires on 100mm and 80mm rims. At around 5 psi, they were the exact same width. The tread width stays the same.
    The tires on 100mm rims look wider because the sidewall is further out but the side wall doesn't contact the ground in normal riding pressures so your not gaining any additional float unless your tire is sinking in up to the sidewalls and if its sunk that deep in the terrain resistance will be so high you're probably better off walking.
    IMO, rims wider than 65mm offer no real advantage for non-snow riding and are just extra weight, and a give a terrible tire profile. I went from 100mm to 80mm rims, and even the 80mm rim profile on a 4" tire is not very good, so I'm going to 60mm rims.
    For winter I'll run 4.8 tires on 60mm rims and 4" tires on the 60's for the other 3 seasons.
    Quote Originally Posted by N8R View Post
    Exactly what I do. Bud / Bud on 65 for winter and Jumbo Jim's 4.0 on 65 for summer. Couldn't be happier and works for my all season riding here in Michigan.
    Jul 2013
    is there any 65mm rims aluminium and tubless ? now i am no dt 710 but thinking about 65mm rims
    Quote Originally Posted by cka3o4nuk View Post
    Marge lites are aluminum and I'm pretty sure I've seen people make them tubeless relatively easy through a few different methods.
    Sent from my Nexus 6 using Tapatalk
    Apr 2016
    I wish that they made a Marge Lite in a 29+...a 65mm wide Rabbit Hole.
    Apr 2016
    The main advantage of wider rims with any bike tire and rim combination isn't that the contact patch gets bigger with the wider rim at the same pressure, it is that you can run a lower pressure with the wider rim and it will work. ...
    Welnic speaks the truth!
    Weight / psi = size of contact patch
    If you have a 170 lb rider on a 30 lb bike, that equals 200 lbs. So if the tires are inflated to 10psi...
    200 lb / 10psi = 20 sq in of rubber touching the ground. Drop the pressure to 5psi and you end up with a 40 sq in contact patch. Makes no difference if the tire is a 29 x 3 or a 26 x 5, as long as there is enough pressure to keep the rim airborne, the contact patch is the same size.
    A larger tire will have a wider contact patch with less lengthwise flattening of the tread when compared to a smaller tire.
    Likewise, the air pressure on the inside surface of the rim is what supports the bike, so the amount of sidewall deformation is a direct product of rim size both in circumference and width. A tire mounted on a 50mm wide rim will have twice the sidewall deformation as that same tire mounted on a 100mm rim at the same pressure. That means that that a BFL can run at half the pressure on a 100mm rim without burping or bottoming out than what would be possible on a 50mm.
    Same thing with rim diameter, a 26 rim needs 11% more pressure to keep the rim airborne as opposed to a 29+ of the same width. So the sidewall deformation of a 29+ running at 10psi is the equivalent of as a 26 running at 11psi but because the 29+ is at a lower pressure, it will have more rubber on the ground.
    Bottom line, if you are running on soft surfaces, a larger rim will allow you to have a larger contact patch without bottoming out but the trade off is that it comes at the expense of additional rotating mass.
    Reputation: mschafer's Avatar
    Jun 2015
    I built up a Borealis Echo with DTswiss BR710 rims, 80mm, running tubeless Bud and Lou 4.8". I'm around 190lbs and ride mostly undulated terrain and the beach along with some snow trails. Reason for this is broad application, i can run the tires well inflated for quicker runs in the summer and on harder surfaces with still a nice grip once its gets slippery and enough flotation for the occasional sand patches that i encounter at the east end of Long Island. When i want to take the rig on the beach i just deflate severely and im good to go. The other day i did a ride when i expected and harder packed surface, but 2 min in i noticed it's all loose sand, so deflation and i was ready to go (for the most part). I ended up on a harder packed beach with some soft patches and all was good. Sometimes i wish for a 29" setup for summer harder and quicker trail runs, but they are only a few, i'm happy with my setup. Maybe Jumbo Jim is my future...
    Reputation: edved37's Avatar
    Dec 2014
    I currently own a Salsa Blackborow with 100mm Clown shoes, while its great in the snow it is slow as molasses compared to my Jones in the summer. Thinking if I find a set of Marge Lites or even 80mm wheels I'll be much happier in the dry months. Oh and I only weight 145# so I really don't need the wide wheels I don't think.
    Beargrease NX1
    Nature Boy 853
    Niner SIR9
    Feb 2013
    Quote Originally Posted by edved37 View Post
    I don't think it would be a huge difference to drop to a 65mm rim if you are still running 4.8" tires. And if you go to smaller tires the bottom bracket will drop. If you are going to get a new wheelset anyway I would try 27.5"x3.8" or 29"x3".
    Dec 2014
    I would run a 3.8 tire most likely which along with he 65mm rim should drop 3-5 lbs off what I'm running now I would think and the blackborow has a higher bottom bracket so I didn't think the drop would effect it too much, but I could be wrong.
    Beargrease NX1
    Nature Boy 853
    Niner SIR9
    Feb 2013
    Going to 3.8" with the 65mm rim will be a big difference. You should just put the 3.8" tires you are going to use on your 100mm rims and see what you think. You won't be able to get as rowdy with the 100mm as the rims won't be that well protected, but it should give you a good feel for the bottom bracket height. Rim width doesn't affect tire diameter very much.
  67. #67
    May 2015
    Love this forum! I had a concern on building up a summer wheelset and low and behold, after a google search I find this thread. So, my question to you all... I'd like to build a 65mm wheelset to use with 4" tires for summer trail riding. Currently have 100mm clownshoes on 4.8 JJ's. Will there be a significant difference in diameter?? Any help would be appreciated.
  68. #68
    turtles make me hot
    Yeah. They'll be smaller. I can take a picture when I get home. I happen to have one bike with 65mm rims and 4" tires and another with 100mm rims and 4.8" tires.
    The little ones look anemic in comparison.
    If you want diameter, build a pair of 29+ wheels for summer. Almost exactly the same as 4.8" tires in height. My son doesn't even want his Marge Lites and Huskerdus any more. He likes his 29+ so much he asked for Darryls and 4.8" tires for fat.
    I like turtles
  69. #69
    Apr 2016
    Quote Originally Posted by Branner View Post
    ...I'd like to build a 65mm wheelset to use with 4" tires ...Will there be a significant difference in diameter?
    If the tires stay the same, there will be no difference in diameter.
    All other things being equal, the differences are threefold:
    A narrow rim will reduce rolling mass while increasing casing flex which will result in a softer ride at the expense of handling and load capacity. A narrow rim also reduces exposure to rim and casing damage due to terrain hazards.
    I wider rim spreads out the casing, reducing flex which increases the load capacity allowing one to gain a larger footprint by running at lower tire pressures. This comes at the expense of added rotating mass but is usually preferable on soft surfaces such as sand and snow.
    It has been my experience that 3.5-4.0" tires on 100mm rims exhibit significant self-steer when ridden on hard surfaces. Self-steer is reduced on rims with less than 80mm inner bead-bead width.
    ...If you want diameter, build a pair of 29+ wheels for summer. Almost exactly the same as 4.8" tires in height...
    Mega dittos! A 29+ wheelset will be lighter while maintaining the same diameter and pedal clearance.
    The diameter of a 3.0 x 29 Knard is identical to a 4.8 x 26 Bud but the effect on the bike is akin to turning a Hummer into a Mustang.
    (see link below)
  70. #70
    Apr 2016
    ...I measured the imprint width in the sand of 4" tires on 100mm and 80mm rims. At around 5 psi, they were the exact same width. The tread width stays the same...
    True, weight of bike - tire psi = contact patch in sq in. So if you maintain the same tire pressure, the contact patch area will be the same regardless of rims or tires.
    A 100mm rim has 20% more load capacity than an 80mm, so the load capacity and rolling resistance of a tire running 5psi on an 80mm rim is equivalent to the same tire at 4psi on a 100mm rim.
    If you are riding on firmer surfaces at higher pressures, the narrow rim has the weight advantage.
  71. #71
    Quote Originally Posted by FatBike&SlenderWoman View Post
    Except you deleted the part where he said he was using 4.8" tires now, so not likely for him that the diameter will stay the same after the switch to narrower rims and smaller tires.
    It would be helpful to know what the new tire will be.
    Latitude 61
  72. #72
    Apr 2016
    ...It would be helpful to know what the new tire will be.
    Agreed, my point was that tire diameter is determined by tire size and is not affected by rim width. A Vee Apache Fattyslick or a 29+ wheelset would be the answer for someone looking for lighter, faster summer wheels while maintaining the same diameter and ride height.
  73. #73
    May 2015
    Sry & FBSW: Here's more info.. My bike is a 2016 Salsa Blackborow, size medium. Currently running clownshoes on 4.8" JJ's. I want to run a 65mm with either a 4" or 4.4" JJ for summer riding along with a suspension fork. I tried a 29+ bike and didn't like it. I like the confidence I get from the fat tires and want a fun, sporty ride for the summer. I'm 99% sure that's the direction I'll be heading.
  74. #74
    Apr 2016
    Like you, I ride a 2016 Blackborow with Bud, Lou and/or JJ 5's tubeless on Clown Shoes.
    In March, at the end of snow season, I installed a set of 3.5 x 26 Vee Speedsters on the Clown Shoes for added speed and to avoid trashing the expensive knobby tires when riding on pavement and dry trails.
    With the smaller diameter tires, it soon became evident that the stock 39-11 top ratio was not tall enough for running on pavement.
    With the 1" lower ride height, pedal strikes also became an issue when riding off road on rough terrain and climbing stairs.
    So, I bit the bullet and laced up a 29+ NoTubes Hugo wheelset that is the same diameter as the 26" fatties which has enabled me to run with the road bikes on the summer rides.
    (You can click this link for details and photos)
    Notubes Hugo 52mm Rim
    I like the confidence I get from the fat tires...
    As I eluded to above, running a lighter, faster wheel that is smaller in diameter seems counter productive to me.
    If you want to stick with the 4" tires, I would suggest doing a 27.5 wheelset. That way, you would maintain close to the same ride height and gear inches.
    (see link below to compare tires and rims)
  75. #75
    Aug 2016
    Bud and Lou tubed / 100mm Clownshoes on a Fatboy Trail Pro with Bluto. About 1/4" clearance front and rear. I weigh 210 lbs.
    The whole setup works fine but barely. If I went tubeless or got rowdy in gnarly stuff I'd probably have at least a little tire rub going on.
  76. #76
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I used to run rolling Daryl's on my old 907.
    I swapped to a Marge lite up front, and now 65mm nextie on my bucksaw.
    Overall the 65mm runs are better for everything.
  77. #77
    Oct 2012
    I have some experience on 3 setups from 80-90 mm rims and 3.8 to 4.6 tires, and my riding weight is 210ish. The softer the terrain, the better a wider the rim is. The said, tread design and psi usually makes a bigger difference.
    I think you will get the best all around with an 80mm rim and then an appropriate tread for the terrain. Going extreme doesn't yield you that much more riding capability, that is fun anyways. Going 100mm rims with 5.0 tires might get you out another day or two. If all you do is ride sugar sand dunes, then that would be awesome. Like all things, if you have a specific use in mind, the best solution usually means giving up some function elsewhere.
    This winter I plan to pick up some Bud and Lou's to put on my 80mm rims...... I will run the Kendas until we have snow. Studded CX bike for when it's icey, which is most of the time
  78. #78
    I've had bikes where the tire rubbed the chainstays under power and tightening the spokes helped. So with little clearance, these things become more critical.
  79. #79
    Reputation: Erock503's Avatar
    Oct 2014
    I'm really liking my 80mm rims with JJ 4.0/4.8, but I don't have anything to compare them against as far as fatbikes. My experience has been limited to riding my friends fatboy a few times.
    I want to build a new set of carbon wheels, basically just to save some weight, but now I'm very torn on what to build. I was planning to get 80mm carbon, but the Nextie 90mm have caught my eye. Love the looks of the snow dragon. Problem is I don't really want to change how the bike rides, just save some weight. I bought the bike originally for snow, but it's too much fun on dirt to be only for snow. Will there be a significant difference going from 80mm to 90mm with 4.0/4.8 tires? I don't want/need the tires any wider.
    Now, tHis thread has me thinking about 65mm rims. Would the 65mm perform well with 4.0/4.8 tires? I already have 2 new sets of tires in those sizes, so I don't really want to get more. I have a couple nice bikes for summer riding, but I have a feeling I'll be riding the fatty a lot in the summer now. 155lbs with gear.
  80. #80
    Sep 2014
    Nice Rog....still wanna ride with you someday on one of your "rest" days....
  81. #81
    Reputation: Weinerts's Avatar
    Not to pick at an old thread..
    I have 80mm rims...
    But I have been riding 99% in the dirt (only1 snow trip this year) and I have been Bud front and Nate rear for the last two years - Bud Finally stopped holding air tubeless (I have to scrape a lot of goo out of that thing) so I put on a pair of (Framed) 4.0s until I have time to get it done.. My bike is named the Nimble Beast (Necromancer - Pugs)- and now I remember why - with a smaller font the bike handles much better - I do not have the adventure level traction but it is way more lively on the trail..
    I miss the grin and point my bike where I want to go feel of the Bud - I went from the Jetty in South Mission Beach CA to Tourmaline Beach (about 6 miles each way) and back in the soft sand two weeks ago for a workout... I made it... and it was a workout!!
    I guess I need a moonlander and my pugs...
    My bike is heavier than yours - it does not have Carbon or Titanium parts - I love it!
  82. #82
    turtles make me hot
    Since the last time I participated in this thread, I built up a set of My Other Brother Darryls for my regular fat bike. They are about 200 grams lighter apiece than the Clownshoes they replaced and since they're 20mm narrower, they altered the tire profile slightly. Bike feels so much better and faster.
    Plus, they set up tubeless without split tube, so further weight loss.
    Total win.
    I like turtles
  83. #83
    Reputation: foresterLV's Avatar
    Dec 2016
    I think this is pretty simple with fat bikes: most if not all original/OEM wheels are heavy alu ones, much worse then carbon alternatives. Going from alu to carbon will be good independently of rim width, weight saving will be (relatively) brutal along with increase in stiffness. There are very few alu rims that can compete with carbon IMO, maybe DT swiss 80mm alu thing can come close to 100mm double-walled carbon (in weight, not in stiffness I suppose), all others are much worse. Branded carbon wheels cost is absurd at this point (IMO), BUT we got chinese carbon "phenomena" situation, where carbon wheels from china can cost less then branded alu.
    So generally if you want to get fast fat bike the first thing to do is to drop original wheels and get carbons, chinese ones to be cost effective. And the width choise is secondary at this point.
    And going down to specifics, basically what chinede carbon players offer, Nextie got some new (?) single-wall (meaning tubeless with no tape) 85mm rims, which are about 500gr each, pair them with lightweight/sturdy DT Swiss hubs, and thats it... 85mm is the best. Because you can get them cheap (well, relatively) and light.
    Sent from my SM-G900F
  84. #84
    bigger than you.
    Quote Originally Posted by Weinerts View Post
    I have 80mm rims...
    Since I last posted in this thread advocating for 65mm rims, I've since built up a new bike using 27.5 x i45mm rims. It's faster in nearly every sense and performs better in most of the conditions that I encounter. I don't see much snow, though; I'm about to ride in 5 inches of slush in a little bit. At my size, flotation is out of the question and I've found that 27.5x3.8 Bontrager Hodags do just fine most of the time, even in the snow.
  1. Replies: 15
    Last Post: 08-16-2014, 08:30 PM
  2. 80mm or 100mm on my NS Suburban?
    By bicyclemech1 in forum Urban/DJ/Park
    Last Post: 03-31-2012, 10:35 PM
  3. Replies: 6
    Last Post: 05-04-2011, 11:42 AM
  4. 80mm or 100mm on Pro 29?
    By MavAndy in forum 29er Bikes
    Last Post: 04-19-2011, 04:15 AM
  5. Going from 100mm to 80mm......
    By MiWolverine in forum Shocks and Suspension
    Last Post: 01-19-2011, 05:29 AM
Members who have read this thread: 45
