Results 1 to 16 of 16
    SCRUBDUNKER
    Reputation: razardica's Avatar
    Singletrack pressures on a 4.0
    What kind of pressures are you guys running now that it's summertime?
    I am running 15psi some Floater 4.0s on Darryls. I weigh 210 geared up.
    I think I could stand to go a bit lower, maybe 12, to reduce basketballing, but wanted to see what some of you guys are doing. Don't wanna experiment with my rims if somebody has already taken the dings for the team.
    Using the search function would be the best way to find your answer.
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    Quote Originally Posted by razardica View Post
    8f 10r
    "ORANGE IS THE NEW BLACK"
    Reputation: OFFcourse's Avatar
    15 is crazy high, drop PSI till your floater falls off the rim then add 0.5 PSI
    Fat & Single
    Reputation: ozzybmx's Avatar
    Depends on the tyre. 7psi Buds on Margelites, 8-8.5psi in HuDu's.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    If you experiment by lowering pressures gradually, your first rim strike will likely be quite soft and not damage anything.
    Jun 2012
    Quote Originally Posted by ozzybmx View Post
    8-8.5psi in HuDu's.
    That its where i am at. No rim damage yet on rocky/rooty trails.
    Approximations are your only available answer.
    Inflation pressure depends on rider weight, riding style, and tire choice ... There is no "One Pressure Fit's All number.
    You'll have to experiment.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    9ish.....
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    Quote Originally Posted by nvphatty View Post
    8f 10r
    This! I am about your weight as well. I accidentally ran 15 psi once and it was horrible!
    Nemophilist
    Reputation: TrailMaker's Avatar
    Quote Originally Posted by Saul Lumikko View Post
    This is the answer for ride optimization.
    You are riding at road pressures. The thump tells you where you need to be offroad. More thumps = more air. No thumps ever = less. Under 2-3 thumps per ride and you are about right. In the end I am only 1-2lbs above snow conditions, generally, and depending on terrain.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Fat & Single
    Thumps... I would be looking for zero, mine are run just above squirm point and they get a decent workout each ride.
    Theres a very small window of pressure that is the sweet spot, I use a digital gauge before every ride to check im in that window.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    bigger than you.
    Reputation: Gigantic's Avatar
    9-ish. any higher and the bike bounces like a beach ball, any lower, I risk pinch flatting. Larry up front and a Vee Mission in rear.
    gone walk about
    Mar 2012
    Quote Originally Posted by MiniTrail View Post
    ditch the gauge
    it's just a number. Feel is everything
    imma feel my gauge and see if i get a number
    Human Test Subject
    Reputation: Volsung's Avatar
    this question gets asked once a month it seems. generally i ride at just under the bouncy point. lower if it's soft snow.
  1. Tire pressures?
    By jjaguar in forum Families and Riding with Kids
    Last Post: 05-05-2012, 10:17 AM
  2. tire pressures
    By akexpress in forum Tandem Mountain Bikes
    Last Post: 03-03-2012, 01:50 PM
  3. Tyre pressures...
    By druidh in forum Fat bikes
    Last Post: 02-10-2012, 05:42 PM
  4. Tire pressures
    By vinnyl26 in forum All Mountain
    Last Post: 12-08-2011, 10:48 PM
  5. Pressures for around town?
    By justin51 in forum Fat bikes
    Last Post: 01-08-2011, 06:30 PM
