Page 2 of 2 FirstFirst 1 2
Results 26 to 41 of 41
  1. #26
    Reputation: Welnic's Avatar
    Feb 2013
    Quote Originally Posted by thunderzy View Post
    I also have the charge maxi. Like it a lot. But I want my next bike to be able to fit 5" tires, 29er plus, have a symmetrical rear end, and bluto compatible. Only reason I haven't pulled the trigger on a mukluk is bc I love the feel of steel. My other bike is a canfield yelli screamy. To be honest I don't like the way aluminum frames ride. Too harsh. My brother built a kona honzo (steel frame) same time I built my screamy. It's a much smoother enjoyable bike.
    You don't have to settle for aluminum with a Mukluk. Titanium is like steel, just better.
  2. #27
    Quote Originally Posted by Welnic View Post
    and 3 times as expensive. But I have been considering taking the plunge!!
  3. #28
    Feb 2013
    On the other hand, if you know exactly what you want, you could have Smudge build a custom titanium fat bike that was perfect. I didn't feel that I knew enough about what I really wanted, so I went with a Mukluk Ti. Of the stock frames available in titanium that I was able to find it had the shortest chain stays and slackest head angle.
  4. #29
    I had to go custom to get what you describe. I didn't just want short CS, I also wanted to use a 4.8" tyre.
    Mine is 16.6" 423mm at the shortest setting on the paragon sliders. I've tried it at various lengths and 430mm seems to be the point at which it feels great, any longer and it starts feeling less nimble.
    It is absolutely superb :-)
    P1030107 by LOVATSTOVES, on Flickr
  5. #30
    No it isn't. Maybe if built heavier stiffer. My indy fab ti 29er was light but not as snappy as my kona unit or charge. And ti is the only frame material that ive broken under my 165lb frame. Owned ti bikes for a total of 12 years. Over it. Steel is the $hit. Even cheap steel.
    Rog
  6. #31
    will rant for food
    Quote Originally Posted by newmarketrog View Post
    Steel is the $hit.
    Implementation is the sh!t.
    I will repeat this until I die.
    I've seen some broken steel frames.
    Implementation. Implementation. Implementation. A thousand times over.
    You could make a bike out of weed and epoxy if you damn well wanted to.
    Disclaimer: I'm not hating on steel. Hooked my brother up with a fat front Karate Monkey. The Karate Monkey is a well implemented steel frame.
  7. #32
    will rant for food
    I am enjoying the pictures in this thread BTW, on both a personal and future professional level. People love short stay fatties. Good to know.
  8. #33
    Reputation: Stopbreakindown's Avatar
    I am in the same boat as the OP. Have been riding a 2010 907 for 4 years, ready to take the next step. I want something that rides similar to my N9, would love a clone of what Virtue has but can't afford to go custom (@ virtue, that thing is rad)
  9. #34
    Shamisen Appreciator
    Quote Originally Posted by Drew Diller View Post
    Pretty much.
    Just about every material used to make bikes can be used to make a great bike. Compromises will always exist with each of those materials and there are always going to be unintended QC issues that will slip out into the world. There are also some people who will break EVERYTHING they ride, regardless of material. I know a few people like that. We don't need to be zealots about material, after all, we're just riding bikes for fun right?
    I sure have fun on my short stay fat bike.
    Sean Chaney :: Owner/Builder :: Vertigo Cycles LLC
    flickr :: www.vertigocycles.com
  10. #35
    Re: Short chainstay / Slack front / SS Fatty Frame?
    Quote Originally Posted by virtueminehonour View Post
    That looks like a pretty high bottom bracket. How does it feel?
  11. #36
    This is going to get a touch off topic but it's important so I'm going to mention it here in context.
    The biggest reason to go to a custom builder is to let them give you their interpretation of what you want. The way it's supposed to work is that we use our experience and expertise to come up with the design of the bike using the input we get from the customer.
  12. #37
    Hey Sean, is there a thread on mtbr with more details on your bike? Wondering if that's a Jones fork, Blacksheep, or a fork you made. Also wondering what kind of head angle you were using and fork offset if it's a fork of your own making. Thanks.
  13. #38
    will rant for food
    smudge, I never noticed your signature before.
    Your bikes are dope.
  14. #39
    Quote Originally Posted by Slow Danger View Post
    I haven't put much info out into the world about it. HTA is 68.5 and offset is 54mm. It's a fork I built just to see what all the hub-bub is about but I'm not going to make a habit of it. As far as I can tell, it attaches the front wheel to the stem just fine but otherwise doesn't do anything special.
  15. #40
    It feels great, BB drop is 50mm so it's a bit higher than the usual 60mm drop and then the height of the Buds raise it a little more, especially at rest.
  16. #41
    Quote Originally Posted by smudge View Post
    rog
  1. Replies: 33
    Last Post: 02-07-2015, 06:09 AM
  2. short travel, slack, short chainstay FS
    By r1Gel in forum 29er Bikes
    Last Post: 07-24-2013, 08:33 PM
  3. FTW Slack and Short Hardtail
    By Singletrack Pig in forum 29er Bikes
    Last Post: 03-12-2013, 08:55 AM
  4. Front derailleur for short chainstay 29" frames.
    By Ronnie in forum 29er Components
    Last Post: 02-29-2012, 09:22 AM
  5. New Frame - Front Hose Is 10 mm Short
    By Toff in forum Brake Time
    Last Post: 12-06-2011, 05:08 AM
