Results 1 to 15 of 15
    Reputation: 5 String's Avatar
    Apr 2015
    Seat tube question: Boris and Thudbuster
    I recently picked up a Thudbuster LT for my Boris X9. It is a 31.6 seat post, but I am having no success getting it in.
    The specs say the Boris has a 31.6mm seat tube, but the post that came out is marked 30.4??
    Any suggestions?
    eta:
    Frame ALLOY 6061 FRAME, W/DISC MOUNT ONLY, TIG WELD, replaceable rear derailleur hanger, H2O bosses, Rear Rack Seatstay Brazeons, 170mm Symmetrical Rear triangle spacing
    Fork 26" 25.4x28.6x30x250L Straight blade CRMO 1 1/8 W/DISC MOUNT ONLY
    Forks are coming with more brazeons/mounts than pictured
    Crankset SRAM X5 22T ALLOY BKx36T ALLOY BKx175MM
    Bottom Bracket SRAM GXP100 100x1.37 BSA Standard English Threaded
    Pedals VP-530 ALLOY BLACK W/CPSC REFLECTOR
    Front Derailleur SRAM FD-X7 2x10 HIGH DIRECT MOUNT
    Rear Derailleur SRAM RD-X9 GRAY CAGE 10SPD STGRY
    Shifters SRAM SL-X7 TRIGGER 20-SP BLACK
    Cassette/Freewheel SRAM PG-1030 10-SPEED 11-36
    Chain KMC X-10 STEEL NP/NP+CL-566R LINK
    Hubs Front 14Gx32Hx135mm alloy BLACK,W/QR / Rear 14Gx32Hx170mm QL205Y alloy BLACK
    Spokes 14G STEEL STAINLESS W/BRASS NIPPLE
    Rims 26"x32H WEINMANN HL-80 WIDTH 80MM W/BIG HOLES, ALLOY BLACK
    Tires/Tubes VEE Rubber 26"x4.0 MISSION 120TPI FB F/V
    Some Bikes arriving upgraded to NEW Mission Command Tires - no extra charge
    Brakes AVID BB7 DISC BRAKE W/F:180MM,R:160MM ROTOR
    Brake Levers AVID FR5 ALLOY BLACK LEVER W/ALLOY
    Headset VP-A42E BLACK W/M-1D ALLOY BLACK CAP
    Handlebar 31.8mm W:700MMx9 DEGREES, ALLOY BLACK
    Stem Alloy, A-Head 15":80mm 17":80mm 19":90mm 21": 100mmx R:45mmx7 DEG
    Tape/Grip 130mm, ALL BLACK, SUPER LIGHT FOAM
    Saddle WTB SPEED V SPORT SE VINYL TOP
    Seat Post Alloy 31.6mm x 350mm aluminum
    Seat Post Clamp 34.9 ALLOY, Q/R
    Sizes See pull down
    Colors See Pull Down menu
    RAKC
    Reputation: tigris99's Avatar
    U can't put a seatpost in that's bigger than the one that came out, just not doable.
    You have to always check stock sizes of what's on the bike for things before just ordering and hoping it fits.
    Apr 2015
    @ Tigris
    I agree with your point, but the specs say 31.6mm seat tube. Others have used a 31.6 seat post on the same bike.
    My thought is they put in a smaller seat post and "pinched" the seat tube to a smaller size. Not sure that is the case, but if it is, is there a way to "unpinch" the seat tube safely?
    The specs on the x9 say 34.6 seat tube. They say 31.6 seat post.
    By those specs your new post should fit. Did they put in a smaller post but stick in a shim that you're not seeing?
    Apr 2015
    @ tfinator
    No shim that I can see. I ran my finger in there looking for burrs, paint, etc. Tube looks clean.
    Apolgies for the mixup on seat tube vs seat post. Gets confusing for a noob like me
    Apr 2015
    I used a digital caliper and the seat tube measures 31.6mm longitudinally and 30.9 laterally. Is there a safe way to expand the tube?
    Reputation: WSUPolar's Avatar
    Sep 2014
    The X9 FS With bluto states 30.4, did they update the frame on the non FS to the same. That's my guess.
    MacGyver is my spirit animal
    -Until proven wrong, assume you are the weak link in any system-
    Apr 2015
    @WSU
    That would suck
    If so, they should update the website. That particular model is the only Boris with that size listed.
    Apr 2015
    @WSU
    Looking at the Boris report thread, it seems the newer X9s have a 30.4mm seat tube. BD needs to update their site.
    I re-calipered the seat tube and it measures F-R: 30.6 / L-R: 30.3 so some slight oval deformation but stock seat tube fits perfectly and is pretty tight as it is pushed all the way in.
    Apr 2015
    I went to Harbor Freight, purchased the adjustable reamer set, and went to town. After about an hour and a half, the seat tube is now at 31.6mm.
    No need to sell the Thudbuster!
    Reputation: tyriverag's Avatar
    Jan 2014
    Could you have just exchanged/returned the Thudbuster?
    And if I read that right, you bought tools to expand the seat tube? Is that a potential safety issue?
    it's a challenge some of us are ultimately worthy of.
    Sep 2014
    Quote Originally Posted by 5 String View Post
    I've considered doing just that... Please report back in a bit if it affected frame in anyway, shaving that half mm off the walls.
    Apr 2015
    Quote Originally Posted by tyriverag View Post
    I bought it used from PB, so no return/exchange. To convert it into a smaller seatpost was going to be a lengthy multi-deal solution that I ultimately chose not to pursue.
    I used a reamer to slowly remove enough material to allow the seatpost to fit. Tubing thickness is nominimally 1.8mm. I imagine there is some compromise in strength and I will report back with any long-term issues.
    Reputation: rollertoaster's Avatar
    I had a similar issue. The specs say 31.6 actual was 30.4. I bought a set of reamers and corrected their cost cutting measure myself. It was not fun. I'd recommend returning the post and exchange it for the correct size
    Apr 2015
    Quote Originally Posted by rollertoaster View Post
    Too late! I did what you did. Have you had any issues?
  1. seat post thudbuster ???
    By raya22486 in forum 29er Components
    Last Post: 10-29-2014, 09:17 PM
  2. MCR seat tube cutout question/help
    By cyclesteel in forum Niner Bikes
    Last Post: 12-29-2013, 06:18 PM
  3. Should I get a Thudbuster suspension seat post?
    By MountB in forum General Discussion
    Last Post: 06-25-2011, 01:54 AM
  4. Geometry Question - seat tube angle
    By jbf in forum Frame Building
    Last Post: 04-13-2011, 07:53 AM
  5. new Ti build, seat tube question
    By lablover in forum 29er Bikes
    Last Post: 03-25-2011, 12:10 PM
