Results 1 to 6 of 6
    Jul 2013
    sand in the brakes?
    My new Mukluk seems to have some rubbing/friction issues in the front tire. I think it has to do with sand getting into the brakes. Is there anything I can do to stop this from happening while I'm riding on the sand? It definitely caused extra drag on the beach. Thanks!
    Reputation: surlybugger's Avatar
    Jan 2013
    This helps your disc-brake pads, for most debris getting up in there. Take the pads out, then champfer the edges on the leading & trailing edges. You can put a small one on the tom & bottom edges as well, but just for cleaning up the edge's sharpness. Then soak in acetone to remove all pad-enemies.
    Much like champfering or radiusing a wooden table edge, it won't chip as easily, and debris won't get hung-up as much.
    Works for me.
    Reputation: OFFcourse's Avatar
    It should be a pretty clear YES my pads are rubbing or NO my pads are not rubbing, otherwise you may have hub issues (tight/contamination). What type of hubs do the muks run?
    Reputation: Velobike's Avatar
    Quote Originally Posted by beachroller View Post
    My new Mukluk seems to have some rubbing/friction issues in the front tire. I think it has to do with sand getting into the brakes. Is there anything I can do to stop this from happening while I'm riding on the sand?...
    Drum brakes.
    But I'm not sure how they would handle the occasional immersion.
    Latitude: 5736' Highlands, Scotland
    Jul 2013
    i wish i knew how to do this. Time to learn about bike mechanics as I'm not in an area where anyone else can fix it. I'll search youtube
    Reputation: vikb's Avatar
    If you have Avid BB7's on your bike you can dial the pads out so they allow more pad clearance. Won't be as good for braking, but on a beach that's not as vital.
    My BB7s have lived at the beach for several months a year and sand hasn't been an issue. I'm not riding down into the water so I'm dealing only with dry sand which isn't sticky.
    Safe riding,
    Vik
    www.vikapproved.com
  1. Bud & Lou on sand
    By racefit in forum Fat bikes
    Last Post: 12-31-2012, 07:44 PM
  2. Sand!!!
    By Tybol in forum General Discussion
    Last Post: 04-03-2012, 06:27 PM
  3. Nates and sand?
    By vikb in forum Fat bikes
    Last Post: 04-03-2012, 02:32 AM
  4. Replies: 10
    Last Post: 06-16-2011, 12:09 PM
  5. Tires for Sand?
    By luckybastard in forum Arizona
    Last Post: 05-08-2011, 06:43 AM
