They've shipped and are arriving at LBS, the Salsa Beargrease! Here is a photo of mine being built at the shop. Post a photo of yours as well. I can't wait for snow!!
The shop owner s building up a bike with Marge Lites, powder coated yellow, carbon bars, Hope brakes, it'll be a trick bike when complete. I'll post photos of mine, and his bike as well.
Sounds like he's shooting for a 25-26 pound fatty.
I'm planning on buying mine next week when they arrive at my shop. It will be my first fatty...I was thinking about the mukluk 2, and am planning on making a final decision when I can ride them side by side, but dang the bg looks sweet. (muk looks like it can run bud and lou, bg would be bud/nate for when speed is not the objective, but that seems like the only think pointing towards the muk. I'll probably end up with the beargrease!
I'll weigh mine at the shop when I pick it up. I've not ridden a 'regular' fat bike, so I won't know the difference between the two.
We need to get all the Wichita Fatbikes together for the Global Fatbike Day ride on the 1st. Where do we ride? Millers Meadow? The dried up Little Arkansas River? I doubt that Air Capital will be ready to ride yet. Some urban fatbiking?
I've almost made the decision to order a frame set. Can anyone help me decide between medium or small?
I'm 5'8, 160 lbs. with average proportions but I don't actually know my inseam. I plan to build it with Rolling Darryl's and Husker Du's for year-round riding.
The Mukluk's run quite big. I am 5'9" with a 31" inseam and quite average arm and leg length. I have a medium 2012 Mukluk 2 with a 100mm stem and feel quite stretched out. But the 2012 has the Salsa bend 2 11 degree bar which bends forward and then back keepong it closer to a straight or 5 degree bar. Could probably go to a 90mm stem. You may be between sizes or closer to a small. It would really be good if you could find one to ride. If you like to ride with a short stem, you could probably go with the medium.
I fall just below the recommended height range for a medium frame set. So my plan is to go with a small frame set, carbon setback seat post, and stem length of 90-110 mm or so.
Can anybody give a ride report yet on their BG? Would love to hear about improvement in climbing efficiency of the BG versus a heavier fatbike.
I have a BG on order, but still on the fence on whether the 3.5 pounds difference is worth the cost of the upgrade and the loss I will take on selling my Mukluk 2. I'm figuring that the BG will be 29.5 stock with pedals. My ML is currently 33 with pedals.
The Mukluk 2 will never be able to ovecome the pound in the fork and the pound in the frame that the BG sheds, but I just read that a lighter cassette and chain netted someone a half pound reduction in their Mukluk. Maybe it is possible to get it down to a 2 pound difference.
all my parts have arrived. Large Beargrease frameset. XTR shifters, brakes, deraileurs, eThirteen double crank, hope hubs, Schlick 47mm rims, thomson post, salsa promoto bar and stem....
Would never try to dissuade anyone from buying such a cool new toy, but you do have options with your (2012?) Muk 2 that will get you to Beargrease weights. None of the options are cheap, unfortunately. Mainly you can drop a pound plus in the fork getting a Carver carbon, and if you build a wheelset along the lines of Marge Lite/hope hubs/dt comps and put HuDu's or UL nates on you could lose 2-3lbs in rotation weight. Change the cassette, put a light bar and seat on, and you'd be there.
The plus side is that you can set up the bike porky for the winter, and switch to the summer dress and presto, like having a brand new bike. The downside is it's not a brand new bike. The geo, however, is basically identical between '12 Muk and '13 BG according to Salsa...
Thanks Montana for thr suggestion on the fork. Hadn't known about the carbon Carver. I see that it is lighter than the BG fork, fits on the 2012 Muk 2 and is really not that expensive. Feel a lot better now about the potentail for getting my Muk's weight down.
