Results 1 to 8 of 8
    Jan 2014
    New question here. Salsa 2013 Mukluk
    What is the differences in a 2013 Mukluk 3 frame and 2014 Mukluk 3 frame. Want to know how big of wheel and tire combination I can add to my 2013 Mukluk 3.
    Reputation: hendricks97's Avatar
    Aug 2013
    the color
    Bud on clownshoe in front. Lou on Darryl sort of fits in the back with drive train alterations.
    WNC Native
    Reputation: nitrousjunky's Avatar
    2014 is suspension correct for a 100mm fork, so a little different geometry but otherwise I think clearances are the same.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Reputation: druidh's Avatar
    Quote Originally Posted by nitrousjunky View Post
    I thought that geometry change was introduced last year?
    nothing to see here
    Reputation: Stevob's Avatar
    from the Salsa website
    2013
    Size X-Small Small Medium Large X-Large
    Recommended Rider Height 157 - 168cm 165 - 175cm 173 - 183cm 180 - 191cm 188cm - Up
    A. Top Tube Effective 565 mm 580 mm 605 mm 625 mm 640 mm
    B. Seat Tube Length 381.0 mm 381.0 mm 431.8 mm 482.6 mm 533.4 mm
    C. Head Tube Angle 69.5 69.5 69.5 69.5 69.5
    D. Seat Tube Angle 73.5 73.5 73 73 73
    E. BB Drop 60 mm 60 mm 60 mm 60 mm 60 mm
    F. Chainstay Length 447 464 mm 447 464 mm 447 464 mm 447 464 mm 447 464 mm
    G. Head Tube Length 100 mm 110 mm 130 mm 150 mm 160 mm
    H. Fork Length 468 mm 468 mm 468 mm 468 mm 468 mm
    J. Fork Offset 45 mm 45 mm 45 mm 45 mm 45 mm
    K. Wheel Base 1078.5 1095.5 mm 1094.2 1114.2 mm 1114.9 1131.9 mm 1136.1 1153.1 mm 1151.8 1168.8 mm
    M. Stack 578.0 mm 587.4 mm 606.1 mm 624.8 mm 634.2 mm
    N. Reach 393.8 mm 406.0 mm 419.7 mm 434.0 mm 446.1 mm
    P. Stand Over 673.5 mm 702.1 mm 744.9 mm 786.7 mm 825.0 mm
    2014
    Recommended Rider Height 157cm - 168cm 165cm - 175cm 173cm - 183cm 180cm - 191cm 188cm - UP
    A. Toptube Effective 565mm 580mm 605mm 625mm 640mm
    B. Seat Tube Length 381.0mm 381.0mm 432.0mm 483.0mm 533.0mm
    C. Headtube Angle 68.5 68.5 68.5 68.5 68.5
    D. Seat Tube Angle 73.5 73.5 73.0 73.0 73.0
    E. BB Drop 60mm 60mm 60mm 60mm 60.0mm
    F. Chainstay Length 447 - 464mm 447 - 464mm 447 - 464mm 447 - 464mm 447 - 464mm
    G. Headtube Length 100mm 100mm 110mm 130mm 140mm
    H. Fork Length 483mm 483mm 483mm 483mm 483mm
    J. Fork Offset 51mm 51mm 51mm 51mm 51mm
    K. Wheelbase 1097.1 - 1114.1mm 1112.1 - 1129.1mm 1132.3 - 1149.3mm 1153.9 - 1170.9mm 1169.7 - 1186.7mm
    M. Stack 593.3mm 593.3mm 602.6mm 621.3mm 630.5mm
    N. Reach 389.2mm 404.2mm 420.9mm 435.0mm 447.2mm
    P. Standover 691.9mm 703.9mm 744.5mm 786.3mm 823.7mm
    I see hills.
    I want to climb them.
    Aug 2013
    oops, I was wrong
    Jan 2014
    Thank You! I will order some big wheels for my rig.
  1. A new Salsa Mukluk
    By Outsider in forum Fat bikes
    Last Post: 07-21-2014, 05:17 AM
  2. 2013 Salsa Mukluk 3 Bottom Bracket
    By Sasquatch1413 in forum Fat bikes
    Last Post: 06-14-2013, 03:23 AM
  3. Replies: 0
    Last Post: 01-05-2013, 03:20 PM
  4. Replies: 0
    Last Post: 12-24-2012, 10:11 AM
  5. Salsa Mukluk 2
    By Misterlime in forum Fat bikes
    Last Post: 09-22-2011, 10:04 PM
