Results 1 to 6 of 6
    Sep 2017
    Saint Brakes on a Carbon Fatboy?
    Houston we have a problem.... I知 in the process of installing Saint brakes on my 2016 Carbon Fatboy but I知 having an issue making the banjo fitting line up on the rear caliper. I have the XTR version of the cable on the way which uses a shorter stainless banjo. Please notice in the pics that the brass banjo is bent 15 degrees or so and it痴 still a tight fit. The 15 degree bend did crack the banjo fitting at the throat so it痴 of no use. By the looks of it I need a banjo fitting with a 45 degree bend. Goodridge makes such a fitting but I知 unsure if the actual banjo end will fit my brakes. The Goodridge fitting has a size of -3 if that痴 any help.
    Saint Brakes on a Carbon Fatboy?-2831a3f5-8487-498b-a142-c99353d86168.jpgSaint Brakes on a Carbon Fatboy?-15023ed9-9936-45c9-b6e0-026f10f087ed.jpg
    Sep 2017
    This looks like it would do the trick:
    Would it work to rotate the banjo fitting until it clears the mounting bracket? You could then use a slightly longer hose with a larger radius bend to line up with the banjo. I suppose this is a moot point now that the original banjo is cracked.
    Latitude 61
    Sep 2017
    I don稚 think that would be possible. Here痴 some better pics to illustrate.
    Keep in mind the banjo in the pics has already been bent beyond its breaking point.
    Nov 2008
    Curious, what size rotor? I had the same problem, I was trying to use a 160mm solved it by using 180mm rotor.
    Steven
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    Sep 2017
    Sadly this is already set up for 180. I知 hoping I don稚 need to go to 203s in the rear. These are already overkill.
  1. RM Blizzard -30 vs Specialized FatBoy/FatBoy Comp?
    By Engineer90 in forum Fat bikes
    Last Post: 10-23-2015, 12:13 PM
  2. Fatboy Trail or Fatboy with Lefty Conversion
    By Khemykal in forum Fat bikes
    Last Post: 10-12-2015, 10:34 PM
  3. Will new Saint levers work with first gen Saint Calipers?
    By jayjudy13 in forum Downhill - Freeride
    Last Post: 02-14-2013, 05:14 PM
  4. Replies: 0
    Last Post: 07-20-2012, 01:04 PM
  5. old saint (m800) lines on new saint (m810) calipers?
    By Evan55 in forum Downhill - Freeride
    Last Post: 08-04-2011, 08:50 AM
Members who have read this thread: 47
