Page 2 of 17 FirstFirst 12345612 ... LastLast
Results 101 to 200 of 1646
  1. #101
    Yes, the 80mm is ideal with only 0.5 degree slacker head angle.
    RSD Bikes - Sales - www.rsdbikes.com
    Instagram - facebook
  2. #102
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Frantiklex View Post
    Wouldn't it be about the same as the stock fork after sag? Of coarse that's if you are not including the stack height of a external lower cup.
    511 c-r @ 100mm
    491 c-r @ 80mm
    20mm sag 471mm
  3. #103
    Yes, except the Bluto has a 51mm offset
  4. #104
    aka bOb
    But fork rake or trail does not affect the actual head angle.
  5. #105
    Reputation: shiggy's Avatar
    Dec 1998
    RSD Bikes "The Mayor"
    Quote Originally Posted by bdundee View Post
    But changing the fork offset changes the trail.
    The real question is whether the fork crown will clear the down tube.
    mtbtires.com
  6. #106
    Sure it does
  7. #107
    aka bOb
    Sure it does
    Here we go again
  8. #108
    aka bOb
    Quote Originally Posted by shiggy View Post
    This I know because you teached it to me
    and the trail does not affect the head tube angle because you teached me that as well.
  9. #109
    Think of it this way: every frame design includes the dimension of a specific fork, regardless of the brand. Our 29ers, for example, are designed with the dimensions of a FOX 34 Float 130mm and of course we take into account sag and headset lower cup. Any deviations from that might potentially change the geometry even ever so slightly. If you use 110mm fork, it will steepen the HA and lower the BBH. If you use 150mm, it will slacken the HA and raise the BBH. Also, the FOX 34 we use has 51mm offset, if you use another fork or the same with a different offset, example 46mm, this will steepen your HA.
    This is the same thing here with our Mayor, the fork is rigid 468mm A to C and 45mm offset. You are right, The Bluto, with 20% sag, sits at 471mm, but it's the offset that causes the 0.5 degree slacker. And yes, the fork crown clears the down tube.
  10. #110
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Got my eyes on The Mayor last weekend nice looking bike.
  11. #111
    aka bOb
    Well there goes my months of research into fork offsets and their direct effect on head tube angle.
  12. #112
    Most Delicious
    Reputation: dr.welby's Avatar
    Actually it will slacken the head angle, but not by enough to even worry about. Less than 1mm.
  13. #113
    Dec 1998
    Ignore it, it is just plain wrong. If there is no change in the AXLE to crown distance, there is no significant change in the HTA. Varying the tire pressure could make more of a change.
    It takes about a 17mm change in A-C to change the HTA by 1 degree.
    If anything, the greater offset of the Bluto would cancel out the minor difference in A-C length (though just by being a suspension fork the A-C/HTA is always changing).
    What DOES change is the trail.
    mtbtires.com
  14. #114
    my apologies for using the wrong terminology. it is the trail that changes, not the HA
  15. #115
    Dec 1998
    Odd mistake to make when trail is not measured in degrees.
    mtbtires.com
  16. #116
    Most Delicious
    The head angle does change, just not enough to matter in this application.
  17. #117
    Rocking on a Rocky
    If one was to swap out the carbon fork for a RS Bluto would it void the frame warranty?
  18. #118
    Jun 2014
    How would this bike be for bike packing ? And has anyone had luck with a two ring set up on the front? I'm a noob deciding between this and upgrading a black muk 3.
    Sent from my Motorola RAZR MAXX using Tapatalk
  19. #119
    Rocking on a Rocky
    2015 are out. Glad I waited.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
  20. #120
    Ya but it's got one of them forks that moves with rider/trail input. No bueno.
    rog
  21. #121
    Rocking on a Rocky
    Complete bikes
    1x10 and Carbon Fork $1949 MSRP
    1x11 and Carbon Fork $2399 MSRP
    1x10 and Bluto $2399 MSRP
    1x11 and Bluto $2799 MSRP
    Frame/Fork combo
    Carbon Fork $799 MSRP
    Bluto Fork $1099 MSRP
  22. #122
    Reputation: OCDKV's Avatar
    Jul 2014
    I'm digging the blue
  23. #123
    Jul 2014
    Looks like Raw is coming too!
  24. #124
    Jun 2013
    Quote Originally Posted by RockyJo1 View Post
    Complete bikes
    Frame/Fork combo
    Any reason why bluto frame/fork is only $300 price diff. But on a complete bike it's $450 diff?
    The Mayor was at the very top of my list last fall at $1799. But with the price hike and increased competition, this bike has fallen to 5-6 on my list now.
  25. #125
    Rocking on a Rocky
    Quote Originally Posted by neons97 View Post
    Have to wait for the build specs I guess. At 1100 bucks is a good price.
  26. #126
    Jun 2013
    With these Chinese Carbon frame/forks coming in at around $550 USD, i'm guessing a frame-only can likely be had for around $425-$450. Add a $650 bluto and you have a sub-$1100 Carbon frame/Bluto combo.
    These frames do look really nice though. And developed by a company in my backyard that tested the bike on my home trails.
  27. #127
    We added some extra value into our complete bikes, but kept the price unchanged.
    It will now come with Snowshoe XL 4.8, instead of the regular Snowshoe which measured around 4.2. We are also changing the saddle in favour of the WTB Volt. It will also come with RF Strafe grips, instead of the Half Nelson
    Full rack mounts front and rear
  28. #128
    Jul 2014
    Re: RSD Bikes "The Mayor"
    I got mine pre-ordered with Bluto. . Alex has been excellent to deal with and has answered any of my questions quickly and professionally. I am more than willing to support a small Canadian company offering a very competitive package to the larger companies.
  29. #129
    Reputation: gord962's Avatar
    It will not come with Snowshoe XL 4.8,...
    Was that supposed to say it will NOW come with the Snowshoe XL?
    If you want all the comforts of home, stay there.
    Rides, Reviews, Races and Random Thoughts
  30. #130
    Oops, that is correct. It will come with the Snowshoe XL.
    Thank you
  31. #131
    Rocking on a Rocky
    Is the only change from 2014 to 2015 the slightly wider rear triangle? Nothing on the head angle or head tube?
  32. #132
    correct, just a few mm extra for better tire clearance. Rack mounts front and rear, which wasn't there on V1, WTB Volt saddle, RF Strafe coloured grips, Snowshoe XL 4.8 and 2 new frame colours (Raw and Blue). The head tube will be slightly longer to 150mm and no changes the already perfect head angle.
    Cheers,
  33. #133
    Jun 2013
    Any of your Toronto dealers have the 2015's in stock now? Any new dealers east end of Toronto? I live 10 min. from Durham Forest, but closest dealer to me is at least 50km's away.
  34. #134
    I would recommend contacting your LBS and placing the order through them. The full 2015 line up will be available in October. We only have 2015 black 1x10 bikes available right now in size large and XL
  35. #135
    Jun 2013
    Thanks for the feedback. But I have no plans to buy one sight unseen.
  36. #136
    Jun 2013
    Quote Originally Posted by krzysiekmz View Post
    +1
    If I ever end up buying any complete bike in person I would like to see it and test ride it. Are there any places that one can do that with RSD bikes?
    Chris.
    I think their dealer in Cambridge had a couple of each sizes last season. But that's about 1.5hrs away from me.
  37. #137
    +1
    Chris.
  38. #138
    Rocking on a Rocky
  39. #139
    Thing is they have none is stock.
    Chris.
  40. #140
    Aug 2014
    I'm running Mulefut 82mm rims and have plenty of clearance for 4.7" tires. More clearance for next year means room for 5.0 tires, right
    Also, I have a medium The Mayor if anyone needs to see one in person in the Anchorage area. Will offer test rides for a good microbrew. Ordered the frame through Cyclepath in Portland, OR.
  41. #141
    Jul 2014
    RSD Bikes "The Mayor"-10411728_576990299076854_3991514959361257070_n.jpgRSD Bikes "The Mayor"-10542977_576990215743529_4535250368237733008_n.jpg
    Just a couple of teasers from the RSD Facebook page
  42. #142
    lookin good!
    nice that they're sporting the seat tube to top tube carry like a suitcase thingy that mikesee invented. wonder if he gets royalties.
    rog
  43. #143
    will rant for food
    Quote Originally Posted by newmarketrog View Post
    lookin good!
    rog
    I have a product recommendation for you.
  44. #144
    aka bOb
    Quote Originally Posted by Drew Diller View Post
    Now that was funny!!
    You must spread some Reputation around before giving it to Drew Diller again.
  45. #145
    aka bOb
  46. #146
    Jun 2014
    At a bike shop nearby the 2014 mayor is $1450 whereas the 2014 fatboy expert is $2200.. It shouldn't be a tough call, but any suggestions?
  47. #147
    Rocking on a Rocky
    Quote Originally Posted by d34nclub View Post
    Do like I did and get The Mayor.
  48. #148
    Jun 2014
    Hehe, I think I would stupid not too.. I just hope they still have one in L in stock when I get up there after work. Hope to try out a couple though around the parking lot, but that is a great deal. U tried a Fatboy Rocky?
  49. #149
    Jul 2013
    Ya just get the RSD.
  50. #150
    Rocking on a Rocky
    No I have not. The LBS will not let you test it. Looked at it hard if they would of had a good riser bar in stock I would have got one. Glad they didn't now.
  51. #151
    Jun 2014
    There is a new mayor in town . Hopefully i can get over my cold so she can be ridden this week. Too good of a deal to pass up.
  52. #152
    Jul 2013
    Is there anything I can do to not have to run a 30 front chain ring. I know my spider isn't removable but would love 26 by 36 gear ratio making it easier on climbs.
    My only complaint is the stock 32 by 36 ratio for climbing.
  53. #153
    Rocking on a Rocky
    Quote Originally Posted by BradOlsen84 View Post
    Try a 42 Wolf tooth on the rear.
  54. #154
    Crappy lbs.
  55. #155
    Rocking on a Rocky
    Quote Originally Posted by ultraspontane View Post
    Crappy lbs.
    We have a few here.
  56. #156
    OHV Gansta
    Reputation: GazaTron's Avatar
    Looks to be a good option frame to fit a bluto on (y)
    Get out and ride
  57. #157
    Hey, jumping in late here, but what shop? What city are you in?
  58. #158
    Sep 2014
    Guys
    Is the RSD considered more of a race/XC geometry like the Specialized/Trek or more adventure slack and long?
    I love the specialized but want to support my local builder and if this is going to feel as fast as the other then I am sold.
    They also have a 14 locally, if the 15 has only minor changes then I will grab that one.
    Bev
    Edit
    10mm longer chain stays, head angle .5 degree different, seat angle the same, bb 10mm higher, hard to compare top tube length as different terminology..
  59. #159
    Rocking on a Rocky
    Quote Originally Posted by Bevo-66 View Post
    Guys
    Bev
    It's nice in the single track.
  60. #160
    Sep 2014
    One thing I like is the spec, not much to change and love that carbon fork.
    10mm longer stays will give it a bit more stability but the same head angle will keep it fast turning.
    The higher bb may also be a bonus as well.
    The shop is also willing to make changes within the price, rear cassette and front chainring to a 30 and 36 rear may be perfect for me..
  61. #161
    Rocking on a Rocky
    The 15 frame us 10 mm wider rear than the 14. I think the 15 carbon fork has rack mounts? I changed my tires to Bulldozers add a few axtra ozs.
  62. #162
    Jun 2014
    Anyone have experience with 90mm rims on the mayor? Wonder what tire size will be the most a guy/gal could do.
  63. #163
    Jul 2014
    I was told by Alex at RSD that the new frame (v2) would easily accommodated 100mm with Bud & Lou, pretty much the biggest combo out there.
  64. #164
    Jun 2014
    I got the 2014 and I know a lou dont fit on the back even with a tube. The lou was trimmed a bit and psi was at like 15.. I'm sure with some adjustment of the psi it would spin without rub but no way it would be rideable with any amount of snow or mud on it. But alex did send me a pick of the 2014 with a snowshoe xl at 15psi tubed and it did fit. He has been super helpful in answering my emails. So I give them credit in that aspect.
  65. #165
    Jul 2014
    I got a v2 on the way (soon I hope) and I have to agree with you there.
  66. #166
    Jun 2014
    Nice.. It is super fun. Cool that you are getting the wider frame and bigger tires. That is what I am wanting to change most of all. Thinking of going to some lighter wheels as well as they are hella heavy. But overall the bike is a deal for what you get, in my opinion at least.
  67. #167
    Rocking on a Rocky
    Can someone with a medium bike and a stock bar give me the measurement from the end of the bar to the floor?
  68. #168
    Reputation: Windigo's Avatar
    Jul 2014
    I hate when a product is made in Canada and is sold cheaper in the US than Canada. No matter what we get hosed on pricing!
  69. #169
    Jun 2013
    There's nothing "made in canada" about it. Just designed/marketed in canada.
    Don't forget 12-13% exchange rate for currency difference.
  70. #170
    That is correct. In fact, with the conversion, dollar for dollar, it's slightly cheaper in Canada
  71. #171
    Jul 2014
    Then shoppers from US should buy from Canada, but no because of import charges would make it more expensive, the same reason the price should even out between US and Canada.
    Still more expensive in Canada no matter how you slice it.
  72. #172
    Jun 2013
    Quote Originally Posted by Windigo View Post
    Sorry, but I don't understand or follow what you're saying.
    Not sure how you conclude its more expensive for a consumer in canada than u.s. When you factor in the current exchange rate.
  73. #173
    Jul 2014
    Because the bike would have an import charge from Canada to the US.
    Even when the dollar was at par or better, products were still more expensive in Canada, reason given; import charges to bring the product in from the US.
  74. #174
    Jun 2013
    There's also a 13% duty (not hst) to import complete bicycles into canada. So omitting one from the U.S. into canada encounters the same costs. Duties are charged based on country of origin and not country of sales.
    I'm not sure what you are asking for from RSD. If you were responsible for pricing the bikes, how would you have prices them in CAD and usd?
  75. #175
    Jul 2014
    That is exactly what I am referring to, Duties, Brokerage fees and import charges, if Canadian vendors are giving these reasons for bikes being imported from the US are more expensive, wouldn't the same sort of charges be incurred by the US vendors when importing a bike from Canada.
  76. #176
    Reputation: Aceldama's Avatar
    Jan 2005
    This bike looks really nice but I have a few questions for people who own one:
    -How do you like the handling of the bike? I'm concerned that the chainstays are a bit long and I won't be able to easily lift the front wheel.
    -Anyone riding one of these in the New England area? Where did you buy it/test it out?
    Thanks.
  77. #177
    Rocking on a Rocky
    This bike is a hard charger in the technical single track. I can wheelie it no problem. And it climbs like a monkey on crack.
  78. #178
    [QUOTE=Aceldama;11553832]This bike looks really nice but I have a few questions for people who own one:
    Handling is great...Wheelies like a champ! I got mine at Chucks Bikes up in Vt...little up there, but a great shop. I have a medium and live around Boston (metro West) if you want a spin.
    Matt
  79. #179
    Aug 2014
    I find it is a little difficult to wheelie compared to bikes with shorter chainstays, however it descends like a rocket when paired with a tall fork (483mm axle-to-crown height), giving it a fairly slack head tube angle. I ran a shorter (460mm) fork and the handling was twitchy and the front wheel very difficult to lift due to the lower front end.
  80. #180
    Rocking on a Rocky
  81. #181
    Jan 2005
    [QUOTE=MB2713;11557290]
    Quote Originally Posted by Aceldama View Post
    Matt
    Hey Matt thanks for the info and invite to check out your bike, I'll send you a PM.
    The Mayor is definitely in the running and I'm sure I could make a fun day trip out of heading up to VT.
  82. #182
    Reputation: mattybfat's Avatar
    so in so waiting in NJ why are the fat gods against me
  83. #183
    Jun 2014
    Anyone have a picture of a Mayor with bluto?
  84. #184
    Reputation: kreater's Avatar
    there is a picture on the RSD twitter site, blue mayor with bluto....
    Product designer @RSDBikes.com
    "Live dangerously and you live right."
    Johann Wolfgang von Goethe
  85. #185
    Reputation: emp?'s Avatar
    anywhere you can buy these online?
    Josh
  86. #186
    Quote Originally Posted by emp? View Post
    give the guys at pedal the planet a call......
  87. #187
    Reputation: bcriverjunky's Avatar
    Jul 2014
    Quote Originally Posted by kreater View Post
    Not sure what the model is that they have pictured in blue but it's not a fatty
    Marin Bobcat Trail 29er - Trek Farley 8
  88. #188
    Quote Originally Posted by bcriverjunky View Post
    Those are 29" wheels , RSD is just letting you know what's possible w/ their fat frames.
    They have done a poor job of marketing these bikes IMO. There is very little info / pics. At one point I was interested.
  89. #189
  90. #190
    Jul 2014
    Quote Originally Posted by rjedoaks View Post
    At one point I was interested too. Couldn't bring myself to spend 2000+ for something I couldn't ride first.
  91. #191
    Jul 2014
    I agree that the website and Facebook page are terrible, but if you have any questions just email them. I've asked a tonne of questions and Alex has always gotten back quickly.
    Now if my bike would just arrive I could post a few pictures and help them out a little with the marketing
  92. #192
    RSD owners how are the wheels on these complete builds. Not seeing much info on them. Anyone set up tubeless?
  93. #193
    Dec 2013
    tubeless can be done bra.
    and seriously, just go grab a Norco Bigfoot or Samsqanch (bubbles rulz) and save your $$$. carbon fork on the 6.1 Bigfoot and tires are aWesome. AND besT? they come with two, yes 2 front rings. dont have to waste $$ on making the RSd werk in the hills.
    all the best
    ps: Norcos are aboot as CDN as RSD's.
    pss: rsd fats will eVentually come w two rings....just a denial thang.
  94. #194
    Thanks for input but you obviously hadn't looked at the specs between the 2. $100 more and rsd blows that Norco Bigfoot 6.1 away in components. Mayor is 190mm vs 170mm and those brakes, no thank you. I would have gone single up front no matter what bike I buy and RSD made my choice easy.
  95. #195
    May 2012
    i need some help with sizing on the mayor. im 6ft and ride not sure if i need medium or large. im gonna use it for winter trail ripping and not much of long distance touring so im thinking i should go for medium which has ETT length of 24inches. seat tube length on large is 21inches which seems too long as well...any thoughts guys?
  96. #196
    Quote Originally Posted by powanddirt View Post
    I am 5'11" and always ride large trail bike but matching them numbers put me on a medium Mayor though I don't have it in my possession yet.
  97. #197
    May 2012
    ya i think we are on a same boat. i like my bikes on a smaller side and ride medium banshee spitfire v2 in summer which has ETT of just over 23inches so i think i will have trouble throwing around large mayor. medium mayor with 50mm is gonna put me when i want it im thinking.... did you go with bluto or carbon fork?
  98. #198
    I am a simple man so carbon fork.
  99. #199
    May 2012
    cool. im intrigued with bluto but since im gonna use it for snow trail riding 90percent of the time im not sure if suspension up front with matter that much. this will be my first fatty and boy do i have no clue!
  100. #200
    Me too can't wait...
  1. watch out for handlebars/grips being too tall on 12"/14"/16" bikes
    By cmc4130 in forum Families and Riding with Kids
    Last Post: 09-12-2017, 03:37 AM
  2. "Next" and "Mongoose" mountain bikes
    By SpAgetttt in forum General Discussion
    Last Post: 09-20-2014, 06:10 PM
  3. RSD Fat Bike "The Mayor"?
    By bikeshane in forum Fat bikes
    Last Post: 02-05-2014, 05:53 PM
  4. "Lil Shredder" high-end kids bikes... these are the goods!"
    By biobike in forum Families and Riding with Kids
    Last Post: 08-06-2013, 07:59 PM
  5. Replies: 2848
    Last Post: 01-01-2013, 09:36 AM
Members who have read this thread: 210
