Results 1 to 9 of 9
    Dec 2010
    Rear derailleur recommendations
    Hey all,
    I'm looking to replace the rear derailleur on my pugsly...any recommendations? Also, is it usually advisable if you replace the derailleur that you replace shifters as well?
    Thx
    Mark
    Reputation: vaultbrad's Avatar
    Oct 2007
    what is the reason for the derailer replacement? That will help guide the people with opinions to share
    wjh
    wjh is offline
    Feb 2012
    I have x9 rd and x7 shifters on my bike. Works great and reasonably priced. I say replace both.
    0
    Also, when someone asks a question on here, why do so many respond with more questions? Annoying
    nvphatty
    Guest
    x9 med cage.
    Dec 2010
    LBS says that it is wearing out. I ride the crap out of the pugs as it is my only bike. Lot's of miles in the summer...100 mile rides...
    Edit:
    It currently has the original derailleur that came with the 2010 Snowblind....
    Oct 2012
    If you switch from Shimano to Sram, the shifter indexing will change, so you will need different shifters if you want to use the indexing feature. Also, I don't think a sram bar end shifter will mount on a paul's thumbie designed for a shimano, or vice versa.
    edit: I have read that with a slight mod, or even without the mod, it is possible to use a Sram 9 speed shifter with a Shimano 10 speed derailleur on a 9 speed cassette, so you can get a clutch style derailleur to work on a 9 speed cassette.
    Quote Originally Posted by nvphatty View Post
    x9 med cage.
    Med cage for 2 ring set-up, long cage for 3 ring.
    Human Test Subject
    Reputation: Volsung's Avatar
    if you want to keep your shimano shifters, i got a 9 speed year old xt on chain reaction cycles for 67 bucks.
    but if you've put so many miles on it that your rd wore out, your shifters might be soon to follow.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I've been happy with shimano xt rd's .
    But you really need to stick to the same brand of shifter you have, unless you want to replace both.
  1. Replies: 0
    Last Post: 03-28-2013, 04:05 AM
  2. Will an X0 rear shifter work with a Red rear derailleur?
    By Jonnybravo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2012, 11:12 PM
  3. Need recommendations on crank, rear derailleur, and shifter...
    By nattyboh74 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-10-2011, 11:49 AM
  4. Rear tire recommendations
    By wjb in forum Wheels and Tires
    Last Post: 08-22-2011, 08:33 PM
  5. Replies: 5
    Last Post: 04-08-2011, 07:09 PM
