Results 1 to 12 of 12
    Mar 2011
    A real Fatbike .
    Now this is a real fat bike .
    dual single-sided swingarms-a righty up front, and lefty out back. Dope! Let's see one of these built up with some Husker Du's.
    Geordie biker
    Reputation: saltyman's Avatar
    he needs to drill his rims to save weight!
    2014 milage so far - 2,485
    www.ukfatbikes.co.uk
    Reputation: Eville140's Avatar
    And it's a tandem.
    Those Quicktimes are beat though, but traction on dry probably isn't an issue for him.
    Administrator Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    No brakes either, must be fun on the downhills,especially wearing flip flops. I guess if you are going to do it Hoosier Dirt Track tires are the way to go.
    Try this: HTFU
    Reputation: westwood's Avatar
    It's got brakes, it's a fixie.
    Not a MTBR legend.
    Aug 2003
    Quote Originally Posted by westwood View Post
    Ah well there you got then, bet that is easy to back pedal to slow! Those tires probably only weigh 10lbs a piece and that frame has got to be light was well. Even more crazy.
    Try this: HTFU
    Reputation: GTR2ebike's Avatar
    May 2010
    Quote Originally Posted by rockcrusher View Post
    10lbs? Try 40+
    It may have a brake on the jackshaft?? Or the front??
    Nov 2007
    Fender and rack mounts?
    wonder what kinda trail numbers you need to compensate for the friction of the contact patch?
    If steel is real then aluminium is supercallafragiliniun!
    aka RossC
    Reputation: ocean breathes salty's Avatar
    Quote Originally Posted by SmooveP View Post
    It doesn't need rack mounts: It comes with a butler to haul your stuff
