RaceFace 100mm BB
Printable View
  • 11-29-2012
    woody_8_5
    4 Attachment(s)
    RaceFace 100mm BB
    Pictures are of the RaceFace Team XC BB that came with my Fat Turbine Crankset and the RaceFace Team DH BB. When the XC inner sleeve was put on the DH BB it ended up being the same length as the XC BB with its original sleeve. The DH BB and the XC BB are both 127.5mm in length when using the XC sleeve. The major difference in the 2 BB's is the DH BB shell is a lot deeper with more cup threading into the frame, the added length of the shell is nice with 2 spacers on the drive side and should improve overall strength.
    Cheers
    Attachment 740933
    XC (left) 127.5mm / DH (right) 118.8mm
    Attachment 740934
    XC sleeve 86.9mm / DH sleeve 78.1mm
    Attachment 740935
    Measurement below is the cup threads.
    XC 14.6mm / DH 19.8mm
    Attachment 740936
    XC sleeve for 100mm BB is machined aluminum not plastic like the DH sleeve
  • 11-29-2012
    nvphatty
    Based upon what i see it makes perfect sense.
  • 11-30-2012
    Leopold Porkstacker
    Iíve been running the team DH BBs for over 3,000 miles of fatbiking. The first one started to develop a noticeable grinding/draggy feel to it after 1,800 miles, but that was because I was constantly dunking it in the sludge/puddles and riding it throughout the rainy season.
  • 12-05-2012
    Om Flyer
    @ Woody, How are the Turbine's working out? Any reviews or pics? Thanks!
  • 12-05-2012
    woody_8_5
    6 Attachment(s)
    I should have my Beargrease frame set in the next week or 2 and will be able to give a better review of the cranks after I have a few rides on them. RaceFace moved the chain line out on all of their Fatbike crank sets so these are not your average Turbines with a 100mm spindle pressed in. I had nothing but problems with last years e.13 crank set. BB issues that was fixed by putting in a Enduro BB and after fixing the BB problem a few months later the non drive side crank arm started to develop play on the spindle. I sent the crank set back to e.13 for warranty replacement and they sent a new crank set back after inspection, good customer service with e.13. I ended up selling the new e.13 cranks and this ended up paying for the new Turbines. I had a chance to look at the new e.13 double crank set out of this years Muk2 and was not impressed, especially with the plastic bearing pre load system. The RaceFace cranks look very solid and well made so it will be interesting to see how they hold up compared to the experiences I had with e.13.
    Cheers
    Attachment 742766
    Attachment 742767
    Attachment 742768
    Attachment 742769
    Attachment 742770
    Attachment 742771
  • 12-05-2012
    smthgfshy
    Could you please give us a weight? Cost?
  • 12-05-2012
    woody_8_5
    I have never been a guy that counts grams or made purchases based off them. I have a few things to do at the LBS tomorrow and will get the total weight of this set up. Not going to post what I payed but here is MSRP cost for everything.
    100mm Fat Turbine crank arms with Team XC BB - $200.00
    Team DH BB - $49.00
    RaceFace 32t Light Bash Guard-$35.00
    10 speed 32t Turbine chainring-$44.00
    10 speed 22t Turbine chainring-$25.00
    Chainring bolts-$12.00
    Total-$365.00
  • 12-06-2012
    Om Flyer
    Brilliant pics, Thanks! Way better than the RF site.
    I'm trying a pair out as well(when they arrive), I opted for 24/36/Bash config. and I guess I'll start with the XC BB but the DH BB looks like the bomber set-up. Both spindle and crank arm machining looks stellar, thanks again for the info and pics.
  • 12-06-2012
    dotMR
    I'm not sure I understand. As pictured, are the BBs intended for different shell sizes? The Team DH BB (on the right) says for 100mm shells but looks notably narrower than the Team XC as pictured. Or does the Team XC rely on more spacers?
  • 12-06-2012
    JoeG
    I second dotMR's confusion...
  • 12-06-2012
    woody_8_5
    I'm not sure why there is are difference in lengths with the 2. All is care about is the DH BB ended up being the same length as the stock Team XC BB that came with the crank set. I ordered the DH BB at the same time as the cranks and when I saw the difference in length I had a WTF moment until I tried the swap and took some measurements. If the stock sleeve in the DH BB was used it would bearing meet up with the other cup and after a few spacers I'm not sure if it would.
  • 12-06-2012
    roobydoo
    AFAIK The DH is narrower to allow for more adjustability. The XC assumes full width with required spacers. It may simply come down to Raceface assuming a certain amount of room/play was needed for the DH, and then by the time they made the XC, they realized it was unnecessary and took out the slop in the spacer and made the cups lighter/cheaper for XC.
    I have the DH version, and it went together just fine regardless.
  • 12-06-2012
    dotMR
    Thanks for the info. Was the goal of running the DH version (rather than the XC that came with the cranks) extra thread engagement in the cups?
  • 12-06-2012
    woody_8_5
    Yes running the DH for the extra thread engagement in the cups was the goal. Total weight of complete crank set with the DH BB - 935.53 grams.
  • 12-06-2012
    Borgschulze
    RaceFace DH BB didn't play well with my Fatback frame.. some thread got mangled from the chainstay holes in the BB shell... it threads in okay, just has a bit of resistance.
  • 12-06-2012
    nvphatty
    thats right about the same as my atlas.
  • 12-06-2012
    damnitman
    Are the drive side splines compatible with Isis?
  • 12-06-2012
    woody_8_5
    Not sure about compatibility but it looks just like Isis
  • 12-06-2012
    smthgfshy
    Thanks for the weight. Seems a bit heavy though as that's only slightly lighter than my Atlas (arms, DH bb, 34t, & bash = 965). I was expecting something like 875 +/-. Yeah, I'm a weight weenie....
    I'd love raceface to throw something out there that would give e-13 a run for their money.
  • 12-06-2012
    bjfalken
    definitely not isis. the whole point of external cups is a bigger spindle diameter. x-type big, isis little. like hollowtech2 vs octalink.
  • 12-06-2012
    JoeG
    Race Face Aluminum - EXI cranksets feature the industry standard ISIS Drive spline for the interface between the RH crank arm and
    the BB spindle.
    That is from Race Face's crank installation instructions http://www.raceface.com/comp/inst/B1...I_Crankset.pdf I believe that Hammerschmidt cranks use the ISIS spline pattern on one side as well.
    It is irrelevant, though as current Race Face cranks all have the spindle pressed into the non-drive side crank. It isn't removable (well, not unless you destroy the crank!) Thus they have to be used with an external cup BB from Race Face or another manufacturer.
    An ISIS BB had the spindle as part of the BB and the cranks bolted on to each end like this
    ISIS cranks both had a 10 spline interface that attached them to the BB with a bolt along the spindle axis. This is a good view of the 10 spline pattern on both the drive and non-drive cranks
  • 12-06-2012
    montana_ben
    Turbine with stock bb cups, set up is 1x (32t) & bash. So far so good...
  • 12-06-2012
    woody_8_5
    Heading to Minneapolis tomorrow morning to pick up my 45NRTH boots. I will get a more accurate weight on the cranks when I'm there. Not convinced that the weight I posted today is correct, old scale and I needed to covert the weight to grams. Your e.13 comment I assume you are talking about weight not durability.
  • 12-07-2012
    smthgfshy
    Yuppers!! That's more like it!! Now we're talking!! Thanks for posting that weight!!
  • 12-07-2012
    bjfalken
    differenter
    " I believe that Hammerschmidt cranks use the ISIS spline pattern on one side as well."
    Hammerschmidt uses a proprietary Hammerschmidt standard of b/b spline, different again. The Hussefelt and a few other cranks uses a different one again: its like a beefed up isis. truvativ does make isis and howitzer b/bs for 100mm b/b shells though.
  • 12-07-2012
    woody_8_5
    montana_ben
    I thought the shop would have a scale like yours for a more accurate weight but this is what they had. I would hope the true weight is not much more from what you came up with.
    Attachment 743271
  • 12-07-2012
    autodoctor911
    I don't see how people are taking a crank arm atatchment interface standard and applying it to a type of BB bearing design. ISIS splined is a standard for the way the crank arm atatches, that's it!
    there are different types of ISIS BBs some are cartridge type with the spindle stuck in it, some are external cup bearings, some have the spindle in one arm, left or right, some have a separate spindle, and surly even has one that has ISIS on one side, and another standard on the other side.
    the only fatbike cranks that don't use ISIS splined that I've seen are the E13s and the old JIS square drive cheapos.
  • 12-07-2012
    bjfalken
    ugh. just trying to be helpful. isis is a crank/b/b interface standard true, but only on older isis cranks and b/bs: truvativ raceface ect. anything else is not isis, is not isis compatible. race face x-type is not isis. the only fatbike cranks that do not use isis are everything except isis cranks.
  • 12-07-2012
    autodoctor911
    Interbike 2008:
    EXI interface details from Race Face:
    Our EXI interface was developed to improve the ease of installation of our cranks without compromising the durability and security of the highly stressed interface area. The EXI BB spindle comes equipped with standard ISIS splines on one side of the spindle which allows for standard ISIS puller tools to be used for removal. The ISIS splines also allows for the crank arm to seat half way on the spindle before tightening. The EXI interface retains Race Faceís unique chainline adjustability with the 1mm chainline spacers which now sit directly on the integrated crank stopper which is installed into the crank arm reducing the amount of loose parts.
    Oh, and it also says so on the RF website if you click on the description for the Atlas cranks:
    Introducing the second generation Atlas cranks. Continuing to utilize the same proprietary OPTIM-AL alloy (20% stronger than 7050) these cranks have been updated to utilize our EXI (external ISIS) interface for improved user installation and removal. In the process we have been able to sculpt away between 31 and 81grams depending on configuration from our first generation offering without sacrificing any strength, producing our lightest big hit, freeride cranks ever! 822g (165x36T, w68/73 + BB) 842g (165x36T, w83 + BB)
    I thought that EXI was ISIS, but I wasn't sure, so I dug up this article about the raceface cranks. I think the Raceface cranks are probably the best out there. I don't know yet where the best place to buy is, or which ones to get, but I probably will try the atlas.
  • 12-08-2012
    bjfalken
    ah, i see your point. RaceFace is just Bell Sports now anyway. i'm going to use my old internal b/b 3 piece isis system turbine cranks till OD cranks are available.
  • 12-08-2012
    jgorrilla
    Weights
    I weighed my 175mm arms at 655 grams. With a 32t single ring and alloy bolts, 696 grams. The Race Face bottom bracket is 113 grams with the Delrin spacers and the packet of hardware, chainring spacer, pedal spacers and inner bolts is 22 grams.
    I'm running mine with a King bottom bracket with no sleeve and it's been absolutely terrific with no issues loosening like I had with last year's e13.
  • 12-25-2012
    autodoctor911
    175mm turbine arms and BB for 209.99. good deal?
    RaceFace Turbine Fatbike 175mm Black Crank Arms with 100mm BB | eBay
  • 12-25-2012
    Wombat
    Here are some other options:
    Universal Cycles -- Product Search - 4 Products
    Tim
  • 12-27-2012
    BertRoot
    So I have a RaceFace Diabolous 100mm downhill crank and a 100mm RaceFace DH bottom bracket and am aiming for a 66mm chainline on an OnOne fatty. Am I going to be able to make this work do you think? Looking at a single 32t chainring where the middle ring would go and a bash where the outer would go.
    Can't try it yet because my bottom bracket tool is out on loan till the start of January...
  • 12-27-2012
    nvphatty
    I believe / think it would be fine........but then i was wrong once. ;)
  • 12-30-2012
    JoeG
    I put a Race Face Evolve 24-36-bash fatbike crank on my Fatty. Per Race Face, its a 67 mm chainline when set up stock (per their recommended spacer configuration). There is 1 mm (yes, 1 mm!) clearance between my 36 middle ring and the chainstay. The 24 has plenty of space. I think that your 32 will be just fine, even if the chainline is slightly inboard of mine.
    The original crank was a Truvativ Holzefeller 32 with Howitzer BB; chainline unknown.
  • 12-30-2012
    Lars_D
    Originally Posted by autodoctor911 View Post
    ...the only fatbike cranks that don't use ISIS splined that I've seen are the E13s and the old JIS square drive cheapos.
    Phil Wood makes some very highquality JIS Bottom Brackets.
  • 12-31-2012
    Blitz Cycle Works
    Was just getting things rolling with them as a supplier so I just put the RaceFace evolve crankest on one of my builds. Rode it for a couple hundred miles and did an endurance fat bike race with it and so far is like a champ! Customer service is outstanding also. Will try the Turbine next time. I'm very happy with the quality.
  • 01-01-2013
    imc2007
    Update? How are they in use?
  • 01-01-2013
    Andy FitzGibbon
    That's why you chase the threads before installing a BB.
