Results 1 to 77 of 77
    Jul 2015
    Race Face Cinch BSA 30mm BB Alternatives?
    So after 4 months of ridding on my Race Face BSA 30mm BB, using a Fat Bike Turbine Cinch Crank(190mm), it has developed the proverbial creak that drives people insane. I'm sure its the BB as everything else has been tightened down to spec with a torque wrench, and some loctite. The reviews in general are almost unanimous in describing this BB has quite terrible in terms of bearing life and creaking.
    Ideally I'd like to try and avoid buying another proprietary BSA 30mm BB, like the E-thirteen format and having to buy another tool. I also would like to avoid buying another Race Face Cinch BB, since it will probably fail again in 4 months. Buying 3 BB's a year for one crank is not a reasonable solution.
    So then is it possible for me to purchase any standard set of reliable BB30 bearings, and have my lbs just press in the new bearings? I don't really care if it costs as much as a whole new RF BSA30, at least it will last at minimum 3 times longer.
    The Sram GXP on my old Fat Bike is still running strong and smooth after almost two years. Hollowtech's last at minimum two years, hell the old faithful Shimano UN-55 on my commuter is 3 years old through 3 winters, and is till smooth and silent. These RF Cinch BB's are really quite a let down.
    Any suggestions/advice is appreciated, I just need to get rid of this creak before I end up in an asylum.
    Jul 2013
    Hope now make a 30mm BB:
    Bottom Bracket 30mm (Threaded) | Hope Tech | Made in Barnoldswick, England
    Needs a proprietary tool dunno if it's the same a RF?
    i don't give a shift
    Reputation: collideous's Avatar
    I'm running RWC's external cup BB30 for my RaceFace and Rotor cranks. Quite a few Enduro bearing options and they come in pretty colors too. I use stainless steel bearings for winter use. Everything else always ended up corroding.
    blogging @29in.CH
    since 4/10/2009
    Reputation: Harold's Avatar
    I am up to about 550mi on my RF BB92 CINCH BB with nary a peep. That includes a few creek immersions, a whole winter's worth of riding, and the wettest summer on record where I live. When I do wear it out, I intend to replace it with the Enduro bearing that fits my bike. Just to mix it up and see if I get different life out of it.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by collideous View Post
    Thanks for the link.
    Each of the options found there says that they are specifically for BB30 cranks. My guess is that it doesn't matter, but I wanted to make sure you were running the RF (Next? Turbine?) Cinch cranks for a fatbike, and not something else?
    Thanks.
    Jul 2015
    Seems like a solid option, they even use the existing RF Cinch Cup standard for their tool. Now I'd just have to get over the CND/US exchange rate, $170 is steep for the Stainless bearings. They're out of stock of individual bearings, so its probably my best/only option.
    Quote Originally Posted by Harold View Post
    I've had this BB for four months, I don't usually count my distance, but a conservative estimate is about 1000miles. I expect all BB's to last at minimum one year, anything below that threshold is inadequate. Reviews online seems to show quite a few cases of early failure.
    Also investing $500-$600 in an alloy Crankset setup, should mean some level of quality, and dependability. I assume if I rode this BB in my winter conditions, it would probably seize up and explode in a month or two. This is probably the last RF crank I ever purchase, since I've had quite some trouble with the whole setup. I just wish Shimano would make a FatBike Crankset setup, I'd be buying it tomorrow and selling my RF on ebay the next day. I always try an support Canadian companies, but I've never had so many early failures in one Crankset setup.
    Quote Originally Posted by mikesee View Post
    Thanks.
    They specifically mention the RF Cinch/Next SL 30mm crank compatibility on their website.
    Thanks.
    I use them on my fat-bike with RF Turbine Cinch cranks and on my 29er with Rotor cranks. They build a little narrower than other BB cups. Nothing the right spacer configuration can't fix.
    I've broken two drive-side cups on my singlespeed, but I'd probably do that with every 30mm external cup. There just isn't much meat for the threaded portion of the cup. Haven't broken one on any of my geared bikes (fat and road).
    blogging @29in.CH
    Oct 2007
    I've used the E13 BBs on my hollowgram conversion. They are alot cheaper, but I can't speak to the bearing quality. My understanding is that replacing the bearings in the e13 stuff is pretty simple. I'm planning on doing it soon.
    Bottom Brackets
    Jul 2015
    So after doing some research, I found this site. It seems the key measurements here are the 30mm inner diameter, and the 42mm outer diameter, and 7mm width.
    VXB Bearings 30mm x 42mm x 7mm]VXB Bearing online: Search Results
    There are Stainless Bearings for about $20 a piece. So two bearings with shipping are about $55. The regular Chrome Steel bearings are only$12.95, I'd guess these are the current bearings in the stock RF BSA30 BB, and E13 BB's. While the Stainless Steel Bearings are the ones in the Hope 30mm BB.
    The angular bearings are more expensive then the RWC versions(which are out of stock), but everything else seems priced well. And it seems you have a huge selection. I just need to figure out if my LBS can even press the bearings for me, and if their service fee will push me past the Hope BB.
    EDIT: Wheels Manufacturing also has this type of bearing for sale.
    Reputation: AllMountin''s Avatar
    I am going to be swapping bearings as well. I've tried to grease/antiseize/Teflon tape every piece, to no avail. Always creaks under power, and horrid snapping/popping sound comes and goes. Stupid annoying.
    The RF bb issues haven't been a problem for us, I have a set on my Mutz and two sets on my Jefe, they are tight and noise free.
    Assuming it becomes a problem, can the bearings be replaced with something better at less cost than buying an aftermarket bb? I went to the bearing sales link and it was a blank page.
    Jul 2015
    So after more research I've confirmed that any 30x42x7 6806 bearings should fit the RF Cups, Race Face BB Specs.
    I've narrowed down the selection to either;
    Enduro 6806 ABEC-5 Sealed Bearing ($34 for a pair), or Enduro 6806 "ZERØ" Ceramic Sealed Bearing ($78 for a pair), plus shipping.
    These seem like the most reasonable options, in terms of cost ratio. I think I'm going to go with the steel bearings, since I have no idea how ceramic bearings behave during winter riding. Wheels Manufacturing also has the tools do extract and press them yourself for about $80 total. Ideally bearings are replaced at long intervals so I don't mind just going to the shop.
    I had my RF bb bearings shit the bed after 6 months. The person I spoke w/ at rwc said the bearings in the rf bb are VERY difficult to extract...and he strongly suggested replacing the cups w/ bearings already installed. He might have been trying to upsell me, but provided first hand knowledge of the issue. Ymmv
    Jul 2015
    Quote Originally Posted by jonshonda View Post
    Sounds like an upsell, takes 2 minutes to remove, then install new bearings.
    Race Face Tech: BSA 30 Bearing Removal Instructions
    Race Face BSA 30 Bearing Install Instructions
    Easy peazy
    Update us when you replace your bearings.
    Reputation: dRjOn's Avatar
    good info. ill be interested to see how my RF bearings fare and im sure there are good options if they struggle - kogel or even ceramic speed are a consideration. another potential option? B.O.R Fatbike Bearing Kit
    Fat & Single
    Reputation: ozzybmx's Avatar
    First RF BSA30 I fitted with my Next SL's, creaked nearly immediately, I ordered another one as it was a good price and I needed a spare to take away for a race. Fitted it and it's been silent for a year now.
    Inconsistent quality with RaceFace, surprising they don't lift their game as charging $500 for a great crank set and supplying a crap BB is not ideal. Easily replaced with a similar 6806rs bearing that is fitted, just haven't got around to it yet.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Quote Originally Posted by l3eaudacious View Post
    Where can you buy the tools shown in the video?
    Sent from my SCH-S968C using Tapatalk
    Jul 2015
    Quote Originally Posted by 8iking VIIking View Post
    I'm not sure about the exact tools show in the videos, but any press/extractor for 6806 bearings should work. They're probably some in-house tools I'd guess.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Nine bucks a bearing at the local bearing shop.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Reputation: Johanneson's Avatar
    May 2012
    I'm also running RF BSA BB30. Two bikes are stock steel bearings and one I switched out to Enduro ceramic they all work great no creaking and smooth but I do keep them greased. The last crankset came with an alloy spindle sleeve (RF 169mm) so I installed it. It creaked, the sleeve, so I took it out. No problem. If you have one of those in there I'd look at that as a possibility for the noise.
    anybody ever used this tool from phil to replace bearings in a BSA 30 bottom bracket?
    http://www.avt.bike/images/Phil_Wood...earingTool.jpg
    i think its for their own bb and will work on other outboard 24mm bb s but not sure if it will work with a 30mm BSA ?
    Quote Originally Posted by Johanneson View Post
    Did you remove the old bearings from the cups, or just replace the entire bb? If you replaced the bearings yourself, can you provide feedback on how the swap went?
    JLF
    JLF is offline
    Quote Originally Posted by dRjOn View Post
    You know, just last week I feel like I was on the same exact hunt that you are on now. I did look at that tool but passed on it as I didn't want to use a vice.
    My solution was to go with a Park Tool BBT-30.3 for bearing removal. For installation, I use the Wheels Manufacturing Press-4 coupled with (2EA) 6806 Over Bearing Drifts. This solution allows me the option to service the BB without removing the cups.
    Additionally, I did look to Enduro Bearings for replacement 6806 bearings and they did attempt to up sell me on their BB. I told them I was sure about purchasing the 6806 bearings from them but asked what the advantage was between their BB versus the RF Cinch BSA30 BB... They informed me that their was in fact no gain between the cups but rather the convenience of have the bearings pre-installed and only requiring me to change out the cups. Realizing that this conversation just jumped by a couple hundred dollars for little gain and realizing that later on down the road I'll have to service the BB due to regular maintenance, I opted for the tools. IMHO, there's nothing wrong with the RF BB, but the bearings are the culprit.
    Good luck, please let us know how you come out on this...
    Rocking on a Rocky
    I just did a bearing swap on my bike. Take off the plastic covers pull the old bearings.
    Rocking on a Rocky
    Hammer or impact bearing puller
    ^$38 on ebay for the set. Not bad....will put on xmas list.
    Aug 2015
    I'm getting the same creak from my Rf cinch bb/crank on my fat bike. I have rebuilt it 5 times and just replaced the bearing, but the creak is still there. Any other suggestions? I barely have 800km on the bike.
    Quote Originally Posted by Cooperg View Post
    Did you have the bb shell faced? If not, have it done to ensure you are working with good mating surfaces. Use lots of lube when assembling also.
    Jul 2015
    So bearings are replaced! Took the lbs about 4 mins to replace the bearings. Any claim about them being difficult is just an up-sell. I ended-up splurging on the Enduro 6806 "ZERØ" Ceramic Sealed Bearing since ceramic apparently fares well in low temperatures, and I've never tried ceramic bearings(curiosity!). Unfortunately I can't really say how well they peddle since my rear Hub exploded a second time, and I'm waiting for the lbs to fix the wheel.
    In terms of the old bearings, the Drive-Side bearing was completely shot, making creaking and grinding noises by simply rotating with my finger. The Non-Drive-Side bearing is in much better shape, but also creaks, although not as loudly, simply rotating with the finger. You can feel the rotation isn't smooth on the Drive-Side, while the Non-Drive-Side seems fine in feel.
    So I'd guess most bearing creaks are early Drive-Side bearing failure. Not enough lube grinding bearings, or faulty bearing balls? In any case, any 6806 non-angular bearing should work, and is a really quick switch!
    Rocking on a Rocky
    FYI if you replace your own bearing pull the seal off and pack it with some synthetic cold weather grease.
    JLF
    JLF is offline
    I ended-up splurging on the Enduro 6806 "ZERØ" Ceramic Sealed Bearing.
    Please let us know of your first impressions along with follow-up reviews on these bearings. I've been told those "ZER0" bearings are quite good. If memory serves me, I think Enduro's top-of-the-line bearings are the "XD-15" followed by the "ZER0".
    Reputation: Velobike's Avatar
    One possibility to bear in mind is that hydroformed frames with large tubes, and also similar carbon ones basically form a large echo chamber. Noises you don't hear on a conventional steel frame get amplified to annoying levels.
    This thread does highlight how ridiculous BB standards are though. What we really need are decent size bearings with grease nipples so we can keep them serviced.
    A bearing that's full of grease can't suck water in - it's not as efficient as an oiled bearing, but these aren't road bikes.
    Latitude: 57º36' Highlands, Scotland
    since 4/10/2009
    There are more stresses on the drive-side bearing compared to NDS. That's why they go first.
    I agree that BB standards are ridiculous. Why so many? Everybody wants to be different?
    Loud hubs save lives!
    Reputation: 43st's Avatar
    Jan 2013
    Quote Originally Posted by JLF View Post
    I thought the ZER0's were recommended for road bikes and dry conditions due to the looser (faster) seals?
    I was installing a brand new RF Cinch BB into my Bucksaw over the weekend. Before pressing them in I decided to pick off the seals and check out the grease levels inside. The OEM grease is slick on your fingers but appears quite thick as it is pressed into the race and not much visible indication of movement can be seen while spinning. Almost like a gel. Maybe some long term friction or heat will break it down a bit and spread it around. (??) On the outboard face of both bearings the grease is packed 100% around the perimeter. On both inboard faces the grease only filled 2/3 of the perimeter. Took the opportunity to squirt in some more marine grease in the gap. Now spinning the bearing you can see the new grease spreading along the surfaces and mixing with the OEM. Can see it working in the race and on the balls.
    since 4/10/2009
    Quote Originally Posted by bme107 View Post
    Pretty sure it does break down and spread around. My BB spins MUCH more freely than it did when new. Should have an Enduro BB to replace the CINCH BB on my Bucksaw this week, because the DS bearings are grindy on top of it.
    Jul 2015
    So I got the Hub back, lbs worked their magic and got me a rebuild with a Hope Pro 2 Evo 2015 full comp! I think they were tired me coming in. Did a quick ride to test everything out.
    So the BB creak is completely gone. I did clean out the BB, greased everything (probably too much grease), made sure to put plenty of grease between the BB shell/cup interfaces. I mainly use Slickoleum now, I know its a suspension grease, but its rated for low temps, and its cheap locally.
    In terms of the ZERO bearings first impressions are great, buttery smooth. I'd say think of the regular RF BB when finally broken in, but better, and right off the bat. It feels really weird not having some kind of break in period. I'll post again with long term use, really looking forward to see how they fair this winter.
    Hopefully with the Hope in the back and the ceramics in the BB, stuff will stop breaking, and I'll be able to do some of the longer rides I had my eye on. Was a bit sheepish with the old parts, didn't want to get stuck in the middle of the forest with a busted BB bearing, or imploded Hub.
    Just did the bearings in my BSA 30. The first one I burned out with a map gas torch. It's super effective, and the bearing just falls out. Your cups won't be black anymore though. For the second cup I just used a ground down washer, about the diameter of the inner race, and sharpened on the edges. Combined with a tapered drift, it does a nice job of replicating the Park Tool. The bearing tapped out easily. I just went with the standard enduro bearings, which spin smoother than the stock RaceFace units.
    Oct 2015
    just curious if anyone has tried this BB or bearings?
    Kogel Bearings - High Quality Bicycle Bearings
    seem to have a lot of positive roadie feedback, haven't seen much for MTB use
    Hi Everyone. I too have recently been bitten by the RF BB30 bearing issue on my Lamere Carbon 190 fatbike. After only 100 miles the drive side bearings begin to degrade into a mind numbing creak at even the slightest pressure during the pedal effort. I have had a lot if experience with carbon, Ti and all grades of aluminum frame bottom bracket issues and have usually been able to remedy it with automotive grade silver thread compound paste. Not this time. I quickly ordered the Real World Cycling BB30 cups/ bearings and problem solved. I have always been a big fan of RF but this time not so much. I only have 3-4 rides on the RWC so I will post an addendum if anything changes.
    aka bOb
    Reputation: bdundee's Avatar
    I just popped my old ones out of the RF cups and installed new Enduro bearings. Took about 30 minutes and didn't even take the bb off of the bike and cost about 23 clams.
    What did you use to punch them out?
    Thanks,
    Mike Tyson
    aka bOb
    Thanks,
    Mike Tyson
    Funny!!
    I'm not into precision, a flat head screw driver and a LFH got er done.
    Oct 2011
    What sleeve did you use with the RWC BB? When combined with the RWC BB, the Race Face sleeve for a 100mm BB pushes the cups out an extra 5mm per side.
    Quote Originally Posted by BlackSheep01 View Post
    On the axle I used RWC's own BB-30 spacers. Behind the BB cups I used VeloSolo's cassette spacers.
    blogging @29in.CH
    Oct 2011
    No center tube between the BB cups?
    No center tube.
    blogging @29in.CH
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    One thing that hasn't been mentioned here is that spindle-on-bearing contact can also be a source of noise in worn BB bearings.
    I read on another site that someone had encountered more noise on replacement Enduro bearings for Shimano than the stock Shimano bearings because the Enduro bearings had removed the plastic seal/sleeve the seperated the spindle from the metal bearing retainer.
    With that being said, though, my XTR BB with the plastic bits still creaks/pops/clicks up a storm, but it's also 3 years old now.
    I'm curious to see how the replacement bearings hold up.
    GIS/GPS Pro using ArcFM for Utility Mapping - Always willing to connect with other MTBers in the industry.
    rth009
    May 2010
    Can anyone confirm that the E13 100mm Threaded bottom bracket BB20.P-BSA100.K will work with a Race Face turbine cinch? Both are 30mm crank spindles. I already have the tool for e13 bottom brackets and dont want to buy the one for Race Face/ RWC. It also appears the bearings are easy to pull and replace on the e13 bottom brackets. Thanks
    since 4/10/2009
    Quote Originally Posted by rth009 View Post
    CINCH cranks only care that your bb has room for a 30mm spindle. You will have to figure out the correct spacers on your own, because the cup thickness may be different. No biggie. CINCH cranks expect you'll use spacers. Better than those damn wavy washer setups or cranksets that require spacers behind the bb to put the bb cups in EXACTLY the correct spot.
    Dec 2014
    I just put those same bearings in my BB 2 months. They are nice and smooth.
    Sent from my SM-G900V using Tapatalk
    May 2005
    For the records, there will be soon a BSA30 bottom bracket from Chris King. I can't wait to get my hands on this beauty:
    SOC16: Chris King leaks new ThreadFit 30 bottom brackets for Cinch Cranks, Centerlock Road Disc hubs - Bikerumor
    Race Face Cinch BSA 30mm BB Alternatives?-chris-king-centerlock-road-hub-40th-anniversary-threadfit-30-bottom-bracketimg_3586.jpg
    And as my Race Face bottom bracket started to creak awfully, I did a search an Google and found this instruction to press out your current bearings from a Race Face bottom bracket. It's in german tough, but i think the pictures are self-explanatory.
    BSA30-Lager austauschen - crazyeddie
    Jul 2015
    Quote Originally Posted by prj71 View Post
    That reminds me I forgot to update.
    The Zero Ceramic Bearings lasted 6 months, and are in much worse shape then the oem RF bearings after the 6 months. Emailed vendor and was told these are really only meant for "Race Day" use not regular ridding. So much for ceramic being super though, harder than steel, and better suited for extreme temperatures.
    I ordered a 10 regular Abec-5 steel 2Rs bearings for $15 direct from china, they look similar to the oem RF bearings. I'm going to re-grease them with a good bearing grease for low temps. For $15 I can swap bearings every 6 months for 5 years. Or as soon as I hear a creak, I can just toss the old bearings, and not even waste my time.
    I was going to try the Angular contact bearings from RWC, but they're made by Enduro as well. The only way I"m ever buying "better" bearings again is if Shimano makes a BSA30 BB some magical day.
    Jul 2015
    Quote Originally Posted by randan View Post
    A bike specific bearing extractor for 6806 bearings is like $20, you can probably get a car bearing extractor in the correct size for cheaper.
    im pretty sure this tool is in here earlier on, but might be worth a repost.
    Race Face Bottom Bracket Service Tool Version 2 | Silverfish UK
    race face have clear 'how to videos' on youtube.
    the ceramic speed website has an interesting article (as you might expect!) discussing how all ceramic bearings are not the same. i suspect to sopme extent you get what you pay for.
    http://www.ceramicspeed.com/sport/te...icspeed-balls/
    Reputation: mfa81's Avatar
Name:	Chris-king-centerlock-road-hub-40th-anniversary-threadfit-30-bottom-bracketIMG_3586.jpg
    any word on availability? price?
    Reputation: mark59's Avatar
    Nov 2006
    Any one use the Hope BB 30 mm with the Race Face Next SL G4 cranks?
    I was going to use the RF BB but after reading all the reviews I want to use something else
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Quote Originally Posted by mark59 View Post
    Funnily enough my Raceface BB lasted far longer than the hope one I had fitted on my last bike. After ONE ride the hope was notchy, unfortunately Hope bearings are really soft Stainless and seem to be pretty poor of late. If you pack the RF bearings with grease they last reasonably well. What ever BB you use, you can just replace bearing fairly easily.
    Once the RF got noisy, I did as described above and pulled the bearings, as easy job that took 30 mins. I replaced with SKF bearings using a 'Blind Puller' set and then a BB30/Headset press to refit. I also removed factory grease from SKF's and refilled with Rock'n'Roll Web Grease. Tools I used below, the RF specific tool is ridiculously expensive.
    Brand New 5PC Inner Bearing Puller Set Kit Remover Blind Internal Slide Hammer | eBay
    BB30 bottom bracket press tool, bearing installation tool, fast UK postage | eBay
    Nov 2006
    Quote Originally Posted by Flying_Scotsman View Post
    Thats very helpful thanks . I had my eye on this bearing as well Threaded to 30mm Ceramic Hybrid BB - Black
    Monday morning I am going to call Chris King and see when theres will be available
    Thingamejigger
    The only problem I foresee is that the inner tube wont be long enough for a 100mm BB, unless you cut it and add a bit in. However, there are many who don't run a centre tube in their BB.
    someone somewhere showed a pic of the centre tube divided and inner tube plugging the gap. problem there being it wont 'push fit' into the cup...
    Reputation: Skrool's Avatar
    Jun 2014
    Thanks Bro! You've no idea how much this has helped me out. This company didn't seem to show up on ANY of my net searches!
    Just ordered the red / ceramic setup for my Sergeant Ti mid-fat 29er +...!!!!!
    Reputation: RSAmerica's Avatar
    I spoke to Chris King today, there BSA30 BB and T47 (new threaded spec BB) will be available in the fall.
    Reputation: IRBent's Avatar
    May 2015
    RWC BB - Longevity?
    I'm looking for a threaded BB to move up to a 30mm spindle myself. The lack of a tube between the two bearing cups looks like a great place for water to get in. So how's your RWC BB been holding up? I'm currently running a SRAM crank on their GXP BB and they use a 24mm spindle. I am thinking about a Race Face crank and going 1X. Any suggestions?
    The RF bearings are fine, I have a few sets, no issues, same with e13, no reason to go crazy, just make sure they dry after use, no high pressure water.
    I like the Next SL, but turbines are fine.
  67. #67
    May 2015
    I eventually opted for a Wheels Manufacturing BB to move up from the 24mm GXP to a 30mm BB on my Santa Cruz.
    http://wheelsmfg.com/bottom-brackets...-bb-black.html
    Sent from my A0001 using Tapatalk
    2015 Santa Cruz Bronson
    Only major components that are still stock on my bike, the Reverb dropper and SLX brakes.
  68. #68
    Jan 2017
    I have about 3500km on my RF BSA30. Lately I've been noticing a creak on the right side. I don't think it's the pedal. I think I will try to replace the bearings instead of spending big money on the Chris King. I don't even see a 100mm version anyways?
  69. #69
    Thingamejigger
    Worth a try, 6806 are the bearings you need for the 30mm axle versions.
  70. #70
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I guess I've been lucky, still running the original RF that came with my cranks when i built my bucksaw....probably close to 5K miles, re-grease it once/season by carefully pulling the seals off with a tiny screwdriver.
  71. #71
    Jan 2017
    The drive side bearing was super crunchy(only 3500 km on it). I cleaned it out and greased but it still had a bunch of snags.
    I put 20,000+ km on my FSA MegaExo with zero maintenance, and it still is spinning like new...
    anyways I bought a pair of 6806 Wheels Mfg bearings off eBay for $30cdn shipped. Punched out the old bearings with a screwdriver and hammer, squeezed the new ones in with a vice. Pretty easily done within an hour.
    Really disappointed with the RF BB. I think I will switch over to the Hope Tech 30mm eventually. Unfortunately and frustratingly, all brands (King, RF, Hope) use their own proprietary bb tools.
  72. #72
    Sep 2013
    Has anybody tried these:
    https://www.aliexpress.com/item/Free...2-2116096d05dd
    for that price I would not mind giving them a shot....
  73. #73
    Quote Originally Posted by tedkopp View Post
    https://www.aliexpress.com/item/Free...earing-.......
    Are those plastic?
  74. #74
    Jul 2016
    Quote Originally Posted by IRBent View Post
    Threaded to 30mm Angular Contact BB - Black
    I put the USA made wheels manufacturing with enduro angular contact bearings on my foes. its worked GREAT and the seals kept all the muc out this winter.
    Then this, 5 months in
    The Dealer was able to get it warrantied by Wheels MFG. so that better.
  75. #75
    Sep 2017
    why not ceramic?
  76. #76
    Sep 2017
  77. #77
    Dec 2017
    Enduro's Zero bearings are apparently made to provide as little resistance as possible, but that comes at the expense of longevity. Their XD-15 bottom brackets (with angular contact bearings) are meant to be the bees knees.
  1. Race Face Turbine Cinch 1x crank
    By LeeL in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2017, 04:34 PM
  2. race face cinch vs sram xo
    By blkcheerio in forum Beginner's Corner
    Last Post: 06-28-2015, 10:16 AM
  3. Race Face Cinch vs. SRAM XO1
    By LaCostaClydesdale in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-30-2015, 09:19 AM
  4. race face turbine cinch 1x10
    By Ruckus99ss in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-28-2014, 09:20 AM
  5. Race face cinch or sram xx1 for 1x9 setup?
    By Ozzy43 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-05-2014, 07:25 PM
Members who have read this thread: 179
