Results 1 to 9 of 9
    Q-Factor for Dummies
    I see the Cannondale CAAD Fat claims to have the best/narrowest Q-Factor in the fat bike market. With a 198 rear hub & 120 bottom bracket, I don't see how this would be possible. Can someone explain this to me in simpleton language, say... compared to a Pug?
    Same q-factor as a Pug or any other 170 frame. They sculpt the chainstays to allow the arms to clear, then run them with a single ring flipped outward for tire clearance.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Clobber View Post
    Q factor is going to be a factor of spindle length, but also with the specific crank arms used (as well as pedal spindles).
    The Hollowgram crank arms probably just have a narrower Q for the arms than most others.
    Jan 2005
    so what is the Q-factor on the Cannondale?
    198 single & 204 double I believe
    I think that Cannondale´s claim is that, for bikes able to fit up to 5¨ tires, they offer the narrowest q-factor, which is true as far as I can tell. For example, the Farley has big clearance and takes the Next Sl 170mm crankset, but that crankset´s q-factor is around 202mm.
    In the case of the Pugsley, you can have a narrower q-factor than Cannondale´s Hollowgram cranks, such as when using the Sram xx1 170mm cranks (195mm q-factor, which do not fit the Farley), or a Phil BB and Eno cranks. However, the Pugsley does not fit 5¨ tires. I hope that helps.
    Jan 2005
    Quote Originally Posted by Estuche View Post
    Great info. Thanks for posting it up.
    Jan 2005
    I did not look on their website but it's interesting that they have different Q-factors for single vs double chainring. They must be doing something similar to Raceface with the single ring and no spider.
    Reputation: Johanneson's Avatar
    May 2012
    Quote Originally Posted by Ranger Pride View Post
    With a single ring they have the C/S clearance to use the short spindle. With a double there is not enough C/S clearance and they use the longer spindle. Spiders and rings don't have anything to do with Q. There are a few bikes out there that have room for " 5" " tires while utilizing 190 r hub spacing in conjunction with a narrow "170" spindle on order to get a narrow Q.
  1. Lefty build for dummies...
    By geffr999 in forum Fat bikes
    Last Post: 09-07-2014, 06:54 AM
  2. 10 speed for dummies...
    By freeriderB in forum All Mountain
    Last Post: 01-24-2013, 01:06 PM
  3. Forks for dummies
    By cpfitness in forum Beginner's Corner
    Last Post: 11-26-2012, 08:54 PM
  4. Chainring Dummies
    By smudge in forum Frame Building
    Last Post: 02-22-2012, 12:54 PM
  5. Lake Tahoe for Dummies
    By Mithrandir in forum California - Norcal
    Last Post: 08-23-2011, 01:41 PM
