Results 1 to 3 of 3
    JYB
    JYB is offline
    Q-factor with 170 and 190mm rear ends
    The wider Q factor of my 170mm Fatback does not really seem to bother my knees. I've been riding this frame, almost exclusively, for over a year. I've ridden both the Fatback FSA crank and a SRAM x-9 crank. It seems that many companies are switching over to 190mm frames. I'm curious how much greater the Q factor will be on these frames with the cranks that are being used. I'm not convinced that I need a 190 rear. 170 feels like all the space I need, especially for summer trail riding. Can anybody chime in on this? Do your feet feel crazy far apart on a 190mm frame?
    Reputation: lancelot's Avatar
    Same Q factor as a 170mm frame unless you're running a double offset crank like the Surly OD to increase chain to tire clearance.
    Surly OD (Moonlander) is 213.8
    E Thirteen XCX is 198
    The LPG
    Reputation: GTR2ebike's Avatar
    May 2010
    Measure your Fatback FSA, I think the Q is larger than a Surly MWOD
  1. 135mm vs 170mm vs 190mm rear end
    By JYB in forum Fat bikes
    Last Post: 12-09-2013, 11:09 AM
  2. Replies: 15
    Last Post: 11-15-2013, 08:16 AM
  3. Replies: 55
    Last Post: 09-16-2013, 09:44 PM
  4. Wide rear ends get rubbed?
    By Pitch in forum Clydesdales/Tall Riders
    Last Post: 04-21-2013, 06:52 AM
  5. Fat bike rear ends 150mm vs 170mm
    By pyranha in forum Frame Building
    Last Post: 04-05-2011, 11:44 AM
