Results 1 to 9 of 9
    Reputation: bighit's Avatar
    Pug fork and 100mm rims
    Being an OG I should know these things, but I ran 50's so long I didn't pay attention.
    Can you run 100mm rims and a 3.7 on a 100mm spaced non offset pugsley fork.
    Recommendations are not to go over 70mm yeah and I shouldn't cut my frame and spread it with a car jack.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    Rhymes with fartmaster
    Im just wondering how to get the thing into the fork without first deflating the tire.
    Yeah also an issue.
    2012 Moonlander.
    Reputation: Velobike's Avatar
    Possibly could squeeze it in if you used a drum brake or removed the brake calliper first.
    (As well as deflating the tyre )
    Latitude: 5736' Highlands, Scotland
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    If the pug fork has canti studs, don't they need to be cut off to fit anything over 70mm?
    Ok here is what I got and want.
    I have a Sturmey archer 100mm spaced front drum hub.
    I want to lace it up to a 90/100mm rim and run a black Floyd.
    I have a moonlander 135mm non offset fork, but my hub dosent fit. I have to find out if I can change axles to a longer one.
    2012 Moonlander.
    Quote Originally Posted by bighit View Post
    I think it would be simpler to get a 100mm Pug fork. I haven't liked the feel under braking of any of the 135mm forks I've ridden.
    I use an 80mm rim
    You may be interested in my mod to the brake mount to make it quick to remove.
    (Used a shortened seat QR)
    Give the brake time to bed in, ie lots of hard use, and it improves.
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Quote Originally Posted by JordyB View Post
    No. I'm using a BFL on a 70mm UMA 2, and it clears the canti studs easily. Getting it in past the Hayes MX2 brake caliper is the tricky part, and I can only do so below 8 or so psi.
    ok i am going with my DNM suspension fork,
    50mm kris holm rims because i can get them in 36. i dont think have the space for 65mm LM's.
    i wish i could get some of the Echo rims in 36, but it looks like they dont make the ones i want.
    and my sturmey archer drum hubs. build on
    2012 Moonlander.
