Results 1 to 6 of 6
    Feb 2013
    problem with FD-M786-D direct mount front mech and small 22 tooth chainring
    Hello,
    I have a problem I have bought
    Problem Solvers Direct Mount Adapter BSA 100 (43,5 mm offset) but it wont work with Shimano xt FD-M786-D 2x front derailleur and phil wood bottom bracket I using it at my 9:Zero:7 fat bike. Problem is that front derailleur is to far than my little chainring 22 tooth I can use only my middle chainring. If I should buy BSA 100 (39,5 mm offset) but it for 3x front derailleur. I have spend my money to nothing... What you recommend?
    This is hard to read.
    Are you saying that the 43.5mm FD adapter pushes the FD too far into the chainrings after adjusting the limit screw? If so, the 39.5mm adapter would help. It's certainly the cheapest fix to try first at least. What crankset are you using?
    Jason
    Disclaimer: www.paramountsports.net
    Feb 2013
    Sorry for my English. Yes, you right. I dont know its 4 mm only not cheap to try. I have use old Shimano FC-M361 crankset
    Reputation: Nater's Avatar
    Re: problem with FD-M786-D direct mount front mech and small 22 tooth chainring
    I'd bet that your cranks are actually a triple crankset, correct? Even if you only run the small and middle rings, it's still effectively a triple crankset.
    You need the other Problem Solvers adapter.
    Feb 2013
    yes, my crankset is triple. 39.5mm adapter would help?
    Feb 2013
    I got 39.5mm adapter its works perfect.
  1. SRAM X9 Direct mount 2X10 front mech issues
    By scarlet in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2013, 01:58 PM
  2. Replies: 7
    Last Post: 12-17-2013, 01:04 PM
  3. Helius AC 2013 direct mount front mech
    By scarlet in forum Nicolai
    Last Post: 04-30-2013, 10:04 AM
  4. Replies: 1
    Last Post: 12-28-2012, 04:59 PM
  5. Direct Mount 3x10 Front mech with 3x9?
    By Surlynot in forum Fat bikes
    Last Post: 04-21-2012, 04:46 PM
