Results 1 to 9 of 9
    Reputation: Jeff_G's Avatar
    Oct 2015
    Presta Plugged with Stan's
    I've been tubeless for a year and I just plugged one of my presta valves. Any pro tips on how to clean it out?
    And, I'm aware replacing it for $.65 is the best route but I need a fix to hold me over until I can get one.
    Thanks.
    Jeff_G
    "At least I'm enjoying the ride"
    16' Trek 8.4 DS
    16' Farley 7
    and I'm OK admitting..
    16' Sturgis
    Minneapolis MN
    Thin Man on a Fat bike
    Reputation: SAM313's Avatar
    Reverse air pressure. If you have a compressor and schrader adapter or presta chuck just dial up the pressure and blow the chunk in. If you have a small hobby torch you could try heating the valve stem too. The metal will expand a bit and it'll blow right in.
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    Have you tried removing the core and reaming it?
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    Jan 2017
    I had a good results with nylon fishing line. Just try to put it trugh and floss everything out.
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Poke it with a stick. It's really that simple.
    Oct 2015
    It's a plastic body so torch would be bad. I do have a compressor and an adaptor so I can try that.
    I don't think there is a chunk in the body, the valve itself sticks when unscrewed and pushed in and out. And it's almost impossible to pump with a hand pump it's so restricted. So I guess I was more curious about soaking the core in something to remove the latex.
    I'll go give it a shot. Thanks.
    16' Trek 8.4 DS
    16' Farley 7
    16' Sturgis
    Minneapolis MN
    Why so uptite?
    Dec 2005
    Remove the valve and clean with alcohol. Then take a thin q-tip and clean out the stem.
    Collection of fun carbon & titanium bikes
    @tgi_cycling
    I Love my Rize
    Reputation: danoalb's Avatar
    Dec 2005
    I got mine plugged recently so I removed the valve core then reamed it out with the right sized Allen wrench...... BINGO 👌👌👌
    Early to bed early to RIZE makes a man healthy, wealthy <(scratch that) and wize.
    RIGHTY on a LEFTY
    Oct 2015
    Soaked the core in alcohol for about 30 minutes. Fixed.
    16' Trek 8.4 DS
    16' Farley 7
    16' Sturgis
    Minneapolis MN
  1. Remove a Stan's presta valve core with a cheap spoke wrench
    By marpilli in forum Wheels and Tires
    Last Post: 07-08-2015, 05:22 AM
  2. Remove Core from Broken Stan's Presta Valve?
    By Mr.Quint in forum Wheels and Tires
    Last Post: 07-24-2012, 05:22 AM
  3. Stan's Presta valva leaking
    By Mr Pink57 in forum Wheels and Tires
    Last Post: 03-17-2012, 09:50 AM
  4. Anyone using Stan's presta valve adaptors?
    By eugenemtbing in forum Wheels and Tires
    Last Post: 08-08-2011, 12:51 AM
  5. I25 N between Santa Fe & York...plugged solid
    By Pau11y in forum Colorado - Front Range
    Last Post: 07-28-2011, 01:25 PM
