Results 1 to 85 of 85
    Reputation: tracerprix's Avatar
    Dec 2009
    Pogies, lobster gloves or 5 finger gloves?
    It's getting to that time of year. I'm trying to figure out my winter gear now that I'm loving the Fatty.
    I thought I was going to get pogies, but after talking to a couple people I might not be. I plan on doing some XC trails and maybe some fire road type trails. I heard that pogies are hard to get in and out of if you need to get your hand out for something quick on the trail. I think lobster gloves would suck for 1 finger braking. So i think I'm going to the normal 5 finger gloves.....
    Mike
    Aug 2010
    What kind of temps are you dealing with? I have Dogwood Designs pogies and haven't had to cinch them up with regular full finger riding gloves in temps down to about -10f. That means they're about as easy to get in or out of as taking your hands off the bars in summer.
    I've seen some of the cheap atv pogies that are much smaller and they look like they might be a pain to deal with.
    Dec 2009
    I'm in syracuse, NY. Plan on going to the ADK too. wind chills are pretty bad here sometimes. Temps usually are 10 degrees F on the cold days usually in the teens or 20s. Up north could be in the single digits and colder at night.
    Maybe i could get away with finger gloves. Sometimes I have issues keeping my hands warm, but I'm not biking Ha HA, usually just standing around.
    Reputation: blockphi's Avatar
    Mar 2012
    I've been commuting in Anchorage AK for going on three winters now. The first two I used some cheap(ish) Grandoe expedition type gloves that were water and windproof. In temps down to -15 they were great up to about an hour, then I started getting chilled quite quickly.
    This year I got a pair of Black Diamond Guide gloves. Similar design to the Grandoe, but with a removable liner so that I can use a lighter weight liner for the warmer days. So far I've been running these with just a thin liner glove in temps down to the upper single digits and they've been quite sufficient.
    What I like about these style gloves is that they have the nice gauntlet to help keep the air out, allow me to easily adjust my lights/zippers/etc while on the bike, and I can use them for other things than just riding.
    I've toyed with the idea of pogies, but just can't bring myself to make the leap. I tend to require that all my gear, apart from chamois, do double or triple duty. I can't really think of any other instance where I would use pogies other than on the bike, so that is a huge turn off for me.
    Oct 2012
    I went out with some new Pearl Iszumi (sp?) lobsters today. 17 degree heat index and my fingers were hot. Two finger braking and downhill grip not as good as five finger gloves but very acceptable.
    Aug 2010
    Windchill, "heat index", or "Feels like temperature" means absolutely nothing when you do not have exposed skin, such as the case when you're wearing gloves or pogies.
    The issues with gloves are that the insulation will compress as you're grabbing the bars and provide less warmth and they can be cumbersome depending on the size of the gloves and what your controls are like. With gloves you may also need to remove them if you're stopping and grabbing something else like a camera, phone, gps, etc. With pogies you could have a lighter weight glove on underneath so you don't have exposed skin.
    With the temps you're facing it's a tough call. When the actual temps are around 10F or above I can wear some windproof gloves with maybe a thin liner glove and my hands are usually warm. With the pogies I know my hands will be warm to temps close to -20 with only full finger riding gloves. A lot depends on how cold your hands get due to circulation, grip, etc.
    Reputation: ecub's Avatar
    I've tried 5 finger gloves, PI lobster gloves, and pogies. I LOVE the pogies, Dogwood Design. The only issues I have with them is taking them on/off THE bike, but removing my hands in/out of the pogies are no problem. The 5 finger gloves don't keep my fingers warm enough. The PI Lobster type gloves keep them a little warmer, but not as well as the pogies. Plus the lobster gloves feel a bit awkward. The pogies kept my hands/finger the warmest. I can even use regular summer/fingerless gloves at times, while inside the pogies.
    - Ed
    2012 Trek Madone 6.7 SSL
    2013 Specialized Tricross Comp Disc
    2011 Trek Top Fuel 9.9 SSL
    2012 Salsa Mukluk 2
    Reputation: temporoad's Avatar
    Quote Originally Posted by blockphi View Post
    Nice glove, I don't know if I could use them without a nose wipe, I always have a drip.
    Reputation: buckfiddious's Avatar
    I've never needed anything more than lobster gloves in Wisconsin.
    Figure if it's too cold for those, I really don't want to be out anyway.
    Lobsters seem to be good down to about -15 or so. Other thing that made a big difference last winter was speed- lobster mits got really cold at -15 and 12-15 mph. worked just fine when the trails got slower and my heart rate went up.
    Reputation: Fat Bob's Avatar
    Pogies seem to be the way to go from those in the know
    Reputation: Smallfurry's Avatar
    My issue with the lobster gloves I have is getting back into them with damp hands. I basically cant. Not comfortably. The liner bunches up.
    I'm probably in 5-finger expedition glove climate. But having froze 3 fingers last year. I'm going with pogies. I'm not risking going through that again.
    Plus it means you can grab food etc. far easier..
    Just need to find some to fit my cut-H bars
    A big boy did it, and ran away.
    62*28'
    Quote Originally Posted by Smallfurry View Post
    Especially if you store some in your pogies.
    I am not a fan of riding in pogies but if it is below about 10 F I have to. No problem getting in and out of quality pogies though, especially the ones with a built in plastic frame. They don't droop. Lobster gloves are not a big problem for me but I concur on the deal with trying to put them on over sweaty hands. Above 15 F or so I just run 5 finger gloves with a liner.
    Latitude 61
    I usually wear a mid weight liner glove and a pair of OR Mitts,especially when starting out,as my body warms up I end up riding with just my liner gloves. Last year I rode in -20 and colder temps with the liner gloves and mitts my hands stayed pretty warm, even on extended rides.I am thinking about trying some pogies this year. I always have a spare pair of liners gloves tucked in my frame bag too!
    Dec 2009
    Thanks for all the responses.
    I tried on lobster's didn't like them, I doubt i'd get used to them. I'm going to look for a windproof maybe waterproof 5 finger. Maybe pick up a set of pogies. I think maybe pogies with a vent so my hands wouldn't get too warm. I hear the Dogwood Design pogies are good, but I don't think they have a vent.
    Oh what to do. Ha Ha.
    Mike
    Oct 2012
    Quote Originally Posted by dehoff View Post
    I disagree. Strong winds, humidity, and sunlight make a big difference - even if you are wearing gloves or in a parka or in a tent.
    Reputation: f00g's Avatar
    My wife made poggies for me last year, and I love them, I used my regular full finger gloves i rode all summer in last year and never had cold fingers.
    Dec 2009
    Quote Originally Posted by f00g View Post
    All summer in pogies! WOW JK I know you meant winter.
    Reputation: SJJ28's Avatar
    Oct 2012
    Quote Originally Posted by akclimber49 View Post
    I usually wear a mid weight liner glove and a pair of OR Mitts,.......!
    OR mitts are the cats meow for anything in the cold!
    Dec 2009
    Quote Originally Posted by SJJ28 View Post
    I agree, but I don't think mitts are brake lever friendly.
    Quote Originally Posted by tracerprix View Post
    ahahaah funny, I did also forget to mention that that is Anchorage though. Didn't think i needed st state winter season. I'll do better next time.
    Dec 2009
    AK isn't that cold in the winter is it?
    Wow those Black Diamond Guide gloves looks awesome. Plus they come in orange to match my orange 9:zero:7
    I was thinking of making some. could you post a picture(s) please?
    thanks
    Dec 2009
    Making some, never thought of it. I doubt i can, I'm not good at sewing. I can barely sew a button on.
    DIY Pogies
    I need to modify the ones she made by adding a bell bottom style triangle panel to open them up a bit. They are a little hard to get into with a heavier jacket on.
    It is a lot easier to ride with mitts than it is with frozen fingers. And Pogies are easier than mitts.
    Latitude 61
    Dec 2009
    Quote Originally Posted by sryanak View Post
    Your right! Frozen fingers are not good!
    Mike
    Pogies have a hole in both ends, one to put through the bar, the other, wider part, for your hands. If you want more ventilation, just don't tighten up the part that wraps around the bar.
    - Ed
    2012 Salsa Mukluk 2
    Aug 2010
    Quote Originally Posted by rmanecke View Post
    Yeah, I was probably a little strong in my wording, or rather lack thereof. I should have qualified my statement with the constraints of talking about feeling colder in temperatures well below freezing with materials covering the skin that have decent windblocking properties(but not necessarily to the point of fleece with windstopping membranes)
    Yes, sunlight can make a big difference but it won't make you feel colder.
    If you're wearing fleece,wool, etc. without any sort of windblocking layer, yes, wind can make you feel colder. With any decent winter gloves or pogies that have a windblocking shell, you will not be able to discern the difference between -20F with a 5 mph wind or a 40 mph wind. If your hands or face aren't covered or you're wearing fleece without any sort of windblocking, you'll be able to feel the difference immediately. I've had the "opportunity" to work outside for a week straight where the temperature never got above -20F with winds anywhere from 5 mph up to 40 mph. With the same clothing, I could not feel any difference on the windy days other than I couldn't handle taking my goggles off, but on the calmer days I could go 10-15 minutes without them.
    Humidity can be an issue especially around freezing. At -20 I honestly can't tell if it's humid or not. There's vapor barrier clothing, but that's a whole other concept.
    Aug 2010
    Mike
    Lobster gloves are like flip flops for my hands. I can't wear either of them comfortably no matter how much I try.
    Dec 2009
    Quote Originally Posted by ecub View Post
    Ah, makes sense
    Dec 2009
    Ha Ha! I HATE FLIP FLOPS!
    Sounds like no Lobsters for me!
    Im pretty close on buying these BLACK DIAMOND Men's Guide Gloves, but still leaning towards pogies.....
    Human Test Subject
    Reputation: Volsung's Avatar
    Last winter I used lobsters with merino wool gloves underneath. Was good even below 0, but it was very mild in MN last year.
    But since we're really talking about pogies, I had also contacted the guy who runs Bar Mitts about making some custom ones for my salsa woodchippers. He was willing and only wanted a few extra bucks. I changed bars though and ended up not needing them, but I'm sure he'd make you some that fit your H-Bars.
    I'd try to find an LBS that stocks them though. The normal bar mitts will probably fit.
    <a href="http://www.flickr.com/photos/9527634@N04/8140759618/" title="IMG_2213 by F00G, on Flickr"><img src="http://farm9.staticflickr.com/8054/8140759618_52e4ff89a3.jpg" width="500" height="333" alt="IMG_2213"></a>
    Here is my Fatback with the pogies my wife made, they are a little hard to see the design, basically if is a Kids coat cut in half and sewn back together, the part that is closest to the stem is the cuffs which I cut a slit in and used the existing velcro to tighten back down, She put some plastic in the seam where your hands go in to make them stay open. Like I said before i plan on widening them even further by sewing polar fleece to a piece of wind stoping ripstop nylon in a V shape, like they used to do to bell bottoms.
    Search for quad gear mitts ~$15-25 from Cabelas, etc. (the link is too long) Cheapest and most effective winter gear I have ever purchased for cycling. I wear them all winter in ND.
    Only thing I do extra is to wear a pair of liner gloves... solely to wick sweat off my hands.
    Karma Vampire
    Reputation: 29Again's Avatar
    Mar 2005
    I have had pair of the Trail's Edge Cyclery "Moose Mitts" for the past seven or so years. The new Super HiVis orange version seems like a good idea when riding through rifle hunting areas.
    http://www.trails-edge.com/
    I suggest calling them to place an order and see what the wait will be.
    I can definitely recommend them for MTB use (road, single or two track). I can't recall not being able to come out of them when crashing. I have used lobster and snowboard gloves too. It seemed harder to regulate temperature with those. If you don't like them, I would bet you could recoup most of the purchase price.
    Reputation: Jaredbe's Avatar
    The real benefit of pogies is the much broader range of temperature situations they can work in. This is true of all good winter gear. When I wear gloves or mittens I find myself both too cold and too hot in my hands on the same ride. Pogies work to keep my hands morning bed warm whether I am producing a lot of heat climbing or when riding slow and easy.
    laotzucycles.blogspot.com
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Quote Originally Posted by OUWxGuesser View Post
    I'll admit it. I use these too and also really like them. Windproof, warm, roomy and really light for their size. I also just wear liner gloves, mainly to keep bare skin off bare metal. Excellent cost to utility ratio.
    <a href="http://www.flickr.com/photos/mababo/5254741633/" title="Snowy 9:Zero:7 by Uncle Bicycle, on Flickr"><img src="http://farm2.staticflickr.com/1397/5254741633_163fec8b72_n.jpg" width="320" height="240" alt="Snowy 9:Zero:7"></a>
    <a href="http://www.flickr.com/photos/mababo/5236403132/" title="Winter Panda Too by Uncle Bicycle, on Flickr"><img src="http://farm6.staticflickr.com/5043/5236403132_d4d8498e1d_n.jpg" width="320" height="240" alt="Winter Panda Too"></a>
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Mittens. Good to -15f . Also nice for snow boarding.
    --Lars
    Attached Thumbnails Attached Thumbnails Pogies, lobster gloves or 5 finger gloves?-uploadfromtaptalk1351697071149.jpg
    --Peace
    Reputation: duggus's Avatar
    Anyone try these guys yet? You would still have the trigger finger for braking, while having a mitten style glove.
    Dec 2009
    Very interesting!!
    Carbon or Commie?
    Reputation: axisofoil's Avatar
    Heated grips would probably help with the warmth lost to the bar.
    Reputation: calzonical's Avatar
    Aug 2005
    Pogies for Loop Bars
    I have used Moose Mitts the past three winters on the mtb with flat bars.
    However this year the moose mitts are to go on a Fattie with Jones Loop Bars.
    I just tested the fit of the moose mitts on the Loops. Fit no good - due to the loop. Any one else have similar experience, and if so how was the problem resolved?
    Here's one idea I found
    I sewed my own pogies a bunch of years ago. I made them big enough to carry snacks in, and shaped them so they could double as booties. I can operate bike controls with mittens on, but I endorse pogies with religious fervour.
    In my little world, gloves are for summer.
    Nov 2006
    Quote Originally Posted by duggus View Post
    I have the Hestra's like that for skiing and they're nice. I mostly bike in old ski gear.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I use military surplus mitts with one compartment for three fingers, one for the index finger and one for the thumb. Kinda like lobster gloves, but instead of 2+2 it's 1+3 - very much like the ones Duggus posted. They are cheap as chips, durable and warm while allowing one-finger braking.
    When I go out, after 15 minutes the index finger feels cold so I tuck it in the same compartment with the other fingers to warm it up for a moment. At that point I have generally warmed up and the "machine is running" so to say, and I can keep the index finger in its own compartment for the rest of the ride. I've worn these as low as -27 degrees celcius (-17F) without problems. Mine are German, but there are Russian, Swiss, Czech and US models available as well to name a few.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Just try to pry my Dogwood Designs pogies from my warm dead hands!
    Self-defeatist
    Reputation: CLONG's Avatar
    Nov 2006
    [VOICE=crotchetyoldman]Back in my day we used to ask how to make it not where to buy it![/VOICE]
    I'm covered in beer.
    Harrumph
    Reputation: G-reg's Avatar
    I'm a huge fan of my Moose Mitts pogies. They are pretty minimalist, a slightly insulated shell. And I add some gloves as necessary. What's nice is as I layer gloves for conditions wind/water resistance is not a factor. So I can use varying thickness wool gloves and my normal summer gloves to fine tune. With the nutso uhber ultra monster mitts it's harder to regulate temperature as conditions / activity changes.
    Slowly slipping to retrogrouchyness
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    The pogies are the bomb. I've used them for years and they do wonders but it is still important to have gloves that are warm enough as well.
    Feb 2012
    I like pogies that way I use my thin gloves under them so when I stop my hand are free with a little protection from the cold
    Quote Originally Posted by calzonical View Post
    I'm considering ordering these for my Jones cut-H bars. What do you think my chances of getting to them work are?
    Cheers for any help.
    62*28'
    Dec 2009
    Sounds like I need a couple things. A pair of wind proof water proof 5 fingered gloves for the warmer days and pogies for the colder days. Sounds good to me. Anyone know the difference between the dogwood pogies and the dogwood plus pogies? Something with more insulation??
    Aug 2010
    From when I called and talked to her, the Pluses are best used for temps starting around -10f or -20f and below. I thought I might want the pluses due to living in the coldest region in the lower 48, but they talked me out of them. She said the regulars are good to -20f.
    Moderator Moderator
    Dec 2009
    ^^ I'm in central VT and glad I got the "regulars". Plenty warm and useful over a wide temp range.
    Dec 2009
    I'm glad I asked! Ill have to get some of the regular ones.
    Dec 2009
    I emailed the dogwood company. Eric replied try will not be making the regular one this season. They are only making the plus ones. Hmmmm now what to do.
    Aug 2010
    Eric from Revelate or Dogwood Designs? I thought the lady's name was Joan that I talked to at Dogwood Designs last year and thought she was the owner. Revelate may only sell the plus version, but you should be able to order directly from Dogwood Designs and get whatever you want custom made. I believe she sent out a PDF that had about 30 color options and you could also have reflective piping for ~$10 more.
    These guys have a few colors in stock- Keep your hands warm with Dogwood Designs pogies made for winter bike riders
    I ordered mine by calling Joan last year in a color of my choosing and had reflective piping added, and IIRC they arrived on my doorstep in about 5 business days.
    Dec 2009
    I thought Revelate Designs made Dogwood Designs Pogies.....
    https://www.revelatedesigns.com/inde...5&ProductID=14
    I guess I'm confused
    Aug 2010
    Hopefully I got ya squared away in the PM.
    Revelate makes some awesome bags and they're also a retailer for the Dogwood Designs plus version pogies. If you contact Dogwood Designs directly you can custom order whatever colors you want and possibly even get the loop bar versions or other custom options. If you talk to Dogwood Designs you're talking to the people that will actually be making your pogies.
    I am looking at these or the moose mitts, the dogwood is twice the price. I can only find two websites that sell the dogwood (fatbike.com and revelate.com). , are there more?
    Dec 2009
    Yes you cleared it up for me. Thank you very much!
    Aug 2010
    Quote Originally Posted by temporoad View Post
    You can order them directly from Dogwood Designs as well. The email address is in this article right above the second photo- Pogies | Commute by Bike
    Dec 2009
    I ordered a set of Dogwood Design Regular Poagies from Joan. She is wonderful and very nice to chat with. We talked about all sorts of things.
    Joan from Dogwood Designs dogwooddesigns@gci.net
    Still need to get some 5 finger waterproof and windproof for the warmer cold rides.
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    I use 5 finger snowboard gloves
    they even have a very handy nose squeegee
    Sj
    I am slow therefore I am
    Hi Ride all winter in the Yukon - only pull out the Dogwood ++ poagies when it's -25c or colder. Too warm until then. Up to that point I use combos of thin wool liners or fleece gloves with windblock and choice of either light windprooff shell mittens or heavier old surplus military Arctic mitts. I always take an extra warm pair of mitts just in case, not usually close to town.
    Stopped riding after -40c, leave that for the heros. Hands stay nice and warm inside!
    Pogies are the way to go. Matter of fact, I have to be careful about getting too warm with the pogies at times. Definitely a problem I don't mind having.
  67. #67
    Dec 2009
    Quote Originally Posted by wrcRS View Post
    Yeah very true, you can always take your hand out to cool off!
  68. #68
    Dec 2009
    I'm glad I ordered the poagies. I tried biking with a heavier pair of 5 finger gloves. These are not very bulky at all, just has some insulation. I really did not like riding with these gloves and couldn't imagine riding with anything bulkier.
  69. #69
    NMBP
    Reputation: gfs69's Avatar
    I bought a pair of Moose Mits at the Iceman expo this past weekend. The owner had a booth set up, and was even selling them at a discount. They seam really well made and durable. Usually my hands are the coldest part of my body while riding in the winter, so I have high hopes for these.
  70. #70
    Self-defeatist
    Nov 2006
    I sewed myself some down insulated pogies out of an old coat. They're really too warm for all but the coldest winter days (I'm on the East Coast of Canada, so our winters are moderated by the sea). I usually use simple work gloves or MTB gloves and a liner.
    You can take your hands out of pogies when they get too hot, but then you can't shift or brake effectively.
    Someone needs to invent foot-pogies.
    EDIT: Pogies also make decent pockets for lightweight items.
  71. #71
    'Tis but a scratch
    Another vote for pogies. I had that same "but can I get out?" feeling before getting them. The answer is "yes, very quickly". Another consideration that was alluded to earlier is the ability to do fine motor skills. I wear a light glove liner inside. That allows me to easily unzipper a pocket, access a camera, take the picture, tweak a new drive train set-up, etc.
  72. #72
    Laramie, Wyoming
    Oct 2012
    I bought some Pearl Izumi lobster gloves a month or two ago. I've tried them but I don't like them. I'd rather use a good pair of gloves. I ordered the dogwoods last night.
    Anyone want a brand new pair of lobsters?
  73. #73
    Oct 2011
    I have the Pearl Izumi Lobster's too. Ideally I'd probably go with Pogies and a thin glove. The Pearl Izumi's aren't warm enough at all.
  74. #74
    Mar 2012
    ***UPDATE***
    I've been living with the BD Guide gloves now in temps to 0 and have some additional insight.
    I've only used the thick liners they came with on three rides, one at 10, one at 5, and this morning at 0. On the 10 degree ride my pinkies got a touch cold, mostly I think because the liners are so thick that they made it a bit difficult for blood to flow properly. After wearing them a bit, though, they have compressed a touch and are now quite comfortable. At 5 and again this morning at 0, my hands stayed toasty warm and, more importantly, dry. The liners do an amazing job of wicking sweat.
    I went out yesterday for a higher intensity ride than my normal commute. It was three degrees out and I wore my thin OR liners under the Guide outer glove and stayed plenty warm. I also took a ride last weekend at around 12 degrees with just the OR liners and the Guide over gloves and after two hours my hands were still warm as can be, but I noticed that the leather of the over gloves were damp from moving the sweat away from my hands. Quite impressed. One concern I do have is if the thicker liners will compress to the point where they do not provide enough insulation. Still waiting for some of the more extreme cold temps to see how they do. My sense is that they will be warm down to -20 or so while active.
    My only complaint is that with the thick liners they came with I do have a bit reduced mobility and it is, at times, a bit hard to shift. Part of this is how I have my cockpit set up with the brake levers almost directly in line with my shifters.
    That is all
  75. #75
    Reputation: Nakedbabytoes's Avatar
    For anyone who has Jones Bars and are wondering about full coverage pogies, I bought the ATV mitts off Amazon for $12.99 and they work great! Overlap the middles and cris cross Velcro straps and you have full bar & loops coverage. I got the ones that have Cordura outers. Figured they'd hold up better with abrasion.
  76. #76
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I used my moosemitts last sat on a 60 mike gravel road ride, low 30 temps and my fingers were toasty. These things rule!
  77. #77
    'Tis but a scratch
    ^ The higher winds related to road riding is when you really see the benefit of the pogies/mitts. And believe me, they're good to much lower temps than the 30's.
  78. #78
    Laramie, Wyoming
    Oct 2012
    I can't even use my Dogwood poggies until it gets below 30 degrees. I'm going to put in a zippered vent into mine with a velcro cover flap so that I can open them up a little and give them a little broader working temperature range.
  79. #79
    Feb 2006
    Quote Originally Posted by huffster View Post
    Yah I can imagine!
    I had to ride with my hands on the outside from time to time because they were too hot.
    The guys I was riding with had numb fingers lol.
  80. #80
    Yukon Rider
    Reputation: Derek.Endress's Avatar
    Bought Dogwood Designs pogies 2 years ago and would never look back!
    Riding here in the Yukon I tested them full on at -38c (-40c = -40f) A light pair of Black Diamond liner gloves with a leather palm and I was good to go. Nice thing with the Dogwood is that they have ample room and have the ability to close out almost all of the elements even on longer rides. Exceptional design for riding FATbikes in the north
  81. #81
    Reputation: Yoreskillz's Avatar
    Is there any offerings on the market that have addressed the entry angle of Pogies for the swept back bars? I have Jeff Jones Loop Bars and would like to get the Dogwoods but the aforementioned issue is a concern. I know that they will "work" but I don't want to be fighting them to get my hands in the mitts. I
    Can anyone confirm they have used them with the aforementioned bars and have photos?
  82. #82
    http://forums.mtbr.com/attachment.ph...1&d=1353984033
    Here is me, with Jones loop bars and pogies. My 9 year old took the picture.
  83. #83
    Aug 2010
    Quote Originally Posted by Yoreskillz View Post
    Dogwood Designs supposedly has a version that works better with the loop bars, but you have to order them directly from Dogwood.
  84. #84
    Dec 2011
    I just received my Bar Mitts, made from thick neoprene. The neoprene is just stiff enough to make them stay open when your hand is out blowing your nose or something. makes it easy to slide right back in on tight twisty trails. I have the larger size to fit over stubby bar ends. they also have a hole for the handle bar end to stick out with the bar end attached if you have longer bar ends. I wear full finger summer gloves and my hands are hot when it is in the 30's, nice and warm into the low 20's. Never going to suffer with cold hands again........
  85. #85
    Reputation: ianick's Avatar
    +1 for Bar Mitts
    This will be my second winter using Bar Mitts. I think they are a game changer for finger numbness. Keeping my fingers warm used to be something I struggled with. Now that I use Bar Mitts it's a non-issue. I sweat a lot and appreciate the minimalist setup of the Bar Mitts. The pogies went too high up on my arm. I tend to wear my summer biking gloves until it gets down in to the 20's. At which point I switch to full finger summer gloves.
    Here they are on my Spearfish:
    Working on keeping my feet warm this winter. Wolvhammers here I come...
Members who have read this thread: 8
