Results 1 to 29 of 29
    Pics of your 1x9 fatties
    Interested in your set ups
    Reputation: NOBBY605's Avatar
    FSA Carbon Team Issue cranks with 32T chainring FSA BB--KMC X-9sl chain and Shimano HG-61 12-36 Casette... Works great on my Moonlander!
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-january-2012-116.jpg
    Reputation: Steve Balogh's Avatar
    2007 Wildfire 1X9
    My Wildfire has Middleburn RS-7 cranks w/38T Uno ring, Phil Wood BB, 11-34 SRAM cassette, and SRAM rear deraiilure.
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Can 1 X 10 Play?
    Some images of my 1 X 10 Salsa Ti Muk here. 11-36T casette, 34T E-13 Guide Ring in purple ano.
    The pink bike was seen at Triple D race in Dubuque, IA January 14th at the pre-race. Belongs to the promoters wife, if I am not mistaken. 1X set up with bash guard on inside of chainring!
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-triple-d-12-001.jpg
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    daveells, sorry to jack your thread!
    I'd like to see 1x chain keeper with phil wood bb install. I recall seeing some but I can't find it now. My chain keeps coming off and I'm looking for to get either the MRP 1.X or Paul Chain Keeper but unsure how you would install it. thanks in advanced!
    MRP makes a direct mount 1x...will also need Problem Solvers 100mm direct mount adapter.
    ent
    e13, 1x10, no chain guide.
    1x 7 of 9
    I had to remove 2 of the 9 so as to fit BFLs on Clownshoes. I have not solved the chain retention problem, but I think I may use a BB mount paul chain keeper and a spacer on the Profile Racing bb spindle to keep the bearings loaded.
    28 tooth Profile Racing Imperial chainring and a 11x34 cassette give me the gear range I think I want. I chose the Profile crank because of the availability of long crank arms and easy availability of 26 and 28 tooth chainrings. I will be replacing the rear derailleur with a short cage version to try to help the tire to chain clearance a little.
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-_1260734.jpg
    Reputation: vikb's Avatar
    This is my 1 x 9 [8 +1] Pugs...the +1 is when I get off and walk...
    Safe riding,
    Vik
    www.vikapproved.com
    A Surly Mr. Whirly with a 30 tooth stainless steel Surly chain ring up front, and a 11-34t rear. The 19 setup looks much cleaner, and works great via the Paul BB Chain Keeper.
    Pictures are here: snowbikes.wordpress.com/2011/12/26/surly-pugsley
    will rant for food
    Anyone consider something like this? 38 TOOTH SPROCKET, 38 TOOTH COG, 38T, BICYCLE, BIKE | eBay
    Harmonius Wrench
    Quote Originally Posted by Drew Diller View Post
    Interesting. I knew Action Tec made titanium cogs this big, but I hadn't seen anything else like that until now.
    I don't run anything Shimano though, so I guess it doesn't matter.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    You are gonna get reamed so hard by a trail nazi with all that mud on your tires!
    Quote Originally Posted by vikb View Post
    Reputation: Tripower's Avatar
    Jan 2011
    How about a 1 X Infnite
    NuVinci
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-nuvinci-pugs.jpg
    Reputation: singlespeedstu's Avatar
    I use the snowguide to keep the chain on at the front on my 1x9 Mukluk.
    2012_0205slussysnow0021 by singlespeedstu, on Flickr
    Doesn't work so well in warmer weather though so have to revert to a bb mounted chainguide when the sun comes out.
    hanging around by singlespeedstu, on Flickr
    danaco
    Guest
    You guys obviously don't climb alot ! Like 1200'+ in two miles like we do around here. I would love to have a 1x9 or 10 but I ain't Fabian Cancellara ! Not even sure he could do it, for long anyway....
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-2012-02-04_14-32-44_529.jpg
    Nov 2008
    Bully getting high 1x...
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-june-creek.jpg
    danaco
    Guest
    Quote Originally Posted by drtoro View Post
    OK Cancellara, your alot tuffer than me !!
    Reputation: danaco's Avatar
    Quote Originally Posted by danaco View Post
    Edit...tougher !
    I certainly do climb, I just don't go very fast on the way back down. I start at around 24 gear inches and I have a chainring to bring that down to 22 and a cog to bring it down to 21 if I decide that I need it. I am only 2 gears up from a typical 3x9 setup and I save some weight and complexity and for me, that is a worthwhile tradeoff. I also placed a high degree of importance on 190mm cranks.
    I don't pretend that 1x or singlespeed is the best solution for everyone, but there are certainly advantages for a lot of people and many of them can and do climb.
    Climbed a lot on the CDN GDR with 4 panniers and full camping gear. I walked about once or twice in a 100km day. By the time I was walking I could keep pace with my buddy who was still on his bike with the same gearing setup.
    We could also cruise at over 30kph at the top end and got into the 70kph+ range bombing hills without pedaling.
    I'm now running an even lower gear [23T vs 21T] on my Pugsley so I probably wouldn't walk any of the CDN GDR.
    Quote Originally Posted by dgw2jr View Post
    I didn't know there were trail Nazi's hanging around on drying mudflats miles from a paved road in Baja. I didn't see any at the time anyways...
    Safe riding,
    Vik
    www.vikapproved.com
    Perpetual n00b
    They lurk on the forums, looking for all-weather mtbers to scold. In my neck of the woods, if they see any signs of mud on your bike then you will never hear the end of it.
    My new 1 x 9 zero7
    No snow, winter almost over. Who cares, going to be fun anyway!
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-img_0189.jpg
    Islip, NY
    C.L.I.M.B.
    Very nice build, I like the 45NRTH's.
    Let it Snow!!!
    2011 Surly Pugsley 3.7/3.8
    2012 Carver Ti O'Beast 4.7
    Reputation: davesauvageau's Avatar
    Truvativ Holzfeller crankset
    Salsa 32t ring
    SRAM X.9 shifter and short cage derailleur
    SRAM PG-990 12-32 cassette
    Paul E-Type chain keeper
    I love this setup. Practical, durable and still a bit flashy
    Attached Thumbnails Attached Thumbnails Pics of your 1x9 fatties-muddy-pugsley.jpg
    My motorcycle runs on infant blood
    1x9
    -bustin punks
    Reputation: fatchanceti's Avatar
    Jan 2005
    <a href="http://www.flickr.com/photos/rmplum/6970630079/" title="DSCF2460 by rmplum, on Flickr"><img src="http://farm8.staticflickr.com/7053/6970630079_214df02627_b.jpg" width="1024" height="768" alt="DSCF2460"></a>
    Still using the stock (heavy) HG61 12-36 cassette in back, but switching to a SRAM PG990 11-34 this week. Pulled my daughter in her WeeHoo trail-a-bike to the store yesterday without having to use the 36t (or 34t) cog, so that's good.
    Crank is a Bontrager Select that I had in the parts box, FSA platinum BB, 32t Niner ring. This dropped well over a pound from the stock Hussefelt crankset.
    Not running any sort of chain guide in front and everything seemed to stay put during my first trail ride on Saturday.
    Tigard, Oregon
    Reputation: clayman29's Avatar
    Quote Originally Posted by fatchanceti View Post
    Nice!
    2011 Salsa Mukluk / 2006 KTM 400 EXC
    don't fear the barleywine
    Reputation: Moe's Tavern's Avatar
    Aug 2010
    1x6.. does that still count?
