Results 1 to 15 of 15
    Is Phil Wood the only 100 mm S/T BB?
    I have a cool set of forged Specialized square taper crank arms that 4x64mm only. With a 28T ring, they would make a great SS crank, but by the time I spend $250+ on the Phil, I'm into other options. I've searched, but came up empty. Anything I'm missing?
    Reputation: vikb's Avatar
    That's what I am running in my Pugs. It's a nice BB and costs $162 on the Phil Wood site.
    Stainless Steel Bottom Bracket Sets
    Safe riding,
    Vik
    www.vikapproved.com
    Bicycle Obsessed
    Reputation: jpettit's Avatar
    Dec 2011
    I don't know of any other square taper bb at 100mm. I too have the Phil Wood, and like Vik I only paid about $150 for it.
    I thought the cups add another $60 or so to it? What cups are you using?
    don't fear the barleywine
    Reputation: Moe's Tavern's Avatar
    Aug 2010
    Choppers USA has one for under $30. Can't vouch.
    100 mm Bottom Brackets
    Quote Originally Posted by Moe's Tavern View Post
    I'm pretty sure the Choppers has a 165mm long spindle. This would rule out all but a few early generation cranks that were made for 120mm+ spindles. There are probably some of those on E Bay from time to time.
    Race Face made a 100mm square taper crank but I've only been able to find one and I have been looking. It has the advantage of not needing unique mounting tools, or additional mounting rings, which as has been pointed out adds $50 to $100 to the price of the Phil BB.
    Latitude 61
    A bit off topic, but is anyone successfully using White Industries crank arms?
    Nov 2007
    Quote Originally Posted by kapow! View Post
    I use Eno cranks on my SS (non-fat), This bike has VBC cranks:
    Frames
    Bicycle Obsessed
    Dec 2011
    you can get the Phil Wood for $149 at AspireVeloTech. If you need cups as well that's another $34. grand total is $184 and shipping is free.
    Quote Originally Posted by jpettit View Post
    Plus at least another $15.00 for the mounting wrench. They are very nice bottom brackets and if you want to go square taper they are the only practical solution.
    Latitude 61
    Harrumph
    Reputation: G-reg's Avatar
    Yes, barely with a 34t. Tightest clearance on a pug is the non drive side with the bend in the chainstay.
    I always feel the need to jump in and promote the Phil square taper, it isn't cheap.... But
    its value is incomparable.
    Slowly slipping to retrogrouchyness
    Reputation: Stopbreakindown's Avatar
    Running a Phil Wood BB w/ a 30t/bashgaurd eno and cranks. Love em. (2010 9zero7)
    Mar 2013
    Getting ready to run some white cranks on Phil BB with custom 28t machined Ti narrow-wide chainring to achieve a 10x1 setup. Will post pics and follow up on how it turns out.
    Cheers,
    Middleburn. Not sure of price
    nothing to see here
    Reputation: Stevob's Avatar
    I see hills.
    I want to climb them.
