Page 5 of 8 FirstFirst 12345678 LastLast
Results 201 to 250 of 386
  1. #201
    Reputation: mtuck1's Avatar
    Quote Originally Posted by tundratrader View Post
    Sweet. Did you setup the lefty yourself? If that is your wife's bike what are you running?
    I have the good fortune of being an hour from Mendon Cyclesmith and Craig helped me with it.
    I have the same bike without orange accents. I also have a HED carbon rear wheel for my bike.
    Attached Thumbnails Attached Thumbnails Panaracer Fat B Nimble!-dscn2295.jpg
  2. #202
    Jul 2014
    Fat b Tubeless. Made the switch yesterday, after about a week of FbNs aired up with tubes. Had to push a bit to break free one bead, other side stayed in place. On the first one I pulled the core of the presta valve, used a blow tip/ comp to inflate- bead popped in place, held enough to replace the core and use compressor to seat the bead firmly. Second tire I left the valve intact, aired up easily and set the bead. 4 oz Stans in each, front tire initially bled a lot of air thru the spoke holes and cutout, near the stem. I needed to air it up 5x or so before it held air. The rear tire some leakage, but sealed up quicker. Marge Lites, clown shoe strips.
    I played around with pressures on the ride, a few hours of xc. All was well until near the end when descending fast, braking more, the rear started leaking around the beads, needed to air up twice, and finally just rode back to the car standing, to avoid the last air up. I'm assuming the braking slipped the bead on the rim, and will seal up as the stans sets. Held air overnight fine.
    Ride wise felt good- seems more responsive, as it should, I'm estimating 17 oz less per wheel, over the Nates with tubes.
  3. #203
    Reputation: spovegas's Avatar
    ^^^Very similar experience here . . .
    1. Rode the FBN's with tubes for a couple of weeks.
    2. Swapped the the stock marge lite rim strips with clownshoe strips (put a layer of lightweight hobby shop ribbon down first).
    3. Used soap and water to seat the beads (probably not necessary) and left the tires aired up at 25 psi for 24 hrs.
    4. Deflated tubes, broke bead on one side, removed tube.
    5. Installed tubeless valve stems, removed cores. Added 4 oz Stan's to each tire.
    5. Set wheel horizontal on 5 gal bucket with broken bead facing down and aired up with compressor and nozzle. Bead popped right into place. Put the valve core in without losing much air. Probably put 20 psi in initially.
    6. Stan's & air leaked at multiple spoke holes and places around the bead. Did the Stan's disco dance for a few minutes.
    7. When the pressure got pretty low, I put some air back in with a floor pump, back up to around 20 psi. More disco, a little more leakage, but the everything sealed up at around 8-10 psi.
    8. Put the wheels back on the bike and went for a short disco ride around the hood.
    9. No more leakage or air loss in the tires over the last 24 hours.
    Haven't had a chance for a real ride yet.
    I weighed things as I went and came out with a slightly less weight differential than you. 380g/13oz difference between Nate w/tubes & marge strip vs tubeless FBN w/ moonie strip and 4 oz stans.
  4. #204
    Oct 2013
    I've been running the 26x4, 120TPI FBN's on my new Bucksaw since picking it up a month or so ago. Ran them with tubes for one ride of 20 miles and then used the cling wrap method to go tubeless. Worked great using a compressor to set the beads. Added 8 oz Stan's and have been enjoying them ever since. Very rocky, chunky, sandy in areas, loose over hard here in so Arizona. Fast rolling, great cornering, no self steer running 10/12psi f/r.
    Ordered a spare off eBay last Wed and it arrived yesterday (Sat). Best deal I've found so far at $52.25 ea with free shipping. Weight came in at 1180.2 grams. Very happy with the purchase at Panaracer Fat B Nimble 26"x 4 0 Folding Bead 120TPI Fat Bike Fast Tire Fit Surly | eBay
    Mine came Priority Mail but just noticed they have changed to Economy Shipping so will prolly take a week or so.
    Hard work MUST have killed someone
  5. #205
    May 2015
    Hey AZMB'er! How's the wheel diameter with MargeLite/FBNs compared to MargeLite/Nates?
  6. #206
    Oct 2013
    I never had the Nates on my bike. My LBS built up a frame and I chose to use the FBN's from the start. When I set the FBN's up tubeless I measured the front tire/wheel at 20psi while off the bike laying on a table. The FBN's have a knob right in the center so I measured to the outside of those knobs using a square and marking the table with a pencil on both sides then measuring between the marks. I guess I'm telling you all this to let you know that this was a pretty accurate way of measureing (and how anal I am lol). Anyway, to answer your question, outer diameter is 29" exactly.
    BTW, the Bucksaws geo is based on a 742mm tire which is 29.21" so the FBN's are pretty close.
  7. #207
    May 2015
    Thank you Sir! That's exactly what I want to hear. Now its time to get a pair of FBN.
  8. #208
    Oct 2013
    Quote Originally Posted by qsysuser View Post
    You won't be disappointed. Where are you getting them from? The eBay ad says 2 sold in the past hour, was that you?
  9. #209
    Jan 2014
    Quote Originally Posted by AZMB'er View Post
    Wasn't me either. I ordered a Fat B Nimble on Saturday and received it just now. Weighed in at 1190 grams. Shipped on Friday, received on Monday to Seattle/Tacoma
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
  10. #210
    Reputation: tundratrader's Avatar
    How are these tires on pavement compared to other tires you all that have had other have used? I am trying to figure out the best rear tire that rolls fast. Knard is the front runner right now unless someone here thinks these are better also because they are smaller. I am doing a fair bit of commuting right now on nates. I want the fastest least resistance setup that I can still ride single track with. The Nate takes lots of work but rides fine. Endomondo showed I went 33mph the other day.
  11. #211
    They are great on pavement. fast and fairly quiet
    I have pair on my OOF and they get about 50 / 50. road and offroad
    also wearing very slowly a good allrounder.
  12. #212
    Mar 2015
    We4 //
  13. #213
    Jan 2014
    Fat B Nimble VS. On-One Floater. Changed out the rear tire that had the Floater yesterday. Floater on Weinman 80, Nimbles on 80 Mulefut.
    Cons:
    Same hill run I use most days and noticed much more slippage over loose/dried dirt. Nimbles don't like to run at 4.5 PSI, and didn't interact with the Larrys on front very well at that pressure. They had what felt to be self steer that affected the rear end handling as well as the Larry's on the front. Had to air them up to 6 PSI. They don't seem to wrap around roots and rocks as well as Floater, and that may be they had to be run at a higher PSI. Had a couple more pedal strikes than I typically do with Floater over the same terrain.
    Pros:
    Nimbles are noticeably lighter on the wheel (Nimbles 1190 g, Floaters 1447 g), but the Mulefuts were 300 g lighter than Weinman. They aren't too bad for traction. I didn't fail to make any of the usual steep sections. I got through the steep sections with noticeably less effort even with some slippage. I didn't really get much time on pavement so I won't even speculate for speed. All in all, I'll keep them for summer single track riding.
  14. #214
    Jan 2014
    ^^ I also felt that lower pressures aren't where these FBNs shine. They seem like a great trail tire. I have been playing around with mine, and I found that about 6.5 lbs F and 8.5 lbs R works well for my trail and gravel riding. Firm, but not too bouncy. They are OK on the beach if I air 'em down a pound or so, but then I'll air 'em back up for the trail or road.
    At 6.5F and 8.5R, on Monday, I had to ride in a truck tire track to make it from the packed sand down near the low tide line up the beach approach, as the sand on the upper beach was dry, soft, lumpy, and deep. It resembled some kind of fat-bike trap, almost. Without that truck tire track to provide a smoother and firmer surface, I would have lost traction for sure.
    There were some spectators, and so I gave it my best effort, and prevailed!
  15. #215
    bigger than you.
    Reputation: Gigantic's Avatar
    Why the eff would you run your tires that low on trails?! I get it for snow & sand but for hard surfaces it seems ridiculous.
    Maverick Moto Media Motorcycles, Mountain Biking & Social Media Mgt
    Facebook Twitter Instagram
  16. #216
    Jan 2014
    I like the cush on the trails (I'm also using a thudbuster), the traction going up steeper hills is far superior, and the tire's, at low pressure, ability to wrap around a root or a rock rather than sliding off, at least for my style (or lack thereof) is much better.
    I carry a pump to experiment with the pressure and have no qualms about adding to or subtracting from.
    Last edited by Bumpyride; 05-20-2015 at 11:37 AM. Reason: grammatical flagrant violation
  17. #217
    Jan 2014
    I weigh only 160 lbs dressed to ride. My Pugs is about 40 lbs with tools and water on board. So, only 200 lbs, total weight on a typical ride. For me, anything over about 7 lbs in the front feels too hard. Seemed like 8 lbs F was not enough cush, and too much bounce. I need more air in the rear, and 8.5 lbs R works fine for me on the trails, and still offers plenty of cush, feels firm enough without bounce.
    For example, my FBNs seemed a bit bouncy and too hard (lack of cush) for me when I tried 8.5 F and 10.5 R.
    I don't feel hardly any rolling resistance on the trails at these (6.5 lbs F and 8.5 lbs R) pressures. My FBNs roll nice and fast. I think I have found the sweet spot for me and my riding. Your experience will likely be different.
  18. #218
    Reputation: Dolbydarma's Avatar
    Mar 2013
    Need some tips. I can't get my new FBN 4" to seat at all (I'm going the split tube method)... Totally confused. Did the same exact set up as my winter 4.5" snowshoes on same 80mm weinmann rims???
    I just can't see having to go back to tubes. HELP!
  19. #219
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Quote Originally Posted by Dolbydarma View Post
    Put tubes in them for a day or so to get them in the right shape. Then break one side, pull the tube and install tubeless valve (or split tube in your case). If the other side won't seat, put an old tube or ratchet strap around the tire to help it hold air. A compressor helps but shouldn't be mandatory.
  20. #220
    Jan 2014
    Did you use dish soap and water?
  21. #221
    Mar 2013
    I didn't use soap and water, the tires went on the rims plenty easy, kinda too easy. They just didn't feel tight on the rims so there was no way to get air to stay in even with a compressor. I ended up using some spare 24" tubes (same ones I use for split tube) to air them up. I'll see if that helps get the tire in the right shape to try again later. The 24" tubes aren't exactly the right size so the sidewalls look at little uneven.
  22. #222
    Loser
    Reputation: Jisch's Avatar
    What Radair says, those tires were pretty kinked when I took them out of the packaging, it took a few days for them to settle in. I aired mine down immediately after getting the bead set with a tube and both beads moved to the middle again. Let them sit a few days aired up and they should be better. I did get mine to take even without doing that on Marge Lite rims split tube.
  23. #223
    Mar 2013
    Thanks for all the good advice. I left the tubes in for a few days and today the split tube plan went on without a hitch. Super Pumped!!!
  24. #224
    Jan 2014
    Glad that worked out for you. My tire was pretty loose to start out with. Took some time to gain their profile with a tube. On a side note, decided that I'm going back to the Floaters. I need a more aggressive tread for my main trails. Lots of large roots to power over going uphill in the Pacific Northwest. Would definitely keep them for a summer tire if I was in a dryer clime. The weight loss is very noticeable. Will probably settle back to one set of wheels. Looks like my setup with the Floaters rear and Larry front works out best for me summer and winter so no real need for two complete wheelsets.
  25. #225
    Mar 2013
    This is what I typically ride so I'm really hoping these FBN's will be the right choice. Definitely loving the weight savings already.
  26. #226
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Zero complaints from me on these tires still.....
  27. #227
    What bike is that? You should also be able to come up on pressure since you have a bluto.
  28. #228
    Mar 2013
    Motobecane Sturgis Bullet. Loving it!
  29. #229
    Loser
    I have about 175 miles on my Fat B Nimbles in technical, rocky terrain. I still love them - they are providing the right amount of grip and very low rolling resistance. They are holding air great split tube tubeless on Marge Lite rims. I'm running them somewhere between 10 and 11 PSI for my rides (on a Bucksaw). I was a bit concerned about their longevity as it seemed like the sharp edges wore off the lugs quickly. After a few more miles, I don't think that's much of a concern, the tread still looks good.
    I think the thing that will take these tires down is the sidewalls. My rear tire has threads showing. I've had other fat tires show threads for a long time before failure, time will tell with these. I'm going to order up another set right now, just to have them here in case (I guess that kind of tells you how much I like these tires).
  30. #230
    Mar 2013
    The sidewalls are my main concern as well. They just feel so thin!
  31. #231
    Jan 2014
    Quote Originally Posted by Jisch View Post
    Even though they didn't work out for me, I'd recommend them to anyone that has different terrain and would like a more versatile tire. Bike rode faster and smoother, and in most cases was all you could ask for outside of my main singletrack which has it's own set of problems.
  32. #232
    Jan 2014
    Hmmm. I was surprised at how solid the 120 tpi sidewalls felt on my FBNs compared the the really thin (almost flimsy) feeling sidewalls on my 60 tpi Halo Nanuks! That's why I'm saving the Nanuks for winter beach riding tires. The Nanuks won't be doing a lot of trail riding, except for the local dune and pine forest trails.
    I'm really liking my FBNs for the trails and gravel, and as an all-around tire.
  33. #233
    Loser
    It could be fine, I had threads showing on Floaters for a long time without failure. Only time will tell.
  34. #234
    shocked at how well the knards have held up after over a year of all conditions riding, but i want to try something different. a bit concerned with how much smaller the fbn is even compared to my knard 3.8. hudu 4.0 are smaller as well. was riding with a guy today that was on a brand new set of maxxis mammoths and wow what a nice looking tire that is. sidewalls seem bomber and they roll fast. he is coming off a set of bulldozer 4.7 so it's no surprise that he had to get used to there being less traction with the mammoth, but he was very happy with how they rolled, obviously. i'd like to go with the lighter fbn, but....
  35. #235
    Not the fake Jay Leno
    Reputation: Chinman's Avatar
    Dec 2014
    Running FBNs on my Spesh Fatboy SE and I really like them so far. I really think they are a great summer tire for the Fatboy. At 55 donuts a piece, I think they are a relative bargain too. Now if I can just keep from getting pinch flats with my Q tubes SLs!
  36. #236
    Mar 2013
    My fat bikes maiden voyage was cut short due to a pinch flat... I've gone the split tube route ever since.
    I haven't gotten these FBNs out for a rock ride yet due to all the trail closures due to rain, but I can attest to their pavement performance. I went on a 17mile urban ride today and actually enjoyed it thanks to these tires. On my snowshoes pavement was never an enjoyable option.
  37. #237
    In your pics where you were looked very rocky or were those just pics taken to take for the sake of the bike? Confused...
  38. #238
    Mar 2013
    Shots on the fun trails were pre-FBNs...
  39. #239
    Gotcha man. Yeah the fbn sounds hard to beat. Especially on price. Has anyone had them on the beach? If I don't have these before a sorta long beach ride soon. I am gonna throw endos on. They are great for beach and sand. They roll so easy.
  40. #240
    Loser
    The one shortcoming I've found with the FBNs is on dry leaves - they don't dig in very well, not a big deal, but they'll slide if you lean in too far.
  41. #241
    my bike's one step closer to getting a bit lighter today. now it'll officially be a 26+ with the new fbn tires
    ordered 4. arriving tuesday
  42. #242
    Is that because it is a 3.5" tire? Sounds good to me.
  43. #243
    no it's because it's a 4" tire that measures less than my 3.8's. from what i here.
  44. #244
    Quote Originally Posted by newmarketrog View Post
    Mounted tubeless on Marge Lite rims my FBN's measure approx 3.57".
    HuDu's on the same rims (tubeless) measure approx. 3.67".
    The FBN's are also 100 - 150 grams lighter (each) than the HuDu's.
    Very good choice for a light, fast rolling summer tire IMHO.
    ...and the price is right!
  45. #245
    Quote Originally Posted by mtuck1 View Post
    ya, quite a bit cheaper than my knards which are quite a bit cheaper than hudus and many others. hudus are definitely a bit smaller than my 3.8 knards so the fbn will look like + tires, lol!!! pedal strikes here i come!!! at least they'll be fast pedal strikes!
    stoked to try them! braaaaaap!!!
  46. #246
    Dec 2014
    ^^no kiddin! I've noticed quite a few more pedal strikes compared to when the spesh GCs were on me Fatboy. It's happening at the same place on the trail too. You'd think I'd learn!
  47. #247
    Mar 2013
    Finally on some trails
    I finally got these FBNs on my regular trail. Had a little bit of everything to ride on. Tons of rocks (of course) but also had some mud, wet rocks and sand too. I gotta say these tires really impressed me. They did everything I wanted very well and did it lighter! The fatty felt a bit more "mountain bikey" if that makes any sense. Quicker with less rolling resistance. No self steer at all but still tons of grip. The soft sidewalls did the job - lots of deforming around the rocks giving tons of grip, and took some hard hits as well without any noticeable damage. They held strong and kept coming back for more. Realistically I think I'll add more air to the rear. It was softer than what I needed but I wanted to really test my spilt tube set up.
    All in all I'm stoked with these tires.
  48. #248
    Quote Originally Posted by Chinman View Post
    the spesh is designed around those HUDGE GC tires and wide rims so it makes sense that you'd be striking left and right. my charge is designed around 4" tires on 80's so the fbn on 65's will be near the same. i was being dramatic
  49. #249
    Reputation: Steve Balogh's Avatar
    Installed mine today, 1180g mounted tubeless on 65mm Nextie rims. There's a lot of wobble on these, on both rims. I hope to be riding tomorrow provided it doesn't storm as the weatherman is predicting. May be too early to tell, but I'm thinking lots of vibration at high speeds.
  50. #250
    Jan 2015
    Cool-blue Rhythm Great first impressions
    Just got these setup toobless today. Bead seats real easy and audibly. Lost about 1.5 lbs over my d5s. Initial impressions after some concrete riding are that these ride A LOT quieter than the Dillingers and turning is much more confident. Can't wait to take them on the trail tomorrow. Even if they're only good for 700 miles, for that price you can't go wrong!
  1. Panaracer Soar
    By DFYFZX in forum 29er Components
    Last Post: 04-15-2015, 10:42 AM
  2. Panaracer Comet
    By offrhodes42 in forum 29er Components
    Last Post: 06-10-2013, 12:53 PM
  3. New Panaracer Rampage 2.35
    By shiggy in forum Wheels and Tires
    Last Post: 05-15-2013, 01:39 PM
  4. Panaracer CG TLC 2.35
    By Dan0930 in forum Wheels and Tires
    Last Post: 01-15-2012, 07:34 PM
  5. Panaracer Fire XC Pro ?
    By Wayne Meuir in forum Wheels and Tires
    Last Post: 07-09-2011, 05:26 PM
