Results 1 to 26 of 26
    Classic weekend warrior
    Reputation: sk1er18's Avatar
    Origin8 80mm rim setup tubeless?
    Not asking "how to", just wondering if anyone has set one of these up tubeless yet.
    Put a set of Buds on these last night with tubes to help shape the tires and the bead seemed very loose. I'm going to give it a shot anyway but figured it was worth checking to see if this is uncharted territory for this rim, or if someone always has some "lessons learned" (ie: dont bother and just run tubes until I upgrade the wheelset )
    -Carver Ti O'Beast
    -Niner RLT 9
    -'16 Trek Farley 7 (hers)
    Reputation: AdamJay's Avatar
    Jan 2014
    Quote Originally Posted by sk1er18 View Post
    Just ordered a pair of these rims. I'm also interested in their capabilities.
    Can I ask you if the Buds mounted easily tubed?
    Huskers fall on and off if thats any help.
    Jan 2014
    Quote Originally Posted by Anthem1 View Post
    Jul 2013
    Does anyone know the weight of these rims? Have t been able to find it.
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by ej132 View Post
    Let me google that for you
    Jan 2014
    Quote Originally Posted by bdundee View Post
    Aha!
    1049g for the sake of those also looking without the magic of google.
    Living the thug life.
    Reputation: Logantri's Avatar
    These look, smell, and act just like the Graceful Fat Sheba rims which were a rim I would NEVER try to make tubeless. Tires fit WAY too loose.
    I proudly ride for these guys.
    My blog.
    Jan 2014
    Quote Originally Posted by Logantri View Post
    These are made by weinmann and appear to be drilled HL80s
    aka bOb
    I agree with this, I have had plenty on experience with the Sheba and these are the same. It was hard enough to get the tires centered on the rim without blowing off with a tube in em, I could never imagine trying tubeless.
    Jul 2013
    I have non drilled version of these. The drilled version is only 0.2 pounds lighter? Thought of trying tubeless on my non drilled ones but sounds like a no go
    aka bOb
    I have drilled out the un-drilled Shebas with 1.5" hole and lost about 150g per rim if I remember right.
    Jul 2013
    Seems to be approx. what the manufacturer is getting between drilled and undrilled. Do you believe that 150+/- grams a rim is a noticeable or worthy while difference in terms of lightening up the wheel set?
    aka bOb
    I actually looked back at my notes and I lost about 260g per rim with 1.5" holes so a little over 500g should be noticeable and look a hell of a lot cooler.
    Jul 2013
    Very cool! I would like to lighten up my wheel set. I have the solid 80mm rims and devist8er tires(not ultra lite versions) so I think I could greatly reduce my rotational weight.
    To repeat what a few others mentioned already..... tubeless is a no-go on these.
    And x2, its hard enough trying to get the tire concentric even with a tube in there. My wheelset came on a rolling frame build that I finished; ill hold out for tubeless until I build a nicer/lighter wheelset like I planned to do regardless.
    -Carver Ti O'Beast
    -Niner RLT 9
    Reputation: akacoke's Avatar
    off topic here, where do you go about ordering them and how much ?
    17 Lynskey Fatskey
    07 Kona Stab
    14 Specialized Fatboy
    04 Santa Cruz V10
    My Parts for sale link
    I'll sell you mine in a few months
    -Carver Ti O'Beast
    -Niner RLT 9
    aka bOb
    Quote Originally Posted by akacoke View Post
    Any shop that buys from JB.
    thank you
    17 Lynskey Fatskey
    07 Kona Stab
    04 Santa Cruz V10
    Jan 2014
    $60
    Black - http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    White - Amazon.com: RIM OR8 26x4.0 AT-PRO80-UL 32/64 WH: Sports & Outdoors
    Jan 2014
    Update.
    The pair I just got from Bicycle Addiction (via Amazon) are 1012g and 1015g
    That's 152g/157g heavier than drilled Rolling Darryl, and $100 less.
    very nice. considering my sun/intense mag30 hoop is 840g on my DH rig. i kinda wondered about the weight on the origin8 rims too.
    what you used for a rear hub?
    17 Lynskey Fatskey
    07 Kona Stab
    04 Santa Cruz V10
    Jan 2014
    XT M756A on a Jenson price match. Couldn't afford much better for the rear but I reckon it will do the job.
    Front hub is Origin8 sealed QR fat front hub. Origin8 OR8 Fat Bike Front Hub > Components > Wheel Goods > Hubs | Jenson USA Online Bike Shop
    This will be my warm weather wheelset running either Origin8 Captiv-8er UL 3.5's or Larry front / Endo rear.
    Jan 2014
    Just received a third ATPRO80 UL rim that weighs in at 995g. Building it out next week with a Hope Pro 2 Evo Fatsno FDS front hub.
    I have a set to sell if anyone is looking for them
  1. New Origin8 80mm Rims
    By BoogieMang in forum Fat bikes
    Last Post: 11-22-2014, 04:13 PM
  2. Tubeless setup
    By dumanichi in forum Wheels and Tires
    Last Post: 10-27-2012, 06:22 AM
  3. tubeless setup
    By Geist262 in forum Wheels and Tires
    Last Post: 10-06-2012, 07:03 AM
  4. Tubeless setup help.
    By meSSican in forum Wheels and Tires
    Last Post: 01-28-2012, 08:57 PM
  5. can I go tubeless with this setup?
    By jrs67 in forum Wheels and Tires
    Last Post: 01-24-2011, 06:48 PM
