Results 1 to 43 of 43
    Reputation: Steve Balogh's Avatar
    Opinions on Race Face Turbine Cranks?
    After a messy ride today, I took apart my e-13 cranks to clean off the bearings, and to my horror the drive side bearing stuck to the spindle. Everything was a mess, and I manage to free the bearing, but can't get it off the other end. The Phil Wood bearings I put in them no longer seem to turn very well. My fatbike is out of commission again and I have an event I paid for in a couple of weeks. I need to replace the bearing shields as those are shot and e-13 is out of stock. I can re-build these, but I'm tired of fixing crank problems. I've never had issues like this on any other bike I own, my 29r has external bearings, works fine.
    This is the third time I've had an issue with these cranks, looking to replace. Looks like the Race Face Turbine is something I could get this week and get my bike up and running again. Would appreciate some feedback on these.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Cranks are good, nothing special. I ran turbines for a few years on a DH bike, stiffness to weight isn't quite as good as a hollow forged crank, but the price was usually reasonable and they were pretty strong. The real issue is the BB, which simply not quite as good as shimano units, but quality has improved for some of these. You can also get the enduro-bearings for pretty cheap to replace them. I'd rather use the x-type race-face setup than the gigapipe whatever setup on my fatbike, it should be better than that.
    Heads up Flyboy!!
    Reputation: mountaingoatepics's Avatar
    I have approx 700 miles on my "Fat" Turbines since February. I've ridden everything from Wet n Slush, powder, sand and super dry they're still spinning as new. My Shimano BB gave out on my 29er about a month ago and I was happy enough that I replaced it with a Raceface Turbine BB.
    Thanks! The Race Face bearings look like they are better protected. Not sure if they are the same size as what goes into e-Thirteen, but I have an extra set of Phil Wood bearings. I'm thinking what happened was those plastic covers that move with the cranks may have worn out enough to let let more gunk in.
    Hey Steve- I have the Turbines on my Mukluk and I like them- way lighter than stock, nice finish and the bearing seem well shielded. I like the fact that are arm and spindle only, so I could set up whatever rings I wanted. I had the e13's on my Pugsley, and they were pretty fussy. I had to add one thin spacer (not included) to the non-drive side of the Turbine's to take out the side play, but other than that I've been very happy. Get some quick before Iceman!
    David
    Reputation: SteveF's Avatar
    Anyone seen these for sale anywhere in 170mm length? Thinking about a set for my Mukluk but I can't spin 175's!
    I have the turbine on my bike, and have not had any issues yet. The latest turbines come with race faces' best bottom bracket. I am 275 lbs and put a fair amount to stress on my drive train.
    Reputation: blockphi's Avatar
    Mar 2012
    I like my turbines. Got them in March. +1 on the BB bearings being crap. Just replaced mine this weekend with Enduro bearings, but the fact that you can change the bearings is what sold me on it. And the snazzy red color. They seem stiff enough for my use.
    Thanks all! I'm picking up some blue RF cranks tomorrow, just in time for the fatty class at Iceman.
    Reputation: BurkeVT's Avatar
    Jul 2003
    I've got the green turbines on my geared hardtail 29er. They're solid cranks. I'd put them on a fatbike in a second.
    -Chris
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Steve Balogh View Post
    Wish I could be there with ya, have fun!!
    Feb 2013
    I have the RF turbines on my fatbike since new.. I found them to have quite a bit of flex under load, as when I was cranking up hill the arm would hit the chainstays.. Moving the spacers all to one side fixed the problem, not ideal but just replaced the BB with a new RF DH version to get a few more threads into the frame..
    Quote Originally Posted by ads-bully View Post
    That's odd, Turbines have been used for a long time, and while not as ideal as a hollow-forged crank, they are plenty stiff with the I-beam setup and you shouldn't be having that flex. I doubt it's the fault of the cranks, maybe the BB shell or something else.
    If turbines are flexing, it would mean pretty much any solid or non-carbon crank would do the same.
    nothing to see here
    Reputation: Stevob's Avatar
    I tend to agree that it wasn't the crank flexing. More likely the rear triangle flexing out to hit the crank. Some cheap cranks will flex badly, but I'd be surprised if the Turbines did.
    I see hills.
    I want to climb them.
    Feb 2013
    Well, it is a Ti frame and although compliant it is a strong material.. I could grip the crank arm in the palm of my hand and holding the chain stay could squeeze it enough to get it to touch ??
    I am going to have to agree with others and say that I very much doubt anyone on this planet has enough power to flex turbine cranks in the manner you describe.
    get down!
    Reputation: appleSSeed's Avatar
    I like mine a lot, but I feel like they are squeaking. Anyone else? Maybe it's my dropouts. I'm running single on the Fatback and there is a lot going on back there with the rockers. Gonna lube up the parts and see if it is indeed the cranks
    For the money, these cranks are the deal!
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    nothing to see here
    To properly test whether it's the frame or the crank flexing, tie a piece of string between the head tube and the rear dropout and then repeat your test. If the string sags when you do the test, it's the frame flexing, if not, it's the crank. Of course it may be a combination of both.
    I see hills.
    I'm up and running again, did a trail ride today with these new Race Face cranks and they work fantastic. No flex at all that I can tell, seem a lot more solid than the e-Thirteens they replaced. These went on my Ti Fatback, no issues hitting the chain stays. I did not need to re-adjust my front deraillure either.
    Ooh, pretty!
    I want to ride behind you at Iceman and see where you use that 44 outer ring!
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Quote Originally Posted by deuxdiesel View Post
    Must have legs like the Incredible Hulk!!
    I found these Turbines in all the colours on eBay for $206, even with shipping to the uk thats was £50 cheaper than we can get them here. I am going to wait until my current BB really gives up then will take the plunge..... in red!
    Reputation: Jstews's Avatar
    Oct 2011
    I also run them on my hardtail 29er, and I love them. Stiff enough and as a single ring setup, I'm pretty sure they are lighter than XT. No problems with the BB either.
    FWIW I think they look great too.
    I see you are running blackspire rings. You find them to be superior to RF, Shimano, Sram rings?
    I am a clyde always searching for the toughest drivetrain components.
    Quote Originally Posted by jonshonda View Post
    A bike shop owner got me into using these several years ago - If I'm not mistaken my XTR Crankset on my 29r came stock with Black Spire rings. They are so stiff they do not need the little support pins that lineup behind the crank arm. I've never broken or bent these like I have with e-Thirteen or even my Middleburn Duo's. Also, those are stainless steel chainring bolts. I believe someone here clued me in on replacing aluminum bolts (either Mangoman or Leopold Porkstacker). That's what helped crack the e-Thirteen's last year. This year I also replaced the SRAM cassette with Shimano XT's. I've probably trashed more SRAM cassettes by getting twigs in them than I have breaking/bending chainrings. Another thing, last year I bought the Blackspires because e-Thirteen was not selling replacement rings at that time, which has changed recently when I looked on their revamped website earlier this week. So far Black Spires are my favorite, the Wolf Tooth also look good to me, but I've never used them. Middleburn does make some good rings too, but on my other fatbikebike the Duo's only have a three-arm Spider. I have used their Mono once and that was really solid, was hard-anodized too.
    Dan - Iceman is a great place for a 44 tooth chainring. Last year in the flats I made a lot of use of it, as well as in some slight DH sections. The e-Thirteen's that were replaced came stock with a 44, so I just stuck with it. I may someday try a different setup, but for now it works fine for me. Don't forget the race starts on flat pavement for a few miles, full gears ahead on that!
    Reputation: c0nsumer's Avatar
    Hey Steve! Funny to see you say this... I just ordered a Turbine crankset for my Mukluk as I'm getting a bit tired of the e*13 crankset. Mine's still working fine, but I've gone through one bearing replacement and another rebuild. I've had no real problems, but I figure that the Race Face stuff is pretty standard, and I like their stuff on my other bikes.
    For what it's worth I also ordered a 32T Truvativ Trushift steel ring and a 22T alloy ring, which'll be mated with a BBG bashguard. I've had a very similar ring setup on my e*13, and I think it'll do well on the Race Face. (I like the steel ring after a wet beach ride which chewed up an alloy ring... The steel is not that heavy and it lasts and lasts and lasts even in gritty situations.)
    I think that pin is actually a safety measure to keep the chain from getting bound between the crank arm and chainring should it drop to the outside. It's not for support. Personally, I like my rings to have this...
    zeb
    zeb is offline
    Pros:104 bdc,2 chainrings and bashguard (old e13 superchager) works flawlessly.
    Con:Shimano 32 th middle ring does not fit due to not symmetrical bulge next to bolts inside of cranks.
    I bought truvativ 32 chainring ,fits fine.
    For those of you who bought the Turbine crankset, did it come with chainring bolts?
    Reputation: mtuck1's Avatar
    I bought one in March and it came with bolts and the granny spider in the box. I bought a second one in July and was surprised to find no bolts or spider in what appeared to be the exact same packaging. I had to buy them separately. I was not happy to learn that the hard way. Should have been paying more attention. They are good cranks, and good value IMHO and I would buy again.
    Quote Originally Posted by mtuck1 View Post
    Thank you. Sounds like it's a good thing that I ordered bolts at the same time. I ended up just going with some of the FSA torx/hex ones.
    What I noticed right away was a sleeve connecting the cups to keep water out from the inside through the BB shell drainhole. Could be where my issues are coming from. An RF BB is cheap to replace too, uses common tools also. So far pretty good, and my feet like the RF better. For chainring bolts it didn't matter - I used my stainless steel bolts. Regarding the pin - on some cranksets I've had way back it is a support. Perhaps nowadays those are just for what you are saying. The Black Spires are nice and strong though.
    That's good to hear. I'm looking forward to mine. I'll have the e*13 for sale soon, as it's still just fine, but just not what I'm wanting. I might even end up selling the massive socket with it... (The Hive tool isn't needed, it's just the same as a very large socket.)
    Quote Originally Posted by c0nsumer View Post
    Steve, check out e-Thirteen's site now. Those shields I was looking for that were out of stock are no longer there. Looks like they redesigned the external BB's, they have a different plastic shield now, and no internal sleeve from what I see. The new shields look nice, but I still don't see much water protection from the inside of the BB shell. Also, appears the only fat bike crank now is the new one they recently came out with. I don't see the one we have anymore.
    Are you talking about this BB? Those seals do look a little better...
    I'm still not sure. 30 minutes ago I was just riding my bike with the e*13 crankset and I didn't think twice about it while pedaling. I guess I'm just hoping the Race Face isn't noticeably heaver or whatnot.
    Reputation: druidh's Avatar
    My RF BB has just given up.
    That's almost exactly two years of regular (ab)use on all sort of trails with occasional immersion in both salt and fresh water. I see that RF do a replacement bearing and shield kit but I'm going to fit a whole new BB this time and repair the old one as a spare.
    Quote Originally Posted by druidh View Post
    Two years including immersion? I'd call that fair play, personally.
    Yep. Just trying to put some balance back into the regular "Raceface BBs are shit" comments
    It's also worth remembering that the BB cups are the same as the 83mm and 68/73mm versions - it's just the interconnecting pipe that's different. So, once you've bought one wide set you can just shop around for the best deal on any size
    Reputation: Schott's Avatar
    Nov 2012
    I think the 83mm (dh) has a few more threads than the 68/73. Not sure which one the 100 sleeve matches. But either one will crush the sleeve, or one won't reach. But yes.
    "You're like a Ferrari engine driving a dump truck"
    That's exactly my plan...
    Feb 2013
    I just bought the DH version for the exact reason above regarding the thereads.. This was in response to my post at the start of this thread on the fact the Xc version only had a couple bites of thread after I moved the spacers to stop the crank arm hitting the frame.
    So far so good and a lot more comfort at the number of threads in the BB
    Reputation: woody_8_5's Avatar
    Posted this last year when the Turbines became available.
    Cheers
    RaceFace 100mm BB
    Reputation: polarflux's Avatar
    I've been using RF Turbines with flats on my 5 Spot for about two seasons. After riding my work commuter a bunch I can tell that the Turbine crank arms bent a bit. I'm not heavy, about 190, but I think torqing through turns and moderate jumping has twisted the arms so the pedals are not longer parallel. Standing on the bike with the pedals at 3 and 9 I can definitely see the arms twist of my feet are to the outside on the pedals. Probably an OK pedal with clips, but maybe not the best for flats.
  1. Cranks - Sram X9 vs Race Face Turbine–need help choosing a 2x10 crank and chain guide
    By AMjunky in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-28-2013, 07:29 AM
  2. SPAM - New Race Face NEXT cranks, Time ATAC carbon pedals, RF Turbine Chrings, MORE
    By Green Giant in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2012, 02:02 PM
  3. Race face Next sl and race face Turbine Sl with Shimano 2x10 drive train
    By kumarpr227 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2012, 09:38 PM
  4. M952 vs Race Face turbine (square taper) cranks......
    By blak_byke in forum Singlespeed
    Last Post: 01-06-2012, 01:16 PM
  5. Race Face Turbine
    By LeeL in forum All Mountain
    Last Post: 11-28-2011, 08:32 AM
