• 01-20-2013
    JoeG
    On-One Fatty Wheelset and Floater Tire Tubeless Setup (How To)
    This is what I did to eliminate the tubes from my fatbike. I was able to save about 14 ounces (390 grams) per wheel. This procedure may or may not work with other rim and tire combinations.
    Stuff that you need:
    - On-One Fatty Wheelset
    - On-One Floater Tires
    - 1 inch (25 mm) wide Gorilla Tape (2 rolls)
    - Styrofoam Sill Foam Gasket (available from Lowes, Home Depot, etc. for about $5)
    - Valve stem with removable core (I cut Presta valves out of Q-Tubes)
    - Stan’s sealant
    - Packaging tape
    - 2 inch (50 mm) wide Gorilla Tape
    - Floor pump or air compressor
    - Sharp scissors
    - Tape measure or ruler
    - Pen or marker
    - A small cat to assist (optional)
    Preparation – The inside of the tires were greasy, my guess is that it they were covered with a mold release agent from manufacturing. I cleaned this off of the tires with laundry detergent and water. Also, each rim has a set of eight small holes in the bead seat. Four are near the valve hole, and four are near the seam in the rim. I plugged them with super glue and used fine sandpaper to smooth out these areas, I do not know if either of these steps is needed. I left the factory tape on the rim that covers the spoke nipples.
    Foam – The foam serves to fill in the area between the bead seats and makes it easier to inflate the tire. It only adds about 18 grams per wheel. Cut 2 pieces of foam for each wheel. Mine were 2 3/8 inches (60 mm) wide and about 67 inches (170 cm) long. I found that it worked best if the foam was about an inch (25 mm) short of wrapping completely around the wheel. The foam his easily able to stretch to close this gap, and it is easier to tape up later if the foam isn’t loose and moving around. I used a piece of clear plastic packaging tape to join the two ends of the foam. The outer layer of foam may need to be a little longer than the first wrap. The valve stem will easily punch a hole through the foam.
    Gorilla Tape – This forms a seal between the tire beads. It is important to take your time and avoid any creases or wrinkles that may leak air. The Gorilla tape is pretty easy to work with, so that’s not too difficult to do. It will take three wraps to cover the foam; one under each bead of the rim and one in the center. I started near the valve hole. The idea is to stick the tape to the aluminum bead shelf of the rim, then on to the foam to form a relatively flat surface. I used a plastic tire lever to make sure that the tape adhered well. I overlapped the ends by an inch or so.
    After the three wraps were finished, I added a single piece of 2 inch (50 mm) square Gorilla Tape to the spot where the valve would go. I then heated a piece of metal on the kitchen stove and melted a hole in the Gorilla tape for the valve to fit through. Next, add the valve stem and tighten the knurled nut on against the rim. I used a valve (with a removable core) cut from a Q-Tube brand inner tube. I previously tried a Stan’s valve stem for a tubeless wheel, but it pulled through the tape and leaked.
    Next, mount the tire onto the rim. Line up the valve with the Floater logo (this is critical!). I was able to mount the tires by hand; I didn’t need to use a tire lever at all. Once both beads are mounted, the tire should not be able to spin on the Gorilla tape. If it can’t spin, that indicates that the foam and tape are in contact with the tire bead, and it should air up easily.
    Pump up your tire. I had no problems using a floor pump. I pumped mine to 30 or 40 psi in order to make sure that the beads were seated all around the tire. If so, you should be able to see some reinforcing all the way around the tire bead like below.
    Let the air out of the tire and remove the valve core. Add your Stan’s sealant. I added about 3 fl oz, or approximately 100 grams worth.
    Reinstall the valve core. Pump up the tire again. Make sure that the bead is seated again, then do the “Stan’s shake and spin” to make sure that the sealant is spread around. If you have any leaks, put it at the bottom and slosh the sealant around until it seals. This was my worst leak below (worringly right at the rim seam!).
    Let it sit for a while to be sure that everything is sealed. Reduce the pressure to what you plan to ride it at (I’ll try about 8 psi, myself) and do the Stan’s dance again to make sure that everything is sealed. Put the wheel on your bike and go ride!
    Weight Data (Ready to ride including skewer and rotor, cassette on rear)
    Front Wheel w/Tube 8 lb 7 oz 3.83 kg
    Front Wheel Tubeless 7 lb 9 oz 3.44 kg
    Front Weight Savings 14 oz 0.39 kg
    Rear Wheel w/Tube 9 lb 11 oz 4.40 kg
    Rear Wheel Tubeless 8 lb 13 oz 4.01 kg
    Rear Weight Savings 14 oz 0.39 kg
    Approximate weights by item
    Valve Stem – 7-8 g
    Foam (one layer) – 8-9 g
    Gorilla Tape – 65-70 g per wheel
    Stan’s sealant – 3 fl oz = 100 g per wheel
    Total per wheel – 180-187 grams
    OEM Tubes - 593 g each
    Cat - 5 lb 9 oz
  • 01-20-2013
    JoeG
    I would appreciate if some folks could read the above and provide feedback if anything is not clear or doesn't make sense.
    I'm crunching the numbers on the weights and will add that in an edit.
  • 01-20-2013
    OFFcourse
    They might be the clearest instructions for a fat-tubeless set up I've seen so far. Nice job.
  • 01-20-2013
    Stevob
    Well done Joe. I'm interested to know if this method will work with just the tape, rim strip and no foam. Maybe people's concerns about tyre hops could be alleviated with a narrow strip of tape on the bead seat.
    When I eventually get a Fatty, I'll be doing drilled rims with clear windows.
  • 01-20-2013
    rockcrusher
    I'm going to try this with my marge set up. I have tried every combination of tape and weather stripping and such but never anything I was comfortable using in a situation where i might need to seat the tire with a pump or CO2 cartridge in field. This looks like what I was looking for and less finicky than Mendon's method. Thanks!
  • 01-20-2013
    gretch
    Great job and explanation of the process.... I run tubeless on all my other bikes but not interested in converting my On-One (yet).... I changed the stock tubes to Schwalbe FR ones and dropped 400g per wheel... same weight savings as going tubeless but a lot less complicated... :)
  • 01-21-2013
    flobukki
    nice work. i'm definitely going to try this once my fatty finally arrives.
  • 01-21-2013
    Schott
    But actually more likely to flat at low psi than stock tubes....weight savings isn't everything.
    OP, nice write up. If I hadn't already done the same thing, I'd go do it right now.
  • 01-21-2013
    builder
    Beautiful job. I hadn't thought of the sill foam. Perfect!!
    For someone wanting to use no foam, there is really too much space between the tire bead and the rim to ever get it to seal. I know, it can probably be done, but at a huge hassle. This is a very elegant solution.
  • 01-21-2013
    Nelson34
    Great thread! I'm stupid when it comes to reading instructions/how to's. you really put up great Picts to go along with instructions-thanks! I may try this on my wheels.
  • 01-21-2013
    bricke
    Thank you, great howto.
    I've a question, a friend of mine has successfully made tubeless an on-one rim-tyre with the same system* but without the Styrofoam.
    So, why do you use the foam?
    *quite the same, they only put some gorilla tape over the junction of the rim and that's all, no need to put the tape on the rim (they've leave the on-one standard tape)
  • 02-22-2013
    flobukki
    i finally got around to trying this for my fatty.
    i did one wheel, pumped it up without sealant liquid. it leaked air but sat well enough. then i added some stan's and after some shake it was fine.
    next day wheel number two. worked just as good. pumped it up to 2 bars and didnt't leak at all for hours.
    day three: wanted to go out for a nightride: shock! one of the wheels was completely deflated. the following hour i was fighting for it to get seated on the rim again. without success. the first couple of times i had no troubles getting the tires to pop on the rims. this time no way. i wonder why. i had to go with tube in the back and tubeless front. later in the middle of the woods i lost my front tire too. different reason this time. it seems the tape i used (european duct tape) got loose because of the sealant.
    i have two suspects:
    1) wrong tape. next time i'll try to find something like your gorilla tape
    2) maybe another layer of foam to get the tire seated. -> my observation: the tire seems very soft and elastic once it's been in contact with stan's sealant. first try i had no problems inflating it with a floordrive. next day it didn't work at all. even with helping hands and a spanner belt around the tire etc.
    anything else i might be doing wrong?
    EDIT: JoeG: how has your system been holding up so far? what kind o´f riding do you do with it. flats or steep trails
  • 02-22-2013
    JoeG
    My front tubeless has been perfect. I rode it again yesterday on frozen ground at 5 psi and it held just fine. That pressure was too low for good steering, so I'll bump the pressure back up a psi or two. I generally ride wooded singletrack trails; not many rocks but some roots and such. Terrain is hilly; lots of twisty ups and downs. Oh, and some snow riding, too and mud at times as well.
    I took the rear gorilla tubeless apart to try a Stan's rim strip and split BMX tube combo. The glue holding the rim strip to the split tube failed, and I just put a tube back in because I plan to try it again. Still looking for the right glue.
    As far as not being able to reinflate your tires, did the foam compress a lot? The sill foam that I use compresses and doesn't spring back, so its really a one time use kind of thing. And wrinkles in the tape are a no-no as well. The gorilla tape is easy to get on without any wrinkles.
    I've used Stan's sealant in regular mountain bike tires for many years and have never seen it soften the tires or anything like that. If it softened the tires, they wouldn't last. Stan's is mostly latex rubber and forms a skin on the inside of the tire over time. I don't see how it could soften or eat into the rubber tier at all.
  • 02-23-2013
    dustyduke22
    The biggest thing to remember whenever converting something to tubeless is this:
    If you cant inflate it with a hand pump, its not a good enough seal to hold its bead.
    I have converted countless tires to tubeless and this fact always remains. Like you said, build up your base a bit and get that 'tire to tape gap' to almost nil and I suspect that will solve your problems.
  • 02-23-2013
    dustyduke22
    oops
    double post
  • 02-24-2013
    JoeG
    Well, I pinch flatted my rear tire yesterday. :sad: It had the heavy On-One tube in it, though. It won't any more! :)
    Tubeless front wheel has been fine.:thumbsup:
  • 04-03-2013
    zarr
    tagged for future ref
  • 04-03-2013
    autodoctor911
    I notice a lot of people use Gorilla brand tape.
    I just got some and noticed it is significantly thicker and heavier than the 3M brand black duct tape I have.
    Who can quantify the weight savings by using standard 3M duct tape compared to using Gorilla tape.
    I have both, and just wondered which would be better to use.
    I also have seen someone on here using a blue tape that looked like non-reinforced vinyl or something. Maybe a non-reinforced tape will seal better, since it doesn't have as much texture as cloth backed tape.
    I don't know, so go ahead and start arguing about which tape is better. Go ahead and throw in any other tape you may have used, like stan's yellow, schwalbe, velocity, Wtb etc.
  • 04-03-2013
    OFFcourse
    Used gorilla tape it was heavy as sh$% and I had to do a few extra layers cause it was leaking through the cutouts & unused spoke holes. Have 'blue' tape in mail to redo wheels :)
  • 04-05-2013
    E6roller
    Nice job on the tutorial!
    yikes......593 grams for the OEM tube!?!! The OEM inner tube alone weighs more than a carbon fiber 80mm fatty rim. http://forums.mtbr.com/fat-bikes/car...ms-846713.html
  • 04-07-2013
    stesteste
    had a go at tubeless everything ok apart from when i let tyres down they come off the seat and when pumped up if i press side near rim it will leak air i know the problem is there not seated properly but i get to 35 psi and darednt pump anymore ,should i here it pop on to the bead what should i look listen for thanks ,
    what pressure can i pump to without blowing me nuts off
  • 04-07-2013
    bikeabuser
    The problem I see is,
    Your tires will probably always leak, when you air them down.
    Some tires are not suited for such a thing.
    Concerning sound,
    Some pop into place, others don't.
    I gave up on tubeless for a reason ... It just ain't worth it, to me.
    YMMV
  • 04-08-2013
    JoeG
    I have not found that to be the case with Floaters at all. There are very, very few pinholes in the tire casing where sealant leaks out when new. The ones that I have leak a lot less than most other standard (tube type) tires; they're almost as good as some tubeless ready tires IME.
    No tube or tire holds air indefinitely.
  • 04-25-2013
    fluap
    I've just converted a stock standard Fatty front wheel with the On One Floater tyre. However I haven't done ANY mod's or extra tape etc, I simply put a valve from an old tube in, added Joes sealant, and pumped it up. I admit I uses a compressor, and it took a few minutes for it to hold pressure and seat into place. I did all the usual shake and rolling it around deal, and it's held air no problem at all. I guess I used about 100ml of sealant, and not much left the tyre. Overnight it hasn't leaked any air either. Impressive!
    Now I just need to give it a go with the wheels that I've drilled. That;ll amount to a saving of about 1.3kg per wheel over the original, making the bike much more manageable and fun to ride.
  • 04-25-2013
    alphazz
    Good pictures, nice instructions, and good weight savings.
    It isn't the way I do it and I would change some things but if this works for you, that's great.
  • 05-09-2013
    troutie-mtb
    Great instructional JoeG
    Here is my attempt very similar to Joes only losing the rim tapes and not using any tape
    my calculations I think I am saving over half a kilo per wheel
    front tyre is still up 2 days and 2 rides later so doing the back wheel this weekend
    Light weight Ghetto tubeless attempt « Singletrack Forum
  • 05-09-2013
    TeddyTS
    Me too..
  • 05-10-2013
    Shark
    The foam layer helps for tires not wanting to take air, but as noted before, the foam will crush down once it's in there with pressure, so it's kind of a 1 time use. However, once the tire is mounted & ridden for a while, they tend to mount back up very easily after.
    For anyone complaining about leaking bead, just add 1 more wrap of gorilla tape on the bead, no more issues. My RD's with 2 wraps on each bead are very difficult to remove the tire from the rim with no pressure inside. I had to stand on the tire to break the bead, couldn't get it with hand power alone.
  • 07-03-2013
    gavinda
    Ok, so I've followed the instructions as above and all has seated apart from a small bit where the rim is joined. This is leaking very slightly at the bead, but also across the join. what should i be looking for or should i just wang some sealant in and hope for the best?
  • 07-04-2013
    OFFcourse
    wang and dance!
  • 07-30-2013
    mrgould
    argh!
    Instructional photos are gone, too popular!?
    JoeG, could you please upload the photos just here,
    to A community photo gallery - Mtbr Mountain Bike Photo Gallery
  • 07-30-2013
    gavinda
    Forgot about this, I did the 'wang and dance' and all is good. I've done a few rides and am confident of the puncture proofing but still don't know the limit of the tyres so I'm still riding with two tubes in my pack!
  • 07-30-2013
    gcappy
    I set up NATE's on Clownshoe's with the split tube method the other day. I used 24x2.25 Q tubes with removable valve stems. I took every thing apart, cleaned it all, installed the Q tubes with some pressure, straightened them on the rims, cut down the middle all the way around, cleaned out the powder, installed the tires making sure the Q tube edges were hanging over the rims, tied a rope around the tires to push the beads out, inflated with a hand pump, removed rope, removed valve core, pumped in three vials of 'sealant, replaced valve core, re-inflated, shake and bake and done to perfection. I rode it for a while at speed and over rough terrain with no problems at 6 psi. I will try this again when I get my new 9-0-7 with Bud/Lou on Clownshoes. It was a very easy and not too long process.
  • 07-30-2013
    Stevob
    Originally Posted by gcappy View Post
    ...tied a rope around the tires to push the beads out, inflated with a hand pump, removed rope, removed valve core, pumped in three vials of 'sealant, replaced valve core, re-inflated, shake and bake and done to perfection. I rode it for a while at speed and over rough terrain with no problems at 6 psi. I will try this again when I get my new 9-0-7 with Bud/Lou on Clownshoes. It was a very easy and not too long process.
    Great that it worked so easily. In place of the rope, you can also stretch a tube around the outside of the tyre. Saves having to undo the rope. I also suggest removing the valve core for quicker and easier inflating, even with a hand pump.
    Also great to hear it held up well @ 6psi when ridden hard.
  • 07-30-2013
    mrgould
    no rim strip?
  • 07-30-2013
    crashtestdummy
    I set up NATE's on BFL's
    Now I'm confused.
  • 07-30-2013
    gcappy
    Originally Posted by crashtestdummy View Post
    Now I'm confused.
    I don't blame you. I meant NATE'S on Clownshoes.
  • 07-30-2013
    gcappy
    Attachment 820687
    Originally Posted by mrgould View Post
    no rim strip?
    Yes, new white rim strips.
  • 07-30-2013
    mrgould
    Nice, timeless black & white look totally trending for 2013!
    White saddle maybe?
    The rim strips are the regular ones or did you use some lightweight material?
  • 07-31-2013
    OFFcourse
    White saddle maybe?
    Damn my eyes hurt its so shiny, I just got thru a whole bottle of acetone on my matt black 907. Ninja!
  • 07-31-2013
    gcappy
    White saddle maybe?
    Surly strip's. I just bought the black saddle but now I am thinking I should have gone white. Maybe.
  • 07-31-2013
    Tor
    I also used the split tube method on my 47mm trial rims for my On-One. Tried first without split tubes, but it seems that the large holes in the rim is a problem for the rim strip and pressure. The pressure pushed the gorilla tape out of the holes. It's very little surface on the sides of the holes, so it is diffiicult to get the tape to stick. The split tube was perfect. Took me 20 min or so. No leaks at all.
  • 10-23-2013
    bvfromru
    JoeG, so how's it going? Any issues with your method? Any additional recommendations after long time use?
    Thanks for the crystal clear instruction! Maybe I'll try it on my Fatty one day.
  • 11-16-2013
    mountaingoatepics
    Thanks JoeG for the pictures and directions. I set up my front Holy Rolling Daryl this way tonight with a Surly Nate and was able to seat the bead with a hand pump and no compressed air.
  • 11-16-2013
    Jisch
    I just did my Floaters last night with the split tube method on weinmann 80 and 100mm rims (back and front respectively). I just laid the split tube in, dumped in a couple of scoops of Stans and aired them up with a compressor. The back aired up on the first attempt, no problems at all. The front took a bit more work, I had a hard time getting the bead to seat, I couldn't get enough pressure in the tire to move the bead out. I tried putting a strap around it, which didn't seem to help. After the third or fourth attempt it finally took air. I think the problem was getting the bead out beyond the cut outs. I was close to putting a tube in temporarily to get at least one bead seated, but ultimately it just took a little patience and a lot of air to get the beads to move. I moistened everything up with the Stans fluid, probably a little soapy water would have helped too.
    I let them sit at 20psi over night, both were still full this morning. I'm going to drop them to riding pressure and do a ride today.
    John
  • 01-05-2014
    Bumpyride
    2nd Post. Just ordered a pair of On-One Floaters for my bike that's to be delivered. They're 15% today only with the code UKTYRE15 at On-One Floater Fat Tyre / 4.0 inch / 120 TPI / Folding / Black.
    My bike is coming with the Vee Missions and I wanted a good all around snow tire. Just happened to have this pop up today.
    Will convert to tubeless after I blow up a tube or two, but will be wanting to ride asap at Big Sky Montana.
    Thanks to all that post with the DIY info. It has clarified a lot of questions I've had.
  • 01-05-2014
    donorco
    Thanks for posting that link to the Floaters I've been on their site before and the tire's are always out of stock so I just ordered a pair.
    I plan on going tubeless with them as well so this post came at the perfect time.
    Thanks everyone for sharing!
  • 01-07-2014
    wadedro
    instead of the sill foam I used a 1/4" closed cell polyethylene foam I had prev used as an insulating spa blanket for a hot tub. you can get this stuff by the foot at local pool and spa dealers. This material will never crush down like sill foam so no need to replace it every time you swap out a wheel. Great instructions, worked perfect. Note- had to angle cut the poly foam on the sides so it fits nicely into the concave of the rim
    this stuff DLR-6THERMAL, Thermal Blanket, Floating, 6' x 6', Light Gray [DLR-6THERMAL] - $52.07 : Superior Spa Parts, Your Trusted Spa Repair Guys
  • 01-07-2014
    Raul34
    So I see they raised the price and are out of stock. Damn it.
  • 01-07-2014
    keyhavenpotterer
    Cool new colours due in soon. 3000 tires due in the end of the month.
  • 02-13-2014
    wadedro
    where can we get the colored ones?!!!
  • 11-17-2014
    helix_it
    Hi guys, and thank you for the interesting feedback.
    I still don't get though why something like this:
    is impacting a rim (painful) design like this:
    (which I think should be closer enough, if not equal, to the OnOne rims).
    I mean, the side-step is the main problem, not having a "flat bed" like tubeless-ready rims usually have.
    Question is the risk bead moves over this gap with low pressure is really high, so my guess is the material you put leave space for the tyre to move, and to come back in place if this occurs.
    I second that, but I am wondering if a tighter spot in the bead area won't solve the issue avoiding all this material in the center... or, even better, if just two stripes of material on the side of bead channels would directly stop the tyre from moving on low PSI in the first place...
    Any guess/test on this side?
  • 12-05-2014
    bad andy
    Bumping this up... as I'm about to undertake the tubeless setup myself with a new set of floaters on the stock rims.
    Concerning the question above, I believe it is valid. Would simply having 2 strips of foam/material near the edges of the rim bead work just as well as foam the entire width of the rim?
  • 12-09-2014
    bad andy
    Ok, so I found some time to try my approach. In my past tubeless experience on other bikes, the key is always to get a pretty snug fit between the tire and rim to begin with. Whether accomplished by rim strips, tubeless tape, gorilla tape, duct tape, unicorn mane, or leprechaun skin... a tight fit before attempting to air up always yielded the best success for me.
    As we know the fit of the Floaters on the on-one rims is crazy loose, like "how can this possibly work?" loose. So here we go.
    • [1] Start with rim (my previously created duct-tape rim strip is in place covering my drilled rim holes)
      [2] cover the small holes used for pinning the rim with elec. tape (the rim tape would probably have done this, I just felt like being sure these won't be an issue later. There were 8 of these on the rim.
      [3] Lay one wrap of this: Armacell 2 in. x 30 ft. R-1 Foam Insulation Tape-TAP18230 at The Home Depot
      [4] then one wrap of this (in 72mm width):**Scotch® Strapping Tape 8898 << This stuff is the same as Stan's tape or whatever.
      [5] run finger along bead edge to get a nice tight seal, with no wrinkles.
      [6] then one more wrap of the foam tape
      [7] then one more wrap of the 8898 tape
      [8] again seal the edges with finger
      [9] create hole for tubeless valve stem (used a heated utensil to melt a hole instead of poking, I figure rips in the tape would be bed, melting = more better)
      [10] place floater on rim and marvel at the nice snug fit (I actually had to use a tire lever briefly for this)
      [12] air up with compressor and jump for joy that the beads are seating! :)
      [12] remove valve core, and fill with 4oz. of tubeless juice goop.
      [13] Do the stans shake and let wheel sit for awhile on sides for sealing.
    So basically the 2 wraps of foam fill the rim's inner channel nicely, and also applies good pressure (once filled with air) to my rim strips so they fill/slightly bulge at the drilled rim holes. And 2 wraps of tubeless tape seems to be good for added pressure on the bead shelf.
    I used a set of floaters 2 seasons old already so expected some seepages and leaks but all in all surprisingly good. A few pinholes on the sidewalls but the goop is doing its thing. As of this AM, still some air in the tires and things are looking promising. Will give a real test this weekend
    Overall I might have gained 2oz over my tubes, but I was using the 180gm Schwalbe tubes and am tired of pinch flatting those things on trail rides. Most of any added weight is in the tubeless goop.
  • 12-09-2014
    tfinator
    Re: On-One Fatty Wheelset and Floater Tire Tubeless Setup (How To)
      [13] Do the stans shake and let rim sit for awhile on sides for sealing.
    So basically the 2 wraps of foam fill the rim's inner channel nicely, and also applies good pressure (once filled with air) to my rim strips so they fill/slightly bulge at the drilled rim holes. And 2 wraps of tubeless tape seems to be good for added pressure on the beat shelf.
    I tried a similar approach. It didn't last because the foam compresses with tire pressure.
    Your exact method may be more sturdy though. Make sure to report back in a few weeks!
  • 01-16-2015
    funnyjr
    Converted on one fatty wheelset ghetto tubeless. A bit difficult to seat the tire bead with Surly Nate but the Bud went on w/o issue. The Nate required some strapping to get beads closer to rim wall. Has been running well down to 6-7 psi is cold climate
