Results 1 to 33 of 33
    Mar 2013
    on one fatty bud and lou
    hi after reading many forums i understand that the bud will fit the on one fatty i have BFLs on mine and still have 10-15mm at either side and near bottom bracket has anyone actually tried the lou on the rear as i thought it was the same casing as BFLs apart from the tread been 5mm larger ,,,70mm rims,, any info appreciated thx
    Sent from my Transformer TF101 using Tapatalk 2
    Fat & Single
    Reputation: ozzybmx's Avatar
    Some info that might help. A bud on a 65mm marge lite measures 111mm at the widest point.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Mar 2013
    Re: on one fatty bud and lou
    i got this with 10-15mm each side left with bfls cany see why lou wouldnt fit
    Sent from my GT-N7100 using Tapatalk 2
    Attached Thumbnails Attached Thumbnails on one fatty bud and lou-uploadfromtaptalk1369743606737.jpg
    Fat & Single
    Just remember to allow some for tyre wiggle, if you are non tubeless there a 10-15mm swagger on the tyres. Tubeless with the beads seated and its pretty straight.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by ozzybmx View Post
    With the tire beads seated properly there should be ZERO difference is the amount of wiggle.
    mtbtires.com
    Fat & Single
    Quote Originally Posted by shiggy View Post
    Thats what i said.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Dec 1998
    Thats what i said.
    Not quite:
    To clarify my reply: with the tire bead properly seated there will be ZERO difference in the amount of wobble regardless if you are using inner tubes or not.
    mtbtires.com
    Fat & Single
    Seating the bead when running tubes on fat wheels isnt an easy task.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Oct 2012
    I haven't tried tubeless yet, but I do get pretty noticeable side to side movement on my fatty floater tires on the Fatty rims with tubes if I run it below 12psi rear or 9 psi front. when aired up to 30-35 it goes away, but If I go below those pressures it will return while riding.
    Narrow (1") tie-down straps worked for me.
    Put about 3psi in the tire/tube, then wrap the circumfrence and cinch it down.
    Over inflating to seat properly, then deflate to desired psi.
    Fat & Single
    Tubeless here
    I can remember the massive wiggle I had on various wheel/rim combos for about the first year.... the buds being the most memorable.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Mar 2013
    i take it nobody ever tried lou on rear of on one fatty
    Reputation: Velobike's Avatar
    I can't remember which tyre it was out of Bud or Lou, but whichever is the rear one doesn't fit in my Fatty.
    Latitude: 57º36' Highlands, Scotland
    Quote Originally Posted by Velobike View Post
    Was that with the stock width rim, or a 100mm ?
    Oct 2012
    I remember your picture of the BFL in there, and it looked tight. Mine doesn't look like it would clear a Lou on a 70 either, just judging by the clearance on a 94mm stock tire.
    edit; after carefull measurements, there would be about 5mm clearance on each side, and to the cross brace on the chainstays. It would fit, but not much room for runout or flex. I would definitely expect it to rub when riding.
    what was the diameter of the 29+ tires again?
    if I have 15mm with a 740mm tire, will it work?
    774 iirc.
    Mar 2013
    thx for that, was that on 70mm rims
    [QUOTE=stesteste;10431893]thx for that, was that on 70mm rims
    Wasn't my wheel. Belongs to a Mukluk, so whatever rim that uses.
    Mar 2013
    oooh i see i think muk uses 82mm rim they still might be hope yet how tight was it? was it minimal thanks
    there must be some one out there with a bud or lou to try on rear for the on one fatty dont wanna waste 90 quid to try and dont wanna by the bud without the lou getting ready for winter early lol
    Reputation: Schott's Avatar
    Nov 2012
    Bud without Lou is still pretty awesome. I run a Nate in the back for winter, and when I switched from Larry to Bud, it was a different bike. Worth it.
    Mar 2013
    Quote Originally Posted by Schott View Post
    thx ,any chance of posting a few pic please ,anyone with different tyre arrangements pics would be greatfull ,heres mine BFLs
    Attached Thumbnails Attached Thumbnails on one fatty bud and lou-uploadfromtaptalk1369989263439.jpg
    Nov 2012
    Mar 2013
    ok might be sold on the Nate and bud combo for winter/muddy/wet wheelset ,I wonder if any other tyre company's are going to do something in-between 3.8 and .4.8 like a 4.5 bud and Lou to fit older frames I love my BFLs for summer would love to stay the same size with just a little more grip
    It was me wot tried my wheel in epicyclo's fatty. A bud tubeless on a RD rim. It didn't fit. ( well it did but with no clearance)
    Shame, it would be great with a pair of buds.
    Reputation: duggus's Avatar
    Quote Originally Posted by stesteste View Post
    I wonder if any other tyre company's are going to do something in-between 3.8 and 4.8 like a 4.5 bud and Lou to fit older frames
    I doubt Surly will... everyone would just start complaining about the cost for them to produce another special tire!
    Aren't the 45nrth's actually 4.0 tires? That is slightly in-between 3.8/4.8
    Mar 2013
    Quote Originally Posted by virtueminehonour View Post
    would they be any clearance with a 70mm rim where did it touch near the crank or on the side and chain
    Oct 2012
    Quote Originally Posted by duggus View Post
    I think all the 4.0 tires measure close to the same as 3.8 tires on any given rim.
    If anyone will develop an in-between, it will be V-Rubber ... The tires on the Beast are right at 4 inches on a 100mm rim.
    Stick a knob out the side and 4.25 it would be.
    Dec 2014
    Hi I used this thread a lot when selecting tyres for my fatty, after fitting a Bud to the front. I then test fitted it to the rear and there was clearance. I am now running a full bud and lou combo but I use the standard on one wheel set.
    Oct 2014
    Quote Originally Posted by benl121076 View Post
    Hi there!
    Do you have any picture of your combo?
    Thanks a lot!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    That's surprising, I could have made the Dillinger 5s work with some modification, but I figured no bigger.
    Did I catch a niner+?
    There is also the Snowshoe 4.5.
    I personally run nates f/r in the winter and floaters the rest of the year. These are on the standard rims that came with my fatty.
    Mar 2013
    i also tested mine with a bud on standard rims on rear but catches on nobs .i use a one up 1x10 though i how can get more clearance on chain .like spacers or summat somewhere
  1. $25 Fatty
    By mtbxplorer in forum Fat bikes
    Last Post: 04-07-2013, 10:40 PM
  2. Fatty SS?
    By fwinter in forum Singlespeed
    Last Post: 03-21-2013, 07:51 AM
  3. On One Fatty
    By craigstr in forum Titus
    Last Post: 10-27-2012, 07:51 AM
  4. You're the one for me Fatty
    By brant in forum Fat bikes
    Last Post: 05-05-2012, 11:36 AM
  5. I'm such a fat fatty-a**-fatty-fat-butt
    By pippinr in forum Clydesdales/Tall Riders
    Last Post: 04-13-2011, 09:03 PM
