Page 59 of 71 FirstFirst ... 9 49 55 56 57 58 59 60 61 62 63 69 ... LastLast
Results 1,451 to 1,475 of 1769
  1. #1451
    Did I catch a niner?
    Quote Originally Posted by Wombat View Post
    Have you checked how your axle sits in the frame? I found the front's was barely short enough to allow the QR to clamp the fork and hub properly. This explains what I mean: On-One Fatty front wheel retention.
    I think in my case the wheel moving was probably user error as I haven't had any problems with this wheel before.
    Tim
    I have not looked yet but I think the rear could stand to remove some paint from the drop out. All 3 times this has happened it is me hammering up a hill in a harder gear vs sitting and spinning. I attribute doing that to riding almost exclusively on a SS bikes, this is actually my only gear bike.
  2. #1452
    Feb 2006
    IT would be great of DT Swiss made a RWS thru-bolt for the 170mm rear. Like this DT Swiss - RWS Thru bolt
  3. #1453
    Fatty Nation
    Reputation: rpedro's Avatar
    Jul 2014
    any idea what HOPE skewer sizes are needed for the stock wheels??? thanks!!!
    found it... 135/170
  4. #1454
    Fatty Nation
    Jul 2014
    looking at my future wheel upgrade... I am worried on them fitting... I will be buying the carbon fatty fork first of course...
    Surly Clown Shoes front and back
    Surly bud and lou tires
    (or are the bfls better???) I will be riding trails, but mostly flatland concrete...
    or if these won't fit (which will be a bummer)
    should I go with a set of the Rolling Darryls... same tire questions...
    thanks!!!
  5. #1455
    zeb
    zeb is offline
    Sorry but CS and 4.8 tires is no go both rear and front .
    On one Fatty carbon fork with RD and Bud is OK but mud clearance is minimal.
  6. #1456
    Fatty Nation
    Jul 2014
    Quote Originally Posted by zeb View Post
    well that sucks... but I guess a set of RD and a bud and lou combo would be sweet as well... or I have also looked at the 45NRTH Du's as well... choices, choices...
    oops... I am assuming the 4.8s don't fit front AND back either... looks like a set of BFLS or DU'S...
  7. #1457
    zeb
    zeb is offline
    I had a change to ride this tubeless Fatty on trail.It was better than original set-up,however i like more Floater as rear tire than Knard 120tpi.
  8. #1458
    Fatty Nation
    Jul 2014
    wow looks cool... I am wondering if running different sized tires like that works properly or should I match a set of BFLs or DUs...
  9. #1459
    zeb
    zeb is offline
    Matching tires looks way better allways but if you have chance to try different front tires i highly recommend to do it.Fatbikes steering and riding characters varies hugely due to the front end ie. tire size/pressure.Rear tire will follow where front goes.
  10. #1460
    Fatty Nation
    Jul 2014
    really good info... thanks...
  11. #1461
    Feb 2012
    So is there any consensus on the sizing on this bike? If you are at the upper range of the medium, should you instead go for the largest one if you like to use a short stem?
  12. #1462
    Quote Originally Posted by bad andy View Post
    They do make one, they come factory on Beargrease carbon. The 12x177 is what it is called but it fits the stock hub that takes 170mm QR or 12x177mm. The spacers are wider to work with the thru frame kit. Looks just the one in your picture.
  13. #1463
    Reputation: tartosuc's Avatar
    Hi,
    After reading a lot on fat bikes for the last year, i decided to order a fatty rolling chassis size large...should get it pretty soon!
    Pics to come.
    One question, any of you tried existing frame bag in the fatty frame? Like something made for another brand of bike... I dont want to go with a custom frame bag if something already made fit.
    expensive cars are a waste of money. Expensive bikes...not so much!
  14. #1464
    Reputation: Wombat's Avatar
    Quote Originally Posted by tartosuc View Post
    Hi,
    One question, any of tou tried existing frame bad in the fatty? Like something made tor another brand of bike...
    I think you are asking if anyone has used a Lefty in a Fatty frame. Many people have done this without any problems. You just need a Lefty with removable clamps and then use the fat bike clamp from Mendon Cycle Smith.
    Tim
  15. #1465
    Tim
    Sorry for the bad spelling of my previous post...i have a hardtime with my tablet keyboard.
    I've corrected my post...i was talking about frame bag
  16. #1466
    Hi
    I just join the fatty family.
  17. #1467
    WNC Native
    Reputation: nitrousjunky's Avatar
    Anyone know if the RS Bluto would work with the 20" frame?
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  18. #1468
    Reputation: MMcG's Avatar
    Jul 2003
    Hi
    What size frame-set and what cranks are those Tarto???
  19. #1469
    Reputation: jvm051's Avatar
    Quote Originally Posted by nitrousjunky View Post
    Yes, I can get pictures tonight. Just got mine installed and an waiting for tires to finish build.
  20. #1470
    WNC Native
    Quote Originally Posted by jvm051 View Post
    Cool, would definitely appreciate it!
  21. #1471
    The crown more than clears the downtube with a Cane Creek External cup.
  22. #1472
    Sep 2014
    Just joined the Fat Bike community.
    Ordered the On-one Fatty Cruiser for £699. Seems like too good a bargain to miss!
  23. #1473
    Apr 2013
    Thanks for the picture! Awesome!
  24. #1474
    WNC Native
    Awesome! Thanks jvm051!
  25. #1475
    Reputation: Lordie's Avatar
    new bike day got the fatty chasis bundle.
    On One Fat Bike Frame-921224-your-latest-fatbike-related-purchase-pics-required-best-copy.jpg
    On-one fatty frame + steel fork
    Hope Fatsno =135/170 /w hope skewers
    Vee Mission tyres, i suppose to get floaters but they shipped this instead
    Race Face Ride 100mm w/ 32T NW RF chainring
    Avid Juicy Carbon 180/160mm
    Brooks C17s
    Thomson 60mm stem
    FSA K-Force carbon bars
    Crankbrothers cobalt 3 seatpost
    XO 9 speed gripshift with PG990 Red cassette
    Crankbrothers Candy 3.
    KMC x10 SL chain
    total weight 15.04kg
  1. Broken frame on Mongoose, new frame? or new bike?
    By Dooms101 in forum Beginner's Corner
    Last Post: 03-12-2011, 06:45 PM
  2. Replies: 1
    Last Post: 05-23-2010, 08:39 AM
  3. Replies: 4
    Last Post: 02-18-2009, 08:06 PM
  4. whats the difference between a road bike frame and an xc frame?
    By tomsmoto in forum Bike and Frame discussion
    Last Post: 10-05-2008, 05:51 PM
  5. Broken 9357 frame in bike/frame discussion
    By grnxb in forum The ReCycle Bin
    Last Post: 02-19-2008, 12:03 PM
