FAT BIKES
WINTER APPAREL
TRAINERS
Page 58 of 69 FirstFirst ... 8 48 54 55 56 57 58 59 60 61 62 68 ... LastLast
Results 1,426 to 1,450 of 1715
  1. #1426
    Apr 2013
    Sorry to ask a question that's been asked in this thread before, but I'm still a little squeamish to pull the trigger on an order. Really looking forward to my Rolling Chassis to arrive!
    I have a set of these on an older giant in the garage (Truvativ FireX Isis). They have a Race Face Narrow Wide on them already and everything:
    Will the stock BB work with these arms? I *think* I read that Hussefelt wasn't true ISIS and I see it's mentioned in the description.
    TruVativ Howitzer Team Bottom Bracket 100mm Shell 66mm Chainline in Tree Fort Bikes Fat Bike Cranks/BB (cat925)
    Or would I be better of with this?
    FSA Platinum DH 100mm ISIS drive Bottom Bracket from Fatbikes.com
    Would be nice to go with the X5 crankset, but still exploring where I can save some money to splurge elsewhere.
    Thanks for any help.
  2. #1427
    nothing to see here
    Reputation: Stevob's Avatar
    I can't answer your question as to whether your crank will fit the FSA bottom bracket.
    The Fatty frame doesn't come supplied with a bottom bracket. Just a standard english threaded bare bottom bracket shell.
    I see hills.
    I want to climb them.
  3. #1428
    Apr 2013
    Quote Originally Posted by Stevob View Post
    Thanks. I can't seem to see anywhere that specifically says howitzer BB is isis. I'd prefer to use it though. FSA says isis, my cranks are isis and I think that's the safe bet.
  4. #1429
    Reputation: Wombat's Avatar
    This makes clear they're not the same: "the Howitzer spline looks similar to the ISIS Drive standard spline but is actually different, so as to prevent the usage of ISIS Drive cranks on the external bearing BB, which would affect chainline and Q-factor." (Bottom bracket - Wikipedia, the free encyclopedia)
    Tim
  5. #1430
    Mar 2011
    I finish my on one fatty build
    Hope you like it!
    On One fatty frame 18"
    On One fatty carbón fork. Mix tapered headset
    On One fatty wheels and orange floater tyres. Specialized inner tubes
    Thomson stem, carbón bar, seatbar, collar and headset top cap
    Hope fatsno skewers
    Spec saddle
    Esi Grips.
    Xt 2013 brakes
    Xt transmisión with Leonardi General lee cogs. Wolftooth 30t chainring and Truvativ Howitzer cranks
    On One Fatty
    On One inbred 29er
    Chumba HX2 singlespeed
    Felt Magno
    Electra Cruiser 1
    Cannondale f1000 ´96 frameset
  6. #1431
    Reputation: Tunalic's Avatar
    Feb 2012
    Quote Originally Posted by ombrotipo View Post
    Hope you like it!
    I like...what's it weigh?
    2015 616 Muenzie / 2013 On One Fatty / 2011 Trek Sawyer / 2011 Kona Dr. Fine / 1985 Schwinn Tempo
  7. #1432
    Apr 2013
    Quote Originally Posted by Wombat View Post
    Tim
    Thanks Tim, I didn't catch that at first!
    Love the carbon fork!, I wish I had got one when I ordered the rolling chassis.
  8. #1433
    Mar 2011
    Quote Originally Posted by Tunalic View Post
    Dont know yet. Will see, thank you!
    On One Fatty
    On One inbred 29er
    Felt Magno
    Electra Cruiser 1
  9. #1434
    Reputation: alshead's Avatar
    Oct 2007
    On One Fat Bike Frame
    Hope you like it!
    Hope fatsno skewers
    Spec saddle
    Esi Grips.
    Xt 2013 brakes
    The carbon fork is sweet. Just curious about the specialized tubes. If those are the same as what comes on the FatBoy, they're some of the heaviest tubes you can find...
    There are two types of mountain bikers. Those who are faster than me, and me.
    "There are two kinds of mountain bikers in the world: those who are faster than me, and me."
  10. #1435
    Mar 2011
    Quote Originally Posted by alshead View Post
    Hi alshead!!!
    The spec inner tubes are the 2.3-3.0 ones. Not the Fatboy inner tubes.
    They are 300gr lighter than the on one inner tubes
    On One Fatty
    On One inbred 29er
    Felt Magno
    Electra Cruiser 1
  11. #1436
    Did I catch a niner?
    What stem length are most of you riding outside of the standard, which I think is 60mm?
    My scenarios I have done so far:
    80mm stem with Titec J Bars
    100mm stem with Mary Bars
    50mm stem with Nukeproof 760mm riser
    40mm stem with Nukeproof 760mm riser
    So far I am at the 40mm and staying there for now. Is anyone else using a stem so short? This is my first venture in to short stem wide bars, although my XC bike is a 90mm stem with 711mm flat bars. But the Fatty seems to lend itself to a more AM setup with a slacker geo.
    EDIT: I should add I am about 5ft 9in 32in inseam more leg then torso and running 175mm cranks on a 16in frame.
  12. #1437
    Feb 2006
    I'm running a 50mm with the std El guapo Ancho bars (760mm wide I think)
  13. #1438
    Nevermind.
  14. #1439
    Mar 2011
    70mm stem with the 730mm Thomson x country carbón bar.
    On One Fatty
    On One inbred 29er
    Felt Magno
    Electra Cruiser 1
  15. #1440
    zeb
    zeb is offline
    What happened to new V2 wheelset that was on market couple weeks ago?
  16. #1441
    Apr 2013
    I decided to go with the x5 crankset like the On One build. Being my first ever build, I have yet another dumb question. She's all together, but the driveline doesn't look right. 32 single ring on the front, 11-36 10x on back. The angle of the chain coming off the 32 and getting to the 36 is a tad extreme. Are the bikes coming with both spacers on the BB (one each side) with the X5 crankset?. Or is it just one on non-drive? Thanks for any help.
  17. #1442
    nothing to see here
    I have the 2x X5 on my Fatty. It has just one spacer each side. For what it's worth, I usually run it like a 1x, and never have issues with shifting into the 36 rear and I use that combo frequently.
    I see hills.
  18. #1443
    Apr 2013
    Great, thanks for the help!
  19. #1444
    Reputation: shiggy's Avatar
    Dec 1998
    Re: On One Fat Bike Frame
    Quote Originally Posted by HOSSinNH View Post
    If you have the tire/chain clearance you can use both spacers on the non driveside to improve the chainline.
    mtbtires.com
  20. #1445
    My Fatty stopped shifting on my last ride. The x-5 shifter froze and it felt like it was stuck between gears. When I got home I pulled the shifter apart and found the cable had jumped out of its retention point and the rotating barrel it sits in had moved. The cable had then bent so it stopped the barrel from turning in either direction.
    I hadn't secured the rear wheel properly and it had jumped partially out of the drop outs. I assume that the wheel moved at the same time I was shifting and this released tension on the derailleur, which in turn released tension on the shifter cable. This doesn't quite make sense, but it's the only cause I can think of.
    I replaced the cable, eventually worked out how to get the shifter's spring back in place and reassembled it. I then found I only had 5 of the 10 gears as I hadn't released the shifter's tension before reconnecting the cable. I puled it apart, did this and everything is working properly again.
    I couldn't find any pictures or diagrams of the x-5s, but other versions are similar enough to work it out.
    Tim
  21. #1446
    That's too bad. I am using a XT shifter/XTR RD and I have had the wheel slip out of the drop out 3 times now, twice in one race. It is annoying and am wishing Shimano made fat bike skewers to stop this non sense. However I have not had a mess like you had from it, but fear I might.
    Can anyone recommend a close cam style skewer to use?
    I also ordered a 30t ringmaster for my setup so it will run 30t x 12-36 9 speed. I think this will be a good mix all year around and I will be able to keep up with the skinny wheel guys without spinning out too much. Two trails here I am wanted more gear on with a 32t up front, but I think the 30t will lend itself to winter riding much more.
  22. #1447
    Quote Originally Posted by Mr Pink57 View Post
    Have you checked how your axle sits in the frame? I found the front's was barely short enough to allow the QR to clamp the fork and hub properly. This explains what I mean: On-One Fatty front wheel retention.
    I think in my case the wheel moving was probably user error as I haven't had any problems with this wheel before.
    Tim
  23. #1448
    Reputation: SundayRiverRider's Avatar
    Any news on if this frameset will be updated in the near future? Wider fork, 190mm rear spacing, Bluto ready etc.?
  24. #1449
    Quote Originally Posted by SundayRiverRider View Post
    There is a Fatty Trail in development right now and as soon as we are confident that we have the details worked out, then we will make sure to let everybody know.
  25. #1450
    Fatty Nation
    Reputation: rpedro's Avatar
    Jul 2014
    love reading this thread being I am waiting on my brand new Fatty... I am looking at adding a one ring crank like the majority of owners here... any advice, thoughts on an ideal chainring size to make it a decent 1x10? and crank option, etc... I see some really nice ones on here just wondering if they are all custom or bought that way...
    thanks!!!
  1. Broken frame on Mongoose, new frame? or new bike?
    By Dooms101 in forum Beginner's Corner
    Last Post: 03-12-2011, 07:45 PM
  2. Replies: 1
    Last Post: 05-23-2010, 09:39 AM
  3. Replies: 4
    Last Post: 02-18-2009, 09:06 PM
  4. whats the difference between a road bike frame and an xc frame?
    By tomsmoto in forum Bike and Frame discussion
    Last Post: 10-05-2008, 06:51 PM
  5. Broken 9357 frame in bike/frame discussion
    By grnxb in forum The ReCycle Bin
    Last Post: 02-19-2008, 01:03 PM
Follow MTBR on Facebook
