Page 43 of 72 FirstFirst ... 33 39 40 41 42 43 44 45 46 47 53 ... LastLast
Results 1,051 to 1,075 of 1782
  1. #1051
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Stock bars that came on mine were 810mm El Guapo Ancho, absolutely friggin huge. Switched out the saddle for a nice 200g model, bar for a 780mm 160g carbon affair, tubes for normal thickness "oversize" ones and gears for a 11-28 219g unit. Now for a testride...
    Edit: It also didn't have that gawdaful rim strip that was in the dissection thread. It seems to have a big wide sturdy rim strip that will prevent any kind of nipple/spoke interference.
  2. #1052
    Feb 2005
    Quote Originally Posted by ro7939 View Post
    Is it true all Lefty forks do not accommodate 203mm rotor?
    Not true.
    Run them on a few of mine, no problems at all.
    You do need "the modern" boot, but they have been the standard for almost 10 years, so I doubt you'd be using the original version anyway, unless you've got a ti legged DLR from around 2001, and never changed the boot.
    Mr. Ford? Great looking set up there!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
  3. #1053
    Thanks Craig, can't thank you enough for all the advice and superb service with delivering that Fat Lefty adapter, which is a piece of CNC art btw
  4. #1054
    Feb 2005
    Quote Originally Posted by fyford View Post
    Can't take credit for that. Kevin at S+S Precision out in Merced CA gets the nod on that, top notch work for sure!
    - FrostyStruthers
  5. #1055
    Jun 2013
    Has anyone used a Chariot trailer with On-One Fatty? Does the hitch fit?
    I mean this one : For Your Second Bike
  6. #1056
    Quote Originally Posted by Jrask View Post
    Considering that there is no real documentation, I'll say ... I doubt it, unless you are able to take that little bracket off, and use it with the stock skewer.
    The skewer in their picture is probably only available for a 135mm (or less) spacing.
  7. #1057
    Jun 2013
    Quote Originally Posted by bikeabuser View Post
    You can use any skewer, i was wondering if there is enough space at the dropout for the bracket.
  8. #1058
    Out and about
    This is still with the Lefty in 26er mode (taking chances...) but heck it is such fun, like being on a bouncy castle at high speed That's with the pressure quite low in the rear, no rebound settings on a Floater
    Had some issues getting the front end dead centre, did not realise you can veer off Mendon's marker line. As always he came to the rescue!
  9. #1059
    Tor
    Tor is offline
    Jan 2013
    you take some beautiful pictures Which top clamp are you using?
  10. #1060
    Quote Originally Posted by Tor View Post
    For the Lefty? That would be Mendon Cycle's, do a search you'll easily find him on this forum. Top bloke and quick postage from the US (I'm in the UK)
  11. #1061
    Reputation: Wombat's Avatar
    Francois
    Have you found the steering any different with the lefty? I get a bit of self-steering on my On-One with a lefty that wasn't present with the original forks. But the slightly narrower rim of the Marge Lite (65mm vs the original 70mm?) might also contribute.
    As others have said, those are great pictures that you take.
    Tim
  12. #1062
    Feb 2005
    Quote Originally Posted by Wombat View Post
    Make sure the tire is fully centered under the frame, easily adjusted via the clamps. Most likely cause actually. Well, that, or it's set up with a taller A to C than the stock fork.
    Rim width shouldn't have any impact.
    - FrostyStruthers
  13. #1063
    Hi Tim,
    no self steer issues here that I've noticed, I'll go handsfree for a bit and let you know . With the Lefty MAX I imagine I've changed the angles a bit, never bothered to measure. Running a Marge Lite myself, I find a slight understeer, but I am pretty sure that's just part and parcel of running mahoosive tyres, and I quite like it!
    I must admit, I did not stick with the original fork for too long, my main aim was to relieve the vibrations (knackered wrists), which this conversion has sorted out big time.
    All in all I am very happy - still waiting for customs to release the rest of my Lefty rebuild mind. Once I have the PBR conversion in place I'll let you know if there's any change. As mentioned to you before, I did have to tweak the clamps beyond the marker a fair bit. Let me know if you want some photos to compare?
  14. #1064
    Curiosity question,
    If the A toC is set correctly ... What's the Lefty do to the Trail ?
  15. #1065
    Bikeabuser
    It's probably a combination of the changed A to C and the different trail. The Fatty forks have, I think, 55mm of offset and I guess the Lefty has a lot less. I did measure the A to C difference, and while I can't remember the figures, I think the lefty was a bit longer.
    Craig
    Thanks for the advice. I did spend a fair bit of time lining up the rim when looking through the steerer tube. I'll have another look at it. I thought it may be rim width as someone on MTBR mentioned they'd see quite a difference in self steering when going to a narrower rim.
    Even with this I think the bike with the lefty is terrific and it saves the bashing my forearms were getting.
    Tim
  16. #1066
    Reputation: shiggy's Avatar
    Dec 1998
    On One Fat Bike Frame
    Bikeabuser
    It's probably a combination of the changed A to C and the different trail. The Fatty forks have, I think, 55mm of trail and I guess the Lefty has a lot less. I did measure the A to C difference, and while I can't remember the figures, I think the lefty was a bit longer.
    Tim
    Do not confuse trail with fork offset.
    The stock fork has 55mm of offset, more than most forks.
    Use a fork with less offset and/or a slacker HTA (longer A-C slackens it) and the trail is increased.
    mtbtires.com
  17. #1067
    Quote Originally Posted by shiggy View Post
    Thanks. I do confuse the 2 and should look at a diagram before posting.
    Tim
  18. #1068
    will there ever be an XL frame?
  19. #1069
    Bumper for Mendon's clamp
    The only problem I've found with Mendon's Lefty clamp (Tall version) is that it has a rather sharp edge. Should you have a crash I can see this leaving a nasty dent in your frame, well it would on the On One Fatty.
    The Cannondale Bumper provides no protection in this setup. Not that I come off the bike that often, but you never know. I used some Sugru (https://sugru.com/) to make a bumper to prevent this. Seems like it will do the trick!
    For what it is worth... I can't really see how the clamp could be designed any better, maybe a slightly less sharp edge, but even then you'll have the same issue.
    Happy cycling!
  20. #1070
    Feb 2005
    Yeah, we messed with that for a while, no real solution in the design.
    What I do, and recommend, (though your solution seems to do the trick) is to take an old road tire, cut off the bead and sidewall, so you just have tread.
    Two wraps around the frame at the point of contact, and then a nice tight wrap of electrical tape covering the whole thing. Makes a nice, shiny black, (or colored if you prefer!) dense bumper for basically free.
    Taken a few good beaters with mine over the last year or two, no issues at all.
    - FrostyStruthers
  21. #1071
    Cool thanks, will look into that one as well!
  22. #1072
    Mr.Green
    Reputation: Lars Thomsen's Avatar
    Quote Originally Posted by MendonCycleSmith View Post
    I’ve done as advised, but instead of using electrical tape, I’ve made three holes and used a zip tie
    The build is still in progress…
    Mr.Green
  23. #1073
    Mr.Green
    To center the ’MendonCycleSmith’ Lefty...
    To center the ’MendonCycleSmith’ Lefty I’ve found that a Mini Maglite:
    will do the job:
    Mr.Green
  24. #1074
    Lars
    That's a very neat solution.
    Tim
  25. #1075
    Feb 2005
    Agreed, that's the slickness for sure!
    - FrostyStruthers
  1. Broken frame on Mongoose, new frame? or new bike?
    By Dooms101 in forum Beginner's Corner
    Last Post: 03-12-2011, 06:45 PM
  2. Replies: 1
    Last Post: 05-23-2010, 08:39 AM
  3. Replies: 4
    Last Post: 02-18-2009, 08:06 PM
  4. whats the difference between a road bike frame and an xc frame?
    By tomsmoto in forum Bike and Frame discussion
    Last Post: 10-05-2008, 05:51 PM
  5. Broken 9357 frame in bike/frame discussion
    By grnxb in forum The ReCycle Bin
    Last Post: 02-19-2008, 12:03 PM
