Page 34 of 36 FirstFirst ... 2430313233343536 LastLast
Results 1,651 to 1,700 of 1796
  1. #1651
    On-One Fatty frames are symmetrical hence the wheel will be standard build too not some funky offset dish.
    Fat Biker
  2. #1652
    Reputation: MTBLoCo29's Avatar
    Feb 2013
    Quote Originally Posted by qclabrat View Post
    thanks all for the quick replies, but I do have a question on the rear hub configuration. I wasn't aware it is dished like a Surly. does it mean that all Surly's have that odd dishing like the 135mm Pug rear wheel? I'll need to read up on what that means, if that's the case, either I'll need the wheel rebuilt or go with another frame choice
    No, the rear is a 170 symmetrical with QR. The front is symmetrical 135. The difference is how the disc is spaced relative to the fork blade. On a rear spaced 135 hub, the disc is 5mm further inboard on the hub, closer to the spokes (just like on a standard rear wheel). Some front hubs have this same spacing. Surly did this so you could swap front and rear wheels in an emergency. A front spaced 135 hub has the disc further outboard, toward the fork leg. This is because there is no gear cluster to offset, so the flanges can be equidistant allowing for a stronger symmetrical wheel. So if you have a front spaced hub and try to mount it onto rear spaced forks (like Surly or On-One), the brake caliper won't be centered over the rotor, and in some case will hit the spokes. Hub, Fork, and Disc Brake Compatibility | Spews | The Information Hole | Surly Bikes
    Where are the wheels coming from? That will determine whether or not they will be a direct fit. Any symmetrical 170 rear will work. Up front it needs to be a symmetrical 135 with rear disc spacing if you are using either On-One fork. If your current wheels have a front spaced 135, you will need to look for a different fork, like the Carver O'beast.
    On heavy rotation: Stooge 27.5+ SS, On-One Fatty, On-One 456 EVO, Surly Cross-Check, Scott CR1 (SS road)
  3. #1653
    Feb 2013
    A picture's worth a 1000 words, so maybe this is a better illustration of the disc spacing issue. There are spacers for rear spaced hubs that move the disc closer to the fork, but it doesn't work the other way. I had to modify the caliper adapter to move it to the right 5mm so my rotor would line up on the On-One fork (I had front spaced hubs). On One Fat Bike Frame-front-vs-rear.png
  4. #1654
    Reputation: Welnic's Avatar
    Feb 2013
    Also should I go longer than 720mm for the bars? I am 5'9".
    Looks like you're getting good advice on the front fork brake rotor spacing issue.
    I don't know exactly what width of bars you should use, but I would recommend going wider than what you are used to. I have wider bars on my fat bike than my normal mountain bike and I think that works pretty well for me. I haven't felt a big need to go wider on my normal bike and I wouldn't want to go any narrower on my fat bike. If you are totally sure that you like the width on your normal mountain bike I would go 40mm wider. If you haven't explored really wide bars then I would go 80mm wider and ride it like that for a while and then cut them down if you want to. If you have lock-on grips then you can move them in and try them before you cut your handlebars.
  5. #1655
    more good stuff from everyone, the rear will be 170mm symmetrical
    the parts are coming from a Moto Boris Bluto, so the front wheel is 150mm thru axle
    Save up to 60% off new Rockshox Bluto Fork Fat Bikes and Mountain Bikes - MTB - Motobecane Boris X9 SRAM
    looks like I'll need a 150 thru axle fork, is the Fatty headtube tapered? i think 150 forks are easier to find tapered
  6. #1656
    Yup Fatties are tapered headtube.
    Fork ? Best / cheapest (depending on your viewpoint) to keep within budget would be Chinese carbon .
    Most vendors have a 150mm spaced tapered carbon fork in their catalogue these days. If not just fire an email off to the vendor of your choice and they'll usually be able to supply one. Some people have a preference as to which vendor they prefer. I find it all a much of a muchness. They all seem to pee in the same pot as it were and non is particularly better than the other as regards to quality/delivery times IME.
    Just remember most Chinese forks are 46mm(ish) trail offset as opposed to the On-One forks being 51mm offset. Which will affect the steering response slightly. But TBH I doubt you would notice a difference unless you jumped off one and straight in the other. Even so I thought it worth mentioning just for completeness.
    Fat Biker
    P.S. Don't forget you'll need a different headset than the one that's on the Boris. Boris appears to be I.S. and the Fatty is E.C. You can't go wrong with the Smoothy Mixer one from On-One to be fair. Not the lightest by far but lasts well enough IME.
  7. #1657
    Feb 2013
    Framed Bikes has a 150x15 carbon fork, tapered head tube. Available in white to match the Fatty. Better quality than the no-name China carbon.
    On Sale Alaskan Carbon Fat Bike Fork
  8. #1658
    Or you might like to do some research and find out where the "named" carbon forks come from and save yourself a bunch o' cash
    $299 on sale vs $130 - $150 retail for a very similar product hmmmn. I know where my cash would be spent.
    Option 1
    Option 2
    Fat Biker
  9. #1659
    Feb 2013
    Quote Originally Posted by Fat Biker View Post
    Option 1
    Option 2
    Fat Biker
    I know a lot of branded items come out of the same factories, I just feel more comfortable dealing with known quantity. I find it easier to deal with a company here in the US if there is any kind of warranty issue. Also, with so many low priced options that look similar, it's hard to know which are high quality vs. cheap knockoffs. One would hope that a company putting their name on a product would vet said product before deciding on a vendor. There is also real world testing, as you can find reviews from customers. I've seen some very high quality carbon come from these ebay and alibbaba companies, but also some horror stories. I'll pay a little more for peace of mind, especially regarding carbon forks or handlebars which can be catastrophic if they fail. Believe me, I'm a cheapskate, but sometimes you can go too cheap. Then you end up buying stuff twice, which isn't really saving you any money. Like Fat Biker said, make sure you do as much research as you can before going with the no-names.
  10. #1660
    more questions, which isn't always to the easiest to find, though would have expected to find it easily, upfront apologies from a novice
    what's the widest (patch contact) tire I can get using an 80mm rim for the rear. Can't always go by tire size, as it's not reliable. for example will Vee Showshoe XL squeeze in the back, guessing no, especially if running at low pressures
  11. #1661
    got the answer after rereading this thread a few times, looks like Dozer in back and Snowshoe XL front should work, will start with Floaters this winter for now, don't want to get spoiled too quick, and switch back to the V8's 120tpi in the summer, still haven't pulled the trigger yet on the Fatty V2, but any day now, nothing going on CyberMonday on PlanetX so there's no rush at this point except impatience. Have all other parts ready except the frame and fork.
  12. #1662
    Reputation: rollo's Avatar
    @qclabrat
    Be aware that the US based PlanetX location was recently destroyed in a fire. I don't know how this impacts website orders, but Vince (who posts here frequently) from PlanetX will definitely have his hands full in the next few weeks/months.
    Oakridge fire destroys headquarters of bike company with Portland roots - BikePortland.org
  13. #1663
    Feb 2013
    Quote Originally Posted by rollo View Post
    @qclabrat
    I ordered some handlebars and brake pads last week, they were here by Friday afternoon. Everything is shipping out of England, so freight was around $20. BTW, took the first ride with the Fleegle bars, like them so far. 720mm width, 15 degree sweep, 0 rise. Downside is that they only have 25.4 diameter. Upside, I have plenty of old stems and the bar was $7.
    On One Fat Bike Frame-12294711_10207196311333474_5665976584991029710_n.jpgOn One Fat Bike Frame-12301601_10207196311213471_3073911954944785837_n.jpg
  14. #1664
    @qclabrat
    yep, what @mtbLoco29 said, they changed to UK only warehouse a while back, not sure why, but shipping charges are pretty high due to air freight
  15. #1665
    Quote Originally Posted by MTBLoCo29 View Post
ID:	1032581Click image for larger version.
    nice looking ride, is that the V2 version? anyone know if the seat post diameter is 31.8mm and seat tube collar 34.9mm?
    Also not crazy with the carbon fork with straight steerer. I don't understand why On-One would use a straight steerer even though the Fatty has a tapered headtube. Any able to rationalize that one? I'm think of getting a Specialized Fatboy carbon fork locally for the same price as the On-One fork but is instead tapered
  16. #1666
    I was told by Brant personally (designer at On-One at the time) it was for compatibility sake. So you could use the fork in other frames than the Fatty. That's great but the crown of the fork is kinda fat so the chances of it looking good on other frames are slim at best. And the ones that it would look good on probably have a tapered headtube for tapered forks anyway. Seemed like marketing waffle at the time. Guess what ? It still does.
    I too would prefer a tapered steerer tube on the fork too.
    If nothing else, just for peace of mind.
    1 1/8 straight is probably plenty strong enough.
    Fat Biker
  17. #1667
    Reputation: blowery's Avatar
    Aug 2014
    Seat post is 31.6, I used a salsa 35mm flip lock, and 31.6mm Thomson Elite 410mm
  18. #1668
    interestingly On-One suggested getting the Orbit C-40 ACB which is an integrated headset, even stranger, I was not able find the same one with 9mm stack from other websites or the FSA website
    Which headset do you have installed? were there changes to the headtube of V2 of the frame?
  19. #1669
    I have the Smoothy Mixer heaset from On-One on a V1 frame. They're heavy (as much as a headset can be/for what it is) but durable. Never had to use anything else.
    I don't think there's been any changes to the headtube but I could be wrong.
    HTH ?
    Fat Biker
  20. #1670
    Aug 2014
    I'm running a Cane Creek 44ZS/49EC and it works great with my Lefty.
  21. #1671
    i have a decision I not able to easily figure out, can you weigh in on the two options?
    1) buy a new budget 150mm carbon fork for the front wheel I already have with 15mm thru axle
    2) buy a used 2014 Specialized Fatboy carbon fork which is 135mm, comes with the matching hub as the owner upgrades to a Bluto. However this will require me to rebuild the wheel.
    btw, my wheels are the cheapo Weinmann builds off of a Boris and rims are 80mm
  22. #1672
    For me it would be a no-brainer.
    Cheap fork that fits what you already have. That way you're saving on the build of a wheel at least if not spokes too . Plus that money could go towards an RCT3 cartridge if your Bluto doesn't already have one. Or some bling carbon hoops.
    The possibilities are endless.
    Fat Biker
  23. #1673
    just ordered the Fatty v2 and should be delivered next week, time to ship off some bikes so the spouse doesn't get pissed with another bike
    have everything except a fork, still undecided, front wheel is 150mm TA so limited with choices. Is there a difference between a 483 vs 468 axle to crown fork, I know it's 15mm, but what should I except the ride to feel like? I plan to use a 50mm stem and 740mm bars
  24. #1674
    Feb 2013
    [QUOTE=qclabrat;12356609]just ordered the Fatty v2 and should be delivered next week, time to ship off some bikes so the spouse doesn't get pissed with another bike
    have everything except a fork, still undecided, front wheel is 150mm TA so limited with choices. Is there a difference between a 483 vs 468 axle to crown fork, I know it's 15mm, but what should I except the ride to feel like? I plan to use a 50mm stem and 740mm bars[/QUOTE
    The shorter fork will have a steeper head angle for quicker steering. Longer will give a slacker HA for more stability at speed. The Fatty was designed to be run a slack HA with short stem/wide bars. Carver and Framed make relatively inexpensive 150 TA forks. There's also a host of Chinese carbon forks out there for even less. I would go with a fork vs a new wheel/hub.
  25. #1675
    Feb 2014
    Just an FYI for anyone wanting to try an Absolute Black Oval C/R on their fatty, the bottom bracket on the drive side will need to be spaced out one extra spacer to clear the chainstay (This is with the 32 tooth C/R).
    I'm running a Race Face crankset and external BB.
  26. #1676
    just running down some bigger tire options for the rear, here's what I believe has been tested. Caveat, most don't mention rim width or 1x or 2x drivetrain
    Yes:
    Snowshoe (small one)
    Bulldozer
    BFL
    Dillinger 4/5 (even a studded 5)
    ChaoYang 4.9 (Big Daddy)
    Lou/Bud (1x only)
    wait to hear:
    Snowshoe XL
    Jumbo Jim
    No way:
    Snowshoe 2XL
  27. #1677
    Clears
    Bud & Lou fit. No issue up front. Rear is tight, slight chain rub when running 1x. No way on a 2x. I run a D5 currently on a rolling Darryl, plenty of room. The 45nrth studs would be fine, Kold Cutters no way.
  28. #1678
    Aug 2014
    Quote Originally Posted by Mamba29er View Post
    Do you have pictures of this and the clearance?
  29. #1679
    good to know I'll update,
    I have a 150mm 9zero7 fork and plans are to eventually go to a Vee 2xl in front and XL in the rear, though no one seems to have confirmed they fit
    do you have a v1 or v2 frame? wondering if the beefer downtube changed anything in the rear
  30. #1680
    Clears
    Sorry I don't have pics of the Bud/Lou combo, that was my neighbors set up. I run the D 5's which I do have pics of, not that that helps.
  31. #1681
    that seems kind of tight, don't you get rub at low pressures and some peanut butter mud or snow would surely get the rear mucked up
  32. #1682
    Clears
    Nope not at all. Plenty of clearance, zero rub at any PSI.
  33. #1683
    Reputation: RAUL77's Avatar
    Jan 2016
    1. On One Fat Bike Frame - From April 2013 to October 2014
    Warranty and Replacement
    2 On One Fat Bike Frame - Since February 2015 for December 2015
    Now I have two cracked frame
    Waiting for an answer Warranty and Replacement.
    Sorry for my English.
  34. #1684
    Aug 2014
    Wow, are those V1 or V2 frames? I don't think I have seen a V2 frame crack.
  35. #1685
    Quote Originally Posted by RAUL77 View Post
    can you tell us how far the seatpost when in for each? I've mostly seen cracks under the support
  36. #1686
    Feb 2013
    Also curious if the second frame is V1 or V2. Also, Med or Large?
  37. #1687
    Clears
    Based upon the dates given the first frame has to be a V1 frame. But the second frame could be either. I sincerely hope it isn't a V2. Oh man....
  38. #1688
    Reputation: River19's Avatar
    Wow, that is a nasty crack......too bad, honestly, I have seen only a handful of cracked frames in person bu 2 of them were On Ones......really blows, they seem like they can be cool rigs.....Hopefully they stand behind the frame
    2016 Pivot Mach 429er Pro 1X
    2008 Cannondale Rush
    2001 Ibis Ripley Soft Tail
    1997 Ibis Alibi HT
    Motobecane Lurch Fat Bike
  39. #1689
    Whatever happened to that rad steel truss frame fatbike that was posted on ON-ONE's social media pages? If I remember correctly it was orange, and looked beyond awesome. I like the Fatty, but prefer steel.
    EDIT: Found it. This bad mofo:
    I'd buy that in a second.
  40. #1690
    That does look pretty cool........slap a bluto on there and I'd like it as well.......until it cracked.....lol
    Like that orange frame though, the shape......would look great in white or deep blue.......
    1997 Ibis Alibi HT
  41. #1691
    Well, that image is over a year old, so I wonder what happened.
  42. #1692
    Reputation: pharcyde's Avatar
    Both frames that are cracked are V1.
    KARMA will get YOU & YOU know who you are.
  43. #1693
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I cracked a frame (not an on-one) like that due to running too much exposed seatpost. While it was within the minimum insertion, that only keeps the post from not failing, in the end I was simply riding a bike that was too small.
  44. #1694
    Jan 2016
    Quote Originally Posted by blowery View Post
    V1
    160 mm (6,3 inch)
    V1, both frame 20 inch
  45. #1695
    Notice 2 different locations for the cracks on each frame!! Im suss on the seatpost depth too.
    V2 has no such issues. Ive had mine for 12months now.
  46. #1696
    Mayor of Waterdog
    Reputation: Ol' Bromy's Avatar
    V1
    160 mm (6,3 inch)
    I wonder if a dropper would help as your culo would be up off the saddle while rolling through the chunder? Seems like it wouldn't have cracked that high up with 6.3" of post inserted. You sure it didn't crack right at the bottom of your post?
    “Life may not be about your bike, but it sure can help you get through it.” ~ Hallman
  47. #1697
    Feb 2013
    Quote Originally Posted by ultraspontane View Post
    I was really hoping to see this bad boy too, I'm steel guy. It would look great next to my 456 Evo. Had an Al 29er, sold it after 5 rides to get a steel.. Only other Al MTBs I've had were full sus.
  48. #1698
    Quote Originally Posted by pharcyde View Post
    One of the main reasons for the V2 being in existence was to beef up the seat tube to remedy the cracking issue in the locations Raul77 has shown. I believe it was a combination of poor seat tube internal diameter tolerance and a weakening of the alloy due to the welding process .
    Hence I am lead to believe that the V2 has a thicker seat tube wall to alleviate these symptoms. There may also be entirely different reasons I am not aware of though.
    Fat Biker
  49. #1699
    nothing to see here folks, V2 is good
    disperse and carry on
  50. #1700
    Mayor of Waterdog
    Glad to hear it
  1. Broken frame on Mongoose, new frame? or new bike?
    By Dooms101 in forum Beginner's Corner
    Last Post: 03-12-2011, 07:45 PM
  2. Replies: 1
    Last Post: 05-23-2010, 09:39 AM
  3. Replies: 4
    Last Post: 02-18-2009, 09:06 PM
  4. whats the difference between a road bike frame and an xc frame?
    By tomsmoto in forum Bike and Frame discussion
    Last Post: 10-05-2008, 06:51 PM
  5. Broken 9357 frame in bike/frame discussion
    By grnxb in forum The ReCycle Bin
    Last Post: 02-19-2008, 01:03 PM
