Page 30 of 36 FirstFirst ... 20262728293031323334 ... LastLast
Results 1,451 to 1,500 of 1796
  1. #1451
    Did I catch a niner+?
    Quote Originally Posted by Wombat View Post
    Have you checked how your axle sits in the frame? I found the front's was barely short enough to allow the QR to clamp the fork and hub properly. This explains what I mean: On-One Fatty front wheel retention.
    I think in my case the wheel moving was probably user error as I haven't had any problems with this wheel before.
    Tim
    I have not looked yet but I think the rear could stand to remove some paint from the drop out. All 3 times this has happened it is me hammering up a hill in a harder gear vs sitting and spinning. I attribute doing that to riding almost exclusively on a SS bikes, this is actually my only gear bike.
  2. #1452
    Feb 2006
    IT would be great of DT Swiss made a RWS thru-bolt for the 170mm rear. Like this DT Swiss - RWS Thru bolt
  3. #1453
    Fatty Nation
    Reputation: rpedro's Avatar
    Jul 2014
    any idea what HOPE skewer sizes are needed for the stock wheels??? thanks!!!
    found it... 135/170
  4. #1454
    Fatty Nation
    Jul 2014
    looking at my future wheel upgrade... I am worried on them fitting... I will be buying the carbon fatty fork first of course...
    Surly Clown Shoes front and back
    Surly bud and lou tires
    (or are the bfls better???) I will be riding trails, but mostly flatland concrete...
    or if these won't fit (which will be a bummer)
    should I go with a set of the Rolling Darryls... same tire questions...
    thanks!!!
  5. #1455
    zeb
    zeb is offline
    Sorry but CS and 4.8 tires is no go both rear and front .
    On one Fatty carbon fork with RD and Bud is OK but mud clearance is minimal.
  6. #1456
    Fatty Nation
    Jul 2014
    Quote Originally Posted by zeb View Post
    well that sucks... but I guess a set of RD and a bud and lou combo would be sweet as well... or I have also looked at the 45NRTH Du's as well... choices, choices...
    oops... I am assuming the 4.8s don't fit front AND back either... looks like a set of BFLS or DU'S...
  7. #1457
    zeb
    zeb is offline
    I had a change to ride this tubeless Fatty on trail.It was better than original set-up,however i like more Floater as rear tire than Knard 120tpi.
  8. #1458
    Fatty Nation
    Jul 2014
    wow looks cool... I am wondering if running different sized tires like that works properly or should I match a set of BFLs or DUs...
  9. #1459
    zeb
    zeb is offline
    Matching tires looks way better allways but if you have chance to try different front tires i highly recommend to do it.Fatbikes steering and riding characters varies hugely due to the front end ie. tire size/pressure.Rear tire will follow where front goes.
  10. #1460
    Fatty Nation
    Jul 2014
    really good info... thanks...
  11. #1461
    Feb 2012
    So is there any consensus on the sizing on this bike? If you are at the upper range of the medium, should you instead go for the largest one if you like to use a short stem?
  12. #1462
    Quote Originally Posted by bad andy View Post
    They do make one, they come factory on Beargrease carbon. The 12x177 is what it is called but it fits the stock hub that takes 170mm QR or 12x177mm. The spacers are wider to work with the thru frame kit. Looks just the one in your picture.
  13. #1463
    Reputation: tartosuc's Avatar
    Hi,
    After reading a lot on fat bikes for the last year, i decided to order a fatty rolling chassis size large...should get it pretty soon!
    Pics to come.
    One question, any of you tried existing frame bag in the fatty frame? Like something made for another brand of bike... I dont want to go with a custom frame bag if something already made fit.
    expensive cars are a waste of money. Expensive bikes...not so much!
  14. #1464
    Reputation: Wombat's Avatar
    Quote Originally Posted by tartosuc View Post
    Hi,
    One question, any of tou tried existing frame bad in the fatty? Like something made tor another brand of bike...
    I think you are asking if anyone has used a Lefty in a Fatty frame. Many people have done this without any problems. You just need a Lefty with removable clamps and then use the fat bike clamp from Mendon Cycle Smith.
    Tim
  15. #1465
    Tim
    Sorry for the bad spelling of my previous post...i have a hardtime with my tablet keyboard.
    I've corrected my post...i was talking about frame bag
  16. #1466
    Hi
    I just join the fatty family.
  17. #1467
    WNC Native
    Reputation: nitrousjunky's Avatar
    Anyone know if the RS Bluto would work with the 20" frame?
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  18. #1468
    Reputation: MMcG's Avatar
    Jul 2003
    Hi
    What size frame-set and what cranks are those Tarto???
  19. #1469
    Reputation: jvm051's Avatar
    Quote Originally Posted by nitrousjunky View Post
    Yes, I can get pictures tonight. Just got mine installed and an waiting for tires to finish build.
  20. #1470
    WNC Native
    Quote Originally Posted by jvm051 View Post
    Cool, would definitely appreciate it!
  21. #1471
    The crown more than clears the downtube with a Cane Creek External cup.
  22. #1472
    Sep 2014
    Just joined the Fat Bike community.
    Ordered the On-one Fatty Cruiser for £699. Seems like too good a bargain to miss!
  23. #1473
    Apr 2013
    Thanks for the picture! Awesome!
  24. #1474
    WNC Native
    Awesome! Thanks jvm051!
  25. #1475
    Reputation: Lordie's Avatar
    new bike day got the fatty chasis bundle.
    On One Fat Bike Frame-921224-your-latest-fatbike-related-purchase-pics-required-best-copy.jpg
    On-one fatty frame + steel fork
    Hope Fatsno =135/170 /w hope skewers
    Vee Mission tyres, i suppose to get floaters but they shipped this instead
    Race Face Ride 100mm w/ 32T NW RF chainring
    Avid Juicy Carbon 180/160mm
    Brooks C17s
    Thomson 60mm stem
    FSA K-Force carbon bars
    Crankbrothers cobalt 3 seatpost
    XO 9 speed gripshift with PG990 Red cassette
    Crankbrothers Candy 3.
    KMC x10 SL chain
    total weight 15.04kg
  26. #1476
    Any word on whether the Fun Fatty 24" will be coming to the states?
    https://www.youtube.com/watch?v=EygF...eid=2f38355240
  27. #1477
    Reputation: bcriverjunky's Avatar
    Jul 2014
    That's just my size!
  28. #1478
    Quote Originally Posted by Nurse Ben View Post
    huh? it's an online store... you order them, they send it to your house. so it's available anywhere!
    the planet x usa webstore has them if that's what you're asking.
    If steel is real then aluminium is supercallafragiliniun!
  29. #1479
    Okay, I see it now.
    So, has anyone ordered it? Why is there a $300 difference between the 2 x 10 and the 1 x 10?
    Is it reasonable to ride this thing if you're six feet tall?
  30. #1480
    i got the rolling chassi lately, i found that the fatty fork was defective(crack Inside the steertude)one one is taking care of me on this...
    While i'm wating on my new fork, i toy ideas around for a 3 day fatbike trip I'm doing this winter with friends.
    this is what i did today... a top tube bag with an old porta pack frame bag i had home, with a custom pocket Inside for my cell phone or a camera
    On One Fat Bike Frame-tartosuc-win_20141005_174210.jpgOn One Fat Bike Frame-tartosuc-top-tube-bag1.jpg
  31. #1481
    I was thinking some similar but filling the space in the triangle also. Having two zippers up top that I could put a phone in and some food in another. Still have the side pocket though.
    There is a local guy here who does frame bags, he has shown interest in building this idea for me.
  32. #1482
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Mr Pink57 View Post
    medium revelate bag works good in the triangle.
  33. #1483
    i tought about it also..but i will have frame bag Under the top tube anyways, the little space Inside the twin top tube iŝ not so big so i dont feel i,m loosing much..plus i already had the bag, just needed some modification....
    let us know if you get the bag made, id like to see it.
  34. #1484
    the full frame bag or the tangle bag?
    i have a tangle bag that fits good
  35. #1485
    full frame bag. It tends to pack out wider than on the surly due to the wider design of the twin top tubes, kind of makes up for the smaller vertical area.
  36. #1486
    Reputation: VeloRyan's Avatar
    Has any one run the On One fatty frame with 29+ wheels yet? Curious if there is enough clearance with a Knard.
    Thanks and if you have pics, post 'em if you got 'em.
    -VeloRyan-
  37. #1487
    Not a chance. The Knard 3.0 on a R/H hits the chainstay bridge. No amount of trimming will get it to fit.
  38. #1488
    Reputation: pharcyde's Avatar
    Bags made by a guy on Etsy called Rogue Panda Designs. Custom fit and custom design all done long distance by email between Arizona and OZ.
    KARMA will get YOU & YOU know who you are.
  39. #1489
    nothing to see here
    Reputation: Stevob's Avatar
    Nice. I hope to do some bikepacking with my fatty in the future and would imagine it set up very similar to yours.
    I see hills.
    I want to climb them.
  40. #1490
    currently my partner has a salsa mukluk, and i am considering porting most of the parts over to a fatty frame with carbon forks as a christmas present.
    how much weight difference would there be between the mukluk frame and fork vs a fatty and carbon fork?
    are the decals on the carbon fork on top or below the lacquer?
    re the frame, what size seatpost does it take? i would be interested in upgrading her to a dropper seatpost.
  41. #1491
    <a href="http://photobucket.com/" target="_blank"><img src="http://img.photobucket.com/albums/v319/mrpink57/Bike/3B98EDDA-403A-439F-AC18-5102CD5C03B4_zpstofdf8qu.jpg" border="0" alt=" photo 3B98EDDA-403A-439F-AC18-5102CD5C03B4_zpstofdf8qu.jpg"/></a>
    Been enjoying my fatty since Feb, it has been ridden more than any of my other bikes by far and away.
    I am trying to find a proper frame bag for it, does anyone use a Ibera large bag?
  42. #1492
    Just rebuilt the wheels after my friend crashed and broke my front wheel, and added a BlutoOn One Fat Bike Frame-20141011_153524.jpg
  43. #1493
    jvm051...that's a good looking Fatty! Are you able to fit any larger tire out back than the "small" snowshoe?
    -VeloRyan-
  44. #1494
    one chain loop
    Reputation: fishcreek's Avatar
    just finished drilling the rims today...
    everything sucks but my vacuum cleaner.
  45. #1495
    Quote Originally Posted by VeloRyan View Post
    Good question, the chain and seat stays could fit more but the chain is really close to the tire in the big cog. I really wanted to get a Bulldozer for the rear but was afraid it would not fit, and since all the reviews said the Snowshoe was nowhere near 4.7, I figured it was worth a try. I wish it had better side knobs. I must say that the Snowshoe XL I'm running up front is an amazing tire, and wish Vee tire made the exact tire, just smaller for the rear. All in all with the Bluto and current setup, this bike is a blast to ride.
  46. #1496
    Thanks for the input jvm, I actually have a Bulldozer on the way also hoping to put it on the back....I guess I'll find out if it will fit.
    -VeloRyan-
  47. #1497
    one chain loop
    it was reported that a 4.7 BFL will fit. i will confirm that today.
  48. #1498
    Thanks fishcreek, i'll be interested to hear if it fits as the bulldozer is almost exactly the width.
    Quote Originally Posted by fishcreek View Post
    -VeloRyan-
  49. #1499
    nothing to see here
    Just rebuilt the wheels after my friend crashed and broke my front wheel, and added a BlutoClick image for larger version.
    I wish I had friends like yours.
    I see hills.
  50. #1500
    one chain loop
    here it is BFL'd.
    like previously mentioned, the tire size issue is not the chainstay clearance but chain clearance. with the BFL, you have less than 10mm gap and most likely touch if you run 2x10.
  1. Broken frame on Mongoose, new frame? or new bike?
    By Dooms101 in forum Beginner's Corner
    Last Post: 03-12-2011, 06:45 PM
  2. Replies: 1
    Last Post: 05-23-2010, 08:39 AM
  3. Replies: 4
    Last Post: 02-18-2009, 08:06 PM
  4. whats the difference between a road bike frame and an xc frame?
    By tomsmoto in forum Bike and Frame discussion
    Last Post: 10-05-2008, 05:51 PM
  5. Broken 9357 frame in bike/frame discussion
    By grnxb in forum The ReCycle Bin
    Last Post: 02-19-2008, 12:03 PM
