Page 17 of 36 FirstFirst ... 713141516171819202127 ... LastLast
Results 801 to 850 of 1797
  1. #801
    127
    127 is offline
    So it is quit easy and inexpensive to loose weight about 1200 g with drilling and lighter tubes.
    With these modification 16" Fatty will weight about 14.7 kg without pedals.
  2. #802
    Nov 2012
    Quote Originally Posted by 127 View Post
    I just change the two on-one 2,7" DH tubes, weight 1226 g, by two Schwalbe AV13F (Schrader) light 3" tubes, 390 g.
    836 g less, it is huge, so far my 18" Fatty weight 15,3 kg without pedals, without drilling the rims !
    French. In France .Near Paris. Yes, really.
  3. #803
    Aug 2010
    Quote Originally Posted by hbourj View Post
    836 g less, it is huge, so far my 18" Fatty weight 14,7 kg without pedals, without drilling the rims !
    That's the only mod I am going to do... I ordered some of The Schwalbe FR tubes last week... easiest, cheapest way to put the Fatty on a diet.
  4. #804
    127
    127 is offline
    Are the valve holes enough big for Schrader (auto) ventil without drilling or using a file.
  5. #805
    Nov 2012
    B
    Are the valve holes enough big for Schrader (auto) ventil without drilling of using a file.
    No. I did drill it a little. You can order the SV23F (Presta). Oups, SV13F.
  6. #806
    Reputation: ljracer's Avatar
    One rim done.
  7. #807
    nothing to see here
    Reputation: Stevob's Avatar
    nice work!
    I see hills.
    I want to climb them.
  8. #808
    Nov 2012
    I posted stuff about building and my initial impressions on the Singletrack magazine forum earlier today. I'll cut and paste them here for a wider audience.
    ST thread at On one fatty first impressions (anyone) « Singletrack Forum
    The smileys didn't transfer over with the cut and paste. You'll just have to deal with it!
  9. #809
    Nov 2012
    Mine Just arrived!!! 2 huge boxes.
    Fedex delevered it today, even thought they updated the expected delivery date to Dec 26 late last night. They done good!
    So I was a little premature with my "taking forever" post above. (note - not on the mtbr forum)
  10. #810
    Nov 2012
    So, still unboxing and weighing stuff, but here's my thoughts:
    - The tires are HUGE! The tread is HUGE! Mine weigh 1444g and 1516g.
    - I like the skewers. Levers look neat and the machined aluminum nut with the captured spring is a really nice touch. F 58g, R 59g
    - Tubes weigh 593g each. If the orange decals weren't bad enough, the valve caps are orange as well!
    - Front wheel 1722g w/ rotor & rim tape, w/o skewer.
    - Rear wheel 2293g w/ rotor & rim tape & cassette, w/o skewer. 30 pt freehub engagement = 12 degrees.
    - Rims are pinned, not welded (not a worry to me). I'm concerned that the profile of the rim bead seat might make it tough to go tubeless, as the shelf isn't very wide.
    More to follow...
  11. #811
    Nov 2012
    Update #1
    Well, I already had to make a trip to the LBS. The socket type Park BB tool I had won't fit the Howitzer BB as the spindle is in the way. LBS was nice enough to lend me a wrench type one. The crank and BB that come on the bike are massive. They could handle the fattest of the fat IMO!
    And by some miracle, the Race Face Evolve 24-36-bash crankset fits!!!
    But there is only one mm of clearance between the chainring and the chainstay! So I need a 34. But I don't see 34s on the Race Face website! So, asked LBS to look into and order one if possible. Comment on this thread if you'd like to.
    More weights:
    - Big Nose Saddle 290g. I wonder why they called it that. It looks kinda odd to me. The front part of it is much wider than my regular saddle. Saddle shell says Velo, the mfr I guess.
    - Twelfty seatpost 282 grams. 31.6x 350. Wondering who the little cartoon guy on the back of it is supposed to be. Customer? Designer?
    - Cassette 391 g SRAM 11-36
    - QR seat clamp 37g.
    - Howitzer BB 430 g.
    - Truvativ Holzfeller crank (170 mm, 32T) 687 g.
    Only issue so far is that there was not a chaingiude on the bike as per the specs. Its not a big deal to me as I am going 2x anyhow.
    I will post photos of the complete bike, but the garage is not lit well and is a complete mess. And I know the response that a messy garage would get on STW!
    Any bets on whether another LBS trip will be needed today or not?
  12. #812
    Nov 2012
    Update #2
    IIRC, the website said that the bike was supposed to come with white bars. My bars are black, and I'm glad! However, the gold print on the bar looks out of place with the rest of the bike as there is no other gold anywhere. Oh, and these bars are 30 inches wide! My regular bike is 26.5 inches wide. There are some real narrow gaps between trees where I ride, so if I like the wide bars, I may have to go cut down some trees!
    As far as headset concerns expressed by someone, I took the fork off, and the headset bearings were nice and smooth. The cups were greased when put into the frame as there were gobs of red grease squeezed out around them. I couldn't figure out how to get the bearings out of the cups, though. I didn't try sharp tools or a hammer, though because I wanted to keep the seals intact. So I just added a little grease to the top and bottom of the cartridge bearing and reassembled things. On-one provided a 5, 15, 15, and 20 mm spacer on the steerer.
    More weights:
    - Stem 145 g, 31.8x60 mm. Looks nice. The steel steerer tube is exposed at the rear of the stem, so I need to figure out how to stop it from rusting.
    - Fork 1300 g with ginormous crown race attached
    - Ancho bar, 316 g, 30" wide
    - Grips 124 g w/ plugs. I will put Ergon grips on mine, but keep these around.
    - Front brake - 333 g with 34" brake line
    - Headset spacers (5,10, 15, 20 mm) 21 grams
    Now I'm getting hungry. I don't think that I've eaten anything all day, which is not normal. More to follow...
  13. #813
    Nov 2012
    Update #3
    Question - is it humanly possible to remove a non-removable (black) SRAM 10 speed powerlink from a chain? I've used the 8 speed (removable) ones forever and love them. I spent a embarrassing amount of time trying to get this 10 speed one undone. Bare hands, needle nosed pliers, etc. And both LBS close at 6 on Saturday! So the second LBS trip of the day was not possible. Grrr! Then, finally I figured out the answer:
    Luckily, I already bought a 6 pack of KMC reusable 10 speed ones off of Amazon! Whew!
    Then I notice, there is no derailleur hanger on the frame! WTF! Panic; look through boxes, etc. Oh no, I won't be able to do anything till next week! Run around, curse, etc. And as above, LBS closed till tomorrow. Then, I notice that it is still attached to the rear derailleur that I had already removed from the bike as I'm going to put on a Shimano one. Disaster averted.
    The frame was masked where the derailleur hanger attaches to the bike, so its not painted there. There was a bit of paint that squeaked in under the rear edge of the mask, though and it was really thick. Enough to cause the hanger to be misaligned? I dunno, but it was easy to scrape off with a razor blade.
    And I found that I needed to run the front brake line in a different way than I've ever done before. It seems to route well when its right beneath where the head tube and down tube join. If I put it out in front of the head tube, it was much too long and twisted around all weird. I don't have a bleed kit for DOT brakes, so shortening the hose isn't possible for me right now.
    So, stay tuned for another exciting chapter of Joe Builds a bike.
  14. #814
    Nov 2012
    Update #4
    What others have said about the tire beads being loose is true. You know how you can usually use a tire lever to sweep the tire bead onto the rim when they're not too tight? I was able to use my finger instead of a tire lever, that's how loose they were. It does make it easy to align the tire logo with the valve stem, though! And when I got the tire mounted and started pumping it up, I think that it took 5 psi or so before the tube contacted the tire tread. Before that, I could feel space between the tire and the inflating tube with my hand on the tread area. I do realize that the pump gauge isn't real accurate at this low of a pressure.
    BIG PROBLEM! The hub logo is not visible through the valve hole, FFS!* Isn't the wheelbuilder aware of this rule? Do you know how expensive it will be for me to have the wheel rebuilt to align said logo and hole?
    Both tires have a noticable "hop" (to use the wheel truing term) to them when mounted on the bike and and spun. The bead is seated fine as far as I can tell. I ran them up to 20 psi, the max on the sidewall, and will leave them overnight. Maybe they're still a little stiff from being folded up for who knows how long since they were made.
    I also noticed that the seam on the rims is at a bit of an angle; it is not parallel to the hub axle. I never noticed this on other wheels, but I never really looked, either. My guess is that at least some other wheels are like this too, but that the width of the rims makes it more noticeable. It is not a concern to me at all, just pointing it out.
    There are no logos or stickers on the rim. IMO, it needs at least a little something to dress it up. And the rim needs a name, like the Surly and Vicious ones, too. On-One names everything else that they make, why not the rims?
    Oh, and the plastic trim pieces underneath the saddle aren't held on with regular phillips or slotted screws; they use a hex key. No real value, but it does look really nice.
    I also discovered that it is absolutely impossible to mount a disc wheel when the brake caliper still has the little plastic travel block between the brake pads. Front wheel or rear wheel, it doesn't matter. Its amazing how easy they go in after it is removed, though. Why on earth did Avid make them out of black plastic? They should be a bright color so that you notice them. Its kinda hard to notice a black plastic block in a black brake caliper. Magura uses yellow, which you can actually see.
    The brakes drag ever so slightly as well. I loosened the tri-align bolts, squeezed the levers, and tightened the bolts again while holding the levers. I did this 2 or 3 times and its still the same. There is not enough drag to slow the wheel (they spin forever) but I can just hear a little rub. Hopefully this will go away once the pads bed in.
    I got one of those Problem Solvers direct mount adapters to mount my front derailleur on. It attached to the seat tube in the area where it is bent. The seat tube is not perfectly round at this spot; I've tightened the clamp but can still see daylight between the front of the clamp and the seat tube. I bet that at least a gram of dirt will accumulate there adding unnecessary weight to the bike!
    I'm tired and going brain dead. i can't make sense of how to attach the cable to the front derailleur. So, tomorrow will be cable time. Front derailleur, rear derailleur, KS Lev dropper seatpost.
    To be continued.
    * I may or may not not give a sh1t about this at all...
  15. #815
    Quote Originally Posted by JoeG View Post
    I think On-One missed a trick with these, they just needed a little bit more of a hook, on them and they'd have doubled up as bottle openers. Would have been perfect for an expedition bike!
  16. #816
    Reputation: Velobike's Avatar
    ...Question - is it humanly possible to remove a non-removable (black) SRAM 10 speed powerlink from a chain? I've used the 8 speed (removable) ones forever and love them. I spent a embarrassing amount of time trying to get this 10 speed one undone. Bare hands, needle nosed pliers, etc...
    It just takes seconds. Squeeze the link on the diagonal and it separates neatly. A small pair of multigrips makes it easier.
    Latitude: 57º36' Highlands, Scotland
  17. #817
    Oct 2012
    Ugh, my Fatty is still at FedEx somewhere. I had it shipped to my workplace, since I had figured it would come on a weekday(it was supposed to get here Thursday). Then, when it didn't show up Thursday, or Friday, I had it rerouted to be held at the local FedEx store since it was going to be delivered on Saturday, and I didn't want to hang out at the Shop all day waiting for it. Then, I kept checking the status. It said it went out on the truck for delivery at 8:11AM, but it never made it to the FedEx store. I went there to check right before they close at 6:00pm, but, not there. Now it says Not Delivered, Local Delivery Exception.
    To make things worse, there is another package with some headset parts they forgot to put in the box, since they didn't assemble theheadset because I asked thet the steerer tube be uncut. This was sent via USPS, also to arrive on Saturday, but the mail carrier holds all the mail when we are closed, so, even though it shows to be delivered on USPS tracking, it is not there, and probably won't be till Wedensday.
  18. #818
    Nov 2012
    Yes, normal ones. I use th e8 speed ones all the time. That 10 speed one was welded shut or something!
  19. #819
    nothing to see here
    I've seen Sram use a different joiner recently. It requires you to bend the chain sideways and then pop off the cover link. The other side has both pins, whereas previous Sram joiners were a symmetrical design. Sorry but I don't have any pics.
    I see hills.
  20. #820
    Nov 2012
    Yes, this 10 speed black quick link is not removable to be more reliable. Somebody has filed down a flat pliers to depart and close this link. Indeed this link is for mount, not for dismount the chain.
    KMC or Connex are better.
  21. #821
    nothing to see here
    can someone get a close-up pic of the link?
    I see hills.
  22. #822
    Nov 2012
    Google can :
  23. #823
    Reputation: druidh's Avatar
    The 10-speed PowerLocks are not designed to be removed in the way that the 8- and 9-speed PowerLinks are. Having said that, they can be removed with a suitable tool and Park actually do such a thing.
  24. #824
    If you use a small multigrip tool this is an easy job.
    One jaw on the left nearside of the link shown above, and the other on the right far side, quick squeeze, and it's done.
  25. #825
    Reputation: Johnclimber's Avatar
    JoeG - FFS stop stressing, get out and ride your bike instead of update #5, 6 or 7
  26. #826
    Oct 2012
    Quote Originally Posted by ljracer View Post
    One rim done.
    what is the orange rim strip? Is it something grime resistant, or is it ribbon?
    Anyone know of what to use that will resist soiling while being available in multiple colors, and is fairly light?
    I was thinking colored vinyl or cloth backed vinyl tape stuck sticky side to sticky side to a wider tape, so that the overlap can stick to the rim.
    Is this what others are doing?
    does it work well?
  27. #827
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    Quote Originally Posted by autodoctor911 View Post
    When searching for material i went to a local fabric outlet with literally thousands of colors, material types, remnants of all sorts of shapes n sizes. I wanted white and found what was a vinyl table cloth 5x6' so i cut 2" strips for marge lites that worked perfectly.
  28. #828
    In my case duct tape. 23 grams for one loop on the rim. Mud washes off fine. Name:  ImageUploadedByTapatalk1356376434.605433.jpg
    Plenty of threads on this forum where people have many nice solutions.
  29. #829
    Te mortuo heres tibi sim?
    Want.
    It's a good thing for my pocketbook that they are out of stock at the moment.
    Yeah, I think one of these is going to be coming soon.
  30. #830
    Does anyone have any severe hops in their tires? I noticed I have it mine. Each one has it and it does not seem to be related to the tube. Ive moved the tires on the rim. Rims are true and have no hops.
    Cant really feel it at low speed. But high speed it is a problem.
    Thanks.
  31. #831
    Nov 2012
    I have big hops in my two tire+tube+wheel, but I think it is from the very narrow tubes I use (Schwalbe SV13F, 190 g each, the on-One weight 610 g !).
    Downhill I feel these hops a lot !
  32. #832
    Based on a tip from a buddy I aired it up to 35 psi. Seemed to seat everything better. I'll let it sit for a bit and the. Test ride.
  33. #833
    Aug 2010
    Just changed my tubes to the Schwalbe FR and had a b!tch of a time getting the tires seated properly without hops... what worked in the end was applying some soapy water to the beads and then inflating to a high psi... voila, no more hops.
    BTW, I dropped 2 lbs of weight in the process.... cheapest diet for this fatty...
  34. #834
    The tire hops because the bead isn't centered around the rim. You have to be very vigilant in getting the tire to inflate evenly around the rim. The tire is seated off-center. This is operator error. Easy/kinda to fix. Deflate the tire, rub something slippery around the bead(Dawn dishsoap diluted a bit works), and keep the tire/rim off the ground while inflating. If still having trouble, you may need an extra pair of hands keeping the tire equal spaced on the rim while you inflate it. The problem is the tire bead falls into the large center section of the rim, and then pops up unequally onto the bead seat. Work with it, and all will be well.
  35. #835
    gone walk about
    Mar 2012
    hops are the main contributor but rest assured they are also out of balance more than folks would suspect. These fat tires no matter the make / model can have severe weight bias in a section.
  36. #836
    Nov 2012
    I just aired the two up to 35 PSI and the hops is disapeared. Thank you. Easy and efficient tip.
  37. #837
    Aug 2010
    Quote Originally Posted by nvphatty View Post
    Did a ride this morning at some relatively fast fat bike speeds (30 km/h) and absolutely no wobble or hops felt in my tires...
  38. #838
    gone walk about
    Mar 2012
    Quote Originally Posted by gretch View Post
    do you feel warm n fuzzy inside??
  39. #839
    Aug 2010
    Absolutely...
  40. #840
    gone walk about
    Mar 2012
    Absolutely...
    me too when i static balanced mine
  41. #841
    Feb 2006
    Yesterday was a great day to continue breaking her in...
  42. #842
    127
    127 is offline
    After couple of rides in snow conditions I have noticed, that 2*10 gears could perhaps help my skinny legs in some situations. I if go to 2*10 gears, I would like to do it inexpensive way. There are now discounted crank options like Hussefelt 2.2 or Truvativ Blaze, which I could take away largets (42 t) ring and replace it with light alumium rock guard. These will go to bike's original bb.
    So I need a front mech and a trigger. Would Shimano's 9 speed e-type mech work or is the only way to go with problem solver adapter and direct mount mech ?
  43. #843
    Nov 2012
    Ed Oxley put a high clamp mech Shimano SLX without the expensive problem solvers adaptor. Photos are on UK fat bike forum.
  44. #844
    Oct 2012
    here is my Fatty. only mod so far is white mary bars.
    Attached Thumbnails Attached Thumbnails On One Fat Bike Frame-imag0152-1-.jpg
  45. #845
    nothing to see here
    lucky man
    I see hills.
  46. #846
    Is it possible for shops to get these? Who's distributing?
  47. #847
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Fwilpum View Post
    On-One sells consumer direct.
    mtbtires.com
  48. #848
    Thanks.
    For me severe hops mean my tires are not seated correctly all the way around. This can be hard to get right on rims without good bead seats such as Fat Shebas or V!Zs. I had trouble on Darryls too but it was because of tape residue on the ramp up to the bead seat. Once I cleaned that all off and broke out the compressor they popped right on and no more hop! Well almost none, you can no longer feel it at speed.
    Latitude 61
  49. #849
    Jan 2013
    We were thinking of getting 8-10 of the fattys for rentals....but we want internal hubs...any problems with the hydraulic brakes getting sluggish in the cold? and no racks? Is there a specific reason in design for not having rack mounts?
  50. #850
    Quote Originally Posted by TikiInn View Post
    Only internal hub that fits a 170mm OLD frame is the 3 speed Sturmey-Archer.
  1. Broken frame on Mongoose, new frame? or new bike?
    By Dooms101 in forum Beginner's Corner
    Last Post: 03-12-2011, 07:45 PM
  2. Replies: 1
    Last Post: 05-23-2010, 08:39 AM
  3. Replies: 4
    Last Post: 02-18-2009, 09:06 PM
  4. whats the difference between a road bike frame and an xc frame?
    By tomsmoto in forum Bike and Frame discussion
    Last Post: 10-05-2008, 05:51 PM
  5. Broken 9357 frame in bike/frame discussion
    By grnxb in forum The ReCycle Bin
    Last Post: 02-19-2008, 01:03 PM
Members who have read this thread: 129
